FN9226-1-02
FN9226-1-02
    SCHAFFNER(夏弗纳)
    Module
    FN9226-1-02
FN9226-1-02 数据手册
DATA SHEET IEC Inlet Filters FN9226 HF Performance EMC/EMI Filter Rated currents up to 10 A Approvals & Compliances Faston connection Optional PCB through hole connection Good HF coupling to the equipment housing Optional medical versions (B type) Performance indicators The FN 9226 IEC inlet filter combines an IEC inlet and mains filter with excellent filter attenuation in a small form factor. The FN 9226 is designed for printed circuit board mounting with good HF coupling to the equipment housing. Choosing the FN 9226 power entry module brings you the rapid availability of a standard filter associated with the necessary safety acceptances. Standard IEC connector filters are a practical solution helping you to pass EMI system approval in a short time. A wide selection on current ratings, output connections and low leakage versions for medical applications helps you to select the desired solution for your application. Features and Benefits High conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Technical Specifications Rear flange mounting Maximum continuous operating voltage 250 VAC, 50/60 Hz Operating frequency DC to 400 Hz Rated currents 1 to 10 A @ 50°C max Approvals by rated current 1 to 10 A (ENEC, UL, CSA) High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 760 VAC for 2 sec Faston connection or PCB through hole pins Protection category IP 40 according IEC 60529 Custom-specific versions are available on request Temperature range (operation and storage) -25°C to +85°C (25/85/21) Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Flammability corresponding to UL 94 V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) 800,000 hours FN 9226 B versions comply with the requirements of 1MOP acc. to IEC/EN 60601-1 for creepage and clearance, leakage current and high potential testing Good HF coupling Rated currents up to 10 A Typical Applications Portable electrical and electronic equipment Small to medium-sized machines and household equipment Single-phase power supplies, switch-mode power supplies Consumer goods Test and measurement equipment EDP and office equipment Medical equipment Rack mounting equipment Typical electrical schematic 2 IEC Inlet Filters Schaffner Group DATA SHEET 15. Jun 2022 Filter Selection Table Filter Rated current @ 50°C (25°C) Leakage current* Inductance Capacitance Resistance @ 250 VAC/50 Hz L Cx Cy R [kΩ] Output connections Weight (@ 120 VAC/60 Hz) [A] [mA] [mH] [nF] [nF] FN 9226-1-.. 1 (1.2) 0.31 (0.18) 4.65 47.0 2.2 -02 -06 40 FN 9226-3-.. 3 (3.5) 0.31 (0.18) 1.24 47.0 2.2 -02 -06 40 FN 9226-6-.. [g] 6 (7.2) 0.31 (0.18) 0.52 47.0 2.2 -02 -06 40 10 (11.6) 0.31 (0.18) 0.27 47.0 2.2 -02 -06 40 FN 9226 B-1-.. 1 (1.2) 0.00 4.65 47.0 2200 -02 -06 40 FN 9226 B-3-.. 3 (3.5) 0.00 1.24 47.0 2200 -02 -06 40 FN 9226 B-6-.. 6 (7.2) 0.00 0.52 47.0 2200 -02 -06 40 10 (11.6) 0.00 0.27 47.0 2200 -02 -06 40 FN 9226-10-.. FN 9226 B-10-.. * Maximum leakage under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Product selector For example: FN 9226-6-02, FN 9226 B-10-06 Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 1 and 3 A types 6 to 10 A types 3 IEC Inlet Filters Schaffner Group DATA SHEET Mechanical Data Connection style -02 Connection style -06 Panel cut out Dimensions FN 9226 FN 9226 Connection style -02 Connections style -06 Tolerances A 48 48 ±0.5 B 22.4 22.4 ±0.3 C 40 40 ±0.2 D 35.15 35.15 ±0.3 E 28.35 28.35 ±0.3 F 5.7 5.7 ±0.3 G 20 20 ±0.3 H Ø4 Ø4 I 6 7.3 J 13.2 13.2 +0.6/-0 K 14 14.25 ±0.5 L 6.8 6.8 ±0.3 M R ≤3.5 R ≤3.5 N 22.6 22.6 +0.2/-0 P 34.4 34.4 +0.2/-0 R Ø3.5 Ø3.5 S 14 14 U 0.8 V 34 ±0.1 34 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. ±0.3 15. Jun 2022 4 IEC Inlet Filters Schaffner Group Accessories Power Cor Cord d with angled LLock ocking ing Syst System em C13 Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Angled Connec Connecttors with LLock ocking ing Syst System em Protects appliances that are vulnerable to vibration Connector cannot be accidentally pulled or vibrated out of the inlet Space availability/constraints Different angles for ease of access Space saving Release locking mechanism Prevents accidental disconnection Technical Data Sheet > IL 13P IEC C13 R Re ewir wireable eable Connec Connecttors with LLock ocking ing Syst System em The locking system has a tensile force of typical 300N. It is recommended to use it with flange mount filters. For details refer to our Application Note "Using IEC Lock Power Cords with IEC Inlets and Filters". Schaffner power connector with IEC lock guard against accidental disconnection of all electrical appliances with an IEC inlet. No exchange or modification of the IEC inlet or IEC inlet filter system is needed. Easy retrofit .for all electronic equipments and devices Technical Data Sheet > DATA SHEET 15. Jun 2022 5 IEC Inlet Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 15. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN9226-1-02 价格&库存
很抱歉,暂时无法提供与“FN9226-1-02”相匹配的价格&库存,您可以联系我们找货
FN9226-1-02
    • 1+108.34560
    • 200+43.23240
    • 400+41.79600
    • 1000+41.07240
