19028324A
19028324A
    COMAIRROTRON
    插件
    19028324A
19028324A 数据手册
SPECIFICATIONS RoHS Model Number:MX3A3 Part Number: 19028324A Version: 02 Dec 18, 2017 Mechanical Drawing: Motor: Additional Features: Normal Voltage = 230 VAC Operating Voltage Range = 207~253VAC Operating Frequency = 50/60Hz Rated Current = 0.17/0.14A Input Power = 23/20Watt Average Speed = 2500/2850RPM Bearings = Ball Airflow = 90/100CFM (Measuring at zero static pressure) Static Pressure = 0.20”/0.25’’ H2O (Measuring at zero air flow) Noise Level = 50/52 dB(A) Net Weight = 460 gram. Insulation Resistance: 100MΩ or more at 500 V megger. Dielectric strength: 2 seconds at 1800 VAC/ 50-60 Hz. Thermal Shock: Test per MIL-STD-202F, method 107G, condition D. Operating Temperature: -10C to 70C Storage Temperature: -40C to 85C Construction: Venturi: High quality magnesium alloy die-casting Frame with ED coating and powder coating, Black. Propeller: Plastic, Black, UL 94V-0 Life Expectancy: This fan is designed for continuous duty life of 83,000 hours at 40ºC. Termination: 0.120” Wide Terminals Agency Approvals: UL, CUL, CE PQ Curve:
19028324A 价格&库存
很抱歉,暂时无法提供与“19028324A”相匹配的价格&库存,您可以联系我们找货
