19031491A
19031491A
    COMAIRROTRON
    插件
    19031491A
19031491A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: SPEC Number: JQ24B7 19031491A 26007458A Rev:01 November 9, 2012 Mechanical Drawing: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Acoustic Additional Features: = 24 vdc = 12 - 28 vdc = 0.85 amps = 1.50 amps = 20.3 watts = 3500 rpm = Ball = 235 cfm = 54.3 dBA Construction: Venturi: Die-Cast Aluminum, Black Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 75,000 hours at 40C. Agencies: UL, CE Brushless DC motor Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature Storage Temperature: -10C to 70C -40C to 85C Tachometer: Output: IC: Pulses Per Revolution: Isolated: 5 Vdc TTL Compatible 5 mA Typical 2 No Termination: 12.0” Lead wires, 22 AWG, UL1061 Red = Fan (Power) Black = Fan (Return) Blue/White = Tachometer (Output)
19031491A 价格&库存
很抱歉,暂时无法提供与“19031491A”相匹配的价格&库存,您可以联系我们找货
