210-299P-KIT
210-299P-KIT
    DIGILENT(迪芝伦)
    210-299P-KIT
210-299P-KIT 数据手册
1300 Henley Court Pullman, WA 99163 509.334.6306 www.digilentinc.com JTAG-HS3™ Programming Cable for Xilinx® FPGAs Revised March 13, 2019 This manual applies to the JTAG-HS3 rev. A Overview The JTAG-HS3 programming cable is a high-speed programming/debugging solution for Xilinx FPGAs and SoCs. It is fully compatible will all Xilinx Tools, and can be seamlessly driven from iMPACT, ChipScope™, EDK, and Vivado™. The HS3 attaches to target boards using Xilinx’s 2x7, 2mm programming header. The PC powers the JTAG-HS3 through the USB port and will recognize it as a Digilent programming cable when connected, even if the cable is not attached to the target board. The HS3 has a separate Vref pin to supply the JTAG signal buffers. The high speed 24mA three-state buffers allow the HS3 to drive target boards with signal voltages from 1.8V to 5V and bus speeds up to 30MBit/sec (see Fig. 1). To function correctly, the HS3’s Vref pin must be tied to the same voltage supply (VCCO_0) that drives the JTAG port on the FPGA. Features include: • • • • • • • Small, complete, all-in-one JTAG programming/debugging solution for Xilinx FPGAs and SoCs Plugs directly into standard Xilinx JTAG header Separate Vref drives JTAG signal voltages; Vref can be any voltage between 1.8V and 5V High-Speed USB2 port that can drive JTAG bus up to 30Mbit/sec (frequency adjustable by user) Compatible with Xilinx ISE® 14.1 and newer, Xilinx Vivado 2013.3 and newer Uses micro_AB USB2 connector Open drain buffer on pin 14 allows debugging software to reset the processor core of Xilinx’s Zynq® platform The JTAG-HS3 The JTAG bus can be shared with other devices as the HS3 signals are held in high-impedance, except when actively driven during programming. The HS3 uses a standard Type-A to Micro-USB cable that attaches to the end of the module opposite the system board connector. The HS3 is small and light, allowing it to be held firmly in place by the system board connector (see Fig. 2). VIO : 5V to 1.8V VREF GND USB 2 Port VIO GND TCK TCK TDO TDO TDI TDI TMS TMS JTAG -HS 3 FPGA Figure 1. Diagram of signal voltages and connections. DOC#: 502-299 Figure 2. Xilinx JTAG header. Dual row, 2mm, 14 pin. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 1 of 6 JTAG-HS3™ Reference Manual 1 Software Support The JTAG-HS3 has been designed to work seamlessly with Xilinx’s ISE (iMPACT, ChipScope, EDK) and Vivado tool suites. The most recent versions of ISE and Vivado include all of the drivers, libraries, and plugins necessary to communicate with the JTAG-HS3. At the time of writing, the following Xilinx software included support for the HS3: Vivado 2014.1+, Vivado 2013.3+, and ISE 14.1+. The HS3 is also compatible with ISE 13.1 – 13.4. However, these versions of ISE do not include all of the libraries, drivers, and plugins necessary to communicate with the HS3. In order to use the JTAG-HS3 with these versions of ISE, version 2.5.2 or higher of the Digilent Plugin for Xilinx Tools package must be downloaded from the Digilent website, and the ISE13 plugin must be manually installed as described in the included documentation. The JTAGHS3 is not compatible with Xilinx Vivado 2013.1 or Vivado 2013.2. In addition to working with the Xilinx Tools, the HS3 is also supported by Digilent’s Adept software and the Adept SDK (the SDK is available to download free from Digilent’s website). Adept includes a full-featured programming environment and a set of public APIs that allow user applications to directly drive the JTAG chain. Using the Adept SDK, custom applications can be created to drive JTAG ports on virtually any device. Please see the Adept SDK reference manual for more information. 2 Xilinx Zynq-7000 and SoC Support The Xilinx Tools occasionally require the processor core of the Zynq-7000 to be reset during debug operations. The Zynq platform processor has a pin dedicated for this purpose (PS_SRST_B). Driving the PS_SRST_B pin low causes the processor to reset while maintaining any existing break points and watch points. The JTAG-HS3 is capable of driving this pin low under the instruction of Xilinx’s SDK during debugging operations. In order for this to work, pin 14 of Xilinx JTAG header on the target board must be connected to the PS_SRST_B pin of the Zynq (see Figs. 3 & 4). GND 1 2 VREF GND 1 2 VCCO_0 GND 3 4 TMS GND 3 4 TMS GND 5 6 TCK GND 5 6 TCK GND 7 8 TDO GND 7 8 TDO GND 9 10 TDI GND 9 10 TDI GND 11 12 ---- GND 11 12 ---- GND 13 14 SRST GND 13 14 PS_SRST_B Figure 3. JTAG-HS3 pinout (seen looking out of the connector). Figure 4. Xilinx System Board Header (seen looking into the connector). The JTAG-HS3 uses an open drain buffer to drive pin 14 of the Xilinx JTAG header (see Fig. 5). This allows the HS3 to drive the PS_SRST_B pin when VCC_MIO1 is referenced to a different voltage than VCCO_0 (see Fig. 6). Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 2 of 6 JTAG-HS3™ Reference Manual Output Pin (SRST) 100 Figure 5. JTAG-HS3 pin 14 output buffer. Should an accidental short occur between pin 14 and GND, the 100 ohm series resistor protects the buffer from being damaged. While this resistor protects the buffer from being damaged, it also limits the drive strength of the buffer. Therefore, it is necessary for the pull-up resistor (RPU) used to establish the voltage level on PS_SRST_B to be greater than or equal to 1.5K ohms. At the time of writing, Xilinx ZC702, Xilinx ZC706, and Avnet® MicroZed™ all feature 10K pull-ups on pin 14 of the their respective Xilinx JTAG headers. For compatibility with other evaluation platforms, please consult the manufacturer’s schematic. VCCO_MIO1 VCCO_0 VCCO_MIO1 VCCO_0 TMS TDI TDO TCK ZYNQ-7000 PS_SRST_B VREF TMS TDI TDO JTAG-HS3 TCK SRST VCCO_MIO1 GND GND ≥1.5K RPU Optional Reset Button Figure 6. Figure 6. System board components. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 3 of 6 JTAG-HS3™ Reference Manual 3 Supported Target Devices The JTAG-HS3 is capable of targeting the following Xilinx devices: • • • • • • Xilinx FPGAs Xilinx Zynq-7000 Xilinx CoolRunner™/CoolRunner-II CPLDs Xilinx Platform Flash ISP configuration PROMs Select third-party SPI PROMs Select third-party BPI PROMs The following devices cannot be targeted by the JTAG-HS3: • • • Xilinx 9500/9500XL CPLDs Xilinx 1700 and 18V00 ISP configuration PROMs Xilinx FPGA eFUSE programming Remote device configuration is not supported for the JTAG-HS3 when used with Xilinx’s iMPACT software. Note: Please see the "Introduction to Indirect Programming – SPI or BPI Flash Memory" help topic in iMPACT for a list of supported FPGA/PROM combinations. Note: Please see the “Configuration Memory Support” section of Xilinx UG908 for a list of the FPGA/PROM combinations that Vivado supports. 4 Design Notes The JTAG-HS3 uses high speed three-state buffers to drive the TMS, TDI, and TCK signals. These buffers are capable of sourcing or sinking a maximum of 50 mA of current. The HS3 has 100 ohm resistors between the output of the buffers and the I/O pins to ensure the cable does not exceed the maximum limit. To further limit short circuit, additional current resistance may be placed in series with the I/O pins of the HS3 and the target board. However, Digilent recommends limiting the amount of additional resistance to 100 ohms or less as higher resistance may result in degraded operation. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 4 of 6 JTAG-HS3™ Reference Manual 5 Programming Solutions Comparison Chart JTAG-USB Max Speed Voltage Range Xilinx Native Support Xilinx Plug-in Support Digilent Adept Support PC Interface Connector Interface 4-Wire JTAG 2-Wire JTAG Zynq-7000 PS_SRST Support SPI Support 6 JTAG-HS2 30 MHz JTAG-HS3 1.6 MHz JTAG-HS1 30 MHz 1.8V – 5V 1.8V – 5V 1.8V – 5V 1.8V – 5V ISE 13.2+ Vivado 2014.2+ ISE 13.2+ Vivado 2012.1+ ISE 13.2+ Vivado 2012.1+ ISE 14.1+ Vivado 2013.3+ ISE 12.1+ ISE 12.1+ ISE 12.1+ ISE 12.1+ YES YES YES YES USB USB USB USB 6-pin 6-pin, 14-pin 6-pin, 14-pin 14-pin YES NO YES NO YES YES YES NO NO NO NO YES YES YES YES NO 30 MHz Absolute Maximum Ratings Symbol Parameter Condition Min Max Unit Vref I/O reference/supply voltage -0.5 6 V VIO Signal Voltage -0.5 6 V IIK,IOK TMS, TCK, TDI, TDO DC Input/Output Diode Current IOUT DC Output Current TSTG Storage Temperature VIO < -0.5V -50 VIO > 6V +20 mA ±50 mA +120 ºC Human Body Model JESD22-A114 2000 V Charge Device Model JESD22-C101 500 V -20 ESD Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Page 5 of 6 JTAG-HS3™ Reference Manual 7 DC Operating Characteristics Symbol Vref Parameter Min Typ Max Unit I/O reference/supply voltage 1.65 1.8/2.5/3.3 5.5 Volts Input High Voltage (VIH) 1.4 5.5 Volts Input Low Voltage (VIL) 0 0.45 Volts TDO Output High (VOH) 0.75 x Vref 0.90 x Vref Vref Volts Output Low (VOL) 0 0.05 x Vref 0.15 x Vref Volts 0 0.4 0.55 Volts 70 ºC TMS, TCK, TDI Output Low (VOL) SRST (RPU = 1.5K ohm) TA 8 Operating Temperature 0 AC Operating Characteristics The JTAG-HS3 JTAG signals operate according to the timing diagram in Fig. 7. The HS3 supports TCK frequencies from 30 MHz to 8 KHz at integer divisions of 30 MHz from 1 to 3750. Common frequencies include 30 MHz, 15 MHz, 10 MHz, 7.5 MHz, and 6 MHz (see Table 4). TCK TCKH TCKL Symbol Parameter Min Max 33ns 125µs TCK TCD TMS/TDI TSU THD TDO TCK TCK period TCKH, TCKL TCLK pulse width 16.6ns 62.5µs TCD TCLK to TMS, TDI 0 15ns TSU TDO Setup time 19ns THD TDO Hold time 0 Figure 7. Timing diagram. Copyright Digilent, Inc. All rights reserved. Other product and company names mentioned may be trademarks of their respective owners. Table 4. JTAG-HS3 Frequency support. Page 6 of 6
210-299P-KIT 价格&库存
很抱歉,暂时无法提供与“210-299P-KIT”相匹配的价格&库存,您可以联系我们找货
