ARVCONNECTOR
Wire-to-wire
Features
●12 Circuits, 18 Circuits and 22 Circuits Wire-to-Wire
Connection
●Optional Wire Routing Attachment (to optimize
packaging space)
●Versatile Mounting Options
●Latch Overstress Feature
●Both Female and Male Connectors utilize
Independent Secondary Lock for Terminal retention
0.64 Unsealed wire-to-wire connection system for
unsealed applications, requiring Automotive durability.
Clip mountable type
¡Normal type
JS
T
1
6
18
Screw hole type
¡Normal type
¡With back cover type
JS
T
1
C-B
6
JS
T
1
18
6
12
18
JS
Specifications
T
1
C-B
6
12
18
JS
T
C-B
¡Current rating: 5 A DC max.
¡Voltage rating: 14 V DC
¡Temperature range: - 40°C to +125°C
(including temperature rise in applying
electrical current)
¡Contact resistance: Initial value/ 15 mΩ max.
After environmental tests/ 15 mΩ max.
¡Insulation resistance: 100 MΩ min.
¡Applicable Wire: TXL/ ISO 0.35 mm2 to 0.75 mm2
O.D. 1.9 mm (AWG #22 to #18)
(Female Terminal)
ISO 0.35 mm2 to 0.5 mm2
O.D. 1.7 mm (AWG #22 to #20)
(Male Terminal)
∗ Compliant with ELV/RoHS.
∗ Contact JST for details.
1
ARV CONNECTOR
Female terminal
Applicable wire range
Conductor
(mm2)
Insulation O.D.
(mm)
Q’ty/reel
SAIT-A03T-M064
0.35 to 0.5
1.9
6,500
SAIT-A02T-M064
0.75
1.9
6,500
1.6
Model No.
14
Material and Finish
6.5
2.25
Copper alloy, tin-plated (reflow treatment)
Female connector
¡12 circuits (With back cover)
19
(25.2)
¡12 circuits
(20.4)
5X2.54=12.7
19
¡18 circuits
(23.85)
12.75
13.65
12.75
19.8
5X2.54=12.7
19
(25.2)
¡18 circuits (With back cover)
(20.4)
5X2.54=12.7
19
16.75
17.65
16.75
5X2.54=12.7
(27.85)
19.8
2
ARV CONNECTOR
Female connector
¡22 circuits (With back cover)
19
(25.2)
¡22 circuits
24.88
(25.48)
7X2.54=17.78
Circuits
12
18
22
Model No.
(27.85)
16.75
17.65
16.75
7X2.54=17.78
Back Cover
Q’ty/box
ARVPB-12-2AK
No
1,500
ARVPB-12C12-2AK
Yes
1,500
ARVPB-18-3AK
No
1,000
ARVPB-18C18-3AK
Yes
1,000
ARVPB-22-3AK
No
600
ARVPB-22C22-3AK
Yes
500
Material and Finish
Housing: PBT, Black
TPA: Glass-filled PBT, Natural (White)
Back cover: Glass-filled PBT, Black
Male terminal
Model No.
Conductor
(mm2)
Insulation O.D.
(mm)
Q’ty/reel
SNAC3W-A021T-0.64
0.35 to 0.5
1.7
7,000
Material and Finish
3
14.9
3
8.9
Brass, tin-plated (reflow treatment)
ARV CONNECTOR
Male connector
¡12 circuits (Clip Mountable Type)
33
33
¡12 circuits (Screw hole Mountable Type)
23.04
20.4
20.4
13.65
13.65
36.4
5X2.54=12.7
5X2.54=12.7
¡18 circuits (Clip Mountable Type)
33
33
¡18 circuits (Screw hole Mountable Type)
23.04
20.4
20.4
17.65
17.65
36.4
5X2.54=12.7
5X2.54=12.7
¡22 circuits (Clip Mountable Type)
33
33
¡22 circuits (Screw hole Mountable Type)
28.73
41.48
25.48
17.65
17.65
25.48
7X2.54=17.78
7X2.54=17.78
Circuits
12
18
22
Model No.
ARVWSB-12B-2AK
ARVWSB-12BC-2AK
ARVWSB-18-3AK
ARVWSB-18C-3AK
ARVWSB-22-3AK
ARVWSB-22C-3AK
Mountable
Style
Q’ty/box
Screw hole
1,000
Clip
1,000
Screw hole
750
Clip
750
Screw hole
450
Clip
450
Material and Finish
Housing: Glass-filled PBT, Black
PBT, Black (22P only)
4
ARV CONNECTOR
Assemby layout
¡12 circuits
¡18, 22 circuits
(4.1)
(4.1)
33
(13.85)
(17.85)
33
¡18, 22 circuits (With back cover)
(4.1)
(4.1)
33
(23.85)
(27.85)
33
(6.25)
(6.25)
Crimping machine, Applicator
Strip terminal
Crimping
machine
SAIT-A03( )-M064
SAIT-A02( )-M064
SNAC3W-A021( )-0.64
AP-K2N
Crimp applicator MKS-L
Dies
Crimp applicator with dies
MK/SAIT-A03-064
APLMK SAIT-A03-064
MK/SAIT-A02-064
APLMK SAIT-A02-064
MK/SNAC3W-A021-064
APLMK SNAC3W-A021-064
Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal.
5
很抱歉,暂时无法提供与“ARVPB-18-3AK”相匹配的价格&库存,您可以联系我们找货
