FN2090-3-06
FN2090-3-06
    SCHAFFNER(夏弗纳)
    高性能单相多级AC/DC EMI滤波器,具备出色衰减性能,有多种可选版本和终端选项
FN2090-3-06 数据手册
DATA SHEET Very High Performance Single-Phase Filters FN2090 Multi-stage AC/DC EMI Filter with Excellent Attenuation Performance Rated currents from 1 to 30 A Approvals & Compliances Two-stage filter Very high differential and common-mode attenuation Optional medical versions (B type) Optional safety versions (A type) Optional enhanced performance versions Optional overvoltage protection (Z type) Features and Benefits FN 2090 two-stage filters are designed for easy and fast chassis mounting. FN 2090 B versions without capacitors to earth comply to 1MOP for ME (medical equipment) acc. IEC 60601-1 Performance indicators FN 2090 A versions with low capacitance to earth for safety critical applications with a requirement for low leakage currents. FN 2090 filters offers an optimized filter range for enhanced performance AC and DC applications , in same compact size (KK, LL, NN types) All filters provide an exceptional conducted attenuation performance, based on chokes with high permeable core material. FN 2090 two-stage filters are designed for noisy applications requiring excellent filter performance. The higher inductivity offers increased attenuation performance with the same form factor as FN 2060 and FN 2080 series. Technical Specifications * ** All FN 2090 filters can be delivered with optional surge pulse protection (Z type). Rated voltage* 250 VAC, 50/60 Hz; 250 VDC Operating frequency DC to 400 Hz Rated currents 1 to 30 A @ 40°C max. High potential test voltage P –> N 1100 VDC for 2 sec P –> PE 2000 VAC for 2 sec (equiv. cap PE 2550 VDC for 2 sec (equiv. cap >88 nF) P –> PE 2500 VAC for 2 sec (B types) FN 2090 filters are also available as singlestage filters (FN 2030 series). Various terminal options allow you to select the desired connection style. Typical Applications Temperature range (operation and storage) -25°C to +100°C (25/100/21)** Electrical and electronic equipment Certified to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to AC and DC applications) Consumer goods Flammability corresponding to Laces for -07 version: UL 94 VW-1 Terminal plastic for -06/-08 version: UL 94 V-0 Grommet for -07 version: UL 94 V-0 Building automation Surge pulse protection (Z type) Helps compliance to IEC61000-4-5 (Differential Mode only) Medical equipment Overvoltage category II acc. IEC 60664-1 Pollution degree Office automation and datacom equipment 2 acc. IEC 60664-1 Altitude 2000m (above derating applies)** Various noisy applications requiring high filter performance MTBF @ 40°C/230 V (Mil-HB-217F) 1,300,000 hours (1 to 10 A types) 1,100,000 hours (12 A types) 517,000 hours (16 and 30 A types) Typical electrical schematic maximum RMS operating voltage at rated frequency or the maximum DC operating voltage for dedicated requests exceeding this specification (e.g. -40 °C or higher altitude) please contact your local Schaffner Sales office Household equipment Industrial applications Machinery Electronic data processing equipment 2 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 12. Aug 2022 Filter Selection Table Filter* Buy Rated current @ 40°C (25°C) Leakage current** Power Loss Inductance*** Capacitance*** @ 250V AC/50 Hz @ 25°C/DC L Cx Cy1 Resistance*** Input/Output Cy2 R connections Weight (@ 120V AC/60 Hz) [A] [mA] [W] [mH] [μF] [nF] [nF] [kΩ] FN2090-1-.. 1 (1.1) 0.45 (0.26) 1.8 20 0.22 2.2 1.0 680 -06 -07 73 FN2090-3-.. 3 (3.4) 0.45 (0.26) 3.7 14 0.33 2.2 1.0 470 -06 -07 158 FN2090-4-.. 4 (4.5) 0.45 (0.26) 6.4 14 0.33 2.2 1.0 470 -06 -07 176 FN2090-6-.. 6 (6.7) 0.61 (0.35) 7.1 8 0.47 3.3 1.0 330 -06 -07 FN2090-8-.. 8 (8.9) 0.61 (0.35) 7.7 8 0.47 3.3 1.0 330 -06 -07 FN2090-10-.. 10 (11.2) 0.61 (0.35) 8.4 8 0.47 3.3 1.0 330 -06 -07 -08 369 FN2090-12-.. 12 (13.4) 0.93 (0.54) 12.1 4 1 10 1.0 220 -06 -07 -08 391 FN2090-16-.. 16 (17.9) 0.93 (0.54) 10.7 4 1 10 1.0 220 -06 -07 FN2090-20-.. 20 (22.4) 0.93 (0.54) 8.2 2.7 1 10 1.0 220 -06 FN2090-30-08 30 (33.5) 0.93 (0.54) 10.1 1.5 1 10 1.0 220 FN2090A-1-.. 1 (1.1) 0.13 (0.07) 1.8 20 0.22 0.47 0.47 680 -06 -07 73 FN2090A-3-.. 3 (3.4) 0.13 (0.07) 3.7 14 0.33 0.47 0.47 470 -06 -07 158 FN2090A-4-.. 4 (4.5) 0.13 (0.07) 6.4 14 0.33 0.47 0.47 470 -06 -07 176 FN2090A-6-.. 6 (6.7) 0.13 (0.07) 7.1 8 0.47 0.47 0.47 330 -06 -07 FN2090A-8-.. [g] -08 191 330 425 -08 530 -08 548 -08 191 8 (8.9) 0.13 (0.07) 7.7 8 0.47 0.47 0.47 330 -06 -07 FN2090A-10-.. 10 (11.2) 0.13 (0.07) 8.4 8 0.47 0.47 0.47 330 -06 -07 -08 330 369 FN2090A-12-.. 12 (13.4) 0.13 (0.07) 12.1 4 1 0.47 0.47 220 -06 -07 -08 391 FN2090A-16-.. 16 (17.9) 0.13 (0.07) 10.7 4 1 0.47 0.47 220 -06 -07 FN2090A-20-.. 20 (22.4) 0.13 (0.07) 8.2 2.7 1 0.47 0.47 220 -06 FN2090A-30-08 30 (33.5) 0.13 (0.07) 10.1 1.5 1 10 10 220 FN2090B-1-.. 1 (1.1) 0.00 1.8 20 0.22 680 -06 -07 73 FN2090B-3-.. 3 (3.4) 0.00 3.7 14 0.33 470 -06 -07 158 FN2090B-4-.. 4 (4.5) 0.00 6.4 14 0.33 470 -06 -07 FN2090B-6-.. 6 (6.7) 0.00 7.1 8 0.47 330 -06 -07 FN2090B-8-.. 8 (8.9) 0.00 7.7 8 0.47 330 -06 -07 FN2090B-10-.. 10 (11.2) 0.00 8.4 8 0.47 330 -06 -07 -08 369 FN2090B-12-.. 12 (13.4) 0.00 12.1 4 1 220 -06 -07 -08 391 FN2090B-16-.. 16 (17.9) 0.00 10.7 4 1 220 -06 -07 FN2090B-20-.. 20 (22.4) 0.00 8.2 2.7 1 220 -06 FN2090B-30-08 30 (33.5) 0.00 10.1 1.5 1 220 FN2090KK-1-06 1 (1.15) 3.46 (1.99) 1.8 20 0.22 22 22 680 -06 FN2090NN-3-06 3 (3.4) 15.71 (9.05) 3.7 14 0.33 100 100 470 -06 200 FN2090NN-4-06 4 (4.5) 15.71 (9.05) 6.4 14 0.33 100 100 470 -06 210 FN2090NN-6-06 6 (6.7) 15.71 (9.05) 7.1 8 0.47 100 100 330 -06 220 425 -08 530 -08 548 176 -08 191 330 425 -08 530 -08 548 Enhanced performance FN2090NN-8-06 -07 95 8 (8.9) 15.71 (9.05) 7.7 8 0.47 100 100 330 -06 FN2090LL-10-.. 10 (11.2) 5.18 (2.98) 8.4 8 0.47 33 33 330 -06 -08 470 FN2090LL-12-.. 12 (13.4) 5.18 (2.98) 12.1 4 1 33 33 220 -06 -08 500 FN2090LL-16-06 16 (17.9) 5.18 (2.98) 10.7 4 1 33 33 220 -06 20 (23) 5.18 (2.98) 8.2 2.7 1 33 33 220 -06 30 (33.5) 5.18 (2.98) 10.1 1.5 1 33 33 220 FN2090LL-20-.. FN2090LL-30-08 340 530 -08 580 -08 600 ** To compile a complete part number, please replace the -.. with the required I/O connection style. ** For surge pulse protection, please add Z (e.g. FN2090Z-10-06, FN2090BZ-20-08). The different letters code the used Cy values in the filter type (A = 0.47nF; K = 22nF; L = 33nF; N = 100nF; as the FN2090 is a dual stage filter each letter stands for one stage of Cy) ** Maximum leakage under usual AC operating conditions (acc. IEC 60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Leakage current for DC application is 0mA *** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% 3 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 12. Aug 2022 Typical Filter Attenuation Per CISPR 17; CM=50 Ω/50 Ω sym; DM=50 Ω/50 Ω asym 1 A: Standard type A type B type Enhanced performance 3 A: Standard type A type B type Enhanced performance 4 A: Standard type A type B type Enhanced performance 6 A: Standard type A type B type Enhanced performance 8 A: Standard type A type B type Enhanced performance 4 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 12. Aug 2022 10 A: Standard type A type B type Enhanced performance 12 A: Standard type A type B type Enhanced performance 16 A: Standard type A type B type Enhanced performance 20 A: Standard type A type B type Enhanced performance 30 A: Standard type A type B type Enhanced performance 5 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 12. Aug 2022 Product Selector Mechanical Data Connection style -06, 1 A types Connection style -06, 3 to 20 A types Connection style -07, 1 A types (same dimensions as style -06) Connection style -07, 3 to 16 A types (same dimensions as style -06) Connection style -08, 10 to 30 A types 6 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 12. Aug 2022 Dimensions 1A 3A 4A 6A 8A 10 A 12 A 16 A 20 A 30 A Tolerances A 71 85 85 85 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 113.5 ±1 ±0.5 B 46.6 54 54 54 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 57.5 ±1 ±0.5 C 22.3 30.3 30.3 30.3 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 45.4 ±1 ±0.5 D 50.5 64.8 64.8 64.8 94 ±1 94 ±1 94 ±1 94 ±1 94 ±1 94 ±1 ±0.5 E 44.5 49.8 49.8 49.8 56 56 56 56 56 56 ±0.5 F 61 75 75 75 103 103 103 103 103 103 ±0.3 G 21 27 27 27 25 25 25 25 25 25 ±0.2 H 10.8 12.3 12.3 12.3 12.4 12.4 12.4 12.4 12.4 12.4 ±0.5 I 16.8 20.8 20.8 20.8 32.4 32.4 32.4 32.4 32.4 32.4 ±0.5 J 25.25 19.9 19.9 19.9 15.5 15.5 15.5 15.5 15.5 15.5 ±0.5 K 5.3 5.3 5.3 5.3 4.4 4.4 4.4 4.4 4.4 4.4 L 6.3 6.3 6.3 6.3 6 6 6 6 6 6 M 0.7 0.7 0.7 0.7 1 1 1 1 1 1 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 O 8.3 8.3 8.3 8.3 8.4 8.4 8.4 8.4 ±0.5 P 14 14.9 14.9 14.9 18 18 18 18 ±0.5 AWG type wire AWG 20 AWG 20 AWG 20 AWG 18 AWG 18 AWG 18 AWG 16 AWG 16 Wire length 140 140 140 140 140 140 140 140 N M4 M4 M4 M4 M4 Recommended torque (Nm) 1.2 - 1.3 1.2 - 1.3 1.2 - 1.3 1.2 - 1.3 1.2 - 1.3 Earth terminal 1.5 - 1.7 1.5 - 1.7 1.5 - 1.7 1.5 - 1.7 1.5 - 1.7 ±0.3 Connection style -06 N Connection style -07 +5 Connection style -08 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. 7 Very High Performance Single-Phase Filters Schaffner Group DATA SHEET 12. Aug 2022 Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Sales and Application Centers China Schaffner EMC Ltd. Shanghai T20-3 C No 565 Chuangye Road Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III Edificio E El Soto de Moraleja Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC 22nd Floor Unit No 2238 Brigade Gateway Campus 26/1 Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 #05-09 Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2 No 97 Section 1 XinTai 5th Road XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780 37FL 98 North-Sathorn Rd Silom Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. Suite 1 Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN2090-3-06
物料型号:FN2090系列
器件简介:这是施耐德集团生产的高性能单相滤波器,具有卓越的衰减性能,适用于多种电流等级和应用场景。
引脚分配:文档中未提供具体的引脚分配信息,但提供了不同的连接方式,例如Faston、Wire leads、Studs等。
参数特性: - 额定电压:250VAC, 50/60Hz 或 250VDC - 工作频率:DC至400Hz - 额定电流:1至30A - 高电位测试电压:P->N 1100VDC,P->PE 2000VAC(对于等效电容小于88nF),P->PE 2550VDC(对于等效电容大于88nF),P->PE 2500VAC(B类型) - 温度范围:-25°C至+100°C - 认证:符合UL1283、CSA 222 No.81986、IECEN60939等标准
功能详解: - FN2090系列滤波器提供两阶段滤波,有很高的差模和共模衰减。 - 可选的医疗版本(B类型)、安全版本(A类型)、增强性能版本。 - 可选的过电压保护(Z类型)。 - 所有滤波器都基于具有高磁导率材料的电感,提供了出色的传导衰减性能。
应用信息: - 适用于电子和电气设备、消费产品、家用电器、楼宇自动化、工业应用、医疗设备、电子数据处理设备、办公自动化和数据通信设备等多种嘈杂应用场景,要求高滤波性能。
封装信息:提供了多种尺寸和连接方式的详细信息,例如1A、3A、4A等不同电流等级的尺寸,以及不同连接风格的推荐扭矩和接地终端等。
FN2090-3-06 价格&库存
很抱歉,暂时无法提供与“FN2090-3-06”相匹配的价格&库存,您可以联系我们找货
