SCPT-A021GF-0.5
SCPT-A021GF-0.5
    JST
    Through Hole
    SCPT-A021GF-0.5
SCPT-A021GF-0.5 数据手册
CPTCONNECTOR Board-to-wire Features ●Compact design 2.0 mm pitch is realized miniaturization and low profile as the connector for automobile. ●Terminal construction Female terminal is designed for simple box structure by having spring structure on male terminal. Developed in pursuit of miniaturization and low profile as PC board connector for automobile. This connector is surface mounting type connector having the spring structure on male terminal disproving the conventional concept. Specifications ●Current rating: 3 A AC, DC (0.3 mm2, Single circuit) ●Voltage rating: 50 V AC, DC ●Temperature range: -40°C to +100°C (including temperature rise in applying electrical current) ●Contact resistance: Initial value/ 8 mΩ max. After environmental tests/ 16 mΩ max. ●Insulation resistance: 100 MΩ min. ●Withstanding voltage: 1,000 VAC/minute ●Applicable wire: AESSX-f/ AVSS 0.3 mm2 * Compliant with ELV/RoHS2. * Contact JST for details. 1 CPTCONNECTOR Female terminal Applicable wire range Conductor (mm2) Insulation O.D. (mm) Q’ty/reel SCPT-A021GF-0.5 0.3 1.4 15,000 Material and Finish Brass, nickel-undercoated, Contact area; gold-plated Barrel area; tin-plated 5.5 1.4 5.5 Model No. Female connector Single row 12.5 ●2 circuits 0.8 6.6 Housing 2 6 Retainer ●4 circuits 04CPT-B1-2B 13.5 13.5 04CPT-B1-2A Housing 2 2 2×3=6 10 Retainer 2×3=6 10 0.8 0.8 6.6 6.6 Housing Retainer 13.5 ●8 circuits Circuits Model No. Q’ty/box 2 02CPT-B-2A 04CPT-B1-2A 04CPT-B1-2B 08CPT-B1-2A 500 4 8 0.8 6.6 Housing 2 2×7=14 18 600 400 Material and Finish Housing: Glass-filled PBT, Black Retainer: Glass-filled PBT, Blue Retainer 2 CPT CONNECTOR Female connector Dual row ●8 circuits ●12 circuits 12.5 13.5 12CPT-B-2A Housing 2 0.8 0.8 9.1 9.1 Housing 2 Retainer Retainer 2×5=10 14 2×3=6 10 ●12 circuits ●16 circuits 12.5 13.5 12CPT-B-2A-FL Housing 2 2 Retainer 2×5=10 0.8 0.8 9.1 9.1 Housing 2×7=14 Retainer 18 14 ●24 circuits 13.5 13.5 ●20 circuits Housing 2 2×9=18 Retainer 22 Circuits 8 12 16 20 24 2 2×11=22 26 Model No. 08CPT-B-2A 12CPT-B-2A 12CPT-B-2A-FL 16CPT-B-2A 20CPT-B-2A 24CPT-B-2A Material and Finish Housing: Glass-filled PBT, Black Retainer: Glass-filled PBT, Blue 3 0.8 9.1 0.8 9.1 Housing Q’ty/box 500 300 250 250 200 Retainer CPT CONNECTOR Male connector Top entry type Single row ●2 circuits 6.8 10.5 1 Circuit No. 2 11.7 Dual row ●12 circuits ●8 circuits 19.6 1 9.2 4 8 5 Circuit No. 2 Type Single row Top Dual row Model No. Q’ty/reel 2 BM02B-CPTK-1A-TB BM08B-CPTK-1A-TB BM12B-CPTK-1A-TB 370 12 6 1 12 7 2 Circuits 8 12.7 9.2 12.7 2.5 15.6 2.5 2 Circuit No. 240 Material and Finish Terminal: Copper alloy, nickel-undercoated, Contact area; gold-plated Solder tail; tin-plated (reflow treatment) Housing: Glass-filled LCP, Black Peg: Brass, nickel-undercoated, tin-plated (reflow treatment) 4 CPT CONNECTOR Male connector Side entry type Single row ●2circuits 2 14.1 15.2 11.6 10.6 6.8 Circuit No. 2 1 ●4 circuits SM04B1-CPTK-1A-TB SM04B1-CPTK-1B-TB 6 6 18.1 15.2 15.6 18.1 10.6 15.2 15.6 4 10.6 Circuit No. 6.8 6.8 Circuit No. 4 1 1 ●8 circuits 14 Type Side Single row Circuits Model No. Q’ty/reel 2 SM02B-CPTK-1A-TB SM04B1-CPTK-1A-TB SM04B1-CPTK-1B-TB SM08B1-CPTK-1A-TB 500 4 8 Material and Finish 15.2 26.1 23.6 6.8 Circuit No. 8 5 1 10.6 Terminal: Copper alloy, nickel-undercoated, Contact area; gold-plated Solder tail; tin-plated (reflow treatment) Housing: Glass-filled LCP, Black Peg: Brass, nickel-undercoated, tin-plated (reflow treatment) CPT CONNECTOR Male connector Side entry type Dual row ●8 circuits ●12 circuits 7 11 1 12 7 9.3 5 6 10.6 ●20 circuits ●16 circuits 15 19 26.1 30.1 15.2 Circuit No. 16 9 10 1 20 11 10.6 9.3 1 9.3 8 15.2 Circuit No. 27.6 10.6 2.5 23.6 2.5 8 9.3 1 15.2 Circuit No. 19.6 10.6 2.5 4 22.1 15.2 Circuit No. 2.5 18.1 15.6 ●24 circuits Type Circuits Model No. Q’ty/reel 8 SM08B-CPTK-1A-TB SM12B-CPTK-1A-TB SM16B-CPTK-1A-TB SM20B-CPTK-1A-TB SM24B-CPTK-1A-TB 390 23 12 Side Dual row 16 20 24 Material and Finish 34.1 15.2 31.6 1 24 13 9.3 12 10.6 2.5 Circuit No. Terminal: Copper alloy, nickel-undercoated, Contact area; gold-plated Solder tail; tin-plated (reflow treatment) Housing: Glass-filled LCP, Black Peg: Brass, nickel-undercoated, tin-plated (reflow treatment) 6 CPT CONNECTOR Taping Specifications Top entry type ●2 circuits Feeding direction φ1.5 +0.1 0 Carrier tape ±0.5 16 +2.5 A -1 ●8, 12 ±0.1 circuits Feeding direction Feeding direction 4 ±0.1 Cover tape leader 2 ±0.1 φ1.5 +0.1 0 C ±0.1 B ±0.1 Leader part The end 100mm min. part Connector 160mm min. mounting part 400mm min. Cover tape ±0.3 Carrier tape D 2 1.75 ±0.1 (φ13) Cover tape 28.4 φ380 ±2.0 14.2 ±0.1 2 ±0.1 32 ±0.3 4 ±0.1 1.75 ±0.1 Feeding direction ±0.1 ●2, 8, 12 circuits Carrier tape 24 ±0.1 Type Circuits A B C D Single row 2 33.5 ー ー ー 8 33.5 14.2 28.4 32 12 45.5 20.2 40.4 44 Dual row Side entry type 4 ±0.1 Feeding direction 2 ±0.1 φ1.5 1.75 ±0.1 ●2, 4, 8, 12, 16, 20, 24 circuits +0.1 0 Cover tape D ±0.3 φ380 C ±0.1 ±2.0 B ±0.1 Feeding direction Carrier tape (φ13) 2 ±0.5 20 ±0.1 +2.5 A -1 Type Feeding direction Carrier tape The end part Connector 160mm min. mounting part 7 Cover tape leader Leader part 100mm min. 400mm min. Single row Dual row Circuits A B C D 2 33.5 14.2 28.4 32 4 33.5 14.2 28.4 32 8 45.5 20.2 40.4 44 8 45.5 20.2 40.4 44 12 45.5 20.2 40.4 44 16 45.5 20.2 40.4 44 20 45.5 20.2 40.4 44 24 57.5 26.2 52.4 56 CPT CONNECTOR PC board layout, Assembly layout Top entry type Assembly layout PC board layout Single row ●2 circuits ●2 circuits 8.2 10.9 ±0.1 6.8 4.35 ±0.05 Circuit No.2 16.1 Circuit No.1 3 ±0.05 4.9 ±0.05 5.8 ±0.3 1.85 ±0.2 1 ±0.05 2 ±0.05 Dual row ●8,12 circuits ●8 circuits 13.5 13.5 9.2 9.2 16.1 5.5 ±0.05 6.2 ±0.05 Circuit /PD 17.1 1.6 ±0.05 Circuit/P 14.5 ±0.1 1.35 ±0.05 4.95 ±0.05 11.8 ±0.1 3 ±0.05 A ±0.1 ●12 circuits 4.75 ±0.05 1 ±0.05 2 ±0.05 B ±0.1 Circuits A B 8 15.7 6 12 19.7 10 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. The dimensions above should serve as guideline. Contact JST for details. 8 CPT CONNECTOR PC board layout, Assembly layout Side entry type PC board layout Single row ●2, 4, 8 (Single) circuits Assembly layout ●2 circuits ●4 circuits 19.6 20.6 15 a Circuit No.1 a 1 Circuits A B 2 2 15.8 4 6 19.8 8 (Single) 14 27.8 A ±0.05 0.75 ±0.03 3.3 ±0.05 6.8 6.8 Circuit No.a ㍑饟 No. 16 1 2 ±0.05 ●8 (Single) circuits 20.6 6.8 5 ±0.05 8.8 ±0.05 16 3.85 ±0.05 7.4 ±0.05 Dual row ●8 (Dual), 12, 16, 20, 24 circuits Circuit No.a Circuit No.1 1 c b 16 Circuit No.b 1b Circuits 0.75 ±0.03 B 8 (Dual) 7 19.8 12 11 23.8 16 15 27.8 20 19 31.8 24 23 35.8 ●16 circuits ●20, 24 circuits 20.6 19.6 16 15 9.3 5 ±0.05 8.8 ±0.05 1 ±0.05 A 3.85 ±0.05 6.4 ±0.05 B ±0.1 Note: 1. Tolerances are non-cumulative: ±0.05 mm for all centers. 2. The dimensions above should serve as guideline. Contact JST for details. Crimping machine, Applicator Crimp applicator MKS-L Strip terminal Crimping machine Dies Crimp applicator with dies SCPT-A021GF-0.5 AP-K2N MK/SCPT-A021-05 APLMK SCPT-A021-05 Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 9 9.3 a c A ±0.05 3.3 ±0.05 20.6 19.6 9.3 a ●12 circuits 15 Circuit No.c Circuit No. ●8 (Dual) circuits 9.3 B ±0.1
SCPT-A021GF-0.5
物料型号: - SCPT-A021GF-0.5 - 02CPT-B-2A - 04CPT-B1-2A - 04CPT-B1-2B - 08CPT-B1-2A - 12CPT-B-2A - 12CPT-B-2A-FL - 16CPT-B-2A - 20CPT-B-2A - 24CPT-B-2A - BM02B-CPTK-1A-TB - BM08B-CPTK-1A-TB - BM12B-CPTK-1A-TB - SM02B-CPTK-1A-TB - SM04B1-CPTK-1A-TB - SM04B1-CPTK-1B-TB - SM08B1-CPTK-1A-TB
器件简介: CPT连接器是一种用于汽车的板对线连接器,具有紧凑设计和2.0毫米的间距,实现了小型化和低轮廓。女性端子设计为简单的盒式结构,男性端子具有弹簧结构,追求作为汽车PCB连接器的小型化和低轮廓。
引脚分配: - 单排2、4、8、12、16、20、24电路 - 双排8、12、16、20、24电路
参数特性: - 电压等级:50V AC/DC - 温度范围:-40°C至+100°C - 电流等级:3A AC/DC(0.3 mm²,单电路)(包括通电时的温度升高) - 初始接触电阻:最大8 mΩ - 环境测试后接触电阻:最大16 mΩ - 绝缘电阻:最小100 MΩ - 耐压:1,000 VAC/分钟 - 适用线材:AESSX-f/ AVSS
功能详解: - 女性连接器:单排2电路,双排8、12电路 - 男性连接器:顶部进入类型单排2、8、12电路,侧面进入类型单排2、4、8电路,双排8、12、16、20、24电路
应用信息: - 适用于汽车PCB连接器 - 符合ELV/RoHS2标准
封装信息: - 女性连接器:材料为黄铜,镀镍底层,接触区域镀金,桶区域镀锡 - 外壳:玻璃填充PBT,黑色 - 保持架:玻璃填充PBT,蓝色 - 男性连接器:端子材料为铜合金,镀镍底层,接触区域镀金,焊接尾部镀锡(回流处理) - 外壳:玻璃填充LCP,黑色 - 销:黄铜,镀镍底层,镀锡(回流处理)
SCPT-A021GF-0.5 价格&库存
很抱歉,暂时无法提供与“SCPT-A021GF-0.5”相匹配的价格&库存,您可以联系我们找货
SCPT-A021GF-0.5
    库存:4593
    SCPT-A021GF-0.5
      库存:225000
      SCPT-A021GF-0.5
        • 1+0.38670
        库存:79
        SCPT-A021GF-0.5
        • 10+2.22180
        • 100+1.32550
        • 1000+0.92780
        • 15000+0.66270
        • 30000+0.62960
        • 150000+0.58320
        库存:15000
