SOLC-115-02-S-Q-LC
SOLC-115-02-S-Q-LC
    SAMTEC(申泰)
    SMD,P=0.64mm
    排母
SOLC-115-02-S-Q-LC 数据手册
QUAD ROW SMT TERMINAL & SOCKET (1.27 mm) .050" PITCH • TOLC/SOLC SERIES TOLC TOLC Mates: SOLC - NO. PINS PER ROW 1 - 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 SOLC Mates: TOLC SPECIFICATIONS PROCESSING PLATING OPTION - Q - –F = Alignment Pin (N/A with -LC) –LC = Locking Clip (N/A with -A) (Manual placement required) –L = 10 µ" (0.25 µm) Gold on contact, Gold flash on tail LEAD STYLE (8.13) .320 A OTHER OPTION –A = Gold flash on contact, Gold flash on tail No. of positions x (1.27) .050 + (2.54) .100 –K = (9.00 mm) .354" DIA Polyimide film Pick & Place Pad –TR MATED HEIGHT –02 (5.59) .220 (6.35) .250 –12 (7.24) .285 (8.00) .315 –22 (9.25) .364 (10.00) .394 –32 (11.23) .442 (12.00) .472 = Tape & Reel –FR = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) (5.08) .200 A Lead-Free Solderable: Yes SMT Lead Coplanarity: (0.10 mm) .004" max (05-35) (0.15 mm) .006" max (40-50)* *(.004" stencil solution may be available; contact IPG@samtec.com) Style –02 Styles –12,–22,–32 SOLC ALSO AVAILABLE - Specify LEAD STYLE from chart (Standard Sizes) Insulator Material: Black Liquid Crystal Polymer Contact Material: Phosphor Bronze Plating: Au over 50 µ" (1.27 µm) Ni Current Rating: 2.4 A per pin (6 adjacent pins powered) Operating Temp Range: -55 °C to +125 °C Insertion Depth (SOLC): (1.68 mm) .066" to (3.61 mm) .142" with (0.38 mm) .015" wipe Normal Force (SOLC): 75 grams (0.74 N) average Max Cycles (SOLC): 100+ LEAD STYLE - NO. PINS PER ROW 1 MOQ Required - –A OPTION 02 - 05, 10, 15, 20, 25, 30, 35, 40, 45, 50 Other sizes Other platings –F = Gold flash on contact, Gold flash on tail (Standard Sizes) –L No. of positions x (1.27).050 + (0.51) .020 = 10 µ" (0.25 µm) Gold on contact, Gold flash on tail (6.35) .250 (1.02) .040 TYP (2) PLATING OPTION (4.06) (4.62) .160 .182 - Q - –LC OPTION OTHER OPTION –A = Alignment Pin (N/A with -LC) –LC = Locking Clip (N/A with -A) (Manual placement required) –K = (7.00 mm) .276" DIA Polyimide film Pick & Place Pad –P = Pick & Place Pad –TR = Tape & Reel –FR Note: Some lengths, styles and options are non-standard, non-returnable. —A OPTION —LC OPTION —P OPTION = Full Reel Tape & Reel (must order max. quantity per reel; contact Samtec for quantity breaks) samtec.com?TOLC or samtec.com?SOLC Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice. F-221
SOLC-115-02-S-Q-LC 价格&库存
很抱歉,暂时无法提供与“SOLC-115-02-S-Q-LC”相匹配的价格&库存,您可以联系我们找货
SOLC-115-02-S-Q-LC
  • 1+102.26520
库存:11
SOLC-115-02-S-Q-LC
  • 26+162.15123
  • 52+158.20110
库存:66
SOLC-115-02-S-Q-LC
  • 1+136.299061+17.66696
库存:126
