0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors
FX16 Series
Supports next generation high-speed transmission
Oct.1.2021 Copyright 2021 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Fig.1
V-by-One® HS compatible connector
(mv)
+200
Eye Diagram
(3.75Gbps)
+100
"V-by-One HS" is a trade mark of Thine Electronics, Inc.
Features
-200
【Shielded FFC 300mm hamess】
1.Supports next-generation high speed
transmissions
FX16 Series supports next-generation high-speed
signals including signal transmission of up to
6Gbps. The FX16 series delivers exceptional
impedance-matching, even at sharp signal rise
times of Tr=50ps (10 - 90%). (Fig.1)
2. V-by-One® HS compatible connector
The FX16 Series connector is recommended by
Thine Electronics, Inc. for their V-By-One® HS nextgeneration panel interface, due to the connector’s
outstanding signal integrity performance at 3.75Gb/
s - the top data rate of the interface. As shown in
Fig.2 on the right, the eye pattern remains wide
open at 3.75Gbps. (Please refer to the transmission
property data shown on Page 4.)
Fig.2
Simplified FFC harness assembly with a flip-lock system
①Insert the FFC into the plug
[Patented]
Direct plug-in
style plug
FFC
3. A patented flip-lock harness simplifies
FFC applications.
We have incorporated our proprietary patented fliplock design that greatly simplifies FFC assembly by
eliminating the need for costly cable soldering
(Fig.3).
wClose the flip-lock
eCompleted mating sequence
Fig.3
4. Vertical cable plug
The vertical plug mating style simplifies the
assembly process. In addition, it offers a lower
profile by limiting the mated height to only 8mm
(Fig.4).
Vertical mating,
horizontal wiring
5. Multiple variations of plug style, cable
type and number of positions available
The series features a common plug for shielded FFC
and micro coaxial cable. Available plug variations
include right-angle, vertical style for batch harness
assembly and direct plugin styles. Multiple position
sizes are available (please see page 5 for variations).
6. RoHS compliant
All materials and substances used to produce
these parts fully comply with RoHS standards.
Easy operation with the use
of a side lock
Vertical style plug
Vertical mating
8mm
Vertical style receptacle
Designed for low mated height
Fig.4
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2018.2③
1
FX16 Series●0.5mm pitch, Next Generation High Speed Wire-to-Board Connectors
Product Specifications
Current Rating 0.5A
Ratings
Storage Temperature Range : -10 to 60℃ (Note 3)
Items
1.Contact resistance
2.Insulation
resistance
3.Withstand voltage
4.Overall push-pull
force
5.Durability
6. Vibration
Voltage Rating AC60V
Operating Temperature Range : -55 to 85℃ (Note 1) (Note 2) Operating Humidity Range : relative humidity of no more than 85% (Note 2) (Note 4)
Operating Humidity Range : relative humidity of no more than 70% (Note 3) (Note 4)
Specifications
Conditions
80mø max (Note 5)
Measured at 1mA
500Mø minimum
Measured at DC 100V
No flashover or breakdown
Inserting force (0.5 × number of pos.) : no more than 1N
Extracting force (0.05 × number of pos.) : no less than 1N
Contact resistance : variation from the initial state : no
more than 20mø
AC 200V is applied for 1 minute
Measured by using applicable connectors
50 mating cycles
Frequency 10 - 55Hz, half amplitude 0.75mm,
2 hours for 3 axial directions
Accelerated velocity : 490m/s2, for 11ms,
half-sine in 3 directions, 3 times for each of
No electrical discontinuity of 1µ or greater
the three directions (axes)
Contact resistance : variation from the initial state : 20mø max 96 hours at 40ç temperature and the
Insulation resistance : minimum of 500Mø
humidity range from 90 to 95%
Temperature : -55 → 5 to 35 → 85 → 5 to 35ç
5 cycles of the testing time period of
Insulation resistance : 500Mø min
30 → 5 → 30 → 5 minutes
7.Shock
8. Humidity
resistance
9. Temperature
cycles
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The operating temperature range when the operating humidity is above 80% shall be -55 to 40ç.
Note 3 : The term “storage” refers to the long-term storage condition of unused products before PCB mounting.
Note 4 : No condensation allowed.
Note 5 : The conductor resistance of connected cables is not included.
Materials / Finish
Receptacle
Part
Insulator
Contact
Shell
Materials
FX16 : LCP resin
FX16M2 : Polyamide resin
Copper alloy
Copper alloy
Finish
Remarks
Black color
UL94V-0
Gold plating
Pure tin-plating
Plug
Part
Insulator
Contact
(FX16-SD/SDL only)
Shell
Materials
FX16-SD/SDL : Polyamide resin
: PC resin
FX16F-HC
FX16M2-HC : PBT resin
Finish
FX16-SD/SDL : Beige color
: Black color
FX16F-HC
FX16M2-HC : Black color
Contact interface area : gold plating
Copper alloy
Termination area : pure tin-plating
FX16-SD/SDL : Stainless steel FX16-SD/SDL : Nickel plating
: Stainless steel FX16F-HC
: Nickel plating
FX16F-HC
FX16M2-HC : Copper alloy
FX16M2-HC : Pure tin-plating
Remarks
UL94V-0
Accessories
Part
Cover shell
2
Materials
Stainless steel
Finish
Remarks
Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
Receptacle
FX 16 M2 - 51 S - 0.5 SH (**)
Plug
FX 16 M2 - 51 P - HC
Accessories (Cover shell)
FX 16 - 31 P - GND
Series Name
Series No.
Shape designation
Number of positions
Contact type
Contact pitch
Product type
(Receptacle)
Product type(Plug)
Product type
(Accessories)
Packaging
: FX
: 16
None/F/M2 : Hirose control identification code
S
P
0.5
None
SH
SV
SD
: female contact
: male contact
: 0.5mm pitch
: No contact
: right-angle type
: vertical type
: Right-angle batch cable assembly type
(Micro coaxial cable)
SDL : Vertical batch cable assembly type
HC
: FFC holder type
GND : Right-angle type cover for micro coaxial cables
GNDL : Vertical type cover for micro coaxial cables
None : embossed tape package (1,000pcs/reel)
(30)
: embossed tape package (100pcs/reel)
3
Transmission properties
Differential impedance [Rise time: Tr=100ps]
A differential impedance of 100ø ±10% is maintained at signal rise time of 100ps. (※Notes), This specification is met by way
of an impedance-matching design based on SI simulation.
(ø)
120
PCB+SMA
FX16
Cable
(ø)
120
110
110
100
100
PCB+SMA
FX16
Cable
90
90
93.6ø
80
[Micro coax cable harness product]
95.2ø
80
[Shielded FFC type harness product]
Eye diagram
The FX16 Series connector shows outstanding performance at 3.75Gbps, the maximum speed of V-By-One® HS developed
by Thine Electronics, Inc.
Testing with actual V-by-One® HS signals shows that the eye pattern is wide open at these signal speeds. (※Notes)
* V-by-One® HS is a trade mark of Thine Electronics, Inc.
Eye Mask
Eye Mask
[Micro coax cable harness 500mm product]
[Shielded FFC type harness 500mm product]
*Note) Results may vary depending on the length and properties of the cables used.
4
Diagram of FX16 Series variations and mating table
Receptacle
Plug
Additional Components
Cable Assemblies
(FX16**-P-0.5SD)
Ground Plate for micro coax cables
(FX16**-P-GND)
Micro coax cable assembly
Right-angle type
(FX16-**S-0.5SH)
FFC cable Assembly
Vertical type
(FX16-**S-0.5SV)
FFC holder type
(FX16**-P-HC)
(FX16**-P-0.5SDL)
Right-angle type
(FX16M2-**S-0.5SH)
FFC holder type assembly
Ground plate for micro coax cables
(FX16**-P-GNDL)
FFC batch assembly type
FFC holder type
(FX16M2**P-HC)
Vertical type
(FX16M2-**S-0.5SV)
5
FX16 Series mating dimensions (Reference dimensions)
Plug
Right-angle, PCB mount type
(FX16-**S-0.5SH)
Right-angle type micro coaxial cable harness
(FX16**P-SD)
Mated condition
(14.85)
(9.95)
(14.6)
Receptacle
Vertical, PCB mount type
(FX16-**S-0.5SV)
Holder FFC type assembly
(FX16**-P-HC)
(10.2)
(8)
Vertical type micro coaxial cable harness
(FX16**-P-SDL)
(FX16M2-**S-0.5SH)
(FX16M2-**S-0.5SV)
(FX16M2-**-P-HC)
(16.5)
(16.75)
(Unit : mm)
6
Receptacle
0.
25±0.
15 5.
55±0.
2
4.
8±0.
2
2.1±0.2
1.
5±0.
1
Right-angle type (FX16-**S-0.5SH)
A±0.
3
B±0.
2
C±0.
15
P=0.5±0.1
n-0.18±0.05
No.1
Polarity mark
No.n
1.
5±0.
1
Product lot No.
4.
4±0.
3
P=E±0.1 D±0.
2 4-0.5±0.1
F±0.
2
G±0.
3
H±0.
15
P=0.
5±0.1
(1.
05) (0.
6)
A±0.3
B±0.2
C±0.15
No.1
P=0.5±0.1
Signal contact:
(0.
5)
Shell:
(0.
7)
(5.
8)
No.n
n-0.18±0.05
1.5±0.1
0.25±0.15
5.55±0.2
4.8±0.2
2.1±0.2
1.5±0.1
Right-angle type (FX16M2-**S-0.5SH)
Polarity mark
P=E±0.1
Product lot No.
6-0.5±0.1
F±0.2
G±0.3
H±0.15
4.4±0.3
P=0.5±0.1
(1.05)
Signal contact:(0.5)
(1.05)
(0.6)
Shell:(0.7)
(5.8)
Recommended PCB layout (Metal mask dimension)
No.
1
No.
n
B±0.
05
C±0.
05
3.
5±0.
05 1.
55±0.
05
Notes:
1 The co-planarity of the contact and shell of this
product is 0.1mm max.
2 Insulation measures such as the pattern prohibited
area or resist processing are required in the area
identified by inside the land pattern.
3 ( ) is a reference dimension.
4 During the manufacturing process, products may
incur some minor cosmetic damage (dents/
scratches), but this will not affect their performance.
5 This product is delivered in an embossed reel
packaging; the packaged quantity for one reel is
2.
05±0.
05
1,000 pieces for standard articles (00) and 100
2
Pattern prohibited area
pieces for the specification of (30).
2.
5±0.
05
5.
1±0.
05
P=0.
5±0.
03
n−0.
25±0.
03(Land pattern)
n−0.
22±0.
03(Metal mask)
K−1.
3±0.
05
D±0.
05 P=E±0.
05
F±0.
05
J±0.
05
2.
5±0.
05
1.
55±0.
05
(1.
05)
Unit : mm
Part No.
HRS No.
No. of
Contacts
A
B C
(n)
21
22.85 16 10
D
E
4
----- 10 20.46 10 19.75
FX16-21S-0.5SH(**)
FX16-31S-0.5SH(**)
575-3411-5 **
575-3412-8 **
31
27.85 21 15 -----
FX16M2-41S-0.5SH(**)
FX16M2-51S-0.5SH(**)
575-3003-9 **
575-3004-1 **
41
51
32.85 26 20 ----37.85 31 25 -----
4
5
F
G
H
J
12 25.46 15 24.75
20 30.46 20 29.75
25 35.46 25 34.75
K RoHS
4
6
(00) : Embossed package (1,000pcs/reel), (30) : Embossed package (100pcs/reel)
7
Vertical type (FX16-**S-0.5SV)
Polarity mark
A±0.
3
B±0.
2
P=0.
5±0.
1
n-0.
18±0.
05
No.1
No.n
1.
5±0.
1
A
4-0.5±0.1
C±0.
2
E±0.
2
F±0.
2
Lot No.
5.
3±0.
3
4.
2±0.
2
Signal contact:(0.7)
Shell:
(0.5)
5.
5±0.
3
Vertical type (FX16M2-**S-0.5SV)
A±0.3
No.1
B±0.2
P=0.5±0.1
n-0.18±0.05
Polarity mark (side face) Lot No. (side face)
No.n
1.5±0.1
A
P=D±0.1
E±0.2
F±0.2
6-0.5±0.1
5.3±0.3
4.7±0.2
Signal contact:
(0.7)
Shell:
(0.5)
5.5±0.3
1.
55±0.
05 3.
5±0.
05 1.
55±0.
05
No.
n
F±0.
05
No.
1
2.
5±0.
05
B±0.
05
n-0.25±0.03(Land pattern)
n-0.22±0.03(Metal mask)
P=0.
5±0.
03
2
05
P=D±0.
05 C±0.
Pattern prohibition area
2.
5±0.
05
G−1.
3±0.
05
E±0.
05
F±0.
05
Notes :
1 The co-planarity of the contact and shell should
measure no more than 0.1 (mm).
prohibited area or resist processing are
required in the area identified by
may incur some minor cosmetic damage
(dents/scratches), but this will not affect their
performance.
package; the packaged quantity in one reel is
Unit : mm
Part No.
HRS No.
No. of
Contacts
A
(n)
21
20.46
B
C
D
FX16-21S-0.5SV(**)
575-3401-1 **
10
4
FX16-31S-0.5SV(**)
575-3402-4 **
31
25.46
15
FX16M2-41S-0.5SV(**)
575-3002-6 **
41
30.46
8
4
E
F
10
16
12
21
G
4
6
RoHS
Emboss carrier dimensions (receptacles only)
Horizontal type (FX16-**S-0.5SH / FX16M2-**S-0.5SH)
FX16-21S-0.5SH(**)
FX16-31S-0.5SH(**)
575-3411-5 **
No. of
Contacts
(n)
21
575-3412-8 **
31
575-3003-9 **
41
575-3004-1 **
51
Part No.
HRS No.
Unit : mm
A
B
C
D
44
40.4
20.2
56
52.4
26.2
W
23.76
28.76
33.76
38.76
44.5
56.5
P=4±0.
1
(6.
7)
(0.
5)
Reel Dimensions
+0.
15
1.
7 0
0.
1
1.
5+
6)(W)
φ380±2
φ80±2
(D)
C±0.
1
B±0.
1
A±0.
3
2±0.
15
(3.
65)
(8.
4)
Note 1 : (
) shows a reference dimension.
Vertical type (FX16-**S-0.5SV / FX16M2-**S-0.5SV)
FX16-21S-0.5SV(**)
FX16-31S-0.5SV(**)
575-3401-1 **
No. of
Contacts (n)
21
575-3402-4 **
31
575-3002-6 **
41
Part No.
HRS No.
Unit : mm
A
B
C
D
44
40.4
20.2
E
20.57
6.9
25.57
30.57
W
44.5
7
P=4±0.1
Reel Dimensions
φ1
3±
0.5
(0.5)
8
0.
(1.
6)(W)
21
φ380±2
φ80±2
A±0.3
B±0.1
φ
(10)
2±0.15
(E)
C±0.1
P=12±0.1
(D)
φ1
5
. +0
0 .
1
Unreeling direction
1.7
φ1
5 +0
P=12±0.
1
φ1
3
φ2 ±0.
5
1
0 .
1
Unreeling direction
+0.1
1.5 0
(7)
(5)
Note 1 : (
9
Recommended Temperature Profile
This temperature profile is a reference based on the following conditions. Since your actual conditions may vary, please
check your process before mounting the connectors.
(Peak temperature : MAX250ç)
250
230
230℃
180℃
Connector surface temperature(ç)
180
150
(Applicable Conditions)
Test PCB Dimensions : 40×30×1(mm)
Reflow method Material : glass epoxy
Solder Composition
: Sn-3 Ag-0.5 Cn
(flux component : 10.5wt%)
Metal mask thickness : 0.12mm
150℃
Note 1 : This temperature profile is a
recommended value.
Note 2 : The reflow process should not be
conducted more than two times.
Note 3 : The values may show a slight variance
due to solder paste type and thickness.
100
25
30 ±10
seconds
90 ±30 seconds
Pre-heating time(150~180ç)
Time (sec)
Soldering time
(minimum of 230°C)
Cleaning Conditions
Cleaning with organic solvents
Solvent
IPA (Isopropyl alcohol)
Clean at normal
temperature
Heated cleaning
Water cleaning
If wet cleaning is necessary, please select the proper cleaning agent (terpene, alkali saponification agent etc.) based on the
reaction it will have on the metals and resins of the connector. This information is issued by the manufacturer of the
cleaning agent. Additionally, please make sure not to apply an excessive amount of the cleaning agent.
Points to note during cleaning
When using organic solvents or wet cleaning agents, please ensure proper rinsing is done to eliminate the possibility of
deterioration in electrical performance caused by flux or cleaning agents remaining in the connector.
10
Plug
Part No.
FX16-21P-0.5SD
FX16-31P-0.5SD
HRS No.
575-3301-7
575-3302-0
Unit : mm
No. of
Contacts (n)
21
31
A
B
C
D
RoHS
21.9
26.9
19.6
24.6
17.57
22.57
10
15
No.
n
No.
1
(1.
6)
(5.
15)
(7.
6)
(10.
9)
(13.
3)
9.
25±0.
3
2.
8±0.
1
P=0.
5±0.
08
D±0.
1
(E)
(F)
3.
5±0.
3
Notes :
1. ( ) shows a reference dimension.
2. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches) or black spots in the
resin, but these small imperfections will not affect their performance.
3. This product is delivered in a tray package.
Right-angle-type cover shell for micro axial cables
FX16-21P-GND
575-3311-0
No. of
Contacts (n)
21
FX16-31P-GND
575-3312-3
31
Part No.
HRS No.
Unit : mm
A
B
C
19.2
13.2
20.06
24.2
18.2
25.06
RoHS
1
+0.
1
A−
0.
15
1.
55±0.
15
8.
45±0.
15
(A)
B±0.
3
C±0.
15
+0.2
B-0.1
2.
2±0.
15
C±0.
15
Notes :
1. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches), but this will not affect
their performance.
2. This product is delivered packaged on a 2500pcs/reel.
3. This product is an accessory to the separately sold item "Right angle batch cable connection type plug (FX16-**P-0.5SD)".
Please be sure to use them together.
11
Vertical batch cable connection type
Part No.
FX16-21P-0.5SDL
FX16-31P-0.5SDL
Unit : mm
HRS No.
No. of
Contacts (n)
A
B
C
D
E
F
RoHS
575-3321-4
575-3322-7
21
31
18.07
23.07
13.7
18.7
11.5
16.5
10
15
23.6
28.6
17.57
22.57
A±0.3
(B)
(C)
D±0.1
(8.65)
(4.9)
(1.6)
P=0.5±0.08
No.1
No.n
(E)
2.4±0.3
(9.6)
F±0.15
(6.55)
A±0.3
2.8±0.1
Notes :
Vertical type cover shell for micro coaxial cables
Part No.
FX16-21P-GNDL
FX16-31P-GNDL
No. of
Contacts (n)
21
31
HRS No.
575-3331-8
575-3332-0
Unit : mm
A
B
C
RoHS
20.37
25.37
11.47
16.47
18.17
23.17
1.3±0.15
9±0.15
A±0.2
B±0.2
2.05±0.15
C±0.15
Notes :
their performance.
2. This product is delivered packaged on a 2000pcs/reel.
3. This product is a compliment to the separately sold item "vertical batch cable assembly type plug (FX16-**P-0.5SDL)".
12
Applicable wires
Micro coaxial cables
Applicable conductor size
(core structure)
36 AWG# (7pcs/0.05mm)
38 AWG# (7pcs/0.04mm)
40 AWG# (7pcs/0.03mm)
Insulation diameter
No. of Contacts (n) Applicable connectors
FX16-21P-0.5SD
FX16-21P-0.5SDL
FX16-31P-0.5SD
FX16-31P-0.5SDL
21
Ø0.3~Ø0.5mm
31
A
B
13.1
10
18.1
15
C
4.55
4.3
4.55
4.3
B±0.
15
7
P=0.
5±0.
07
0.
9 MAX
Solder coat
1 MIN
1−0.
1
Marginal cable length
cutting position 3 4
A±0.
2
8 (C)
Selected cable material
3
Internal conductor
Dielectric
0.
6±0.
1
Metal bar
0.
05
5 1+
−0.
2
Recommended micro coaxial cable dimensions
External conductor
6
Jacket
AWG #36, 38, 40 micro axial cables
Notes :
1 ( ) shows a reference dimension.
2 Pulse heat batch soldering is recommended to affix the harness to the connector
3 To prevent any conductor deformation prior to harnessing, please use the cable material immediately after cutting
4 After confirming that the soldered state has no problems, departure from recommended values is permissible
5 Use of out-of-spec dimension cables may hinder the correct attachment to the connector. Additionally, use of excessive force
during cable connection may cause faults such as unsoldered areas and disconnects.
6 The protrusion of the external conductor from the metal bar should be minimized.
7 Apply a solder coat (pre-tinning) on the internal conductor.
8 Shows the position at which the connector should be connected and the cable inserted into the connector when the cable
has been stripped at the recommended length.
If cable is stripped at a different length, the amount of cable insertion will need to be changed as well.
13
FFC holder type (FX16F-**P-HC)
Part No.
FX16F-21P-HC
FX16F-31P-HC
HRS No.
575-3265-5
575-3266-8
Unit : mm
No. of
Contacts (n)
21
31
A
B
C
RoHS
22.4
27.4
17.57
22.57
20.4
25.4
(3.2)(4)
A±0.3
3.7±0.3
2.8±0.1
8.7±0.3
B±0.15
C±0.3
Notes :
2. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches). But this will not affect
their performance. Additionally there may be mold sinks present.
FFC holder type (FX16M2-**P-HC)
Part No.
FX16M2-41P-HC
FX16M2-51P-HC
HRS No.
575-3262-7
575-3263-0
Unit : mm
No. of
Contacts (n)
41
51
A
B
RoHS
35.4
40.4
27.57
32.57
(A)
B±0.15
(6.45)
3.5±0.3
15±0.3
11.2±0.3
1.65±0.2
Notes :
2. During the manufacturing process, products may incur some minor cosmetic damage (dents/scratches), but this will not affect
14
Applicable wires
Completely shielded FFC for holder type
No. of
Contacts (n)
21
31
Unit : mm
A
B
C
D
E
F
FX16F-21P-HC
FX16F-31P-HC
13.2
18.2
12.8
17.8
11.2
16.2
10
15
12.8
17.8
10.7
15.7
Recommended FFC dimensions
+3
(L+14.4)
6.2 +0.1
ax
m
2
R0 max
2
R0.
−0.06
2
0.85 max
max
R0.2 max
2
R0.
(0.7)
E±0.05
5 0.3±0.03
1.4±0.05 1.4±0.05
D±0.05
P=0.5±0.03
C±0.05
A±0.1
◆B±0.05
Enlarged view
(7.2)
1.05
6.05 +
−0.7
Connector cut-off position(Mi
n7.
1mm)
1
6
2
F±0.4
4
3.5±0.5
10.7±1
Enlarged view
Conductor
(gold-plated annealed copper foil) Insulator (polyester)
◆0.
45±0.
03
0.
33±0.
03
◆0.
3±0.
03
(0.
12)
◆3.8
2.3±0.05
Reinforcing film Ground plate (conductive tape)
10
The length of the harness when
the harness is used for both sides.
(7.
2)
FX16F-**P-HC
9
L+3
2)
FX16F-**P-HC
Notes :
1 The plating on the ground plate (tape) must be at least 1.5µm of Sn plating, with the first 1 to 5µm of Ni plating + at least 0.2µ
of Au plating on the pad surface as well as C-2000-equivalent sealing.
2 denotes the shielded area. (both sides are shielded).
3 denotes the area for the ground plate (conductive tape).
4 denotes the area for the reinforcing film.
5 The width of the conductor must be 0.3 ±0.03mm.
6 The ground plate (tape) and shield must overlap each other. This will allow a conductive path to be established through both
ground plates and on both sides.
7 FFC must be made to satisfy the differential impedance value of 100ø ±7%.
8 ( ) denotes the reference dimension and ◆ mark denotes important dimensions.
9 The L dimension is the length of the harness from one end face to the other end face of the connector cable port.
15
No. of
Contacts (n)
41
51
Unit : mm
A
B
C
D
E
F
FX16M2-41P-HC
FX16M2-51P-HC
24.4
29.4
23
28
21.2
26.2
23.5
28.5
20.7
25.7
+3
(L+26.3)
R0.2 MAX
L
+3
R0
(0.7)
0.85 MAX
X
11
+0.5
Connector cut-off position(NIN 13.12mm)
6
2
3
+0.4
1
FX16M2-**P-HC
FX16M2-**P-HC
MA
.2
M
AX
E±0.1
A MAX
+3
(L+26.3) 0
(13.15)
(13.15)
4
.5
.2
C0
2
R0
Enlarged view
Harness lengths and tolerance for
double-ended assemblies
9.1+0.1
◆B±0.05
C±0.05
D±0.05
P=0.5±0.03
5 0.3±0.03
1.5±0.05
1.5±0.05
◆6.5 −00.06
2.5±0.5
F−1
9
Warpage provision
OK
NG
Reinforcing film
4±0.5
(12)
◆0.45±0.03
0.33±0.03
◆0.3±0.03
5 0.035±0.01
1
Conductor
Enlarged view
Reinforcing film
Notes :
1 The plating on the grounding plate (tape) must be at least 1.5µm of Sn plating, with the first 1 to 5µm of Ni plating + at least
0.2µ of Au plating on the pad surface as well as C-2000-equivalent sealing.
7 The manufacturing work should be directed to ensure that the FFC is made to satisfy a differential impedance value of 100ø ±7%.
9 Warpage of the reinforcing film is permitted only in the direction of OK in reference to ▲ ▲ on both sides. However, please
make sure that the film can still be inserted into the connector without any problems.
16
Precautions of use
Plug (Vertical/horizontal batch cable connection type)
[Precautions for soldering]
[1] Recommended soldering iron
Wire solder with flux (lead-free type: Sn-3Au-0.5Cu)
When using micro coax cables……Ø0.15 Length : number of pos. ×0.5mm
Be careful not use an excessive amount of flux, especially when using a wire solder that contains flux. Doing so
may cause the flux to run up to the contact portion which can lead to contact failure.
[2] Prior to fixing the cables to the connector, make sure
that the conductor is placed correctly in the center of
the contact.
Fix the cable at the metal bar guide on the connector.
[3] Before you solder down the cables onto the connector, please check for the following issues :
・Deformation of the conductor
Pitch deviation
・Pitch deviations to the conductor relative to the contact
・Extreme uplift of the conductor tip end
This feature can lead to unsoldered spaces or solder
bridges.
Uplift
[4] Recommended pulse heat conditions
Conditions will vary depending on the length/type of cable used, type of solder, etc…
Please reference the recommended profile conditions when setting up your working conditions.
Pressure on the iron tip
13-17N
Main heating
Y℃
Main heating
Temperature (Y)
Hold time (X)
220℃
275±5℃
2 ±0.5 seconds
Preheating
220℃
Idling
50℃
2s
2s
2s
Xs
Time to apply pressure on the iron tip
[5] Please check the soldered part after soldering to ensure no deformities were made. The illustrations below depict
some examples of correct parts and some examples of incorrectly soldered parts.
Example of a correctly soldered part
The conductor is located at the center of the contact, and the whole
area is uniformly soldered.
Examples of incorrectly soldered parts
Solder bridge
Insufficient amount of solder used
Scattered solder balls
Floating
Uplift of the
conductor
The conductor is located too
close to the extended contact.
17
Precautions of use
[Precautions for resin sealing]
[1] To prevent insulation failure due to foreign materials, cable disconnection during the routing of the cable and other failures,
we recommend that the soldered area be protected with an ultraviolet curable resin or another equivalent material.
Recommended resin sealing material : Ultraviolet curable resin 3033 manufactured by ThreeBond Co., Ltd.
[2] Please refer to the resin manufacturer’s directions for recommended usage conditions.
[3] Ensure that the complete soldering area of the conductor is covered with resin. Be careful not to let the applied
resin flow into or stick to the connector contacts.
(0.65)
(1)
(2.7)
(16.5)
[4] Please pay close attention to the load (e.g. tension, stress.) placed on the soldered part after soldering. Poor
handling could cause cable disconnection.
[How to mount the cover shell]
[1] After connecting the cables, mount the separately sold cover shell (for micro coax cables : FX16-31P-GND).
[2] Place the cover shell over the connector from above, set it on the connector while holding it with your fingers.
Pinch together
Pinch together
Cover shell
qPrepare the cover shell.
wPlace it horizontally on the
connector from above.
eSet it on the connector
and pinch it down
[3] After applying it to the connector, check to see if all six "joining point" locations are correctly in place.
Illustration showing proper joining
Joining point
Joining point
Joining point
(cross-section of the joining point).
Joining point
Joining point
The cover shell is
locked into place and is
seated correctly.
Joining point
OK
18
The cover shell is not
locked and is still
incomplete.
NG
Precautions of use
[Ground soldering of the connector to the cable]
[1] Soldering the metal bar of the cable and the connector shell will enhance the shielding properties and provide
additional cable strain relief.
Soldered part
Soldered part
[2] Do not apply too much solder as this can lead to deformation/melting of the cable/connector due to the heat
generated while soldering.
Plug (FFC holder type)
[Precautions during harness work]
[1] Inserting FFC
Insert the FFC straight along the guide rib of the mold, as shown in the following figure.
It cannot be inserted in different directions.
Please be careful not to deform FFC or damage the case or spring contact.
Connector
(FX16M2-**P-HC)
Molded guide rib
Spring
contact
Conductor
portion
FFC has been
completely inserted.
FFC
[2] Confirming the insertion of the FFC
Check if the FFC has been inserted correctly by observing the tip end of the FFC from above the connector.
* If the FFC was inserted correctly, the tip of the FFC will meet up with the wall of the connector.
Check the tip end of the FFC by observing it from above
the connector as shown in the figure on the left.
Check to see if the FFC edge meets
Wall of the connector
If the end of the FFC does not meet the wall of the connector
*Re-insert it until they meet evenly with each other.
19
Precautions of use
[3] Fixing the FFC
As shown in the figure below, hold the connector in both hands and push the lock straight with both thumbs.
At this time, verify the hooks are tightly attached to each other on both sides.
Additionally, after closing the lock, verify that the FFC cannot be easily pulled out, and that the hooks on both
sides are tightly attached to each other by holding both ends of the assembly and pulling the FFC in the drawing
direction with a force of 3 to 5 N
Hinges (at 4 places)
Right side
Left side
Check to see that the FFC cannot be pulled
out with a force of 3 to 5 N.
Left side
Right side
Check to see that the hooks on both sides
are tightly attached to each other.
[4] Other cautions
qFrom the time of opening the package until the assembly process, please do not handle the product in the
manner which will cause the lock of the connector to be pushed down.
If the lock gets deflected it in the direction shown in the figure below, discard the connector.
wOnce FFC has been removed from the connector, do not reuse the connector.
eAt the time of packing the harness, be careful not to let the connector be damaged or deformed.
Precautions of use
General cautions
[Cautions for handling]
[1] Insertion into the connector on the side of PCB
The mating direction of this connector has been specified. Mating should be done with the mark facing the
direction shown in the figure below.
Additionally, insertion should be done until the locks on both sides are set.
PCB side: FX16M2-**S-0.5SH
Triangle
mark
When inserting it, do not touch the button of
the plug, and hold this face to insert it.
Mating
Although this connector is designed to prevent reverse insertion, the connector could be damaged if it were
mated forcibly with a force exceeding 25 N. Avoid forced mating, and please verify the triangle mark position
before mating.
Do not pull it out at an angle as shown in the figure below. This could damage the connector.
[2] Unmating the connector mounted on a PCB
This connector is structured to lock on both ends when mated.
When unmating the connector, pull it out straight while pushing on both sides with your fingers to unlock it.
Please do not pull out FFC with a strong force.
Pull-out
① Push it.
① Push it.
Pull-out
wPull it out straight.
ePull it out straight while pushing in the buttons.
〈Incorrect insertion method〉
21
Precautions of use
〈Incorrect pull-out method〉
[3] In the case when the connector has been unmated forcibly.
If the connector has been unmated forcibly, push it back once to the
completely mated condition, from this state, pull the plug by the "correct pullout method".
Be sure to push it once to the completely mated condition.
[4] In the case when you have pulled it out with one side locked
If the plug has been pulled out with one side locked, the locked part
could be damaged if you pull it out forcibly.
In such a situation, do not try to unlock it forcibly, but mate the plug
again as it is, and pull out the plug by the "correct pull-out method"
again with both sides locked.
be sure to mate them again.
[5] Handling after mating
After mating, be careful not to apply load to the connector during cable routing.
The connector could be damaged if you pull the cable with a force of 20 N or more. Additionally, it could cause
Please make sure that you do not pull the cable forcibly.
Repeated strain could also cause cable disconnection.
Avoid any use which involves repeated strain.
Repeated tension
When you use a cable that is folded back from the
connector base, please maintain a large bend radius or
keep the folding position away from the connector base in
order minimize the load on the connector.
Allow for a large
bend radius.
Keep the folding position away
from the connector base.
Using the cable in a folded state.
22
MEMO:
23
USA:
HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE
2300 Warrenville Road, Suite 150,
Downers Grove, IL 60515
Phone : +1-630-282-6700
http://www.hirose.com/us/
USA:
HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE
2841 Junction Ave, Suite 200
San Jose, CA. 95134
Phone : +1-408-253-9640
Fax : +1-408-253-9641
USA:
HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE)
17197 N. Laurel Park Drive, Suite 253,
Livonia, MI 48152
Phone : +1-734-542-9963
Fax : +1-734-542-9964
USA:
HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE
300 Brickstone Square Suite 201,
Andover, MA 01810
Phone : +1-978-662-5255
THE NETHERLANDS:
HIROSE ELECTRIC EUROPE B.V.
Hogehillweg #8 1101 CC Amsterdam Z-O
Phone : +31-20-6557460
Fax : +31-20-6557469
http://www.hirose.com/eu/
GERMANY:
HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH
Schoenbergstr. 20, 73760 ostfildern
Phone : +49-711-456002-1
Fax : +49-711-456002-299
GERMANY:
HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE
Neumeyerstrasse 22-26, 90411 Nurnberg
Phone : +49-911 32 68 89 63
Fax : +49-911 32 68 89 69
GERMANY:
HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE
Bayernstr. 3, Haus C 30855 Langenhagen, Germany
Phone : +49-511 97 82 61 30
Fax : +49-511 97 82 61 35
FRANCE:
HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE
130 Avenue Joseph Kessel, Bat E, 78960
Voisins le Bretonneux, France
Phone : +33-1-85764886
Fax : +33-1-85764823
UNITED KINGDOM:
HIROSE ELECTRIC EUROPE BV (UK BRANCH)
4 Newton Court, Kelvin Drive, Knowlhill,
Milton Keynes, MK5 8NH
Phone : +44-1908 202050
Fax : +44-1908 202058
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO., LTD.
18, Enterprise Center Tower 2, 209# Gong He
Road, Jing’an District, Shanghai, CHINA 200070
Phone : +86-21-6391-3355
Fax : +86-21-6391-3335
http://www.hirose.com/cn/
CHINA:
HIROSE ELECTRIC (SHANGHAI) CO.,LTD. BEIJING BRANCH
A1001, Ocean International Center, Building 56# East 4th
Ring Middle Road, ChaoYang District, Beijing, 100025
Phone : +86-10-5165-9332
Fax : +86-10-5908-1381
CHINA:
HIROSE ELECTRIC TECHNOLOGIES (SHENZHEN) CO., LTD.
Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre,
5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008
Phone : +86-755-8207-0851
Fax : +86-755-8207-0873
HONG KONG:
HIROSE ELECTRIC HONGKONG TRADING CO., LTD.
Room 1001, West Wing, Tsim Sha Tsui Centre, 66
Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong
Phone : +852-2803-5338
Fax : +852-2591-6560
http://www.hirose.com/hk/
TAIWAN:
HIROSE ELECTRIC TAIWAN CO., LTD.
103 8F, No.87, Zhengzhou Rd., Taipei
Phone : +886-2-2555-7377
Fax : +886-2-2555-7355
http://www.hirose.com/tw/
KOREA:
HIROSE KOREA CO.,LTD.
143, Gongdan 1-daero, Siheung-si,
Gyeonggi-do, 15084, Korea
Phone : +82-31-496-7000
Fax : +82-31-496-7100
http://www.hirose.co.kr/
SINGAPORE:
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE
03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C,
Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India
Singapore 079909
Phone : +91-12-660-8018
Phone : +65-6324-6113
Fax : +91-120-4804949
Fax : +65-6324-6123
http://www.hirose.com/sg/
INDIA:
HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE
Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma
Gandhi (MG) Road, Bangalore 560 001, Karnataka, India
Phone : +91-80-4120 1907
Fax : +91-80-4120 9908
MALAYSIA:
THAILAND:
PENANG REPRESENTATIVE OFFICE
BANGKOK OFFICE (REPRESENTATIVE OFFICE)
73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn
Road, Yannawa, Sathorn, Bangkok 10120 Thailand
Lepas Penang, 11950, Malaysia
Phone : +66-2-686-1255
Phone : +604-648-5536
Fax : +66-2-686-3433
24
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 02/2018. Contents are subject to change without notice for the purpose of improvements.
