18-141
18-141
    CINCH
    接线端子 间距P=9.53mm
18-141 数据手册
INDUSTRIAL Barrier Blocks Series 141 0.438 Density, 6-32 x 1/4”, Combination/BH Screw, Open Bottom, Double Row • Interposing barriers between terminals yield higher electrical ratings and provide additional protection against frayed wire shorting. • A wide variety of barrier blocks makes it possible to select the combination of mechanical and electrical characteristics that best meet the exact requirements of your application. • Simplify wiring work by reducing splicing, preventing current leaks and short circuits, and increasing insulation. Materials Insulation Eyelets Screws Solder Terminals Marker Strip Material Molded monoblock, general purpose phenolic, black, UL Rated 94V-1 Material: Brass Plating: Nickel Material: Steel Plating: Nickel over copper flash Material: Brass Plating: Electro-Tin Nema Grade XPC, UL Rated 94V-O Environmental Operating Temperature -55°F to +300°F Electrical Voltage Rating Current Rating Maximum Watts Per Terminal 250 VAC RMS maximum 20 Amps maximum 5000 Mechanical Maximum Wire Size Recommended Tightening Torque #14 AWG Screw 14lb.-in. Mounting holes torque 7lbs Terminal Block Quick Reference Barrier Block Series Center-to- Number Number of Center of Row(s) Spacing Terminals Screw Size Operating Voltage Current Rating Maximum Wire Size Maximum Watts/ Terminal Voltage Rating w/ Marker V Voltage Rating w/o Marker Marker Strip Mounting 140 0.375 1-25 Double 5-40 250 Volts 15 Amps #16 3750 2000 1100 Bottom 141 0.438 1-20 Double 6-32 250 Volts 20 Amps #14 5000 2400 1100 Bottom 142 0.563 1-17 Double 8-32 250 Volts 30 Amps #10 7500 2600 1600 Bottom *Marketed exclusively through distribution. belfuse.com/cinch belfuse.com/cinch Series 141 Barrier Blocks 0.438 Density, 6-32 x 1/4”, Combination/BH Screw, Open Bottom, Double Row Solder Terminal Options Marker Strips Standard Y Terminals Y Terminals Ordering Information Ordering Information Number of Combination Screw Catalog Number Binder Head Catalog Number 1 1-141 1-141-Y 2 2-141 2-141-Y 3 3-141 4 Number of Catalog Number Catalog Number 1 MS-1-141 MS-1-141-Y 2 MS-2-141 MS-2-141-Y 3-141-Y 3 MS-3-141 MS-3-141-Y 4-141 4-141-Y 4 MS-4-141 MS-4-141-Y 5 5-141 5-141-Y 5 MS-5-141 MS-5-141-Y 6 6-141 6-141-Y 6 MS-6-141 MS-6-141-Y 7 7-141 7-141-Y 7 MS-7-141 MS-7-141-Y 8 8-141 8-141-Y 8 MS-8-141 MS-8-141-Y 9 9-141 9-141-Y 9 MS-9-141 MS-9-141-Y 10 10-141 10-141-Y 10 MS-10-141 MS-10-141-Y 11 11-141 11-141-Y 11 MS-11-141 MS-11-141-Y 12 12-141 12-141-Y 12 MS-12-141 MS-12-141-Y 13 13-141 13-141-Y 13 MS-13-141 MS-13-141-Y 14 14-141 14-141-Y 14 MS-14-141 MS-14-141-Y 15 15-141 15-141-Y 15 MS-15-141 MS-15-141-Y 16 16-141 16-141-Y 16 MS-16-141 MS-16-141-Y 17 17-141 17-141-Y 17 MS-17-141 MS-17-141-Y 18 18-141 18-141-Y 18 MS-18-141 MS-18-141-Y 19 19-141 19-141-Y 19 MS-19-141 MS-19-141-Y 20 20-141 20-141-Y 20 MS-20-141 MS-20-141-Y Terminals Solder Terminals can be ordered Separately Terminal Type Catalog Number Y Y-141 Terminals Accessories • • • Jumpers Fanning Strips Quick Clamp *Marketed exclusively through distribution. Asia Pacific +86 21 5442 7668 ccs.asia.sales@as.cinch.com Europe, Middle East & Africa +44 (0) 1245 342060 CinchConnectivity@eu.cinch.com North America +1 630 705 6000 inquiry@us.cinch.com belfuse.com/cinch © 2022 Cinch Connectivity Solutions ds-ccs-industrial-cinch-barriers-141-06272022 2
18-141
物料型号:Series 141 Barrier Blocks
器件简介:这些是双排带隔离块的端子块,具有0.438英寸的间距和6-32 x 1/4英寸的组合/BH螺丝,底部开口。隔离块在端子之间提供更高的电气等级并防止因线缆磨损导致的短路。
引脚分配:文档中没有提供具体的引脚分配图,但提供了端子块的中心间距和每排的端子数量。
参数特性: - 操作温度:-55°F 至 +300°F - 电气特性:250 VAC RMS最大电压,最大20安培电流,每个端子最大5000瓦特 - 机械特性:最大线径为#14 AWG,螺丝推荐的拧紧扭矩为14lb.-in.,安装孔扭矩为7lbs
功能详解:通过减少接线工作,防止电流泄漏和短路,提高绝缘,简化布线工作。
应用信息:适用于需要高电气等级和额外保护以防止磨损线缆短路的应用。
封装信息:绝缘眼圈材料为通用酚醛塑料,黑色,UL等级94V-1。材料为黄铜,镀镍。螺丝材料为钢,镀铜闪镀镍。焊接端子材料为黄铜,镀电锡。标记条材料为Nema Grade XPC,UL等级94V-0。
订购信息:提供了不同端子数量的组合螺丝和装订头的目录编号,以及焊接端子和配件的目录编号。
联系方式:提供了亚太、欧洲、中东、非洲、北美的联系电话和电子邮件地址。
18-141 价格&库存
很抱歉,暂时无法提供与“18-141”相匹配的价格&库存,您可以联系我们找货
  • 1000+134.199721000+17.38356
