PBA300F-48
PBA300F-48
    COSEL
    PBA300F-48是一款300W的AC-DC电源模块,输入电压范围为85-264V AC或120-370V DC。输出电压为48V,最大输出电流为6.6A。具有多种保护功能,如过流保护和过压保护。
PBA300F-48 数据手册
AC-DC Power Supplies Enclosed Type Power Factor Correction World wide Safety Approvals EMI Inrush current limiting OCP OVP Remote ON/OFF Parallel Operation PBA, PBW-series Feature CE marking Small-size & light weight Harmonic attenuator (Complies with IEC61000-3-2) : except PBA1500T Universal input (AC85 - 264V) : PBA1500T(AC170 - 264V 3f) Efficiency increased with synchronous rectification technology (PBA50F - 150F) Variety of option (PBA10F - 150F, PBW15F - 50F) Parallel operation and Parallel redandancy operation (PBA300F - 1500F, PBA1500T) Fan alarm, Remote ON/OFF and other functions (PBA300F - 1500F, PBA1500T) Safety agency approvals Low Voltage Directive RoHS Directive EMS Compliance : EN61204-3, EN61000-6-2 EN61000-4-2 EN61000-4-3 EN61000-4-4 EN61000-4-5 EN61000-4-6 EN61000-4-8 EN61000-4-11 UL60950-1, C-UL(CSA60950-1), EN62368-1 UL508 (PBA10F - 150F, -24, with cover) Complies with DEN-AN EMI Complies with FCC-B, CISPR22-B, EN55011-B, EN55022-B, VCCI-B 5-year warranty (refer to Instruction Manual) March 08, 2022 PBA/PBW-1 AC-DC Power Supplies Enclosed Type PBA10F Ordering information PB 1 A 2 10 3 F Example recommended EMI/EMC filter NAC-06-472 R -O -O 4 High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. 5 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current E : Low leakage current and EMI class A T : Vertical terminal block J1 : VH (J.S.T.) connector type N : with Cover (UL508 is acquired) N1 : with DIN rail and Cover V : Output voltage setting potentiometer externally Cover is optional *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA10F-5 10 5V 2A PBA10F-12 10.8 12V 0.9A PBA10F-24 12 24V 0.5A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] *6 LOAD REGULATION[mV] *6 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBA10F-5 PBA10F-12 PBA10F-24 AC85 - 264 1f or DC110 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *3) 0.30typ (Io=100%) 0.20typ (Io=100%) 50/60 (47 - 440) or DC 74typ 76typ 77typ 74typ 76typ 77typ 15typ (Io=100%) 30typ (Io=100%) 0.15/0.30max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1, DENAN) 5 12 24 2 0.9 0.5 20max 48max 96max 40max 100max 150max 80max 120max 120max 140max 160max 160max 120max 150max 150max 160max 180max 180max 50max 120max 240max 60max 150max 290max 20max 48max 96max 200typ(ACIN 100V, Io=100%) *Start-up time is 700ms typ for less than 1minute of applying input again from turning off the input voltage. 20typ (ACIN 100V, Io=100%) 4.50 - 5.50 10.0 - 13.2 19.2 - 27.0 5.00 - 5.15 12.00 - 12.48 24.00 - 24.96 Works over 105% of rated current and recovers automatically 5.75 - 7.00 15.0 - 18.0 30.0 - 37.0 LED (Green) None AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Not built-in to active filter *4) *7 31X78X68mm [1.22X3.07X2.68 inches] (without terminal block) (WXHXD) / 150g max (with cover : 180g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Derating is required. *4 When two or more units are used,they may not comply with the harmonic attenuator. Please contact us for details. PBA/PBW-2 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about dynamic load and input response. *7 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. March 08, 2022 PBA10F Block diagram FUSE AC250V 2.5A AC IN 85 - 264V NOISE FILTER INRUSH CURRENT LIMIT RECTIFIER AND FILTER FG TRANSFORMER CONTROL RECTIFIER AND FILTER INVERTER DC OUT CURRENT SENSING Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION External view ¶ External size of option T,J1,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. 18 Voltage adjust [0.71] 12.2±1.5 [0.48] 2.5 LED [0.1] 16.5±2 Cover name plate 68 [0.65] [2.68] M3 2-M3 Mounting hole AC(N) 15.1±1.5 [0.59] 78 49.5±0.5 Terminal cover 4 [1.95] 22.6±1.5 [0.89] [1.36] 11.5 9.5 [0.45] [0.37] 34.5 [0.3] FG AC(L) [3.07] Cover (option) -V 7.5 70.5 [2.78] +V [0.16] Point A:C102 Name plate 18 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 150g max (with cover : 180g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Hot-dip galvanized steel plate ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.6N • m(6.3kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. [0.71] 31 PBA10F [1.22] 34.5 [1.36] 2-M3 Mounting hole 36 ±0.5 [1.42] March 08, 2022 11 [0.43] PBA/PBW-3 AC-DC Power Supplies Enclosed Type PBA15F Ordering information PB 1 A 2 15 3 F 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. Cover is optional -O -O 5 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current E : Low leakage current and EMI class A T : Vertical terminal block J1 : VH (J.S.T.) connector type N : with Cover (UL508 is acquired [5V, 12V, 24V]) N1 : with DIN rail and Cover V : Output voltage setting potentiometer externally *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA15F-3R3 9.9 3.3V 3A PBA15F-5 15 5V 3A PBA15F-9 15.3 9V 1.7A PBA15F-12 15.6 12V 1.3A PBA15F-15 15 15V 1A PBA15F-24 16.8 24V 0.7A PBA15F-48 16.8 48V 0.35A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS PBA15F-3R3 PBA15F-5 PBA15F-9 PBA15F-12 PBA15F-15 PBA15F-24 PBA15F-48 AC85 - 264 1f or DC110 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *3) ACIN 100V 0.30typ (Io=100%) 0.4typ (Io=100%) ACIN 200V 0.15typ (Io=100%) 0.2typ (Io=100%) 50/60 (47 - 440) or DC ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] *6 LOAD REGULATION[mV] *6 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] 68typ 74typ 75typ 75typ 77typ 75typ 75typ 68typ 75typ 77typ 78typ 80typ 78typ 78typ 15typ (Io=100%) (At cold start) 30typ (Io=100%) (At cold start) 0.15/0.30max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) 3.3 5 9 12 15 24 48 3 3 1.7 1.3 1 0.7 0.35 20max 20max 36max 48max 60max 96max 192max 40max 40max 100max 100max 120max 150max 240max 80max 80max 120max 120max 120max 120max 150max 140max 140max 160max 160max 160max 160max 200max 120max 120max 150max 150max 150max 150max 250max 160max 160max 180max 180max 180max 180max 300max 50max 50max 90max 120max 150max 240max 480max 60max 60max 120max 150max 180max 290max 600max 20max 20max 36max 48max 60max 96max 192max 200typ(ACIN 100V, Io=100%) *Start-up time is 700ms typ for less than 1minute of applying input again from turning off the input voltage. 20typ (ACIN 100V, Io=100%) 2.85 - 3.60 4.50 - 5.50 7.50 - 10.0 10.0 - 13.2 13.2 - 18.0 19.2 - 27.0 39.0 - 53.0 3.30 - 3.40 5.00 - 5.15 9.00 - 9.36 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 48.00 - 49.92 Works over 105% of rated current and recovers automatically 4.00 - 5.25 5.75 - 7.00 11.5 - 14.0 15.0 - 18.0 20.0 - 25.0 30.0 - 37.0 58.0 - 65.0 LED (Green) None AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Not built-in to active filter *4) *7 31X78X85mm [1.22X3.07X3.35 inches] (without terminal block) (WXHXD) / 200g max (with cover : 235g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Derating is required. *4 When two or more units are used,they may not comply with the harmonic attenuator. Please contact us for details. PBA/PBW-4 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about dynamic load and input response. *7 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. March 08, 2022 PBA15F Block diagram FUSE AC250V 2.5A AC IN 85 - 264V INRUSH CURRENT LIMIT NOISE FILTER RECTIFIER AND FILTER FG TRANSFORMER CONTROL RECTIFIER AND FILTER INVERTER DC OUT CURRENT SENSING Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION External view ¶ External size of option T,J1,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. 18 Voltage adjust [0.71] 12.2±1.5 [0.48] 2.5 [0.1] LED 16.5±2 85 [0.65] Cover name plate [3.35] M3 78 [1.36] 34.5 7.5 [1.22] Point A:C102 [1.44] 2-M3 Mounting hole Name plate 2-M3 Mounting hole [1.36] [0.89] 36.5 31±0.5 Terminal cover 22.6±1.5 34.5 [0.59] 18 [0.71] ¶ Tolerance : ±1 [±0.04] ¶ Weight : 200g max (with cover : 235g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Hot-dip galvanized steel plate ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.6N • m(6.3kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. 31 PBA15F PBW15F [1.22] 15.1±1.5 [0.3] AC(N) [0.45] [0.37] FG AC(L) [3.07] Cover (option) -V 11.5 9.5 70.5 [2.78] +V 60 ±0.5 [2.36] March 08, 2022 5 [0.2] PBA/PBW-5 AC-DC Power Supplies Enclosed Type PBA30F Ordering information PB 1 A 2 30 3 F 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. Cover is optional -O -O 5 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current E : Low leakage current and EMI class A T : Vertical terminal block J1 : VH (J.S.T.) connector type N : with Cover (UL508 is acquired [5V, 12V, 24V]) N1 : with DIN rail and Cover V : Output voltage setting potentiometer externally *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA30F-3R3 19.8 3.3V 6A PBA30F-5 30 5V 6A PBA30F-9 30.6 9V 3.4A PBA30F-12 30 12V 2.5A PBA30F-15 30 15V 2A PBA30F-24 31.2 24V 1.3A PBA30F-48 31.2 48V 0.65A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS PBA30F-3R3 PBA30F-5 PBA30F-9 PBA30F-12 PBA30F-15 PBA30F-24 PBA30F-48 AC85 - 264 1f or DC110 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *3) ACIN 100V 0.50typ (Io=100%) 0.70typ (Io=100%) ACIN 200V 0.30typ (Io=100%) 0.40typ (Io=100%) 50/60 (47 - 440) or DC ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] *6 LOAD REGULATION[mV] *6 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C *2 DRIFT[mV] START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] 68typ 74typ 75typ 76typ 78typ 78typ 79typ 69typ 77typ 77typ 78typ 81typ 81typ 81typ 15typ (Io=100%) (At cold start) 30typ (Io=100%) (At cold start) 0.30/0.65max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) 3.3 5 9 12 15 24 48 6 6 3.4 2.5 2 1.3 0.65 20max 20max 36max 48max 60max 96max 192max 40max 40max 100max 100max 120max 150max 240max 80max 80max 120max 120max 120max 120max 150max 140max 140max 160max 160max 160max 160max 200max 120max 120max 150max 150max 150max 150max 250max 160max 160max 180max 180max 180max 180max 300max 50max 50max 90max 120max 150max 240max 480max 60max 60max 120max 150max 180max 290max 600max 20max 20max 36max 48max 60max 96max 192max 200typ(ACIN 100V, Io=100%) *Start-up time is 700ms typ for less than 1minute of applying input again from turning off the input voltage. 20typ (ACIN 100V, Io=100%) 2.85 - 3.60 4.50 - 5.50 7.50 - 10.0 10.0 - 13.2 13.2 - 18.0 19.2 - 27.0 39.0 - 53.0 3.30 - 3.40 5.00 - 5.15 9.00 - 9.36 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 48.00 - 49.92 Works over 105% of rated current and recovers automatically 4.00 - 5.25 5.75 - 7.00 11.5 - 14.0 15.0 - 18.0 20.0 - 25.0 30.0 - 37.0 58.0 - 65.0 LED (Green) None AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Not built-in to active filter *4) *7 31X78X103mm [1.22X3.07X4.06 inches] (without terminal block) (W XHXD) / 270g max (with cover : 310g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Derating is required. *4 When two or more units are used,they may not comply with the harmonic attenuator. Please contact us for details. PBA/PBW-6 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about dynamic load and input response. *7 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. March 08, 2022 PBA30F Block diagram FUSE AC250V 3.15A AC IN 85 - 264V INRUSH CURRENT LIMIT NOISE FILTER RECTIFIER AND FILTER FG TRANSFORMER CONTROL INVERTER RECTIFIER AND FILTER DC OUT CURRENT SENSING Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION External view ¶ External size of option T,J1,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. 18 Voltage adjust [0.71] 12.2 ±1.5 [0.48] 2.5 [0.1] LED 16.5±2 Cover name plate 103 [0.65] [4.06] M3 22.6 ±1.5 [0.89] 78 [3.07] 40.5 [1.81] [1.59] Point A:C102 2-M3 Mounting hole Name plate 2-M3 Mounting hole 18 PBA30F PBW30F ¶ Tolerance : ±1 [±0.04] ¶ Weight : 270g max (with cover : 310g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Hot-dip galvanized steel plate ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.6N • m(6.3kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. [1.44] 36.5 46±0.5 Terminal cover 75 ±0.5 [2.95] March 08, 2022 [1.36] [0.59] [0.71] 31 [1.22] 34.5 15.1±1.5 7.5 AC(N) [0.3] FG AC(L) 11.5 9.5 Cover (option) -V [0.45] [0.37] 70.5 [2.78] +V 8.5 [0.33] PBA/PBW-7 Ordering information AC-DC Power Supplies Enclosed Type PBA50F PB 1 A 2 50 3 F 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current (0.15mA max / ACIN 240V) E : Low leakage current and EMI class A (0.5mA max / ACIN 240V) T : Vertical terminal block J1 : VH (J.S.T.) connector type R : with Remote ON/OFF N : with Cover (Only 24V UL508 is acquired) N1 : with DIN rail and Cover V : Output voltage setting potentiometer externally Cover is optional *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA50F-3R3 33 3.3V 10A PBA50F-5 50 5V 10A PBA50F-9 50.4 9V 5.6A PBA50F-12 51.6 12V 4.3A PBA50F-15 52.5 15V 3.5A PBA50F-24 52.8 24V 2.2A PBA50F-36 50.4 36V 1.4A PBA50F-48 52.8 48V 1.1A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR(Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT -RC *3 INPUT-FG OUTPUT-RC-FG *3 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBA50F-3R3 PBA50F-5 PBA50F-9 PBA50F-12 PBA50F-15 PBA50F-24 PBA50F-36 PBA50F-48 AC85 - 264 1f or DC120 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *4) 0.5typ 0.7typ 0.3typ 0.4typ 50/60 (47 - 63) 75typ 80typ 79typ 80typ 81typ 82typ 83typ 83typ 76typ 82typ 81typ 82typ 83typ 84typ 85typ 85typ 0.98typ 0.99typ 0.87typ 0.93typ 15typ (Io=100%) (At cold start) 30typ (Io=100%) (At cold start) 0.4/0.75max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) 3.3 5 9 12 15 24 36 48 10 10 5.6 4.3 3.5 2.2 1.4 1.1 20max 20max 36max 48max 60max 96max 144max 192max 40max 40max 100max 100max 120max 150max 240max 240max 80max 80max 120max 120max 120max 120max 150max 150max 140max 140max 160max 160max 160max 160max 200max 200max 120max 120max 150max 150max 150max 150max 250max 250max 160max 160max 180max 180max 180max 180max 300max 300max 50max 50max 90max 120max 150max 240max 360max 480max 60max 60max 120max 150max 180max 290max 450max 600max 20max 20max 36max 48max 60max 96max 144max 192max 350typ(ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 - 3.63 4.00 - 5.50 7.50 - 10.0 10.0 - 13.2 13.2 - 18.0 19.2 - 27.0 28.8 - 39.6 39.0 - 53.0 3.30 - 3.40 5.00 - 5.15 9.00 - 9.36 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 35.00 - 37.44 48.00 - 49.92 Works over 105% of rated current and recovers automatically 4.00 - 5.25 5.75 - 7.00 11.5 - 14.0 15.0 - 18.0 20.0 - 25.0 30.0 - 37.0 43.0 - 50.0 58.0 - 65.0 LED (Green) Optional (Required external power source) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *6 31X82X120mm [1.22X3.23X4.72 inches] (without terminal block) (WXHXD) / 280g max (with cover : 325g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Applicable when Remote ON/OFF(optional) is added. RC is insulated with input, output and FG. *4 Derating is required. PBA/PBW-8 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. March 08, 2022 PBA50F Block diagram FUSE 250V2A NOISE FILTER AC IN 85 - 264V RECTIFIER INRUSH CURRENT LIMIT FG CURRENT SENSING BOOSTER INDUCTOR CURRENT SENSING OPTION RC EXTERNAL SOURCE RECTIFIER AND FILTER CONTROL CONTROL OVER VOLTAGE PROTECTION INVERTER INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL E DC OUT External view ¶ External size of option T,J1,R,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. CN3 Connector for Remote ON/OFF (option) (20) (16.5) 120 [0.65] [0.02] LED [0.43] [4.72] 0.5 [0.79] Voltage adjust (11) 12 M3 Cover (option) [3.03] (21.5) 4 [0.16] [0.85] 88 ±0.5 [3.46] March 08, 2022 Connector type CN3 Option (Mfr : J.S.T.) Pin No. 1 2 Contents RC(+) RC( - ) 31 PBA50F 18 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 280g max (with cover : 325g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.49N • m(5kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. 3.5 Name plate 2-M3 Mounting hole [0.14] 77 ±0.5 Terminal cover Point A [1.22] (14) [0.55] 35 (12) 9.5 [0.47] [0.37] AC(N) A 2-M3 Mounting hole [1.38] FG AC(L) 11 [0.43] [0.71] 7.5 82 [3.23] -V [0.3] [2.8] (71) +V Barrier strip type Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 ( ) PBA/PBW-9 Ordering information AC-DC Power Supplies Enclosed Type PBA75F PB 1 A 2 75 3 F 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current (0.15mA max / ACIN 240V) E : Low leakage current and EMI class A (0.5mA max / ACIN 240V) T : Vertical terminal block J1 : VH (J.S.T.) connector type R : with Remote ON/OFF N : with Cover (Only 24V UL508 is acquired) N1 : with DIN rail and Cover V : Output voltage setting potentiometer externally Cover is optional *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA75F-3R3 49.5 3.3V 15A PBA75F-5 75 5V 15A PBA75F-9 75.6 9V 8.4A PBA75F-12 75.6 12V 6.3A PBA75F-15 75 15V 5A PBA75F-24 76.8 24V 3.2A PBA75F-36 75.6 36V 2.1A PBA75F-48 76.8 48V 1.6A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR(Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT -RC *3 INPUT-FG OUTPUT-RC-FG *3 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBA75F-3R3 PBA75F-5 PBA75F-9 PBA75F-12 PBA75F-15 PBA75F-24 PBA75F-36 PBA75F-48 AC85 - 264 1f or DC120 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *4) 0.7typ 1.0typ 0.4typ 0.5typ 50/60 (47 - 63) 77typ 81typ 80typ 81typ 82typ 83typ 84typ 84typ 78typ 83typ 82typ 83typ 84typ 85typ 86typ 86typ 0.98typ 0.99typ 0.87typ 0.93typ 15typ (Io=100%) (At cold start) 30typ (Io=100%) (At cold start) 0.4/0.75max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) 3.3 5 9 12 15 24 36 48 15 15 8.4 6.3 5 3.2 2.1 1.6 20max 20max 36max 48max 60max 96max 144max 192max 40max 40max 100max 100max 120max 150max 240max 240max 80max 80max 120max 120max 120max 120max 150max 150max 140max 140max 160max 160max 160max 160max 200max 200max 120max 120max 150max 150max 150max 150max 250max 250max 160max 160max 180max 180max 180max 180max 300max 300max 50max 50max 90max 120max 150max 240max 360max 480max 60max 60max 120max 150max 180max 290max 450max 600max 20max 20max 36max 48max 60max 96max 144max 192max 350typ(ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 - 3.63 4.00 - 5.50 7.50 - 10.0 10.0 - 13.2 13.2 - 18.0 19.2 - 27.0 28.8 - 39.6 39.0 - 53.0 3.30 - 3.40 5.00 - 5.15 9.00 - 9.36 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 36.00 - 37.44 48.00 - 49.92 Works over 105% of rated current and recovers automatically 4.00 - 5.25 5.75 - 7.00 11.5 - 14.0 15.0 - 18.0 20.0 - 25.0 30.0 - 37.0 43.0 - 50.0 58.0 - 65.0 LED (Green) Optional (Required external power source) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *6 32X82X135mm [1.26X3.23X5.31 inches] (without terminal block) (WXHXD) / 350g max (with cover : 400g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Applicable when Remote ON/OFF(optional) is added. RC is insulated with input, output and FG. *4 Derating is required. PBA/PBW-10 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. March 08, 2022 PBA75F Block diagram FUSE 250V3.15A AC IN 85 - 264V NOISE FILTER RECTIFIER INRUSH CURRENT LIMIT FG CURRENT SENSING BOOSTER INDUCTOR OPTION RC EXTERNAL SOURCE CURRENT SENSING RECTIFIER AND FILTER CONTROL CONTROL OVER VOLTAGE PROTECTION INVERTER INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL E DC OUT External view ¶ External size of option T,J1,R,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. CN3 Connector for Remote ON/OFF (option) [0.79] (11) (16.5) LED 135 [0.65] [0.43] [5.31] 0.5 Voltage adjust [0.02] (20) 12 M3 Cover (option) [3.23] 82 -V [0.3] FG 7.5 Terminal cover (21.5) 35 [0.16] Name plate 105.5±0.5 [4.15] March 08, 2022 3.5 18 PBA75F ¶ Tolerance : ±1 [±0.04] ¶ Weight : 350g max (with cover : 400g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.49N • m(5kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. 2-M3 Mounting hole [0.14] [0.85] Point A 4 94 ±0.5 [3.7] 32 (14) [0.55] A [1.26] AC(N) 2-M3 Mounting hole [1.38] (12) 9.5 [0.47] [0.37] AC(L) 9 [0.35] [0.71] [2.8] (71) +V Connector type CN3 Option (Mfr : J.S.T.) Pin No. 1 2 Contents RC(+) RC( - ) Barrier strip type Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 ( ) PBA/PBW-11 Ordering information AC-DC Power Supplies Enclosed Type PBA100F PB 1 A 100 F 2 3 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current (0.15mA max / ACIN 240V) E : Low leakage current and EMI class A (0.5mA max / ACIN 240V) T : Vertical terminal block J1 : VH (J.S.T.) connector type (Only -12,-15,-24,-36,-48) R : with Remote ON/OFF N : with Cover (Only 24V UL508 is acquired) N1 : with DIN rail and Cover V : Output voltage setting potentiometer externally Cover is optional *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA100F-3R3 PBA100F-5 66 100 3.3V 20A 5V 20A PBA100F-9 94.5 9V 10.5A PBA100F-12 102 12V 8.5A PBA100F-15 105 15V 7A PBA100F-24 108 24V 4.5A PBA100F-36 100.8 36V 2.8A PBA100F-48 100.8 48V 2.1A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR(Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC *3 INPUT-FG OUTPUT-RC-FG *3 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBA100F-3R3 PBA100F-5 PBA100F-9 PBA100F-12 PBA100F-15 PBA100F-24 PBA100F-36 PBA100F-48 AC85 - 264 1f or DC120 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *4) 0.9typ 1.3typ 0.5typ 0.7typ 50/60 (47 - 63) 77typ 82typ 80typ 81typ 83typ 84typ 84typ 84typ 79typ 84typ 82typ 83typ 86typ 86typ 86typ 86typ 0.98typ 0.99typ 0.87typ 0.93typ 20typ (Io=100%) (At cold start) 40typ (Io=100%) (At cold start) 0.4/0.75max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1, DENAN) 3.3 5 9 12 15 24 36 48 20 20 10.5 8.5 7 4.5 2.8 2.1 20max 20max 36max 48max 60max 96max 144max 192max 40max 40max 100max 100max 120max 150max 240max 240max 80max 80max 120max 120max 120max 120max 150max 150max 140max 140max 160max 160max 160max 160max 200max 200max 120max 120max 150max 150max 150max 150max 250max 250max 160max 160max 180max 180max 180max 180max 300max 300max 50max 50max 90max 120max 150max 240max 360max 480max 60max 60max 120max 150max 180max 290max 450max 600max 20max 20max 36max 48max 60max 96max 144max 192max 350typ(ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 - 3.63 4.00 - 5.50 7.50 - 10.0 10.0 - 13.2 13.2 - 18.0 19.2 - 27.0 28.8 - 39.6 39.0 - 53.0 3.20 - 3.40 5.00 - 5.15 9.00 - 9.36 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 36.00 - 37.44 48.00 - 49.92 Works over 105% of rated current and recovers automatically 4.00 - 5.25 5.75 - 7.00 11.5 - 14.0 15.0 - 18.0 20.0 - 25.0 30.0 - 37.0 43.0 - 50.0 58.0 - 65.0 LED (Green) Optional (Only -3R3, -5 Option -K) Optional (Required external power source) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *6 32X93X147mm [1.26X3.66X5.79 inches] (without terminal block) (WXHXD) / 440g max (with cover : 500g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Applicable when Remote ON/OFF(optional) is added. RC is insulated with input, output and FG. *4 Derating is required. PBA/PBW-12 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. March 08, 2022 PBA100F Block diagram FUSE 250V3.15A AC IN 85 - 264V NOISE FILTER RECTIFIER INRUSH CURRENT LIMIT FG CURRENT SENSING BOOSTER INDUCTOR CURRENT SENSING OPTION RC EXTERNAL SOURCE RECTIFIER AND FILTER CONTROL CONTROL OVER VOLTAGE PROTECTION INVERTER INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL E DC OUT External view ¶ External size of option T,J1,R,N1,V and K is different from standard model and refer to 7 Option of instruction manual for details. CN3 Connector for Remote ON/OFF (option) CN4 Connector for Remote sensing (option : only -3R3, -5) (20) (13.5) Terminal cover [5.79] 0.5 147 [0.53] [0.02] LED 93 (11) Voltage adjust [0.43] [3.66] [0.79] 12 M4 +V +V Cover (option) -V (14) 124±0.5 [0.55] [0.16] 3-M3 Mounting hole [0.93] [0.37] [0.51] 9.5 13±0.5 3.5 Name plate PBA100F [0.71] 18 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 440g max (with cover : 500g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.49N • m(5kgf • cm)max ¶ Mounting torque : M4:1.6N • m(16.9kgf • cm)max ¶ Please connect safety ground to FG terminal on the unit. 112.5 ±0.5 [4.43] March 08, 2022 [1.32] 4 [4.88] (23.5) Point A 15 [0.59] [0.14] AC(N) [1.26] (10) 10 [0.39] [0.39] AC(L) A 2-M3 Mounting hole 33.5 ) 32 8.6 FG( [0.34] (81) [3.19] -V Connector type CN3 Option (Mfr : J.S.T.) Pin No. 1 2 Contents RC(+) RC( - ) Barrier strip type Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 ( ) PBA/PBW-13 Ordering information AC-DC Power Supplies Enclosed Type PBA150F PB 1 A 150 F 2 3 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current (0.15mA max / ACIN 240V) E : Low leakage current and EMI class A (0.5mA max / ACIN 240V) T : Vertical terminal block J1 : VH (J.S.T.) connector type (Only -12,-15,-24,-36,-48) R : with Remote ON/OFF N : with Cover (Only 24V UL508 is acquired) N1 : with DIN rail and Cover V : Output voltage setting potentiometer externally Cover is optional *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA150F-3R3 PBA150F-5 99 150 3.3V 30A 5V 30A PBA150F-9 150.3 9V 16.7A PBA150F-12 156 12V 13A PBA150F-15 150 15V 10A PBA150F-24 156 24V 6.5A PBA150F-36 154.8 36V 4.3A PBA150F-48 158.4 48V 3.3A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR(Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT[A] LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC *3 INPUT-FG OUTPUT-RC-FG *3 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBA150F-3R3 PBA150F-5 PBA150F-9 PBA150F-12 PBA150F-15 PBA150F-24 PBA150F-36 PBA150F-48 AC85 - 264 1f or DC120 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *4) 1.3typ 2.0typ 0.7typ 1.0typ 50/60 (47 - 63) 80typ 83typ 82typ 83typ 84typ 85typ 85typ 85typ 82typ 86typ 85typ 86typ 87typ 88typ 88typ 88typ 0.98typ 0.99typ 0.87typ 0.93typ 20typ (Io=100%) (At cold start) 40typ (Io=100%) (At cold start) 0.4/0.75max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) 3.3 5 9 12 15 24 36 48 30 30 16.7 13 10 6.5 4.3 3.3 20max 20max 36max 48max 60max 96max 144max 192max 40max 40max 100max 100max 120max 150max 240max 240max 80max 80max 120max 120max 120max 120max 150max 150max 140max 140max 160max 160max 160max 160max 200max 200max 120max 120max 150max 150max 150max 150max 250max 250max 160max 160max 180max 180max 180max 180max 300max 300max 50max 50max 90max 120max 150max 240max 360max 480max 60max 60max 120max 150max 180max 290max 450max 600max 20max 20max 36max 48max 60max 96max 144max 192max 350typ(ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 2.85 - 3.63 4.00 - 5.50 7.50 - 10.0 10.0 - 13.2 13.2 - 18.0 19.2 - 27.0 28.8 - 39.6 39.0 - 53.0 3.30 - 3.40 5.00 - 5.15 9.00 - 9.36 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 36.00 - 37.44 48.00 - 49.92 Works over 105% of rated current and recovers automatically 4.00 - 5.25 5.75 - 7.00 11.5 - 14.0 15.0 - 18.0 20.0 - 25.0 30.0 - 37.0 43.0 - 50.0 58.0 - 65.0 LED (Green) Optional (Only -3R3, -5 Option -K) Optional (Required external power source) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *6 34X93X168mm [1.34X3.66X6.61 inches] (without terminal block) (WXHXD) / 560g max (with cover : 630g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Applicable when Remote ON/OFF(optional) is added. RC is insulated with input, output and FG. *4 Derating is required. PBA/PBW-14 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. March 08, 2022 PBA150F Block diagram FUSE 250V4A NOISE FILTER AC IN 85 - 264V RECTIFIER INRUSH CURRENT LIMIT FG CURRENT SENSING BOOSTER INDUCTOR CURRENT SENSING OPTION RC EXTERNAL SOURCE RECTIFIER AND FILTER CONTROL CONTROL OVER VOLTAGE PROTECTION INVERTER INVERTER RECTIFIER AND FILTER TRANSFORMER CONTROL E DC OUT External view ¶ External size of option T,J1,R,N1,V and K is different from standard model and refer to 7 Option of instruction manual for details. CN3 Connector for Remote ON/OFF (option) [0.45] LED (13.5) 168 [0.53] [6.61] 0.5 Voltage adjust (11.5) [0.02] CN4 Connector for Remote sensing (option : only -3R3, -5) (20.5) [0.81] 12 +V M4 +V Terminal cover 93 TB1 [0.57] 78 ±0.5 58.5 [3.07] [2.3] 2-M3 Mounting hole (24) 3.5 Name plate 19 [0.75] PBA150F ¶ Tolerance : ±1 [±0.04] ¶ Weight : 560g max (with cover : 630g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.49N • m(5kgf • cm)max ¶ Mounting torque : M4:1.6N • m(16.9kgf • cm)max ¶ Keep drawing current per pin below 20A for TB1. ¶ Please connect safety ground to FG terminal on the unit. 139.5±0.5 [5.49] March 08, 2022 Connector type CN3 Option (Mfr : J.S.T.) Pin No. 1 2 Contents RC(+) RC( - ) 34 [0.94] [0.14] (14.5) Point A [1.34] AC(N) A 2-M3 Mounting hole 37.5 (10) 10 AC(L) [1.48] 8.6 ) [0.34] -V [0.39] [0.39] (81) [3.19] FG( [3.66] Cover (option) -V 9 [0.35] Barrier strip type Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 ( ) PBA/PBW-15 Ordering information AC-DC Power Supplies Enclosed Type PBA300F PB 1 A 300 F 2 3 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *5 C : with Coating G : Low leakage current U : Operation stop voltage is set at a lower value F3 : Reverse air exhaust type F4 : Low speed fan N1 :with DIN rail Refer to instruction manual 7.1. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA300F-3R3 198 ACIN 100V 3.3V 60A ACIN 200V *3 3.3V 60A PBA300F-5 300 5V 60A 5V 60A PBA300F-7R5 300 7.5V 40A 7.5V 40A PBA300F-12 324 12V 27A 12V 27A PBA300F-15 330 15V 22A 15V 22A PBA300F-24 336 24V 14A 24V 14(16.5)A PBA300F-36 324 36V 9A 36V 9A PBA300F-48 336 48V 7A 48V 7A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] ACIN 100V CURRENT[A] ACIN 200V *3 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -20 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -20 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -20 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC INPUT-FG OUTPUT-RC-AUX-FG OUTPUT-RC -AUX OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBA300F-3R3 PBA300F-5 PBA300F-7R5 PBA300F-12 PBA300F-15 PBA300F-24 PBA300F-36 AC85 - 264 1f or DC120 - 350 (AC50 or DC70 Please refer to the instruction manual 7. option *4) 3typ 4.1typ 1.6typ 2typ 50/60 (47 - 63) 68typ 74typ 76typ 78typ 78typ 79typ 81typ 71typ 77typ 79typ 81typ 81typ 82typ 84typ 0.98typ (Io=100%) 0.95typ (Io=100%) 20/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More then 3 sec. to re-start) 40/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More then 3 sec. to re-start) 0.45/0.75max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) 3.3 5 7.5 12 15 24 36 60 60 40 27 22 14 9 60 60 40 27 22 14(16.5) 9 20max 20max 36max 48max 60max 96max 144max 40max 40max 60max 100max 120max 150max 150max 80max 80max 120max 120max 120max 120max 150max 140max 140max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 200max 160max 160max 180max 180max 180max 180max 240max 40max 50max 75max 120max 150max 240max 360max 60max 75max 120max 180max 180max 290max 440max 12max 20max 30max 48max 60max 96max 144max 300typ(ACIN 100/200V, Io=100%) *Start-up time is 500ms typ for less than 1minute of applying input again from turning off 20typ (ACIN 100/200V, Io=100%) 2.64 - 3.96 3.96 - 6.00 5.25 - 8.25 8.25 - 13.20 10.50 - 16.50 16.50 - 26.40 25.20 - 39.60 3.30 - 3.40 5.00 - 5.15 7.50 - 7.80 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 36.00 - 37.44 Works over 105% of rated current or 101% of peak current and recovers automatically 4.3 - 6.3 6.5 - 8.0 9.0 - 11.6 14.4 - 18.6 18.0 - 23.3 28.8 - 37.2 43.2 - 54.0 LED (Green) Provided Provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -20 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *6 102X42X170mm [4.02X1.65X6.69 inches] (without terminal block and screw) (W XHXD) /1.0kg max Forced cooling (internal fan) *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 () means peak current. Peak loading for 10s. And Duty 35% max, refer to Instruction manual in detail. *4 Derating is required.Consult us for details. PBA/PBW-16 *5 Please contact us about safety approvals for the model with option. *6 Please contact us about class C. * A sound may occur from power supply at pulse loading. March 08, 2022 PBA300F-48 79typ 82typ 48 7 7 192max 300max 150max 400max 200max 500max 480max 600max 192max the input voltage. 38.40 - 56.00 48.00 - 49.92 57.6 - 80.0 PBA300F Block diagram FUSE AC IN 85 - 264V NOISE FILTER 250V10A INRUSH CURRENT LIMIT RECTIFIER FG RECTIFIER AND FILTER INVERTER DC OUT ±M THERMAL PROTECTION CURRENT SENSING OVER VOLTAGE PROTECTION ACTIVE FILTER RECTIFIER AND FILTER SWITCHING DEVICE VOLTAGE SENSING CONTROL CONTROL ±S(REMOTE SENSING) RC(REMOTE ON / OFF) MASTER SLAVE CONTROL CURRENT SENSING INTERNAL REGULATOR VOLTAGE SENSING CONTROL FAN VB(VOLTAGE BALANCE) CB(CURRENT BALANCE) ALARM PG(POWER GOOD) AUX(12 V 0.1A) External view 20 ±0.5 12 [0.79] [0.47] 4-M4 Mounting Hole 54 74±0.5 [2.13] (15.5) [0.61] (30) [1.18] [4.02] 102 50.5 [1.99] (87) [0.98] [3.43] (75) [2.95] [0.93] 12 H V.ADJ M4 2-M4 Mounting Hole (Bottom side) 25max [0.47] [1.97] [0.47] Output terminal(+) (23.5) 8.6 [0.34] (50) Terminal cover 12 10 7 AC(L) AC(N) FG( ) Output terminal(-) (6) [0.55] Name plate M4 [0.39][0.28] [0.24] (14) [2.91] CN3 CN2 Name plate CN1 LED Output voltage adjustable potentiometer 28.5 [1.12] 170 [6.69] 6max [0.24] AIR FLOW 42 [1.65] ¶ Tolerance : ±1 [±0.04] ¶ Weight : 1.0kg max ¶ PCB Material/thickness : FR-4 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 1.2N • m max ¶ Screw tightening torque : 1.6N • m max ¶ The housing for the remote sensing unused is mounted on CN1 ¶ Please connect safety ground to FG terminal on the unit. 64±0.5 [2.52] March 08, 2022 PBA/PBW-17 Ordering information AC-DC Power Supplies Enclosed Type PBA600F PB 1 A 600 F 2 3 4 Example recommended EMI/EMC filter NAC-16-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *6 C : with Coating G : Low leakage current U : Operation stop voltage is set at a lower value F1 : With Long-Life fan F3 : Reverse air exhaust type F4 : Low speed fan Refer to instruction manual 7.1. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA600F-3R3 396 ACIN 100V 3.3V 120A ACIN 200V *3 3.3V 120A PBA600F-5 600 5V 120A 5V 120A PBA600F-7R5 600 7.5V 80A 7.5V 80A PBA600F-12 636 12V 53A 12V 53A PBA600F-15 645 15V 43A 15V 43A PBA600F-24 648 24V 27A 24V 27(31)A PBA600F-36 648 36V 18A 36V 18A PBA600F-48 624 48V 13A 48V 13A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] ACIN 100V CURRENT[A] ACIN 200V *3 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -20 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -20 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -20 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] *4 OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC INPUT-FG OUTPUT-RC-AUX-FG OUTPUT-RC -AUX OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBA600F-3R3 PBA600F-5 PBA600F-7R5 PBA600F-12 PBA600F-15 PBA600F-24 PBA600F-36 AC85 - 264 1f or DC120 - 350 (AC50 or DC70 Please refer to the instruction manual 7. option *5) 5.8typ 8.2typ 3typ 4.1typ 50/60 (47 - 63) 70typ 75typ 76typ 79typ 79typ 81typ 82typ 72typ 77typ 79typ 82typ 82typ 84typ 84typ 0.98typ (Io=100%) 0.95typ (Io=100%) 20/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 3 sec. to re-start) 40/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 3 sec. to re-start) 0.45/0.75max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1, DENAN) 3.3 5 7.5 12 15 24 36 120 120 80 53 43 27 18 120 120 80 53 43 27(31) 18 20max 20max 36max 48max 60max 96max 144max 40max 40max 60max 100max 120max 150max 150max 80max 80max 120max 120max 120max 120max 150max 140max 140max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 200max 160max 160max 180max 180max 180max 180max 240max 40max 50max 75max 120max 150max 240max 360max 60max 75max 120max 180max 180max 290max 440max 12max 20max 30max 48max 60max 96max 144max 400typ(ACIN 100/200V, Io=100%) *Start-up time is 500ms typ for less than 1minute of applying input again from turning off 20typ (ACIN 100/200V, Io=100%) 2.64 - 3.96 3.96 - 6.00 5.25 - 8.25 8.25 - 13.20 10.50 - 16.50 16.50 - 26.40 25.20 - 39.60 3.30 - 3.40 5.00 - 5.15 7.50 - 7.80 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 36.00 - 37.44 Works over 105% of rated current or 101% of peak current and recovers automatically Vo+0.66 - 1.32 Vo+1.0 - 2.0 Vo+1.5 - 3.0 Vo+2.4 - 4.8 Vo+3.0 - 6.0 Vo+4.8 - 9.6 Vo+7.2 - 14.4 LED (Green) Provided Provided AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -20 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *7 120X61X190mm [4.72X2.4X7.48 inches] (without terminal block and screw) (W XHXD) /1.6kg max Forced cooling (internal fan) *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 () means peak current. Peak loading for 10s. And Duty 35% max, refer to Instruction manual in detail. *4 Overvoltage protection circuit to follow to output voltage setting. Standard overvoltage protection circuit is please contact us for details. PBA/PBW-18 *5 Derating is required.Consult us for details. *6 Please contact us about safety approvals for the model with option. *7 Please contact us about class C. * A sound may occur from power supply at pulse loading. March 08, 2022 PBA600F-48 81typ 83typ 48 13 13 192max 300max 150max 400max 200max 500max 480max 600max 192max the input voltage. 38.40 - 56.00 48.00 - 49.92 Vo+4.8 - 12.0 PBA600F Block diagram FUSE AC IN 85 - 264V NOISE FILTER 250V15A INRUSH CURRENT LIMIT RECTIFIER FG RECTIFIER AND FILTER INVERTER DC OUT ±M THERMAL PROTECTION CURRENT SENSING OVER VOLTAGE PROTECTION ACTIVE FILTER RECTIFIER AND FILTER SWITCHING DEVICE VOLTAGE SENSING CONTROL CONTROL ±S(REMOTE SENSING) RC(REMOTE ON / OFF) MASTER SLAVE CONTROL CURRENT SENSING INTERNAL REGULATOR VOLTAGE SENSING CONTROL FAN VB(VOLTAGE BALANCE) CB(CURRENT BALANCE) ALARM PG(POWER GOOD) AUX(12 V 0.1A) External view Name plate [0.94] 10 [0.39] 120 [4.72] 150 ±0.5 [5.91] 190 ¶1(F1:190.5) 6max [7.48] [0.24] 8-M4 Mounting Hole (Both sides) 61 [2.4] ¶ Tolerance : ±1 [±0.04] ¶ Weight : 1.6kg max ¶ PCB Material/thickness : FR-4 / 1.6mm [0.06] ¶ Chassis material : Aluminum 24 ¶ Dimensions in mm, [ ]= inches [0.94] ¶ Mounting torque : 1.2N · m(12.8kgf·cm)max ¶ Screw tightening torque : M4 1.6N • m(16.9kgf • cm)max M5 2.5N • m(24.5kgf • cm)max ¶ The housing for the remote sensing unused is mounted on CN1 ¶1 F1(Optional):190.5 ¶ Please connect safety ground to FG terminal on the unit. March 08, 2022 AIR FLOW 38 ±0.5 [1.91] 24 [0.98] [1.5] (48.5) 25max Output voltage adjustable potentiometer 12.5 [0.71] M5 [0.49] Output terminal cover (18) 100 ±0.5 [2.07] (52.5) 14 [0.55] 27.5 [1.08] [0.34] [3.64] [0.55] [0.67] CN1 LED Output terminal(+) 14 17 CN2 CN3 CN2 CN1 (92.5) CN3 Output terminal(-) 4-M4 Mounting Hole (Bottom side) Name plate [0.79] 8.7 ) (6) AC (N) FG FG( [0.24] AC (L) AC(L) AC(N) 10 7 [0.54] [3.94] Input terminal cover 20max M4 [0.39][0.28] (13.8) 150 ±0.5 [5.91] PBA/PBW-19 Ordering information AC-DC Power Supplies Enclosed Type PBA1000F PB 1 A 1000 F 2 3 4 Example recommended EMI/EMC filter NAC-20-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *6 C : with Coating G : Low leakage current U : Operation stop voltage is set at a lower value F1 : With Long-Life fan F3 : Reverse air exhaust type F4 : Low speed fan Refer to instruction manual 7.1. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA1000F-3R3 660 ACIN 100V 3.3V 200A ACIN 200V *3 3.3V 200A PBA1000F-5 1000 5V 200A 5V 200A PBA1000F-7R5 1005 7.5V 134A 7.5V 134A PBA1000F-12 1056 12V 88A 12V 88A PBA1000F-15 1050 15V 70A 15V 70A PBA1000F-24 1056 24V 44A 24V 44(51)A PBA1000F-36 1044 36V 29A 36V 29A PBA1000F-48 1056 48V 22A 48V 22A PBA1000F-3R3 PBA1000F-5 PBA1000F-7R5 PBA1000F-12 PBA1000F-15 PBA1000F-24 PBA1000F-36 AC85 - 264 1f or DC120 - 350 (AC50 or DC70 Please refer to the instruction manual 7. option *5) 9typ 13typ 5typ 7typ 50/60 (47 - 63) 74typ 79typ 80typ 82typ 82typ 84typ 84typ 76typ 81typ 83typ 84typ 84typ 86typ 86typ 0.98typ (Io=100%) 0.95typ (Io=100%) 20/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 10 sec. to re-start) 40/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 10 sec. to re-start) 0.5/1.0max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1, DENAN) 3.3 5 7.5 12 15 24 36 200 200 134 88 70 44 29 200 200 134 88 70 44(51) 29 20max 20max 36max 48max 60max 96max 144max 40max 40max 60max 100max 120max 150max 150max 80max 80max 120max 120max 120max 120max 150max 140max 140max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 200max 160max 160max 180max 180max 180max 180max 240max 40max 50max 75max 120max 150max 240max 360max 60max 75max 120max 180max 180max 290max 440max 12max 20max 30max 48max 60max 96max 144max 400typ(ACIN 100/200V, Io=100%) *Start-up time is 500ms typ for less than 1minute of applying input again from turning off 20typ (ACIN 100/200V, Io=100%) 2.64 - 3.96 3.96 - 6.00 5.25 - 8.25 8.25 - 13.20 10.50 - 16.50 16.50 - 26.40 25.20 - 39.60 3.30 - 3.40 5.00 - 5.15 7.50 - 7.80 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 36.00 - 37.44 Works over 105% of rated current or 101% of peak current and recovers automatically Vo+0.66 - 1.32 Vo+1.0 - 2.0 Vo+1.5 - 3.0 Vo+2.4 - 4.8 Vo+3.0 - 6.0 Vo+4.8 - 9.6 Vo+7.2 - 14.4 LED (Green) Provided Provided AC3,000V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -20 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *7 150X61X240mm [5.91X2.4X9.45 inches] (without terminal block and screw) (W XHXD) /2.2kg max Forced cooling (internal fan) PBA1000F-48 SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] ACIN 100V CURRENT[A] ACIN 200V *3 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -20 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -20 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -20 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] *4 OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC INPUT-FG OUTPUT-RC-AUX-FG OUTPUT-RC -AUX OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). Ripple and ripple noise is measured on measuring board with capacitor of 22mF within 150mm from the output terminal. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 () means peak current. Peak loading for 10s. And Duty 35% max, refer to Instruction manual in detail. PBA/PBW-20 84typ 86typ 48 22 22 192max 300max 150max 400max 200max 500max 480max 600max 192max the input voltage. 38.40 - 56.00 48.00 - 49.92 Vo+4.8 - 12.0 *4 Overvoltage protection circuit to follow to output voltage setting. Standard overvoltage protection circuit is please contact us for details. *5 Derating is required.Consult us for details. *6 Please contact us about safety approvals for the model with option. *7 Please contact us about class C. * A sound may occur from power supply at pulse loading. March 08, 2022 PBA1000F Block diagram FUSE AC IN 85 - 264V NOISE FILTER 250V30A RECTIFIER INRUSH CURRENT LIMIT FG RECTIFIER AND FILTER INVERTER DC OUT THERMAL PROTECTION CURRENT SENSING ±M OVER VOLTAGE PROTECTION ACTIVE FILTER RECTIFIER AND FILTER SWITCHING DEVICE VOLTAGE SENSING CONTROL CONTROL RC(REMOTE ON / OFF) MASTER SLAVE CONTROL CURRENT SENSING INTERNAL REGULATOR VOLTAGE SENSING CONTROL ±S(REMOTE SENSING) FAN VB(VOLTAGE BALANCE) CB(CURRENT BALANCE) ALARM PG(POWER GOOD) AUX(12 V 0.1A) External view [5.91] 20 150 110±0.5 [4.33] 104.75 [4.12] [0.1] Output terminal(+) (24) Output terminal(-) 2.5 CN1 H V.ADJ CN2 CN3 Output voltage adjustable potentiometer LED Name plate [0.79] 4-M4 Mounting Hole (Bottom side) 25max [0.94] 79 FG CN3 CN2 CN1 Input terminal cover [0.98] [3.11] 13 9 (7.5) AC (N) [0.51][0.35] [0.3] AC (L) AC(L) AC(N) FG( ) 10 [0.62] Name plate [0.39] M4 15.85 51.25 [2.02] 29 [1.14] (35) 165 ±0.5 [6.5] 240 6max [9.45] [0.24] [1.38] 8-M4 Mounting Hole (Both sides) 2-M4 2-º9 March 08, 2022 [6.5] [2.4] 61 38±0.5 165±0.5 [1.5] 29 [1.14] 11.5 ¶ Tolerance : ±1 [±0.04] 7 13 ¶ Weight : 2.2kg max [0.28] [0.51] ¶ PCB Material/thickness : FR-4 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 1.2N • m(12.8kgf • cm)max ¶ Screw tightening torque : 1.6N • m(16.9kgf • cm)max ¶ The housing for the remote sensing unused is mounted on CN1 ¶ Please connect safety ground to FG terminal on the unit. AIR FLOW [0.45] [0.71] [0.98] (18) (25) [0.35] PBA/PBW-21 Ordering information AC-DC Power Supplies Enclosed Type PBA1500F PB 1 A 1500 F 2 3 4 Example recommended EMI/EMC filter NAC-20-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -5 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *6 C : with Coating G : Low leakage current U : Operation stop voltage is set at a lower value F1 : With Long-Life fan F3 : Reverse air exhaust type F4 : Low speed fan Refer to instruction manual 7.1. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA1500F-36 1692 36V 42A 36V 47(70)A PBA1500F-48 1680 48V 32A 48V 35A PBA1500F-3R3 PBA1500F-5 PBA1500F-7R5 PBA1500F-12 PBA1500F-15 PBA1500F-24 PBA1500F-36 AC85 - 264 1f or DC120 - 370 (AC50 or DC70 Please refer to the instruction manual 7. option *5) 15typ 19typ 8typ 10typ 50/60 (47 - 63) 72typ 77typ 81typ 81typ 83typ 84typ 84typ 75typ 81typ 83typ 84typ 86typ 87typ 87typ 0.98typ (Io=100%) 0.95typ (Io=100%) 20/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 10 sec. to re-start) 40/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 10 sec. to re-start) 0.9/1.5max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1, DENAN) 3.3 5 7.5 12 15 24 36 300 300 200 125 100 65 42 300 300 200 125 100 70(105) 47(70) 20max 20max 36max 48max 60max 96max 144max 40max 40max 60max 100max 120max 150max 150max 80max 80max 120max 120max 120max 120max 150max 140max 140max 160max 160max 160max 160max 160max 120max 120max 150max 150max 150max 150max 200max 160max 160max 180max 180max 180max 180max 240max 40max 50max 75max 120max 150max 240max 360max 60max 75max 120max 180max 180max 290max 440max 12max 20max 30max 48max 60max 96max 144max 600typ(ACIN 100/200V, Io=100%) 20typ (ACIN 100/200V, Io=100%) 2.64 - 3.96 3.96 - 6.00 5.25 - 8.25 8.25 - 13.20 10.50 - 16.50 16.50 - 26.40 25.20 - 39.60 3.30 - 3.40 5.00 - 5.15 7.50 - 7.80 12.00 - 12.48 15.00 - 15.60 24.00 - 24.96 36.00 - 37.44 Works over 105% of rated current or 101% of peak current and recovers automatically Vo+0.66 - 1.32 Vo+1.0 - 2.0 Vo+1.5 - 3.0 Vo+2.4 - 4.8 Vo+3.0 - 6.0 Vo+4.8 - 9.6 Vo+7.2 - 14.4 LED (Green) Provided Provided AC3,000V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -20 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B, additional EMI/EMC Filter required for Complies with IEC61000-3-2 *7 178X61X268mm [7.01X2.4X10.55 inches] (without terminal block and screw) (W XHXD) /3.4kg max Forced cooling (internal fan) PBA1500F-48 PBA1500F-3R3 990 ACIN 100V 3.3V 300A ACIN 200V *3 3.3V 300A PBA1500F-5 1500 5V 300A 5V 300A PBA1500F-7R5 1500 7.5V 200A 7.5V 200A PBA1500F-12 1500 12V 125A 12V 125A PBA1500F-15 1500 15V 100A 15V 100A PBA1500F-24 1680 24V 65A 24V 70(105)A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] ACIN 100V CURRENT[A] ACIN 200V *3 LINE REGULATION[mV] LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -20 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -20 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -20 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] *4 OPERATING INDICATION REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC INPUT-FG OUTPUT-RC-AUX-FG OUTPUT-RC -AUX OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). Ripple and ripple noise is measured on measuring board with capacitor of 22mF within 150mm from the output terminal. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 () means peak current. Peak loading for 10s. And Duty 35% max, refer to Instruction manual in detail. PBA/PBW-22 84typ 87typ 48 32 35 192max 300max 150max 400max 200max 500max 480max 600max 192max 38.40 - 56.00 48.00 - 49.92 Vo+4.8 - 12.0 meeting class B *4 Overvoltage protection circuit to follow to output voltage setting. Standard overvoltage protection circuit is please contact us for details. *5 Derating is required.Consult us for details. *6 Please contact us about safety approvals for the model with option. *7 Please contact us about class C. * A sound may occur from power supply at pulse loading. March 08, 2022 PBA1500F Block diagram FUSE AC IN 85 - 264V NOISE FILTER 250V30A INRUSH CURRENT LIMIT RECTIFIER FG RECTIFIER AND FILTER INVERTER DC OUT ±M THERMAL PROTECTION CURRENT SENSING OVER VOLTAGE PROTECTION ACTIVE FILTER RECTIFIER AND FILTER SWITCHING DEVICE VOLTAGE SENSING CONTROL CONTROL ±S(REMOTE SENSING) RC(REMOTE ON / OFF) MASTER SLAVE CONTROL CURRENT SENSING INTERNAL REGULATOR VOLTAGE SENSING CONTROL FAN VB(VOLTAGE BALANCE) CB(CURRENT BALANCE) ALARM PG(POWER GOOD) AUX(12 V 0.1A) [6] CN1 CN2 CN3 V.ADJ [7.01] Name plate 178 152.4 ±0.5 [5.2] 132 [0.5] 8-M4 Mounting Hole (Both sides) 25max [0.98] 107 (7.5) 10 FG [0.39] NC ) CN1 CN2 CN3 Input terminal cover [4.21] AC (N) FG( AC (L) AC(L) AC(N) NC Name plate 13 9 [0.62] [0.51][0.35] [0.3] M4 15.85 12.8 External view 4 [0.16] (24) LED Output terminal(-) [0.94] Output voltage adjustable potentiometer Output terminal(+) 51.25 19 [2.02] (45) [0.75] 171.5 ±0.5 [6.75] [1.77] 268 6max [10.55] [0.24] 8-M4 Mounting Hole (Both sides) 4-M4 2-º9 [6.75] March 08, 2022 [2.4] 61 38 ±0.5 171.5 ±0.5 [1.5] 19 [0.75] 11.5 ¶ Tolerance : ±1 [±0.04] 10 15 ¶ Weight : 3.4kg max [0.39] [0.59] ¶ PCB Material/thickness : FR-4 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 1.2N • m(12.8kgf • cm)max ¶ Screw tightening torque : 1.6N • m(16.9kgf • cm)max ¶ The housing for the remote sensing unused is mounted on CN1 ¶ Please connect safety ground to FG terminal on the unit. AIR FLOW [0.45] [0.71] [0.98] (18) (25) [0.35] PBA/PBW-23 Ordering information AC-DC Power Supplies Enclosed Type PBA1500T PB 1 A 1500 T 2 3 Example recommended EMI/EMC filter TAC-10-683 R -5 4 * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. 5 -O 6 1 Series name 2 Single output 3 Output wattage 4 Triple input phase 5 Output voltage 6 Optional *6 C : with Coating G : Low leakage current U : Operation stop voltage is set at a lower value F1 : With Long-Life fan F3 : Reverse air exhaust type F4 : Low speed fan Refer to instruction manual 7.1. *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBA1500T-24 1680 24V 70(105)A PBA1500T-48 1680 48V 35A PBA1500T-12 PBA1500T-24 AC170 - 264 3f (AC100 Please refer to the instruction manual 7. option *5) ACIN 200V 6typ 50/60 (47 - 63) PBA1500T-48 ACIN 200V *3 PBA1500T-5 1500 5V 300A PBA1500T-12 1500 12V 125A SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] FREQUENCY[Hz] INPUT PBA1500T-5 84typ ACIN 200V 81typ 87typ 87typ ACIN 200V 0.95typ (Io=100%) INRUSH CURRENT[A] ACIN 200V 40/40typ (Io=100%) (Primary inrush current /Secondary inrush current) (More than 10 sec. to re-start) LEAKAGE CURRENT[mA] 1.5max (ACIN 240V 60Hz, Io=100%, According to IEC62368-1, DENAN) EFFICIENCY[%] POWER FACTOR VOLTAGE[V] CURRENT[A] OUTPUT 5 ACIN 200V *3 300 12 24 48 125 35 LINE REGULATION[mV] 20max 48max 70(105) 96max LOAD REGULATION[mV] 0 to +50C *1 RIPPLE[mVp-p] -20 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -20 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -20 to +50C 40max 100max 150max 300max 80max 120max 120max 150max 140max 160max 160max 400max 120max 150max 150max 200max 160max 180max 180max 500max 50max 120max 240max 480max 75max 180max 290max 600max DRIFT[mV] 20max 48max 96max 192max 300typ(ACIN 200V, Io=100%) *Start-up time is 500ms typ for less than 1 minute of applying input again from turning off the input voltage. 20typ (ACIN 200V, Io=100%) *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] 3.96 - 6.00 OUTPUT VOLTAGE SETTING[V] 5.00 - 5.15 8.25 - 13.20 16.50 - 26.40 38.40 - 56.00 12.00 - 12.48 24.00 - 24.96 48.00 - 49.92 OVERCURRENT PROTECTION Works over 105% of rated current or 101% of peak current and recovers automatically Vo+4.8 - 9.6 4 Vo+2.4 - 4.8 PROTECTION OVERVOLTAGE PROTECTION[V] * Vo+1.0 - 2.0 CIRCUIT AND OPERATING INDICATION LED (Green) OTHERS Provided REMOTE SENSING REMOTE ON/OFF INPUT-OUTPUT -RC ISOLATION ENVIRONMENT INPUT-FG OUTPUT-RC-AUX-FG OUTPUT-RC -AUX OPERATING TEMP.,HUMID.AND ALTITUDE 192max Vo+2.0 - 12.0 Provided AC3,000V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) AC2,000V 1minute, Cutoff current = 25mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MWmin (At Room Temperature) -20 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max STORAGE TEMP.,HUMID.AND ALTITUDE -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max VIBRATION 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis IMPACT 196.1m/s2 (20G), 11ms, once each X, Y and Z axis SAFETY AND AGENCY APPROVALS (At only AC input) NOISE REGULATIONS CONDUCTED NOISE CASE SIZE/WEIGHT OTHERS COOLING METHOD UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B, additional EMI/EMC Filter required for meeting class B 178X61X268mm [7.01X2.4X10.55 inches] (without terminal block and screw) (W XHXD) /3.4kg max Forced cooling (internal fan) *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN :RM101). Ripple and ripple noise is measured on measuring board with capacitor of 22mF within 150mm from the output terminal. *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 () means peak current. Peak loading for 10s. And Duty 35% max, refer to Instruction manual in detail. PBA/PBW-24 *4 Overvoltage protection circuit to follow to output voltage setting. Standard overvoltage protection circuit is please contact us for details. *5 Derating is required.Consult us for details. *6 Please contact us about safety approvals for the model with option. * A sound may occur from power supply at pulse loading. March 08, 2022 PBA1500T Block diagram FUSE AC250V16A AC IN 170 - 264V (3º) NOISE FILTER INRUSH CURRENT LIMIT RECTIFIER FG RECTIFIER AND FILTER INVERTER DC OUT ±M(MONITOR) THERMAL PROTECTION CURRENT SENSING OVER VOLTAGE PROTECTION ACTIVE FILTER RECTIFIER AND FILTER SWITCHING DEVICE VOLTAGE SENSING CONTROL CONTROL ±S(REMOTE SENSING) RC(REMOTE ON / OFF) MASTER SLAVE CONTROL CURRENT SENSING INTERNAL REGULATOR VOLTAGE SENSING CONTROL FAN VB(VOLTAGE BALANCE) CB(CURRENT BALANCE) ALARM PG(POWER GOOD) AUX(12 V 0.1A) OPEN PHASE CN1 [7.01] 4 [0.16] (24) [0.94] LED 178 V.ADJ CN2 CN3 Output voltage adjustable potentiometer [6] 152.4 ±0.5 [5.2] 132 Name plate Output terminal(-) [0.5] 8-M4 Mounting Hole (Both sides) 25max [0.98] 107 (7.5) 10 FG [0.39] (L3) ) CN1 CN2 CN3 Input terminal cover [4.21] AC (L2) FG( (L1) AC(L1) AC(L2) AC(L3) Name plate 13 9 [0.62] [0.51][0.35] [0.3] M4 15.85 12.8 External view Output terminal(+) 51.25 19 [2.02] (45) [0.75] 171.5 ±0.5 [6.75] [1.77] 268 6max [10.55] [0.24] 8-M4 Mounting Hole (Both sides) 4-M4 2-º9 [6.75] March 08, 2022 [2.4] 61 38 ±0.5 171.5 ±0.5 [1.5] 19 [0.75] 11.5 ¶ Tolerance : ±1 [±0.04] 10 15 ¶ Weight : 3.4kg max [0.39] [0.59] ¶ PCB Material/thickness : FR-4 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 1.2N • m(12.8kgf • cm)max ¶ Screw tightening torque : 1.6N • m(16.9kgf • cm)max ¶ The housing for the remote sensing unused is mounted on CN1 ¶ Please connect safety ground to unit in M4 holes. AIR FLOW [0.45] [0.71] [0.98] (18) (25) [0.35] PBA/PBW-25 AC-DC Power Supplies Enclosed Type PBW15F Ordering information PB W 1 2 15 3 F 4 Example recommended EMI/EMC filter NAC-06-472 R High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. -O -O 5 6 1 Series name 2 Dual output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *10 C : with Coating G : Low leakage current E : Low leakage current and EMI class A T : Vertical terminal block J1 : VH (J.S.T.) connector type N : with Cover N1 : with DIN rail V : Output voltage setting potentiometer externally Cover is optional *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBW15F-12 16.8 VOLTAGE[V] *6 t12 ( +24 ) CURRENT1[A] 0.7 CURRENT2[A] *5 1.4 PBW15F-15 15.0 t15 ( +30 ) 0.5 1.0 *5 SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT1[A] CURRENT2[A] *5 *9 LINE REGULATION[mV] *11 *3 LOAD REGULATION 1[mV] *11 *4 LOAD REGULATION 2[mV] *11 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBW15F-12 PBW15F-15 AC85 - 264 1f or DC110 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *8) 0.40typ (CURRENT1) 0.20typ (CURRENT1) 50/60 (47 - 440) or DC 74typ (CURRENT1) 78typ (CURRENT1) 77typ (CURRENT1) 80typ (CURRENT1) 15typ (CURRENT1) (At cold start) 30typ (CURRENT1) (At cold start) 0.15/0.30max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) / ( +24V reference number ) / ( +30V reference number ) t12 t15 0.7 / 0.7 0.5 / 0.5 1.4 /1.0 /60max / 96max 60max / 96max 600max / 150max 600max / 150max 750max /750max /120max / 240max 120max / 240max 160max / 320max 160max / 320max 150max / 300max 150max / 300max 180max / 360max 180max / 360max 120max 150max 150max 180max 48max 60max 200typ(ACIN 100V, Io=100%) *Start-up time is 700ms typ for less than 1minute of applying input again from turning off the input voltage. 20typ (ACIN 100V, Io=100%) 9.60 - 13.2 (+V and -V are simultaneously adjusted) 13.2 - 16.5 (+V and -V are simultaneously adjusted) 11.5 - 12.5 (+V and -V CURRENT1) 14.4 - 15.6 (+V and -V CURRENT1) Works over 105% of rated current and recovers automatically 16.8 - 24.0 20.0 - 29.0 LED (Green) None AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Not built-in to active filter *7) *12 31X78X85mm [1.22X3.07X3.35 inches] (without terminal block) (WXHXD) / 200g max (with cover : 235g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN : RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Figures for 0 to rated current 1.The current not measured side is fixed. *4 Figures for 0 to rated current 2.The current not measured PBA/PBW-26 side is fixed. *5 The sum of +power -power must be less than output power. t12,t15 can be used as +24 and +30. *6  *7 When two or more units are used,they may not comply with the harmonic attenuator. Please contact us for details. *8 Derating is required. *9 Figures to rated current 1. March 08, 2022 *10 Please contact us about safety approvals for the model with option. *11 Please contact us about dynamic load and input response. *12 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. PBW15F Block diagram FUSE AC250V 2.5A AC IN 85 - 264V INRUSH CURRENT LIMIT NOISE FILTER RECTIFIER AND FILTER FG TRANSFORMER CONTROL RECTIFIER AND FILTER INVERTER +V COM CURRENT SENSING RECTIFIER AND FILTER DC OUT -V Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION External view ¶ External size of option T,J1,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. 18 Voltage adjust [0.71] 12.2±1.5 [0.48] 2.5 LED [0.1] Cover name plate 16.5± 2 85 [0.65] [3.35] M3 +V [0.89] 78 36.5 [1.22] [1.44] 2-M3 Mounting hole [1.36] 7.5 34.5 31±0.5 Point A:C102 Name plate 2-M3 Mounting hole 18 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 200g max (with cover : 235g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Hot-dip galvanized steel plate ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.6N • m(6.3kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. 60± 0.5 [2.36] March 08, 2022 [0.71] 31 PBA15F PBW15F 34.5 22.6±1.5 Terminal cover [1.36] [0.59] [1.22] 15.1±1.5 [0.3] AC(N) 11.5 9.5 FG AC(L) [3.07] Cover (option) -V [0.45] [0.37] 70.5 [2.78] COM 5 [0.2] PBA/PBW-27 AC-DC Power Supplies Enclosed Type PBW30F Ordering information PB W 1 2 30 3 F Example recommended EMI/EMC filter NAC-06-472 R -O -O 4 High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. 5 6 1 Series name 2 Dual output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *10 C : with Coating G : Low leakage current E : Low leakage current and EMI class A T : Vertical terminal block J1 : VH (J.S.T.) connector type N : with Cover N1 : with DIN rail V : Output voltage setting potentiometer externally Cover is optional *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBW30F-5 15 VOLTAGE[V] *6 t5 ( +10 ) CURRENT1[A] 1.5 CURRENT2[A] *5 2.0 *5 PBW30F-12 31.2 t12 ( +24 ) 1.3 1.7 PBW30F-15 30.0 t15 ( +30 ) 1.0 1.4 SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT1[A] CURRENT2[A] *5 *9 LINE REGULATION[mV] *11 *3 LOAD REGULATION 1[mV] *11 *4 LOAD REGULATION 2[mV] *11 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT INPUT-FG OUTPUT-FG OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBW30F-5 PBW30F-12 PBW30F-15 AC85 - 264 1f or DC110 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *8) 0.4typ (CURRENT1) 0.7typ (CURRENT1) 0.25typ (CURRENT1) 0.4typ (CURRENT1) 50/60 (47 - 440) or DC 75typ (CURRENT1) 77typ (CURRENT1) 78typ (CURRENT1) 75typ (CURRENT1) 81typ (CURRENT1) 79typ (CURRENT1) 15typ (CURRENT1) (At cold start) 30typ (CURRENT1) (At cold start) 0.30/0.65max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) / ( +10V reference number ) t12 / ( +24V reference number ) t15 / ( +30V reference number ) t5 1.5 / 1.5 1.3 / 1.3 1.0 / 1.0 2.0 /1.7 /1.4 /20max / 36max 60max / 96max 60max / 96max 250max / 100max 600max / 150max 600max / 150max 500max /750max /750max /80max / 240max 120max / 240max 120max / 240max 140max / 320max 160max / 320max 160max / 320max 120max / 300max 150max / 300max 150max / 300max 160max / 360max 180max / 360max 180max / 360max 50max 120max 150max 60max 150max 180max 20max 48max 60max 200typ(ACIN 100V, Io=100%) *Start-up time is 700ms typ for less than 1minute of applying input again from turning off the input voltage. 20typ (ACIN 100V, Io=100%) 4.99 - 6.00 (+V and -V are simultaneously adjusted) 9.60 - 13.2 (+V and -V are simultaneously adjusted) 13.2 - 16.5 (+V and -V are simultaneously adjusted) 4.99 - 5.30 (+V and -V CURRENT1) 11.5 - 12.5 (+V and -V CURRENT1) 14.4 - 15.6 (+V and -V CURRENT1) Works over 105% of rated current and recovers automatically 6.90 - 10.0 16.8 - 24.0 20.0 - 29.0 LED (Green) None AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 25mA, DC500V 50MW min (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 (Not built-in to active filter *7) *12 31X78X103mm [1.22X3.07X4.06 inches] (without terminal block) (W XHXD) / 270g max (with cover : 310g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN : RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Figures for 0 to rated current 1.The current not measured side is fixed. *4 Figures for 0 to rated current 2.The current not measured PBA/PBW-28 side is fixed. *5 The sum of +power -power must be less than output power. *6 t5,t12,t15 can be used as +10,+24 and +30. *7 When two or more units are used,they may not comply with the harmonic attenuator. Please contact us for details. *8 Derating is required. *9 Figures to rated current 1. March 08, 2022 *10 Please contact us about safety approvals for the model with option. *11 Please contact us about dynamic load and input response. *12 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. PBW30F Block diagram FUSE AC250V 3.15A AC IN 85 - 264V INRUSH CURRENT LIMIT NOISE FILTER RECTIFIER AND FILTER FG TRANSFORMER CONTROL RECTIFIER AND FILTER INVERTER +V COM CURRENT SENSING RECTIFIER AND FILTER DC OUT -V Photocoupler CONTROL Photocoupler OVER VOLTAGE PROTECTION External view ¶ External size of option T,J1,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. Voltage adjust 18 2.5 [0.71] [0.1] 12.2±1.5 [0.48] LED Cover name plate 16.5± 2 103 [0.65] [4.06] M3 +V Point A:C102 2-M3 Mounting hole Name plate 18 75±0.5 [2.95] March 08, 2022 [1.36] 2-M3 Mounting hole PBA30F PBW30F ¶ Tolerance : ±1 [±0.04] ¶ Weight : 270g max (with cover : 310g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Hot-dip galvanized steel plate ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.6N • m(6.3kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. [3.07] 78 [1.59] [1.44] 36.5 40.5 [1.81] 34.5 [0.89] 46±0.5 [1.22] 22.6±1.5 Terminal cover 31 [0.59] [0.71] 15.1±1.5 7.5 AC(N) [0.3] FG AC(L) 11.5 9.5 Cover (option) -V [0.45] [0.37] 70.5 [2.78] COM 8.5 [0.33] PBA/PBW-29 AC-DC Power Supplies Enclosed Type PBW50F Ordering information PB W 1 2 50 3 F Example recommended EMI/EMC filter NAC-06-472 R -O -O 4 High voltage pulse noise type : NAP series Low leakage current type : NAM series * A higher current rating EMI/EMC filter may be recommended in view of the other devices that could be connected in parallel with the power supply. Cover is optional 5 6 1 Series name 2 Dual output 3 Output wattage 4 Universal input 5 Output voltage 6 Optional *9 C : with Coating G : Low leakage current (0.15mA max / ACIN 240V) E : Low leakage current and EMI class A (0.5mA max / ACIN 240V) T : Vertical terminal block J1 : VH (J.S.T.) connector type R : with Remote ON/OFF N : with Cover N1 : with DIN rail V : Output voltage setting potentiometer externally *Make sure necessary tests will be carried out on your end equipment with the power supply installed in accordance with any required EMC/EMI regulations. MODEL MAX OUTPUT WATTAGE[W] DC OUTPUT PBW50F-5 30 VOLTAGE[V] *8 t5 ( +10 ) CURRENT1[A] 3.0 CURRENT2[A] *6 4.0 *6 PBW50F-12 50.4 t12 ( +24 ) 2.1 2.7 PBW50F-15 51 t15 ( +30 ) 1.7 2.4 SPECIFICATIONS MODEL VOLTAGE[V] CURRENT[A] ACIN 100V ACIN 200V FREQUENCY[Hz] INPUT OUTPUT PROTECTION CIRCUIT AND OTHERS ISOLATION ENVIRONMENT SAFETY AND NOISE REGULATIONS OTHERS ACIN 100V ACIN 200V ACIN 100V POWER FACTOR(Io=100%) ACIN 200V ACIN 100V INRUSH CURRENT[A] ACIN 200V LEAKAGE CURRENT[mA] VOLTAGE[V] CURRENT1[A] CURRENT2[A] *6 LINE REGULATION[mV] LOAD REGULATION 1[mV] *4 LOAD REGULATION 2[mV] *5 0 to +50C *1 RIPPLE[mVp-p] -10 - 0C *1 0 to +50C *1 RIPPLE NOISE[mVp-p] -10 - 0C *1 0 to +50C TEMPERATURE REGULATION[mV] -10 to +50C DRIFT[mV] *2 START-UP TIME[ms] HOLD-UP TIME[ms] OUTPUT VOLTAGE ADJUSTMENT RANGE[V] OUTPUT VOLTAGE SETTING[V] OVERCURRENT PROTECTION OVERVOLTAGE PROTECTION[V] OPERATING INDICATION REMOTE ON/OFF INPUT-OUTPUT -RC *7 INPUT-FG OUTPUT-RC-FG *7 OPERATING TEMP.,HUMID.AND ALTITUDE STORAGE TEMP.,HUMID.AND ALTITUDE VIBRATION IMPACT AGENCY APPROVALS (At only AC input) CONDUCTED NOISE HARMONIC ATTENUATOR CASE SIZE/WEIGHT COOLING METHOD EFFICIENCY[%] PBW50F-5 PBW50F-12 PBW50F-15 AC85 - 264 1f or DC120 - 370 (AC50 or DC70 Please refer to the instruction manual 1.1 Input voltage *3) 0.45typ (CURRENT1) 0.70typ (CURRENT1) 0.30typ (CURRENT1) 0.40typ (CURRENT1) 50/60 (47 - 63) 76typ (CURRENT1) 81typ (CURRENT1) 81typ (CURRENT1) 77typ (CURRENT1) 83typ (CURRENT1) 83typ (CURRENT1) 0.98typ 0.99typ 0.87typ 0.93typ 15typ (CURRENT1) (At cold start) 30typ (CURRENT1) (At cold start) 0.40/0.75max (ACIN 100V/240V 60Hz, Io=100%, According to IEC62368-1,DENAN) / ( +10V reference number ) t12 / ( +24V reference number ) t15 / ( +30V reference number ) t5 3.0 / 3.0 2.1 / 2.1 1.7 / 1.7 4.0 /2.7 /2.4 /20max / 36max 48max / 96max 60max / 96max 250max / 100max 600max / 150max 600max / 150max 500max /750max /750max /80max / 240max 120max / 240max 120max / 240max 140max / 320max 160max / 320max 160max / 320max 120max / 300max 150max / 300max 150max / 300max 160max / 360max 180max / 360max 180max / 360max 50max 120max 150max 60max 150max 180max 20max 48max 60max 350typ(ACIN 100V, Io=100%) 20typ (ACIN 100V, Io=100%) 4.99 - 6.00 (+V and -V are simultaneously adjusted) 9.60 - 13.2 (+V and -V are simultaneously adjusted) 13.2 - 16.5 (+V and -V are simultaneously adjusted) 4.99 - 5.30 (+V and -V CURRENT1) 11.5 - 12.5 (+V and -V CURRENT1) 14.4 - 15.6 (+V and -V CURRENT1) Works over 105% of rated current and recovers automatically 6.90 - 10.0 16.8 - 24.0 20.0 - 29.0 LED (Green) Optional (Required external power source) AC3,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC2,000V 1minute, Cutoff current = 10mA, DC500V 50MW min (At Room Temperature) AC500V 1minute, Cutoff current = 100mA, DC500V 50MW min (At Room Temperature) -10 to +71C (Refer to “Derating”), 20 - 90%RH (Non condensing) 3,000m (10,000feet) max -20 to +75C, 20 - 90%RH (Non condensing) 9,000m (30,000feet) max 10 - 55Hz, 19.6m/s2 (2G), 3minutes period, 60minutes each along X, Y and Z axis 196.1m/s2 (20G), 11ms, once each X, Y and Z axis UL60950-1, C-UL(CSA60950-1), EN62368-1 Complies with DEN-AN Complies with FCC Part15 classB, VCCI-B, CISPR22-B, EN55011-B, EN55022-B Complies with IEC61000-3-2 *10 31X82X120mm [1.22X3.23X4.72 inches] (without terminal block) (W XHXD) / 280g max (with cover : 325g max) Convection *1 Measured by 20MHz oscilloscope or Ripple-Noise meter(equivalent to KEISOKU-GIKEN : RM101). *2 Drift is the change in DC output for an eight hour period after a half-hour warm-up at 25C. *3 Derating is required. *4 Figures for 0 to rated current 1.The current not measured side is fixed. PBA/PBW-30 *5 Figures for 0 to rated current 2.The current not measured side is fixed. *6 The sum of +power -power must be less than output power. *7 RC is applied to remote ON/OFF option. RC is isolated with input/output and FG. *8 t5,t12,t15 can be used as +10,+24 and +30. March 08, 2022 *9 Please contact us about safety approvals for the model with option. *10 Please contact us about class C. * Parallel operation with other model is not possible. * Derating is required when operated with cover. * A sound may occur from power supply at peak loading. PBW50F Block diagram FUSE 250V2A NOISE FILTER AC IN 85 - 264V RECTIFIER INRUSH CURRENT LIMIT FG CURRENT SENSING BOOSTER INDUCTOR CURRENT SENSING OPTION RC EXTERNAL SOURCE CONTROL RECTIFIER AND FILTER E CONTROL OVER VOLTAGE PROTECTION INVERTER INVERTER RECTIFIER AND FILTER CONTROL +DC OUT COM RECTIFIER AND FILTER TRANSFORMER -DC OUT External view ¶ External size of option T,J1,R,N1 and V is different from standard model and refer to 7 Option of instruction manual for details. [0.65] [4.72] Cover name plate 0.5 LED [0.02] (11) [0.43] 82 Voltage adjust (16.5) [3.23] CN3 Connector for Remote ON/OFF (option) 120 (20) [0.79] 1 2 M3 +V 77 ±0.5 ¶ Tolerance : ±1 [±0.04] ¶ Weight : 280g max (with cover : 325g max) ¶ PCB Material/thickness : CEM3 / 1.6mm [0.06] ¶ Chassis material : Aluminum ¶ Dimensions in mm, [ ]= inches ¶ Mounting torque : 0.49N • m(5kgf • cm)max ¶ Screw tightening torque : M3 0.8N • m(8.5kgf • cm)max ¶ Please connect safety ground to the unit in 2-M3 holes. 18 PBW50F [1.36] Connector type 2-M3 Mounting hole CN3 Option (Mfr : J.S.T.) Name plate 34.5 [0.85] [0.16] 31 (21.5) 4 [3.03] Terminal cover Point A [1.22] (14) [0.55] 35 [0.3] (12) 9.5 AC(N) A 2-M3 Mounting hole [1.38] FG AC(L) [0.71] Cover (option) 7.5 -V [0.47] [0.37] [2.8] (71) COM Pin No. 1 2 Contents RC(+) RC( - ) Barrier strip type 88 ±0.5 [3.46] 11 [0.43] Model B2B-XH-A Mating Connector (Terminal) XHP-2 BXH-001T-P0.6 or SXH-001T-P0.6 ( March 08, 2022 ) PBA/PBW-31 PBA∙PBW-series Terminal Blocks *The following information covers PBA300F - 1500F. Please see External View for PBA10F - 150F and PBW15F - 50F. ¿ PBA300F ¿ PBA600F å 9 0 7 8 å 0 CN3 H V. ADJ AC ( L) 1 2 4 5 6 7 CN2 8 CN1 AC ( N) FG 124 ¿ PBA1000F 5 6 ¿ PBA1500F 0 å 9 8 å 7 0 H V. ADJ AC (L) 9 AC (N) 8 7 V. ADJ CN1 FG 9 AC ( L) CN2 AC ( N) CN1 NC FG CN2 CN3 CN3 1 2 4 5 6 1 2 3 4 5 ¿ PBA1500T å 0 9 8 7 V.ADJ (L1) AC (L2) CN1 (L3) FG CN2 CN3 1 2 3 4 5 6 *PBA300F - 1500F *PBA1500T 1AC (L) Input Terminals AC85 - 264V f47 - 63Hz 2AC (N) (M4) 3NC 4Frame ground (M4 ) 5-Output 6+Output 7LED 8Output voltage adjustable potentiometer 9CN1 0CN2 Connectors åCN3 *Please see Optional Parts for dedicated harnesses. 1AC (L1) 2AC (L2) 3AC (L3) 4Frame ground (M4 ) 5-Output 6+Output 7LED 8Output voltage adjustable potentiometer 9CN1 0CN2 Connectors åCN3 PBA/PBW-32 March 08, 2022 6 PBA∙PBW-series Terminal Blocks ¿ PBA300F, 600F Pin Configuration Pin No. 1 2 3 4 5 6 7 8 9 10 PCB 8 7 2 10 CN3 19 2 10 19 CN2 2 CN1 1 ¿ PBA1000F, 1500F Pin Configuration Pin Configuration and Functions of CN3 Pin No. Function 1 -S : -Sensing 2 -S : -Sensing 3 AUX : Auxiliary output (12V 0.1A) 4 RC1 : Remote ON/OFF 5 AUXG : Auxiliary output (GND) 6 N.C. : No connection 7 PG : Alarm 8 PGG : Alarm (GND) *Common signs among CN1, CN2 and CN3 such as -S represent the same potential. PCB 2 1 10 2 9 1 10 2 9 1 8 7 Pin Configuration and Functions of CN1 and CN2 Function +M : Self sensing terminal. (Do not wire for external connection.) +S : +Sensing -M : Self sensing terminal. (Do not wire for external connection.) -S : -Sensing VB : Voltage balance CB : Current balance TRM : Adjustment of output voltage -S : -Sensing RC2 : Remote ON/OFF RCG : Remote ON/OFF (GND) CN1 CN2 CN3 Matching connecters and terminals on CN1, CN2 and CN3 Connector CN1 CN2 CN3 Housing S10B-PHDSS PHDR-10VS S8B-PHDSS PHDR-08VS Terminal Mfr. Reel : SPHD-002T-P0.5 J.S.T. Loose : BPHD-001T-P0.5 Assembling and Installation Method Installation Method ¡Do not insert a screw more than 6mm from the outside of a power supply to keep enough insulation distance between the screw and Chassis of PBA series Chassis of customer system internal components. Mounting Screw 6mm max ¿ PBA10F, PBA15F, PBW15F, PBA30F, PBW30F, PBA50F, PBW50F, PBA75F, PBA100F and PBA150F A B C ¡If you use two or more power supplies side by side, please keep a sufficient distance between them to allow enough air ventilation. ¡Ambient temperature around each power supply should not exceed the temperature range shown in ‟derating”. Normal mounting ¿ PBA300F, PBA600F, PBA1000F, PBA1500F and PBA1500T ¡The power supplies have a built-in forced cooling fan. Do not block ventilation at the suction side (terminal block side) and its opposite side (fan installation side). If you need to secure a power supply by screws, securely fix it, taking into consideration of its weight. You can install it in any direction. ¡If you use a power supply in a dusty environment, it can give a cause for a failure. Please consider taking such countermeasures as installing an air filter near the suction area of the system to prevent a failure. ¡In PBA300F, PBA1500F and PBA1500T, ventilation holes are located on the mounting side. If you would like to install the unit by using that side, please contact us for details. March 08, 2022 PBA/PBW-33 PBA∙PBW-series Derating ¿PBA10F, PBA15F, PBW15F, PBA30F, PBW30F Input voltage Derating Curve ¿PBA1500F Input voltage Derating Curve 100 100 at AC100V Load [%] Load [%] 80 80 85 90 85 95 [AC V] [AC V] ¿PBA10F, PBA15F, PBW15F, PBA30F, PBW30F, PBA50F, PBW50F, PBA75F, PBA100F, PBA150F Ambient temperature derating curve Load factor [%] 100 2 80 60 1 1Convection 2Forced air (0.5m3 / min) 40 20 0 -10 A 0 10 20 30 [20] 40 [30] 50 [40] 60 [50] 70 [60] 80 [70] 20 [10] 30 [20] 40 [30] 50 [40] 60 [50] 70 [60] B 20 [10] 30 [20] 40 [30] 50 [40] 60 [50] 70 [60] C Ambient temperature [C] Inside [ ] is with case cover ¡In the hatched area, the specification of Ripple, Ripple Noise is different from other area. ¡The ambient temperature should be measured 5 to 10 cm away from the power supply so that it won’t be influenced by the heat from the power supply. Please consult us for more details. ¡Make sure the temperature at point A is less than the temperatures shown in Instruction Manual 4. ¿PBA300F, PBA600F, PBA1000F, PBA1500F, PBA1500T Ambient temperature derating curve [%] 100 90 Load factor 80 70 60 71C 50 40 30 20 10 0 - 20 - 10 0 10 20 30 40 50 60 70 80 Ambient temperature[C] ¡In the hatched area, the specification of Ripple, Ripple Noise is different from other area. ¡Derating curve depending on an ambient temperature (temperature of air sucked in for a cooling purpose) is shown above. PBA/PBW-34 March 08, 2022 PBA∙PBW-series Instruction Manual ◆ It is neccessary to read the “Instruction Manual” and “Before using our product” before you use our product. Instruction Manual https://en.cosel.co.jp/product/powersupply/PBA/ Instruction Manual https://en.cosel.co.jp/product/powersupply/PBW/ Before using our product https://en.cosel.co.jp/technical/caution/index.html PBA PBW NOTICE Basic Characteristics Data Basic Characteristics Data Model Circuit method Switching frequency [kHz] Input current [A] PBA10F Flyback converter 100 0.3 PBA15F Flyback converter 100 0.4 PBA30F Flyback converter 100 0.7 Active filter 60 - 550 Forward converter 130 Active filter 60 - 550 Forward converter 120 Active filter 60 - 550 Forward converter 120 PBA50F PBA75F PBA100F PBA150F PBA300F PBA600F PBA1000F Active filter 60 - 550 Forward converter 120 Active filter 230 Forward converter 330 Active filter 130 Forward converter 330 Active filter 130 Forward converter 280 0.7 Rated input fuse Inrush current protection circuit Material Single sided Series/Parallel operation availability Double Series Parallel sided operation operation PCB/Pattern LF CEM-3 Yes Yes *1 Thermistor CEM-3 Yes Yes *1 250V 3.15A Thermistor CEM-3 Yes Yes *1 Thermistor CEM-3 Yes Yes *1 Thermistor CEM-3 Yes Yes *1 Thermistor CEM-3 Yes Yes *1 Yes Yes *1 250V 2.5A 250V 2A 1.0 250V 3.15A 1.3 2.0 250V 4A Thermistor CEM-3 4.1 250V 10A SCR FR-4 Yes Yes Yes 8.2 250V 15A SCR FR-4 Yes Yes Yes SCR FR-4 Yes Yes Yes SCR FR-4 Yes Yes Yes SCR FR-4 Yes Yes Yes 13 250V 30A Active filter 130 Forward converter 200 Active filter 130 Forward converter 200 PBW15F Flyback converter 100 0.4 250V 2.5A Thermistor CEM-3 Yes Yes *1 PBW30F Flyback converter 100 0.7 250V 3.15A Thermistor CEM-3 Yes Yes *1 Active filter 60 - 550 Forward converter 130 CEM-3 Yes Yes *1 PBA1500F PBA1500T PBW50F 19 6 0.7 250V 16A 250V 2A Thermistor *1 Refer to Series/Parallel Operation of Instruction Manual. * The value of input current is at ACIN 100V and rated load, ACIN 200V 3f and rated load in PBA1500T. March 08, 2022 PBA/PBW-35
PBA300F-48 价格&库存
很抱歉,暂时无法提供与“PBA300F-48”相匹配的价格&库存,您可以联系我们找货
PBA300F-48
    • 1+2409.85562
    • 13+2385.42476
    • 25+2317.89103
    库存:10
