FN2410-16-44
FN2410-16-44
    SCHAFFNER(夏弗纳)
    FN2410-16-44
FN2410-16-44 数据手册
DATA SHEET Standard Performance Single-Phase Filters FN2410 and FN2412 EMC/RFI Filters for Industrial Electronics Excellent filter performance for applications with high interference levels Approvals & Compliances Filters for two-phase supply up to 2x 520 VAC (P-P) available Fast and comfortable snap-in installation on popular TS 35 DIN-rails up to 45 A Industrial grade terminal blocks for unsurpassed electrical safety Features and Benefits FN 2410 filters up to 100 A are designed for traditional chassis mounting Performance indicators For extra fast installation, FN 2412 filters up to 45 A can comfortably be snapped-in on popular TS 35 DIN-rails which are common in most electrical cabinets Both FN 2410 and FN 2412 are also avail- able as „H versions“. These are ideally suitable for an operation on two phases in a three-phase power network, handling voltages up to 520 VAC All filters provide an exceptional conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior. Thus, all filters retain the expected filter performance even in very noisy applications and under full load conditions Touch-safe industrial grade terminal blocks provide maximum electrical safety and protect humans from undeliberate contact with life conductors. They help to fulfill the most demanding installation standards Typical Applications Technical Specifications Small to medium-sized machines and industrial equipment Maximum continuous operating voltage 2x 520/300 VAC (FN 2410 H/FN 2412 H) 1x 250 VAC (FN 2410/FN 2412) Operating frequency DC to 400 Hz Rated currents 8 to 45 A @ 50°C (FN 2412) 8 to 100 A @ 50°C (FN 2410) High potential test voltage P –> P 2250 VDC for 2 sec (H types) P –> E 2000 VAC for 2 sec P –> N 1100 VDC for 2 sec P –> E 2700 VDC for 2 sec (H types) Protection category IP 20 Overload capability 4x rated current at switch on, 1.5x rated current for 1 minute, once per hour Temperature range (operation and storage) -25°C to +100°C (25/100/21) Flammability corresponding to UL 94 V-2 or better Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 MTBF @ 50°C/250 V (Mil-HB-217F) 1,200,000 hours 250,000 hours (H types) High-end single-phase power supplies Single-phase variable speed motor drives, inverters and converters DIN-rail filter versions are ideal for panel building and electrical cabinets Various noisy applications with higher power single-phase or two-phase supply Typical electrical schematic 2 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 15. Jun 2022 Filter Selection Table Filter Rated current @ 50°C (40°C) Leakage current* Power loss Input/Output @ 250 VAC /50 Hz @ 25°C/50 Hz connections Weight (@ 120 VAC /60 Hz) [A] [mA] [W] 8 (8.8) 2.60 (1.49) 2.6 -44 0.4 FN 2410-16-44 16 (17.5) 2.60 (1.49) 3.5 -44 0.5 FN 2410-25-33 25 (27.4) 2.60 (1.49) 5.5 -33 0.6 FN 2410-32-33 32 (35.0) 2.60 (1.49) 5.6 -33 0.7 FN 2410-45-33 45 (49.3) 2.60 (1.49) 7.4 -33 0.7 FN 2410-60-34 60 (65.7) 2.60 (1.49) 5.5 -34 1.8 FN 2410-80-34 80 (87.6) 2.60 (1.49) 9.9 -34 1.8 FN 2410-100-34 100 (109.5) 2.60 (1.49) 15.4 -34 1.8 FN 2410 H-8-44 8 (8.8) 2.60 (1.49) 2.6 -44 0.5 FN 2410 H-16-44 16 (17.5) 2.60 (1.49) 3.5 -44 0.6 FN 2410 H-25-33 25 (27.4) 2.60 (1.49) 5.5 -33 0.7 FN 2410 H-32-33 32 (35.0) 2.60 (1.49) 5.6 -33 0.8 FN 2410 H-60-34 60 (65.7) 2.60 (1.49) 5.5 -34 1.9 FN 2410 H-80-34 80 (87.6) 2.60 (1.49) 9.9 -34 1.9 100 (109.5) 2.60 (1.49) 15.4 -34 1.9 8 (8.8) 2.60 (1.49) 2.6 -44 0.4 FN 2412-16-44 16 (17.5) 2.60 (1.49) 3.5 -44 0.6 FN 2412-25-33 25 (27.4) 2.60 (1.49) 5.5 -33 0.7 FN 2412-32-33 32 (35.0) 2.60 (1.49) 5.6 -33 0.8 FN 2412-45-33 45 (49.3) 2.60 (1.49) 7.4 -33 0.8 8 (8.8) 2.60 (1.49) 2.6 -44 0.5 FN 2412 H-16-44 16 (17.5) 2.60 (1.49) 3.5 -44 0.7 FN 2412 H-25-33 25 (27.4) 2.60 (1.49) 5.5 -33 0.8 FN 2412 H-32-33 32 (35.0) 2.60 (1.49) 5.6 -33 0.9 FN 2410-8-44 FN 2410 H-100-34 FN 2412-8-44 FN 2412 H-8-44 [kg] * Maximum leakage under normal operating conditions (acc. to IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 8 to 45 A types 60 to 100 A types 3 Standard Performance Single-Phase Filters Schaffner Group DATA SHEET 15. Jun 2022 Mechanical Data FN 2410 (H) FN 2412 (H) Dimensions FN 2410 FN 2412 8A 16 A 25 A 32 A 45 A 60 A 80 A 100 A 8A 16 A 25 A 32 A 45 A A 130 130 130 130 130 165 165 165 110 110 110 110 110 B 93 93 93 93 93 115 115 115 93 93 93 93 93 C 62 62 76 76 76 100 100 100 73 73 87 87 87 D 108 108 108 108 108 140 140 140 E 120 120 120 120 120 155 155 155 F 70 70 70 70 70 90 90 90 G 5.3 5.3 5.3 5.3 5.3 5.3 5.3 5.3 H 1.0 1.0 1.0 1.0 1.0 1.2 1.2 1.2 I 22 22 25 25 25 39 39 39 22 22 25 25 25 J M6 M6 M6 M6 M6 M8 M8 M8 M6 M6 M6 M6 M6 Rec. torque (Nm) 3.5 - 4.0 3.5 - 4.0 3.5 - 4.0 3.5 - 4.0 3.5 - 4.0 8.0 - 9.0 8.0 - 9.0 8.0 - 9.0 3.5 - 4.0 3.5 - 4.0 3.5 - 4.0 3.5 - 4.0 3.5 - 4.0 L 17.5 17.5 31.5 31.5 31.5 39.2 39.2 39.2 28.5 28.5 42.5 42.5 42.5 All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Filter Input/Output Connector Cross Sections -33 -34 -44 Solid wire 16 mm2 35 mm2 10 mm2 Flex wire 10 mm2 25 mm2 6 mm2 AWG 6 AWG 2 AWG 8 1.5-1.8 Nm 4.0-4.5 Nm 1.0-1.2 Nm AWG type wire Recommended torque Please visit www.schaffner.com to find more details on filter connectors. 4 Standard Performance Single-Phase Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 15. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN2410-16-44 价格&库存
很抱歉,暂时无法提供与“FN2410-16-44”相匹配的价格&库存,您可以联系我们找货
FN2410-16-44
    • 20+700.04822
    • 40+686.04714
    • 80+672.32754
    库存:31
    FN2410-16-44
    • 1+960.858871+117.49586
