20CPT-B-2A
20CPT-B-2A
    JST
    P=2mm
    2X10P 2MM
20CPT-B-2A 数据手册
CPTCONNECTOR Board-to-wire Features ●Compact design 2.0 mm pitch is realized miniaturization and low profile as the connector for automobile. ●Terminal construction Female terminal is designed for simple box structure by having spring structure on male terminal. Developed in pursuit of miniaturization and low profile as PC board connector for automobile. This connector is surface mounting type connector having the spring structure on male terminal disproving the conventional concept. Specifications ●Current rating: 3 A AC, DC (0.3 mm2, Single circuit) ●Voltage rating: 50 V AC, DC ●Temperature range: -40°C to +100°C (including temperature rise in applying electrical current) ●Contact resistance: Initial value/ 8 mΩ max. After environmental tests/ 16 mΩ max. ●Insulation resistance: 100 MΩ min. ●Withstanding voltage: 1,000 VAC/minute ●Applicable wire: AESSX-f/ AVSS 0.3 mm2 * Compliant with ELV/RoHS2. * Contact JST for details. 1 CPTCONNECTOR Female terminal Applicable wire range Conductor (mm2) Insulation O.D. (mm) Q’ty/reel SCPT-A021GF-0.5 0.3 1.4 15,000 Material and Finish Brass, nickel-undercoated, Contact area; gold-plated Barrel area; tin-plated 5.5 1.4 5.5 Model No. Female connector Single row 12.5 ●2 circuits 0.8 6.6 Housing 2 6 Retainer ●4 circuits 04CPT-B1-2B 13.5 13.5 04CPT-B1-2A Housing 2 2 2×3=6 10 Retainer 2×3=6 10 0.8 0.8 6.6 6.6 Housing Retainer 13.5 ●8 circuits Circuits Model No. Q’ty/box 2 02CPT-B-2A 04CPT-B1-2A 04CPT-B1-2B 08CPT-B1-2A 500 4 8 0.8 6.6 Housing 2 2×7=14 18 600 400 Material and Finish Housing: Glass-filled PBT, Black Retainer: Glass-filled PBT, Blue Retainer 2 CPT CONNECTOR Female connector Dual row ●8 circuits ●12 circuits 12.5 13.5 12CPT-B-2A Housing 2 0.8 0.8 9.1 9.1 Housing 2 Retainer Retainer 2×5=10 14 2×3=6 10 ●12 circuits ●16 circuits 12.5 13.5 12CPT-B-2A-FL Housing 2 2 Retainer 2×5=10 0.8 0.8 9.1 9.1 Housing 2×7=14 Retainer 18 14 ●24 circuits 13.5 13.5 ●20 circuits Housing 2 2×9=18 Retainer 22 Circuits 8 12 16 20 24 2 2×11=22 26 Model No. 08CPT-B-2A 12CPT-B-2A 12CPT-B-2A-FL 16CPT-B-2A 20CPT-B-2A 24CPT-B-2A Material and Finish Housing: Glass-filled PBT, Black Retainer: Glass-filled PBT, Blue 3 0.8 9.1 0.8 9.1 Housing Q’ty/box 500 300 250 250 200 Retainer CPT CONNECTOR Male connector Top entry type Single row ●2 circuits 6.8 10.5 1 Circuit No. 2 11.7 Dual row ●12 circuits ●8 circuits 19.6 1 9.2 4 8 5 Circuit No. 2 Type Single row Top Dual row Model No. Q’ty/reel 2 BM02B-CPTK-1A-TB BM08B-CPTK-1A-TB BM12B-CPTK-1A-TB 370 12 6 1 12 7 2 Circuits 8 12.7 9.2 12.7 2.5 15.6 2.5 2 Circuit No. 240 Material and Finish Terminal: Copper alloy, nickel-undercoated, Contact area; gold-plated Solder tail; tin-plated (reflow treatment) Housing: Glass-filled LCP, Black Peg: Brass, nickel-undercoated, tin-plated (reflow treatment) 4 CPT CONNECTOR Male connector Side entry type Single row ●2circuits 2 14.1 15.2 11.6 10.6 6.8 Circuit No. 2 1 ●4 circuits SM04B1-CPTK-1A-TB SM04B1-CPTK-1B-TB 6 6 18.1 15.2 15.6 18.1 10.6 15.2 15.6 4 10.6 Circuit No. 6.8 6.8 Circuit No. 4 1 1 ●8 circuits 14 Type Side Single row Circuits Model No. Q’ty/reel 2 SM02B-CPTK-1A-TB SM04B1-CPTK-1A-TB SM04B1-CPTK-1B-TB SM08B1-CPTK-1A-TB 500 4 8 Material and Finish 15.2 26.1 23.6 6.8 Circuit No. 8 5 1 10.6 Terminal: Copper alloy, nickel-undercoated, Contact area; gold-plated Solder tail; tin-plated (reflow treatment) Housing: Glass-filled LCP, Black Peg: Brass, nickel-undercoated, tin-plated (reflow treatment) CPT CONNECTOR Male connector Side entry type Dual row ●8 circuits ●12 circuits 7 11 1 12 7 9.3 5 6 10.6 ●20 circuits ●16 circuits 15 19 26.1 30.1 15.2 Circuit No. 16 9 10 1 20 11 10.6 9.3 1 9.3 8 15.2 Circuit No. 27.6 10.6 2.5 23.6 2.5 8 9.3 1 15.2 Circuit No. 19.6 10.6 2.5 4 22.1 15.2 Circuit No. 2.5 18.1 15.6 ●24 circuits Type Circuits Model No. Q’ty/reel 8 SM08B-CPTK-1A-TB SM12B-CPTK-1A-TB SM16B-CPTK-1A-TB SM20B-CPTK-1A-TB SM24B-CPTK-1A-TB 390 23 12 Side Dual row 16 20 24 Material and Finish 34.1 15.2 31.6 1 24 13 9.3 12 10.6 2.5 Circuit No. Terminal: Copper alloy, nickel-undercoated, Contact area; gold-plated Solder tail; tin-plated (reflow treatment) Housing: Glass-filled LCP, Black Peg: Brass, nickel-undercoated, tin-plated (reflow treatment) 6 CPT CONNECTOR Taping Specifications Top entry type ●2 circuits Feeding direction φ1.5 +0.1 0 Carrier tape ±0.5 16 +2.5 A -1 ●8, 12 ±0.1 circuits Feeding direction Feeding direction 4 ±0.1 Cover tape leader 2 ±0.1 φ1.5 +0.1 0 C ±0.1 B ±0.1 Leader part The end 100mm min. part Connector 160mm min. mounting part 400mm min. Cover tape ±0.3 Carrier tape D 2 1.75 ±0.1 (φ13) Cover tape 28.4 φ380 ±2.0 14.2 ±0.1 2 ±0.1 32 ±0.3 4 ±0.1 1.75 ±0.1 Feeding direction ±0.1 ●2, 8, 12 circuits Carrier tape 24 ±0.1 Type Circuits A B C D Single row 2 33.5 ー ー ー 8 33.5 14.2 28.4 32 12 45.5 20.2 40.4 44 Dual row Side entry type 4 ±0.1 Feeding direction 2 ±0.1 φ1.5 1.75 ±0.1 ●2, 4, 8, 12, 16, 20, 24 circuits +0.1 0 Cover tape D ±0.3 φ380 C ±0.1 ±2.0 B ±0.1 Feeding direction Carrier tape (φ13) 2 ±0.5 20 ±0.1 +2.5 A -1 Type Feeding direction Carrier tape The end part Connector 160mm min. mounting part 7 Cover tape leader Leader part 100mm min. 400mm min. Single row Dual row Circuits A B C D 2 33.5 14.2 28.4 32 4 33.5 14.2 28.4 32 8 45.5 20.2 40.4 44 8 45.5 20.2 40.4 44 12 45.5 20.2 40.4 44 16 45.5 20.2 40.4 44 20 45.5 20.2 40.4 44 24 57.5 26.2 52.4 56 CPT CONNECTOR PC board layout, Assembly layout Top entry type Assembly layout PC board layout Single row ●2 circuits ●2 circuits 8.2 10.9 ±0.1 6.8 4.35 ±0.05 Circuit No.2 16.1 Circuit No.1 3 ±0.05 4.9 ±0.05 5.8 ±0.3 1.85 ±0.2 1 ±0.05 2 ±0.05 Dual row ●8,12 circuits ●8 circuits 13.5 13.5 9.2 9.2 16.1 5.5 ±0.05 6.2 ±0.05 Circuit /PD 17.1 1.6 ±0.05 Circuit/P 14.5 ±0.1 1.35 ±0.05 4.95 ±0.05 11.8 ±0.1 3 ±0.05 A ±0.1 ●12 circuits 4.75 ±0.05 1 ±0.05 2 ±0.05 B ±0.1 Circuits A B 8 15.7 6 12 19.7 10 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. The dimensions above should serve as guideline. Contact JST for details. 8 CPT CONNECTOR PC board layout, Assembly layout Side entry type PC board layout Single row ●2, 4, 8 (Single) circuits Assembly layout ●2 circuits ●4 circuits 19.6 20.6 15 a Circuit No.1 a 1 Circuits A B 2 2 15.8 4 6 19.8 8 (Single) 14 27.8 A ±0.05 0.75 ±0.03 3.3 ±0.05 6.8 6.8 Circuit No.a ㍑饟 No. 16 1 2 ±0.05 ●8 (Single) circuits 20.6 6.8 5 ±0.05 8.8 ±0.05 16 3.85 ±0.05 7.4 ±0.05 Dual row ●8 (Dual), 12, 16, 20, 24 circuits Circuit No.a Circuit No.1 1 c b 16 Circuit No.b 1b Circuits 0.75 ±0.03 B 8 (Dual) 7 19.8 12 11 23.8 16 15 27.8 20 19 31.8 24 23 35.8 ●16 circuits ●20, 24 circuits 20.6 19.6 16 15 9.3 5 ±0.05 8.8 ±0.05 1 ±0.05 A 3.85 ±0.05 6.4 ±0.05 B ±0.1 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. The dimensions above should serve as guideline. Contact JST for details. Crimping machine, Applicator Crimp applicator MKS-L Strip terminal Crimping machine Dies Crimp applicator with dies SCPT-A021GF-0.5 AP-K2N MK/SCPT-A021-05 APLMK SCPT-A021-05 Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 9 9.3 a c A ±0.05 3.3 ±0.05 20.6 19.6 9.3 a ●12 circuits 15 Circuit No.c Circuit No. ●8 (Dual) circuits 9.3 B ±0.1
20CPT-B-2A 价格&库存
很抱歉,暂时无法提供与“20CPT-B-2A”相匹配的价格&库存,您可以联系我们找货
20CPT-B-2A
    • 1+8.486241+1.09927
    • 50+6.2237950+0.80620
    • 100+5.71827100+0.74072
    • 300+5.37020300+0.69563
    • 500+5.30390500+0.68704
    • 1000+5.254181000+0.68060
    • 2000+5.229312000+0.67738
    库存:2998
    709-972-501
      库存:2395
