FN3270H-20-44
FN3270H-20-44
    SCHAFFNER(夏弗纳)
    FN3270H-20-44
FN3270H-20-44 数据手册
DATA SHEET 3-Phase Filters FN3270 / FN3271 Compact EMC/RFI Filter for Industrial Motor Drive Applications Very compact and light weight design requiring minimum space Approvals & Compliances Easy, time-saving installation and contacting Protective covers as optional accessory available Attenuation performance according to EN 61800-3/A11 FN3270H - for standard EMI envirnoments FN3271H - high impedance load EMI environment FN3270HQ1 - low leakage current version Features and Benefits A compact and light weight filter design requiring minimum mounting space in installations and cabinets Simple and time-saving installation with good accessibility for automatic and hand tools Solid, touch-safe terminal blocks, for all filters from 10 to 100 A, offering sufficient contacting cross section according to the EN 60204-1 installation standard Performance indicators Optionally available transparent protective covers for all filters with busbars from 150 to 1000 A, to protect the installer, operator or inspector from accidental touching of live conductors. They can easily be retrofitted even if the filter is already installed and connected These EMC filters provide the attenuation performance needed to fulfill EN 61800-3/A11 Guaranteed filter performance under fullload operating conditions 15 different filter models allow the specific choice for most industrial applications Typical Applications Technical Specifications Maximum continuous operating voltage 3x 520/300 VAC (480 VAC +10% possible) Operating frequency DC to 60 Hz Rated currents 10 to 1000 A @ 50°C High potential test voltage P –> E 2750 VDC for 2 sec P –> P 2250 VDC for 2 sec Protection category IP 20 (10 to 100 A) IP 00 (150 to 1000 A) Overload capability 4x rated current at switch on, 1.5x rated current for 1 minute, once per hour Temperature range (operation and storage) -25°C to +100°C (25/100/21) Flammability corresponding to UL 94 V-2 or better Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 MTBF @ 50°C/400 V (Mil-HB-217F) >320,000 hours Variable speed electrical power drive systems/ motor drives for mainly industrial purpose Various industrial applications comprising frequency inverters, motor drives and servo drives FN3270H / FN3270HQ1 - Typical electrical schematic (up to 100 A) FN3270H / FN3270HQ1 - Typical electrical schematic (>100 A), for FN3271 refer to page 2 2 3-Phase Filters Schaffner Group DATA SHEET 27. Sep 2022 Filter Selection Table Filter Buy Rated current Typical drive Leakage current FN3270H / FN3271H Leakage current FN3270HQ1*** Power loss Input/Output @ 50°C (40°C) power rating* @ 520 VAC/50 Hz @ 520 VAC/50 Hz @ 25°C/50 Hz connections [mA]** [W] [A] [kW] [mA]** FN3270H-10-44 10 (11) 5.5 3.1 FN3270H-20-44 20 (22) 11 3.1 FN3270H-35-33 35 (38) 22 3.4 FN3270H-50-34 50 (55) 30 FN3270H-65-34 65 (71) FN3270H-80-35 80 (88) FN3270H-100-35 Weight [kg] 2.4 –44 0.4 0.4 4.1 –44 0.5 0.4 6.8 –33 0.7 3.4 12.8 –34 1.2 37 3.4 13.5 –34 1.3 45 3.4 13.5 –35 2.2 100 (110) 55 3.4 17.1 –35 FN3270H-150-99 150 (164) 75 6.9 FN3270H-200-99 200 (219) 110 6.9 FN3270H-250-99 250 (274) 132 FN3270H-320-99 320 (350) 160 FN3270H-400-99 400 (438) 220 FN3270H-600-99 600 (657) 315 FN3270H-800-99 800 (876) 1000 (1095) FN3270H-1000-99 0.4 Protective covers**** Order code 2.6 7.5 –99 6.1 801916 0.9 13.2 –99 6.1 801916 6.9 0.9 20.6 –99 6.1 801916 6.9 0.9 12.2 –99 7.2 801916 6.9 19.2 –99 7.2 801916 6.9 35.6 –99 7.7 801916 400 6.9 51.8 –99 15.8 806275 560 6.9 81.0 –99 15.8 806275 FN3271H-150-99 150 (164) 75 6.9 7.5 –99 6.1 801916 FN3271H-200-99 200 (219) 110 6.9 13.2 –99 6.1 801916 FN3271H-250-99 250 (274) 132 6.9 20.6 –99 6.1 801916 FN3271H-320-99 320 (350) 160 6.9 12.2 –99 7.2 801916 FN3271H-400-99 400 (438) 220 6.9 19.2 –99 7.2 801916 FN3271H-600-99 600 (657) 315 6.9 35.6 –99 7.7 801916 FN3271H-800-99 800 (876) 400 6.9 51.8 –99 15.8 806275 1000 (1095) 560 6.9 81.0 –99 15.8 806275 FN3271H-1000-99 * Calculated at rated current, 480 VAC and cos phi=0.8. The exact value depends upon the efficiency of the drive, the motor and the entire application. ** Standardized calculated leakage current acc. IEC60939 under normal operating conditions. *** A low leakage version is available for limited versions. e.g. FN3270HQ1-20-44 **** Please contact your local Schaffner partner to order the optional protective covers with the order code in the table above. Versions FN3271 typical electrical schematic FN3270H - standard EMI environments / standard leakage currents FN3271H - high impedance load EMI environment (> 100 Ohm), standard leakage currents FN3270HQ1 - standard EMI environments, low leakage current version Typical Filter Attenuation FN3270H / FN3271H Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 10 and 20 A types 35 to 65 A types 80 and 100 A types 150 to 1000 A types 3 3-Phase Filters Schaffner Group DATA SHEET 27. Sep 2022 Mechanical Data 10 to 100 A types 150 to 1000 A types D B D B P X I J Z J L H K C V C L L A E H G A E U F U G F I I Dimensions 10 A 20 A 35 A 50 A 65 A 80 A 100 A 150 A 200 A 250 A 320 A 400 A 600 A 800 A 1000 A A 150 150 160 170 170 200 230 300 300 300 300 300 300 370 370 B 58 58 70 85 85 95 95 200 200 200 200 200 200 190 190 C 58 58 68 80 80 90 90 86 86 86 86 86 86 125 125 D 120 120 130 140 140 170 200 240 240 240 240 240 240 310 310 E 132.5 132.5 142.5 152.5 152.5 182.5 212.5 275 275 275 275 275 275 345 345 F 42 42 50 65 65 75 75 165 165 165 165 165 165 155 155 G 4.5 4.5 5.5 5.5 5.5 5.5 5.5 Ø11 Ø11 Ø11 Ø11 Ø11 Ø11 Ø11 Ø11 H 1 1 1 1 1 1.5 1.5 2 2 2 2 2 2 3 3 I 22 22 25 39 39 45 45 40 40 40 40 40 40 50 50 J M4 M4 M5 M6 M6 M8 M8 M10 M10 M10 M10 M10 M10 M12 M12 92 92 92 92 92 92 138 138 20.5 20.5 20 15 15 16 16 37 37 37 37 37 37 67 67 M 380 380 380 380 380 380 610 610 N 211 211 211 211 211 211 201 201 O 93 93 93 93 93 93 132 132 P 26.5 26.5 26.5 26.5 26.5 26.5 29 29 U 60 60 60 60 60 60 60 60 V 20 20 20 25 25 25 40 40 W 3 3 3 6 6 8 8 8 X 10 10 10 12.5 12.5 12.5 20 20 Y 37 37 37 37 37 37 47 47 Z Ø9 Ø9 Ø9 Ø11 Ø11 Ø11 Ø13.5 Ø13.5 K L All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Filter Input/Output Connector Cross Sections -33 -34 -35 -44 Solid wire 16 mm2 35 mm2 50 mm2 10 mm2 Flex wire 10 mm2 25 mm2 50 mm2 6 mm2 AWG type wire AWG 6 AWG 2 AWG 1/0 AWG 8 Recommended torque 1.5-1.8 Nm 4.0-4.5 Nm 7-8 Nm 1.0-1.2 Nm Please visit www.schaffner.com to find more details on filter connectors. 4 3-Phase Filters Schaffner Group Accessories Transparent protective covers for FN3359 and FN3270 with busbars from 150 to 1000 A Protection for the operator or inspector from accidental touching of live conductors. Easily to be added after the filter has been installed and connected. Technical Data Sheet > Sur Surge ge P Prrot otec ection tion D De evices SPD with a fail safe function to prevent short-circuit (separation of circuit and element is visually confirmable) Compliance with IEC 61643-1 that meets the new JIS standards Against indirect lightning surge for single phase / three phase power supplies Quick response for surge Impulse current capacity 8/20μs-5,000A Impulse test category: Class II (Type II) Every pathway consists of same elements. Between line and line/between lines and ground can protect as the same level. Technical Data Sheet > DATA SHEET 27. Sep 2022 5 3-Phase Filters Headquarters, Global Innovation and Development Switzerland Schaffner Group Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C No 565 Chuangye Road Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93 Miniparc III Edificio E El Soto de Moraleja Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC 22nd Floor Unit No 2238 Brigade Gateway Campus 26/1 Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 27. Sep 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1 #05-09 Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2 No 97 Section 1 XinTai 5th Road XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780 37FL 98 North-Sathorn Rd Silom Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. Suite 1 Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN3270H-20-44 价格&库存
很抱歉,暂时无法提供与“FN3270H-20-44”相匹配的价格&库存,您可以联系我们找货
