MSACONNECTOR
Wire-to-wire
Features
●16 and 20 circuits, Wire-to-Wire Connection
●Connector Position Assurance (CPA) Design
●Unsealed Inline Connector
●1.2 mm Terminal Compliant with USCAR Standards
1.2 mm unsealed wire-to-wire connector system for
automotive applications.
1
10
Specifications
●Current rating: 14 A AC, DC max.
(0.75 mm2, Single circuit)
19 A AC, DC max. (1.5 mm2, Single circuit)
●Withstanding voltage:1,000 VAC/minute
●Temperature range: - 40°C to +105°C (Sn plating)
- 40°
C to +125°
C (Ag plating)
(including temperature rise in applying
electrical current)
●Contact resistance: Initial value/ 8 mΩ max.
After environmental tests/ 8 mΩ max.
●Insulation resistance: 100 MΩ min.
mm2
●Applicable wire: FLRY-A 0.35 to 1.5
FLRY-B
0.75 mm2
FLR2X-A
0.35 to 1.5 mm2
* Compliant with ELV/RoHS2.
* Contact JST for details.
1
MSA CONNECTOR
Female terminal
Applicable wire range
SSS/SS barrel
Size
15
1.83
7.3
Model No.
Conductor
(mm2)
Insulation O.D. Q˖ty/reel
(mm)
SSS
ΖSMSA-A001T-M1.2
0.13
0.95 to 1.05
9,000
SS
ΖSMSA-A011T-M1.2
0.35
1.2 to 1.4
9,000
S
ΖSMSA-A031T-M1.2
0.5 to 0.75
1.6 to 1.9
8,500
M
ΖSMSA-A041T-M1.2
1.0 to 1.5
2.1 to 2.4
6,000
SSS
ΗSMSA-A001A-M1.2
0.13
0.95 to 1.05
9,000
SS
ΗSMSA-A011A-M1.2
0.35
1.2 to 1.4
9,000
S
ΗSMSA-A031A-M1.2
0.5 to 0.75
1.6 to 1.9
8,500
M
ΗSMSA-A041A-M1.2
1.0 to 1.5
2.1 to 2.4
6,000
Material and Finish
S/M barrel
ΖCopper alloy, tin-plated (reflow treatment)
ΗCopper alloy, nickel-undercoated, Contact area: silver-plated
Barrel area: tin-plated
16
1.83
7.3
Female connector
●16 circuits
Circuits
22
16
Model No.
16MSA-RBC-1A-A-K
16MSA-RBC-1A-B-H
20MSA-RBC-1A-A-K
Housing
Color
Q˖ty/box
Black
441
Gray
441
Black
378
Material and Finish
Housing: PBT
Retainer: Glass-filled PBT, Natural (White)
CPA: Glass-filled PBT, Natural (White)
Note: Color/Key codes other than above-mentioned housing are also available.
23.5
CPA
15.7
19.3
Housing
Retainer
(28.1)
22
●20 circuits
28
CPA
15.7
19.3
Housing
Retainer
2
MSA CONNECTOR
Male terminal
SSS/SS barrel
(7.8)
8
(24.5)
Size
Model No.
Conductor
(mm2)
(mm)
SSS
ΖSMSAW-A001T-M1.2
0.13
0.95 to 1.05
10,000
SS
ΖSMSAW-A011T-M1.2
0.35
1.2 to 1.4
9,000
S
ΖSMSAW-A031T-M1.2
0.5 to 0.75
1.6 to 1.9
9,000
M
ΖSMSAW-A041T-M1.2
1.0 to 1.5
2.1 to 2.4
6,500
SSS
ΗSMSAW-A001A-M1.2
0.13
0.95 to 1.05
10,000
SS
ΗSMSAW-A011A-M1.2
0.35
1.2 to 1.4
9,000
S
ΗSMSAW-A031A-M1.2
0.5 to 0.75
1.6 to 1.9
9,000
M
ΗSMSAW-A041A-M1.2
1.0 to 1.5
2.1 to 2.4
6,500
Material and Finish
S/M barrel
(8.8)
8
(25.5)
Male connector
●16 circuits
Circuits
16
41.2
Model No.
16MSA-PB-1A-A-K
16MSA-PB-1A-B-H
20MSA-PB-1A-A-K
Housing
Color
Q˖ty/box
Black
252
Gray
252
Black
216
Material and Finish
Housing: PBT
26.7
8
9
16
22.6
1
18.9
Housing
Retainer
41.2
●20 circuits
31.2
10
1
11
18.9
Housing
Retainer
3
MSA CONNECTOR
Assembly layout
●16, 20 circuits
(23.1)
(46.9)
Clip layout
9.7
8.5
14
0.7
1.4
+0.1
+0.1
7.3
Recommended clip layout
Note: Contact JST for details.
Crimping machine, Applicator
Strip terminal
SMSA-A001( )-M1.2
SMSA-A011( )-M1.2
SMSA-A031( )-M1.2
SMSA-A041( )-M1.2
SMSAW-A001( )-M1.2
SMSAW-A011( )-M1.2
SMSAW-A031( )-M1.2
SMSAW-A041( )-M1.2
Crimping
machine
AP-K2N
Crimp applicator MKS-L
Dies
Crimp applicator with dies
MK/SMSA-A001-12
APLMK SMSA-A001-12
MK/SMSA-A011-12
APLMK SMSA-A011-12
MK/SMSA-A031-12
APLMK SMSA-A031-12
MK/SMSA-A041-12
APLMK SMSA-A041-12
MK/SMSAW-A001-12
APLMK SMSAW-A001-12
MK/SMSAW-A011-12
APLMK SMSAW-A011-12
MK/SMSAW-A031-12
APLMK SMSAW-A031-12
MK/SMSAW-A041-12
APLMK SMSAW-A041-12
Note: 1. Contact JST for details.
2. When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal.
4
很抱歉,暂时无法提供与“SMSA-A031T-M1.2”相匹配的价格&库存,您可以联系我们找货
