RD5122-16-2M0
RD5122-16-2M0
    SCHAFFNER(夏弗纳)
    RD5122-16-2M0
RD5122-16-2M0 数据手册
DATA SHEET Common Mode Chokes RD series Current-compensated Chokes Rated currents from 6 to 64 A Approvals & Compliances Up to 600 VAC or 850 VDC DC to 400 Hz frequencies Dual, triple and quad-choke configurations RD chokes are attenuating common-mode or asymmetric (P/N –> E) interference signals, by being connected in series with the phase and neutral lines of an AC powerline input. Symmetrical components of the noise are also attenuated by the leakage inductance of the windings. These chokes are typically used in conjunction with suppression capacitors. Features and Benefits High saturation resistance and excellent thermal behavior Through hole or wire connections Dual, triple and quad-choke configuration Up to 64 A quad configuration Multiple housing options Custom-specific versions are available on request Typical Applications Phase-angle control circuits in combination with saturating chokes EMI input filters Technical Specifications For suppressing equipment with no earth connection Maximum continuous operating voltage 600 VAC/850 VDC @ 40°C Operating frequency DC to 400 Hz Rated currents 6 to 64 A @ 40°C max. High potential test voltage winding-to-winding 2500 V, 50 Hz, 2 sec, factory test 2500 VAC, 60 sec, guaranteed winding-to-housing 4000 VAC, 60 sec, guaranteed Surge current @ 10 msec 20 x IN @ 25 °C Temperature range (operation and storage) -25°C to +110°C (25/110/21) Flammability corresponding to UL 94 V-0 (insulation tubes UL 94 V-2) MTBF @ 40°C/230 V (Mil-HB-217F) >5,000,000 hours Suppressing high interference levels Typical electrical schematic 2 Common Mode Chokes Schaffner Group DATA SHEET 15. Jun 2022 Choke Selection Table Choke Buy Nominal current Inductance Resistance Choke Input/Output Pin footprint connections connections @ 40°C L R configuration [A] [mH/path] [mΩ/path] [Qty] RD5122-6-9m6 6 9.6 52.55 2 RD5122-10-6m0 10 6 24.25 2 RD5122-16-2m0 16 2 9.5 RD5132-6-5m0 6 5 RD5132-10-3m0 10 3 RD5132-16-1m0 16 1 RD6127-6-15m0 6 RD6127-10-9m0 10 RD6127-16-3m0 Weight [mm] [g] -02 Ø1 160 -02 Ø1.3 160 2 -02 Ø1.6 160 38 3 -02 Ø1 160 17.6 3 -02 Ø1.3 160 6.9 3 -02 Ø1.6 160 15 66.65 2 -07 Ø1 235 9 25.9 2 -07 Ø1.5 235 16 3 10.9 2 -07 Ø1.8 235 RD6137-6-7m5 6 7.5 49 3 -07 Ø1 235 RD6137-10-4m5 10 4.5 18.35 3 -07 Ø1.5 235 RD6137-16-1m5 16 1.5 8.3 3 -07 Ø1.8 235 RD7127-6-25m0 6 25 84.2 2 -07 Ø1 320 RD7127-10-14m0 10 14 33.5 2 -07 Ø1.4 350 RD7127-16-5m7 16 5.7 14.1 2 -07 Ø1.8 370 RD7127-25-2m8 25 2.8 6.4 2 -07 Ø2.4 400 RD7127-36-1m0 36 1 3.3 2 -07 Ø2.7 380 RD7137-6-12m0 6 12 60.6 3 -07 Ø1 340 RD7137-10-6m6 10 6.6 21.9 3 -07 Ø1.5 380 RD7137-16-2m8 16 2.8 10.7 3 -07 Ø1.8 380 RD7137-25-1m3 25 1.3 4.45 3 -07 Ø2.5 440 RD7137-36-0m5 36 0.5 2.75 3 -07 Ø2.7 400 RD7147-6-6m0 6 6 45.1 4 -07 Ø1 320 RD7147-10-3m5 10 3.5 19.1 4 -07 Ø1.4 370 RD7147-16-1m5 16 1.5 8.5 4 -07 Ø1.8 390 RD7147-25-0m7 25 0.7 3.65 4 -07 Ø2.4 430 RD7147-36-0m2 36 0.2 2.3 4 -07 Ø2.5 400 RD8127-16-12m0 16 12 20.05 2 -07 Ø2 590 RD8127-25-5m0 25 5 8.45 2 -07 Ø2.4 630 RD8127-36-3m0 36 3 4.55 2 -07 1.5 x 4.5 690 RD8127-50-1m0 50 1 2.5 2 -07 1.7 x 5 640 RD8127-64-0m8 64 0.8 1.6 2 -07 2.5 x 5 710 RD8137-16-5m0 16 5 11.6 3 -07 Ø2 630 RD8137-25-2m5 25 2.5 6.4 3 -07 Ø2.4 650 RD8137-36-1m5 36 1.5 3.65 3 -07 1.5 x 4.5 720 RD8137-50-0m6 50 0.6 2.15 3 -07 1.7 x 5 700 RD8137-64-0m5 64 0.5 1.35 3 -07 2.5 x 5 780 RD8147-16-3m0 16 3 9.25 4 -07 Ø2 650 RD8147-25-1m3 25 1.3 5.05 4 -07 Ø2.4 650 RD8147-36-0m8 36 0.8 3 4 -07 1.5 x 4.5 760 RD8147-50-0m3 50 0.3 1.75 4 -07 1.7 x 5 740 RD8147-64-0m2 64 0.2 1.1 4 -07 2.5 x 5 820 Test conditions: Measuring frequency: 1 kHz; 500 μA >0.16 mH >1.6 mH; 50 μA >1.6 mH
RD5122-16-2M0 价格&库存
很抱歉,暂时无法提供与“RD5122-16-2M0”相匹配的价格&库存,您可以联系我们找货
