19039695A
19039695A
    COMAIRROTRON
    插件
    19039695A
19039695A 数据手册
SPECIFICATIONS (RoHS Compliant) Model Number: Part Number: PQD24Z3A2 19039695A Version: 00 Apr 19, 2017 Mechanical Drawing: Additional Features: Motor: Nominal Voltage Operating Voltage Range Nominal Running Current Locked Rotor Current Running Power Average Speed Bearings Air Flow Static Pressure Acoustic = 24 vdc = 12 – 32 vdc = 1.450 amps = 2.500 amps = 35 watts = 4450 rpm = Ball = 300 CFM = 1.30” of Water = 60.2 dBA Construction: Venturi: Die-Cast Aluminum, Black Propeller: Polycarbonate, Black, UL 94V-0 Agency Approvals: UL, CE, UL 507 Life Expectancy: This fan is designed for continuous duty life of 50,000 hours at 40°C. Brushless DC Motor Soft Start Inrush Current Electronic Locked Rotor Protection Polarity Protected Automatic Restart Capability Operating Temperature: -40°C to 85°C Storage Temperature: -40°C to 85°C Programmable: PWM Input, 5 volt TTL 0% Duty: 100% Duty: Off 4450 RPM Tachometer Specifications: Output: 5 volt TTL compatible Ic: 5 mA. Typ. Pulses per Revolution: 2 Isolated: No Termination: 12” Leadwires, 22 AWG, UL 1061 Red - Power (+) Black - Return (-) Blue/White - Tachometer Yellow - Program Lead 2” Programmable harness, Connector, Molex 050579005 Pin Contact, Moelx 16020069 PQ Curve:
19039695A 价格&库存
很抱歉,暂时无法提供与“19039695A”相匹配的价格&库存,您可以联系我们找货
