DF17(1.0H)-80DP-0.5V(57) 数据手册
0.5mm Pitch Board to Board Connector
Oct.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
DF17 Series
Solution of Connector
Damage
Caused when Mobile
Phone is Dropped
■Features
1. Withstands Drop Impact or Shock
・All 4 sides covered by box design
・Bellows contacts strong against vibration
・Convex on receptacle increases strength enhance
shock-proof, pinch-proof and scoop-proof performance.
(Fig.1)(Fig.2)
2. With Metal Fitting available
In order to grade up the strength against the mechanical
stress, the metal fitting specification is also available.
3. Wide Variety of No. of Positions
Fig.1
The connectors are lined up per 10 contacts from 20 to
80 pos. to take countermeasures for multi-signalization.
4. Stacking Height 4 to 8mm
The stacking height can be selected (per milimeter)
between 4mm and 8mm in combination of the receptacle
with the header.
Fig.2
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2021.12
1
DF17 Series●0.5mm Pitch Board to Board Connector
DF17#(□)-*DS-0.5V
Receptacle
3.0
4.0
Receptacle DF17(3.0H)-*DS-0.5V
Header
Header
DF17(1.0H)-*DP-0.5V
4mm
2.0
5mm
6mm
5.5mm
6.5mm
7mm
8mm
2.5
DF17#(□)-*DP-0.5V
4.0
■Applications
Mobile phones, LCD, miniature equipment and so on
2
Note : The stacking height doesn't
include the solder paste thickness.
■Product Specifications
Rating
Current rating
Voltage rating
0.3A
50V AC
Items
Operating Temperature Range -35 to 85ç (Note 1) Storage Temperature Range -10 to 60ç (Note 2)
40 to 80%
40 to 70%
Operating Humidity Range
Storage Humidity Range
Specifications
Conditions
1. Insulation Resistance 500MΩ min.
2. Withstanding voltage No flashover or insulation breakdown.
3. Contact Resistance 60mΩ max.
100V DC
150V AC/1 minute
100mA
Frequency : 10 to 55 Hz, single amplitude of
0.75mm, 2 hours in each of the 3 directions.
4. Vibration
No electrical discontinuity of 1μs or more
5. Humidity (Steady state)
Contact resistance : 60mΩ max.
Insulation resistance : 250MΩ min.
96 hours at temperature of 40ç and humidity of
90% to 95%
6. Temperature Cycle
Insulation resistance : 500MΩ min.
(-55ç : 30 minutes 5 to 35ç : 10 minutes 85ç :
30 minutes 5 to 35ç : 10 minutes) 5 cycles
7. Durability (Mating/un-mating) Contact resistance : 60mΩ
8. Resistance to
Soldering heat
50 cycles
Reflow : At the recommended temperature profile
Manual soldering : 350ç for 3 seconds
No deformation of components affecting
performance.
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating
Temperature Range and Humidity range covers non conducting condition of installed connectors in storage,
shipment or during transportation.
Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and
specifications for a specific part number shown.
■Materials / Finish
Product
Receptacle
Header
Part
Material
Finish
Remarks
Insulator
Polyamide
White
UL94V-0
Contact
Phosphor copper
Gold plated (Note 1)
Solder tab
Phosphor copper
Tin-lead plated
Insulator
Polyamide
White
UL94V-0
Contact
Phosphor copper
Gold plated (Note 2)
Solder tab
Phosphor copper
Tin-lead plated
Note1 : DF17(0.3)-*DS-0.5V : Contact area : gold plating/lead area : flash gold plated
DF17(4.0)-*DS-0.5V : Contact area : gold plating/lead area : tin plated
DF17(4.0)-*DP-0.5V : Contact area : gold plating/lead area : tin plated
Note2 : The header gold plated product : Contact area : gold plating/lead area : tin plated
DF17(1.0H)-*DS-0.5V only : Contact area : gold plating/lead area : flash gold plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
●Receptacle/Header
DF17 #
1
2
- * DS - 0.5 V (**)
4
3
1 Series Name : DF17
6
7
8
4 Number of Pos.
2 Type
DF17
DF17B
5
20, 26, 30, 40, 50, 60, 70, 80 contacts
Solder tab
K
K
Boss
K
5 Connector Type
DS : Receptacle
DP : Header
6 Contact Pitch : 0.5mm
7 Contact Style
V : Straight SMT
3 Product height
The stacking height can be determined by adding the
figures in parentheses to receptacle and header.
8 Packaging Type (57) : Gold plated,embossed
tape packaging
3
■Receptacle
A
B
With Solder Tab
C
D
3.9
1.8
5.7
A
4.7
P=0.5
0.2
H
0.7
G
0.2
Ø0.5
1.5
1.9
E
F
● Stacking Height : 4mm
Part No.
HRS No.
Number of Pos.
A
B
C
D
E
F
DF17(3.0H)-26DS-0.5V(57) 683-0253-2 57
26
11.5
08.3
07.0
06.0
08.5
11.3
DF17(3.0H)-30DS-0.5V(57) 683-0268-0 57
30
12.5
09.3
08.0
07.0
09.5
12.3
DF17(3.0H)-60DS-0.5V(57) 683-0361-5 57
60
20.0
16.8
15.5
14.5
17.0
19.8
DF17(3.0H)-70DS-0.5V(57) 683-0393-1 57
70
22.5
19.3
18.0
17.0
19.5
22.3
DF17(3.0H)-80DS-0.5V(57) 683-0369-7 57
80
25.0
21.8
20.5
19.5
22.0
24.8
G
H
RoHS
3.0
3.0
YES
G
H
RoHS
3.5
3.0
YES
G
H
RoHS
4.5
4.0
YES
● Stacking Height : 5mm, 7mm
Part No.
HRS No.
Number of Pos.
A
B
C
D
E
F
DF17(3.0)-20DS-0.5V(57)
683-0002-2 57
020
10.0
06.8
05.5
04.5
07.0
09.8
DF17(3.0)-26DS-0.5V(57)
683-0241-3 57
026
11.5
08.3
07.0
06.0
08.5
11.3
DF17(3.0)-30DS-0.5V(57)
683-0003-5 57
030
12.5
09.3
08.0
07.0
09.5
12.3
DF17(3.0)-40DS-0.5V(57)
683-0004-8 57
040
15.0
11.8
10.5
09.5
12.0
14.8
DF17(3.0)-50DS-0.5V(57)
683-0005-0 57
050
17.5
14.3
13.0
12.0
14.5
17.3
DF17(3.0)-60DS-0.5V(57)
683-0006-3 57
060
20.0
16.8
15.5
14.5
17.0
19.8
DF17(3.0)-70DS-0.5V(57)
683-0007-6 57
070
22.5
19.3
18.0
17.0
19.5
22.3
DF17(3.0)-80DS-0.5V(57)
683-0008-9 57
080
25.0
21.8
20.5
19.5
22.0
24.8
● Stacking Height : 6mm, 8mm
Part No.
HRS No.
Number of Pos.
A
B
C
D
E
F
DF17(4.0)-20DS-0.5V(57)
683-0042-7 57
06.8
05.5
04.5
07.0
09.8
DF17(4.0)-30DS-0.5V(57)
683-0043-0 57
30
12.5
09.3
08.0
07.0
09.5
12.3
DF17(4.0)-40DS-0.5V(57)
683-0044-2 57
40
15.0
11.8
10.5
09.5
12.0
14.8
DF17(4.0)-50DS-0.5V(57)
683-0045-5 57
50
17.5
14.3
13.0
12.0
14.5
17.3
DF17(4.0)-60DS-0.5V(57)
683-0046-8 57
60
20.0
16.8
15.5
14.5
17.0
19.8
DF17(4.0)-70DS-0.5V(57)
683-0047-0 57
70
22.5
19.3
18.0
17.0
19.5
22.3
DF17(4.0)-80DS-0.5V(57)
683-0048-3 57
80
25.0
21.8
20.5
19.5
22.0
24.8
Note 1 : In regard to this product, the embossed tape packaging is the standard packaging. (1000 pcs./ reel.)
Note 2 : If the without boss specification is required, please contact HRS sales department.
4
■ Header
With Solder Tab
A
B
C
D
A
5.7
4.7
3.8
1.8
P=0.5
H
G
0.25
0.2
1.9
E
1.5
0.7
Ø0.5
F
Part No.
HRS No.
Number of Pos.
A
B
C
D
E
F
DF17(1.0H)-26DP-0.5V(57) 683-0257-3 57
26
11.5
08.2
07.1
06.0
08.5
11.3
DF17(1.0H)-30DP-0.5V(57) 683-0272-7 57
30
12.5
09.2
08.1
07.0
09.5
12.3
DF17(1.0H)-60DP-0.5V(57) 683-0365-6 57
60
20.0
16.7
15.6
14.5
17.0
19.8
DF17(1.0H)-70DP-0.5V(57) 683-0397-2 57
70
22.5
19.2
18.1
17.0
19.5
22.3
DF17(1.0H)-80DP-0.5V(57) 683-0373-4 57
80
25.0
21.7
20.6
19.5
22.0
24.8
G
H
RoHS
3.3
1.0
YES
G
H
RoHS
4.3
2.0
YES
G
H
RoHS
6.3
4.0
YES
G
H
RoHS
4.8
2.5
YES
● Stacking Height : 5mm, 6mm
Part No.
HRS No.
Number of Pos.
A
B
C
D
E
F
DF17(2.0)-20DP-0.5V(57)
683-0082-1 57
020
10.0
06.7
05.6
04.5
07.0
09.8
DF17(2.0)-30DP-0.5V(57)
683-0083-4 57
030
12.5
09.2
08.1
07.0
09.5
12.3
DF17(2.0)-40DP-0.5V(57)
683-0084-7 57
040
15.0
11.7
10.6
09.5
12.0
14.8
DF17(2.0)-50DP-0.5V(57)
683-0085-0 57
050
17.5
14.2
13.1
12.0
14.5
17.3
DF17(2.0)-60DP-0.5V(57)
683-0086-2 57
060
20.0
16.7
15.6
14.5
17.0
19.8
DF17(2.0)-70DP-0.5V(57)
683-0087-5 57
070
22.5
19.2
18.1
17.0
19.5
22.3
DF17(2.0)-80DP-0.5V(57)
683-0088-8 57
080
25.0
21.7
20.6
19.5
22.0
24.8
● Stacking Height : 7mm, 8mm
Part No.
HRS No.
Number of Pos.
A
B
C
D
E
F
DF17(4.0)-20DP-0.5V(57)
683-0122-4 57
06.7
05.6
04.5
07.0
09.8
DF17(4.0)-30DP-0.5V(57)
683-0123-7 57
30
12.5
09.2
08.1
07.0
09.5
12.3
DF17(4.0)-40DP-0.5V(57)
683-0124-0 57
40
15.0
11.7
10.6
09.5
12.0
14.8
DF17(4.0)-50DP-0.5V(57)
683-0125-2 57
50
17.5
14.2
13.1
12.0
14.5
17.3
DF17(4.0)-60DP-0.5V(57)
683-0126-5 57
60
20.0
16.7
15.6
14.5
17.0
19.8
DF17(4.0)-70DP-0.5V(57)
683-0127-8 57
70
22.5
19.2
18.1
17.0
19.5
22.3
DF17(4.0)-80DP-0.5V(57)
683-0128-0 57
80
25.0
21.7
20.6
19.5
22.0
24.8
● Stacking Height : 5.5mm,6.5mm
Part No.
HRS No.
Number of Pos.
A
B
C
D
E
F
DF17(2.5)-26DP-0.5V(57)
683-0245-4 57
26
11.5
08.2
07.1
06.0
08.5
11.3
DF17(2.5)-80DP-0.5V(57)
683-0168-5 57
80
25.0
21.7
20.6
19.5
22.0
24.8
Note 1 : In regard to this product, the embossed tape packaging is the standard packaging. (1000 pcs./reel.)
5
■PCB Mounting Pattern
●Receptacle
●Header
J+0.1
K -0.1
D±0.03
1.9±0.02
S -0.05
6.3 +0.1
P= 0.5±0.02
.05
+00
.6
Ø0
0.25±0.02
E±0.03
Number of Pos.
020
D
04.5
E
07.0
J
10.4
K
07.6
S
Receptacle
4.3
026
06.0
08.5
11.9
9.1
Header
4.0
030
07.0
09.5
12.9
10.1
040
09.5
12.0
15.4
12.6
050
12.0
14.5
17.9
15.1
060
14.5
17.0
20.4
17.6
070
17.0
19.5
22.9
20.1
080
19.5
22.0
25.4
22.6
Note 1 :
* The recommended solder paste
thickness is 150µm.
If the pattern is included in the shaded area, and not
treated with resist, it could touch the connector contact.
Note 2 : If the boss isn't included, the boss hole shown in the above figure
isn't required.
6
■Packaging Specification
2±0.1
.1
+00
.5
Ø1
12±0.1
4±0.1
Y−Y
N±0.3
M±0.1
L±0.1
Y
1.75±0.1
●Embossed Carrier Tape Dimensions
■Receptacle
R0
5
.7
0.2±0.05
R0
.75
+0
0 .1
5
15
0.
+ 0
Y
Unreeling direction
0.3±0.1
X−X
Connector
L
P±0.15
M
P
Q
R
Connector
L
M
N
P
Q
R
DF17#(3.0)-20DS-0.5V 11.5
24
3.8
25.5
330
DF17#(3.0)-50DS-0.5V 14.2
28.4
32
3.8
33.5
330
DF17#(3.0)-30DS-0.5V 11.5
24
3.8
25.5
330
DF17#(3.0)-60DS-0.5V 14.2
28.4
32
3.8
33.5
330
DF17#(3.0)-40DS-0.5V 11.5
24
3.8
25.5
330
DF17#(3.0)-70DS-0.5V 20.2
40.4
44
3.8
45.5
330
DF17#(3.0)-26DS-0.5V 11.5
24
3.8
25.5
330
DF17#(3.0)-80DS-0.5V 20.2
40.4
44
3.8
45.5
330
N
P
Q
R
M
N
P
Q
R
DF17#(4.0)-20DS-0.5V 11.5
Connector
L
24
4.8
25.5
330
DF17#(4.0)-50DS-0.5V 14.2
Connector
L
28.4
32
4.8
33.5
330
DF17#(4.0)-30DS-0.5V 11.5
24
4.8
25.5
330
DF17#(4.0)-60DS-0.5V 14.2
28.4
32
4.8
33.5
330
DF17#(4.0)-40DS-0.5V 11.5
24
4.8
25.5
330
DF17#(4.0)-70DS-0.5V 20.2
40.4
44
4.8
45.5
330
DF17#(4.0)-80DS-0.5V 20.2
40.4
44
4.8
45.5
330
Connector
L
M
N
P
Q
R
24
3.3
25.5
330
24
3.3
25.5
330
28.4
32
3.3
33.5
330
40.4
44
3.3
45.5
330
40.4
44
3.3
45.5
330
.2
●Reel Dimensions
Ø1
3±
Ø1.5 Lead hole depth
ØR±2
X
X
Q±0.5
(Q+4)±1
7
2±0.1
4±0.1
.1
+00
.5
Ø1
12±0.1
1.75±0.1
■Header
Y−Y
N±0.3
M±0.1
L±0.1
Y
R0
5
.7
+0
0 .15
.75
R0
0.2±0.05
15
0.
+ 0
X
X
Unreeling direction
Connector
Y
0.3±0.1
P±0.15
X−X
N
P
Q
R
DF17#(2.0)-20DP-0.5V 11.5
24
4.6
25.5
330
DF17#(2.0)-30DP-0.5V 11.5
24
4.6
25.5
330
DF17#(2.0)-40DP-0.5V 11.5
24
4.6
25.5
DF17#(2.5)-26DP-0.5V 11.5
24
5.1
25.5
DF17#(2.5)-80DP-0.5V 20.2
44
5.1
45.5
330
N
P
Q
R
DF17#(4.0)-20DP-0.5V 11.5
24
6.6
25.5
380
DF17#(4.0)-30DP-0.5V 11.5
24
6.6
25.5
380
DF17#(4.0)-40DP-0.5V 11.5
24
6.6
25.5
380
Connector
L
L
Connector
L
M
N
P
Q
R
DF17#(2.0)-50DP-0.5V 14.2
28.4
32
4.6
33.5
330
DF17#(2.0)-60DP-0.5V 14.2
28.4
32
4.6
33.5
330
330
DF17#(2.0)-70DP-0.5V 20.2
40.4
44
4.6
45.5
330
330
DF17#(2.0)-80DP-0.5V 20.2
40.4
44
4.6
45.5
330
M
N
P
Q
R
DF17#(4.0)-50DP-0.5V 14.2
28.4
32
6.6
33.5
380
DF17#(4.0)-60DP-0.5V 14.2
28.4
32
6.6
33.5
380
DF17#(4.0)-70DP-0.5V 20.2
40.4
44
6.6
45.5
380
DF17#(4.0)-80DP-0.5V 20.2
40.4
44
6.6
45.5
380
M
N
P
Q
R
DF17(1.0H)-26DP-0.5V 11.5
24
3.6
25.5
330
DF17(1.0H)-30DP-0.5V 11.5
24
3.6
25.5
330
DF17(1.0H)-60DP-0.5V 14.2
28.4
32
3.6
33.5
330
DF17(1.0H)-70DP-0.5V 20.2
40.4
44
3.6
45.5
330
DF17(1.0H)-80DP-0.5V 20.2
40.4
44
3.6
45.5
330
Connector
L
Connector
L
Ø1
3±
0.2
●Reel Dimensions
ØR±2
Q±0.5
8
(Q+4)±1
■Precautions
Temperature (ç)
250ç
250
220ç
200
180ç
150
1. Recommended
150ç
90~120sec
Preheating
100
Temperature Profile
(SMT)
60sec max
Soldering
50
Room temperature
100
150
200
250
300
Time (sec.)
Note1 : Up to 2 cycles of Reflow soldering are possible under the same conditions, provided that
there is a return to normal temperature between the first and second cycle.
Note2 : The temperature profile indicates the board surface temperature at the point of contacts
with the connector terminals.
2. Recommended Manual
Soldering Condition
Soldering iron temperature: 350±3çoldering time: Within 2 seconds
(SMT)
3. Recommended
Screen Thickness
0.15mm
(SMT)
4. Board Warp(SMT)
Max 0.02mm in the connector center area, based on the both connector edges
5. Cleaning Condition
Refer to the "Nylon Connector Use Hand book".
■ The header is designed in a structure where contacts are exposed. Touching it with bare
hands would cause contact failure or electrostatic element damage.
■ Where no board is mounted, the insertion or extraction will cause damage or contact deformation.
6. Cautions
■ Avoid retaining the board with the connector only, and fix the board by any other means than the connector.
■ Excessive scoop insertion or extraction may result in damage.
■ In the manual soldering process, don't carry out the flux coating which will cause a flux blister on the connector.
■ The color phase of this product may be slightly different from that of the formed product
according to the manufacturing lot. However, the difference doesn't affect the performance.
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
https://www.hirose.com/
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 12/2021. Contents are subject to change without notice for the purpose of improvements.
9
