HCMCONNECTOR
Board-to-wire/Wire-to-wire
Features
●Miniaturized Connectors, Compliant with the
Automotive Performance Specifications
●Boxed Female Terminal with Triple Over-stress
Protection Mechanism
●Accept 0.64 or 1.0 mm Male Blade
●Optional Connector Position Assurance (CPA)
Design
●Terminal Independent Secondary Lock
●Variations
Multiple circuits sizes and circuit board locking
mechanisms available to suit your needs.
0.64 unsealed, low profile, miniaturized connectors for
automobile applications.
Meets or exceeds the major performance specifications
for automotive electrical connector systems.
Specifications
¡Current rating: 5 A DC
¡Voltage rating: 14 V DC
¡Temperature range: -40°C to +100°C
(including temperature rise in applying
electrical current)
¡Contact resistance: Initial value/ 20 mΩ max.
After environmental tests/ 20 mΩ max.
¡Insulation resistance: 20 MΩ min.
¡Applicable wire: SAE/ AVSS/ CAVS
0.3 mm2 to 0.5 mm2
: UL Cable
0.21 mm2
∗ Compliant with ELV/RoHS.
∗ Contact JST for details.
1
HCM CONNECTOR
Female terminal
Applicable wire range
11.6
Model No.
Conductor
(mm2)
Insulation O.D.
(mm)
Q’ty/reel
SHCM-A03T-P025
0.3 to 0.5
1.4 to 1.9
5,000
SHCM-A04T-P025
0.21
1.5
5,000
Material and Finish
2.5
Copper alloy, tin-plated
Female connector
Single row
Inner lock type
¡3 circuits
14.8
14.8
¡4 circuits
12.46
9.92
Housing
7.95
(11.25)
7.95
(11.25)
Housing
2.54
2X2.54=5.08
Retainer
Retainer
3X2.54=7.62
¡6 circuits
14.8
14.8
¡5 circuits
17.54
15
Housing
2.54
Retainer
2.54
7.95
(11.25)
7.95
(11.25)
Housing
4X2.54=10.16
Retainer
5X2.54=12.7
14.8
¡12 circuits
32.78
7.95
Housing
2.54
Retainer
11X2.54=27.94
2
HCM CONNECTOR
Female connector
Single row
Outer lock type
¡5 circuits
(20.8)
15.8
13.8
Inner lock type
¡6 circuits (W/CPA type)
8
15
Housing
17.54
9.25
8.95
10.75
Housing
2.54
Retainer
4×2.54=10.16
2.54
Retainer
5×2.54=12.7
Single row
Dual row
Inner lock type
¡8 circuits
Type
Circuits
14.8
3
4
Inner lock
5
12.46
Housing
6
12
12.55
∗12
2.54
Inner lock
(W/CPA)
6
Outer lock
5
Retainer
Model No.
Q’ty/box
Housing
Color
HCMPB-03-K
800
Black
HCMPB-03-S
800
White
HCMPB-04-K
600
Black
HCMPB-04-H
600
Gray
HCMPB-04-S
600
Natural (White)
HCMPB-A05-K
8,000
HCMPB-A05-S
500
Black
HCMPB-06-K
400
Black
HCMPB-06-S
400
Natural (White)
HCMPB-12-K
200
Black
HCMPB-A12-K
200
Black
Natural (White)
HCMPB-C06A-K
4,500
Black
HCMPB-C06A-S
4,500
Natural (White)
HCMPB-05-K
500
Black
HCMPB-05-S
500
Natural (White)
3×2.54=7.62
Material and Finish
Housing: PBT
Retainer: PBT, Blue
CPA (Only for 6 circuits with CPA): Glass-filled PBT, Red
¡9 circuits
14.8
∗Additional keying
Dual row
15
Housing
Circuits
12.55
8
Retainer
2.54
4×2.54=10.16
3
9
Model No.
Q’ty/box
Housing
Color
HCMDPB-08-K
400
Black
HCMDPB-08-S
400
Natural (White)
HCMDPB-09-K
400
Black
Material and Finish
Housing: PBT
Retainer: PBT, Blue
HCM CONNECTOR
Male connector
(Top entry type)
Inner lock type
¡3 circuits
13.7
¡6 circuits
13.7
13.7
¡5 circuits
17.78
12.7
20.32
3
1
Circuit No.
1
12
1
Circuit No.
12
10.8
Circuit No.
5
2.54
2.54
5.08
2.54
10.16
Screw hole
¡4 circuits
6
12.7
13.7
13.7
¡5 circuits
17.78
15.24
(22.05)
(26.32)
12
10.8
1
Circuit No.
φ2.4
20.32
1
5
4
2.54
10.16
Circuit No.
7.62
Outer lock type
¡5 circuits
Type
Circuits
3
12.7
Inner lock
5
6
17.78
Inner lock
(Screw hole)
4
8.5
5
Outer lock
5
Model No.
Q’ty/box
Housing
Color
B03B-HCMKS
480
Black
B03B-HCMSS
480
Natural (White)
B05B-AHCMKK
288
Black
B05B-AHCMSK
288
Natural (White)
B06B-HCMKK
240
Black
B06B-HCMSK
240
Natural (White)
B04B-HCMKS-R
240
Black
B04B-HCMKS-RA
240
Black
B04B-HCMKS-2R
240
Black
B05B2-AHCMKS-A
270
Black
B05B-HCMKS-R
432
Black
B05B-HCMSS-R
432
Natural (White)
2.54
10.16
Material and Finish
Housing: Glass-filled PBT
Pin: Brass, tin-plated
4
HCM CONNECTOR
Male connector
(Side entry type)
Reinforcement type
¡3 circuits (S04B1A-HCMKS)
13.7
13.7
¡3 circuits (S03B1-HCMKS)
12.7
15.24
16.51
19.05
Circuit No.
4
2.54
10.8
1
12.8
3
10.8
1
12.8
Circuit No.
2.54
5.08
13.97
11.43
¡4 circuits
Q’ty/box
Housing
Color
S03B1-HCMKS
180
Black
S04B1A-HCMKS
165
Black
S04B1-HCMKS
165
Black
S04B1-HCMSS
165
Natural (White)
Circuits
13.7
3
4
Model No.
Material and Finish
15.24
19.05
4
10.8
1
12.8
Circuit No.
2.54
7.62
13.97
Male terminal
Model No.
Conductor
(mm2)
SHCMW-A03T-040
0.3 to 0.5
Insulation O.D.
(mm)
1.9
Material and Finish
(23.85)
Brass, tin-plated (reflow treatment)
7.2
5
8.95
Q’ty/reel
5,000
HCM CONNECTOR
Male connector
(Wire-to-wire)
Single row
Model No.
Q’ty/box
Housing
Color
Type
Circuits
Single row
5
HCMWSB-05-K
200
Black
Dual row
4
HCMDWSB-04-S
250
Natural (White)
Q’ty/box
Housing
Color
¡5 circuits
12.5
Material and Finish
Housing: PBT
Retainer: PBT, Blue
17.8
14.65
30.8
2.54
4X2.54=10.16
Dual row
12.5
¡4 circuits
30.8
2.54
16
12.85
4.6
Female connector
Single row
¡5 circuits
Type
Circuits
Single row
5
Dual row
4
Model No.
HCMWPB-05-K
500
Black
HCMDWPB-04-S
13,000
Natural (White)
HCMDWPB-04-K
13,000
Black
14.8
8.65
Material and Finish
Housing: PBT
Retainer: PBT, Blue
4×2.54=10.16
15
Dual row
11.65
¡4 circuits
9.78
8.58
2.54
14.8
4.6
6
HCM CONNECTOR
PC board layout
φ1.1+0.1
φ1.35+0.1
φ1.1+0.1
–0.05
10.16
¡4 circuits (with screw hole)
12.7–0.05
10.16–0.05
φ3.4+0.1
0.35–0.05
φ1.1+0.1
2.54–0.05
–0.05
¡5 circuits (with screw hole)
4.45–0.05
20.32–0.1
φ3.4+0.1
φ1.35+0.1
φ1.1+0.1
2.54–0.05
2.54–0.05
5.08
¡6 circuits
2.54–0.05
φ1.1+0.1
2.6–0.05
φ1.35+0.1
2.5–0.05
¡5 circuits
2.5–0.05
¡3 circuits
2.5–0.05
Top entry type
5.08–0.05
1.27–0.05
φ1.35+0.1
10.16–0.05
7.62–0.05
Side entry type (with reinforcement)
¡3 circuits
¡3 circuits (with 4 circuits housing)
¡4 circuits
5.08–0.05
7.62–0.05
2.54–0.05
φ3+0.1
(Cu plated)
φ3+0.1
(Cu plated)
11.43–0.1
φ1.1+0.1
9.4–0.05
φ1.1+0.1
9.4–0.05
φ1.1+0.1
2.54–0.05
φ3+0.1
(Cu plated)
13.97–0.1
9.4–0.05
2.54–0.05
13.97–0.1
Note: 1. Tolerances are non-cumulative.
2. Hole dimensions differ according to the type of PC board and piercing method.
The dimensions above should serve as guideline. Contact JST for details.
Assembly layout
Top entry type
Side entry type
HCMPB-05-S
HCMPB-A05-S
(17.5)
(17.5)
(16.5)
(17.5)
HCMPB-04-S
HCMPB-04-S
B04B-HCMKS-( )( )
B05B-HCMSS-R
B05B-AHCMSK
S04B1-HCMSS
Wire-to-wire type
(34.1)
(34.1)
HCMDWPB-04-S
HCMWPB-05-K
HCMDWSB-04-S
HCMWSB-05-K
Crimping machine, Applicator
Strip terminal
Crimping
machine
SHCM-A03T-P025
SHCM-A04T-P025
SHCMW-A03T-040
AP-K2N
Crimp applicator MKS-L
Dies
Crimp applicator with dies
MK/SHCM-A03-025
APLMK SHCM-A03-025
MK/SHCM-A04-025
APLMK SHCM-A04-025
MK/SHCMW-A03-040
APLMK SHCMW-A03-040
Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal.
7
很抱歉,暂时无法提供与“HCMPB-03-K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+8.70100
- 50+6.52630
- 100+4.35050
- 国内价格
- 100+1.81100
- 300+1.56960
- 国内价格 香港价格
- 1+5.426001+0.70460
- 10+4.6714010+0.60660
- 25+4.2761025+0.55530
- 100+3.85690100+0.50080
- 250+3.52150250+0.45730
- 800+2.91070800+0.37800
- 2400+2.731002400+0.35460
- 5600+2.599205600+0.33750
- 10400+2.4675010400+0.32040
- 国内价格 香港价格
- 1+3.808191+0.49489
- 50+3.3455950+0.43477
- 100+2.84169100+0.36929
- 300+2.50300300+0.32527
- 500+2.43691500+0.31669
- 1000+2.387351000+0.31025
- 4000+2.346044000+0.30488
