FN2360W-3-06
FN2360W-3-06
    SCHAFFNER(夏弗纳)
    FN2360W-3-06
FN2360W-3-06 数据手册
DATASHEET Two-Stage Filters FN 2360 High performance EMC/EMI filter Rated currents from 3 to 6 A Exceptional differential and common-mode attenuation Approvals UL-rated materials Optional medical versions (B type) Features and benefits FN 2360 filters are designed for easy and fast chassis mounting FN 2010 filters have a perfect performance/size ratio All filters provide a very high differential and common-mode attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Faston terminal connection with additionl spade solder possibility Optional medical versions (B type) Custom-specific versions on request Typical applications Electrical and electronic equipment Consumer goods Technical specifications Medical equipment Power supplies Maximum continuous operating voltage 250 VAC, 50/60 Hz Office automation equipment High potential test voltage P –> PE 2000 VAC for 2 sec P –> N 1100 VDC for 2 sec Typical electrical schematic Operating frequency Rated currents Temperature range (operation and storage) Flammability corresponding to Design corresponding to MTBF @ 40°C/230V (Mil-HB-217F) dc to 400 Hz 3 to 6 A @ 40 °C max. -25 °C to +100 °C (25/100/21) UL 94 V-2 or better UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 2,400,000 hours Datacom equipment 2 EMC/EMI Products Schaffner Group Datasheets 2014 Filter selection table Filter Rated current Leakage current* [A] 6 (6.7) @ 40 °C (25 °C) FN 2360W-3-06 3 (3.35) FN 2360B-3-06 3 (3.35) FN 2360X-6-06 FN 2360B-6-06 @ 230 VAC/50 Hz 6 (6.7) Inductance L L1 [mA] [mH] 0.7 48.2 0.52 0.004 0.004 32.3 32.3 48.2 Capacitance Resistance Cx Cy [mH] [μF] [nF] [MΩ] 1.7 1.5 4 1 0.4 0.4 1.7 0.47 0.47 1.5 3 R Input/Output Weight -06 300 connections 1 1 1 * Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Typical filter attenuation Per CISPR 17; A = 50 Ω/50 Ω sym; B = 50 Ω/50 Ω asym; C = 0.1 Ω/100 Ω sym; D = 100 Ω/0.1 Ω sym 3 A types (W types) 3 A types (B types) 6 A types (X types) Mechanical data 3 A types 6 A types 6 A types (B types) -06 -06 -06 [g] 500 300 500 EMC/EMI Products 3 Schaffner Group Datasheets 2014 Dimensions 3A 6A A 85 ±0.5 113.5 ±1 C 40.3 ±0.5 45.5 ±1 E 49.8 B D F G H I J K L M N All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m / EN 22768-m 54 ±0.5 64 ±0.5 57.5 ±1 94 ±1 56 ±0.5 25 ±0.2 75 103.5 12.3 12.4 11.4 15.5 27 29.8 5.3 6.3 0.7 6.3 x 0.8 Tolerances 32.4 4.4 6 1 6.3 x 0.8 ±0.3 ±0.5 ±0.5 ±0.5
FN2360W-3-06 价格&库存
很抱歉,暂时无法提供与“FN2360W-3-06”相匹配的价格&库存,您可以联系我们找货
