17000541A
17000541A
    COMAIRROTRON
    17000541A
17000541A 数据手册
Comair Rotron Specification Sheet Specification Date: Dec 12, 2017 Version:02 COMAIR ROTRON PART NUMBER: COMAIR ROTRON MODEL NUMBER: 17000541A CREC9225-4000 A.) MOTOR: RATED VOLTAGE: 100~240VAC±10% OPERATING VOLTAGE RANGE: 90~264VAC LOW-START VOLTAGE: 80VAC RUNNING CURRENT: 0.03~0.05 Amps OPERATING FREGUENCY: 50~60Hz INPUT POWER: 4 Watts NOMINAL SPEED: 4,000 RPM 5% (At Free Delivery) MOTOR TYPE: Brushless EC MOTOR PROTECTION: By Integrated Circuit LOCKED ROTORT PROTECTION: IC protected POLARITY PROTECTION: Yes AUTOMATIC RESTART CAPABILITY: By Integrated Circuit ROTATION: Counter Clockwise when viewed from the impeller B.) MECHANICAL DIMENSIONS: 92mm x92mm x 25mm WEIGHT: 181g (0.386 Lbs.) BEARING TYPE: Permanently Lubricated Ball Bearings VENTURI: Die Cast magnesium alloy, ED coating and powder coating PROPELLER: P.B.T+30%GF(Glass fiber) UL 94V-0 -1- Comair Rotron Specification Sheet Specification Date: Dec 12, 2017 Version:02 Figure 1 C.) ENVIRONMENTAL OPERATING TEMPERATURE: -20C to +70C STORAGE TEMPERATURE: The storage temperature will be suggested at -20℃ ~ 50℃ to ensure a better performance. HUMIDITY: 20 to 85% RH, non-condensing -2- Comair Rotron Specification Sheet Specification Date: Dec 12, 2017 Version:02 D.) PERFORMANCE CHARACTERISTICS AIR FLOW: 49 CFM  5% (Measuring at zero static pressure) STATIC PRESSURE: 0.35” Inches of H20 (Measuring at zero airflow) ACOUSTIC LEVEL: 43 dBA Max. at MAX. speed (Measured via Freely Suspended at 1 meter ) -3- Comair Rotron Specification Sheet Specification Date: Dec 12, 2017 Version:02 E.) TERMINATION Joint terminal: suit with 0.5×3×7mm PIN F.) RELIABILITY Bearing type Ball bearing Temperature 20℃ Hours 60,000 40℃ 50,000 60℃ 40,000 90℃ 20,000 G.) SAFETY UL, CUL, CE H.) FLAMMABILITY The fan including all components meets a UL94V-0 rating or better. -4-
17000541A 价格&库存
很抱歉,暂时无法提供与“17000541A”相匹配的价格&库存,您可以联系我们找货
17000541A
  • 1+405.004961+50.60930
  • 10+329.9715310+41.23315
  • 30+296.7262930+37.07883
  • 50+289.4710450+36.17222
库存:155
