B03B-HCMKS
B03B-HCMKS
    JST
    插件,P=2.54mm
    线对板针座 1x3P 直插 间距:2.54mm
B03B-HCMKS 数据手册
HCMCONNECTOR Board-to-wire/Wire-to-wire Features ●Miniaturized Connectors, Compliant with the Automotive Performance Specifications ●Boxed Female Terminal with Triple Over-stress Protection Mechanism ●Accept 0.64 or 1.0 mm Male Blade ●Optional Connector Position Assurance (CPA) Design ●Terminal Independent Secondary Lock ●Variations Multiple circuits sizes and circuit board locking mechanisms available to suit your needs. 0.64 unsealed, low profile, miniaturized connectors for automobile applications. Meets or exceeds the major performance specifications for automotive electrical connector systems. Specifications ¡Current rating: 5 A DC ¡Voltage rating: 14 V DC ¡Temperature range: -40°C to +100°C (including temperature rise in applying electrical current) ¡Contact resistance: Initial value/ 20 mΩ max. After environmental tests/ 20 mΩ max. ¡Insulation resistance: 20 MΩ min. ¡Applicable wire: SAE/ AVSS/ CAVS 0.3 mm2 to 0.5 mm2 : UL Cable 0.21 mm2 ∗ Compliant with ELV/RoHS. ∗ Contact JST for details. 1 HCM CONNECTOR Female terminal Applicable wire range 11.6 Model No. Conductor (mm2) Insulation O.D. (mm) Q’ty/reel SHCM-A03T-P025 0.3 to 0.5 1.4 to 1.9 5,000 SHCM-A04T-P025 0.21 1.5 5,000 Material and Finish 2.5 Copper alloy, tin-plated Female connector Single row Inner lock type ¡3 circuits 14.8 14.8 ¡4 circuits 12.46 9.92 Housing 7.95 (11.25) 7.95 (11.25) Housing 2.54 2X2.54=5.08 Retainer Retainer 3X2.54=7.62 ¡6 circuits 14.8 14.8 ¡5 circuits 17.54 15 Housing 2.54 Retainer 2.54 7.95 (11.25) 7.95 (11.25) Housing 4X2.54=10.16 Retainer 5X2.54=12.7 14.8 ¡12 circuits 32.78 7.95 Housing 2.54 Retainer 11X2.54=27.94 2 HCM CONNECTOR Female connector Single row Outer lock type ¡5 circuits (20.8) 15.8 13.8 Inner lock type ¡6 circuits (W/CPA type) 8 15 Housing 17.54 9.25 8.95 10.75 Housing 2.54 Retainer 4×2.54=10.16 2.54 Retainer 5×2.54=12.7 Single row Dual row Inner lock type ¡8 circuits Type Circuits 14.8 3 4 Inner lock 5 12.46 Housing 6 12 12.55 ∗12 2.54 Inner lock (W/CPA) 6 Outer lock 5 Retainer Model No. Q’ty/box Housing Color HCMPB-03-K 800 Black HCMPB-03-S 800 White HCMPB-04-K 600 Black HCMPB-04-H 600 Gray HCMPB-04-S 600 Natural (White) HCMPB-A05-K 8,000 HCMPB-A05-S 500 Black HCMPB-06-K 400 Black HCMPB-06-S 400 Natural (White) HCMPB-12-K 200 Black HCMPB-A12-K 200 Black Natural (White) HCMPB-C06A-K 4,500 Black HCMPB-C06A-S 4,500 Natural (White) HCMPB-05-K 500 Black HCMPB-05-S 500 Natural (White) 3×2.54=7.62 Material and Finish Housing: PBT Retainer: PBT, Blue CPA (Only for 6 circuits with CPA): Glass-filled PBT, Red ¡9 circuits 14.8 ∗Additional keying Dual row 15 Housing Circuits 12.55 8 Retainer 2.54 4×2.54=10.16 3 9 Model No. Q’ty/box Housing Color HCMDPB-08-K 400 Black HCMDPB-08-S 400 Natural (White) HCMDPB-09-K 400 Black Material and Finish Housing: PBT Retainer: PBT, Blue HCM CONNECTOR Male connector (Top entry type) Inner lock type ¡3 circuits 13.7 ¡6 circuits 13.7 13.7 ¡5 circuits 17.78 12.7 20.32 3 1 Circuit No. 1 12 1 Circuit No. 12 10.8 Circuit No. 5 2.54 2.54 5.08 2.54 10.16 Screw hole ¡4 circuits 6 12.7 13.7 13.7 ¡5 circuits 17.78 15.24 (22.05) (26.32) 12 10.8 1 Circuit No. φ2.4 20.32 1 5 4 2.54 10.16 Circuit No. 7.62 Outer lock type ¡5 circuits Type Circuits 3 12.7 Inner lock 5 6 17.78 Inner lock (Screw hole) 4 8.5 5 Outer lock 5 Model No. Q’ty/box Housing Color B03B-HCMKS 480 Black B03B-HCMSS 480 Natural (White) B05B-AHCMKK 288 Black B05B-AHCMSK 288 Natural (White) B06B-HCMKK 240 Black B06B-HCMSK 240 Natural (White) B04B-HCMKS-R 240 Black B04B-HCMKS-RA 240 Black B04B-HCMKS-2R 240 Black B05B2-AHCMKS-A 270 Black B05B-HCMKS-R 432 Black B05B-HCMSS-R 432 Natural (White) 2.54 10.16 Material and Finish Housing: Glass-filled PBT Pin: Brass, tin-plated 4 HCM CONNECTOR Male connector (Side entry type) Reinforcement type ¡3 circuits (S04B1A-HCMKS) 13.7 13.7 ¡3 circuits (S03B1-HCMKS) 12.7 15.24 16.51 19.05 Circuit No. 4 2.54 10.8 1 12.8 3 10.8 1 12.8 Circuit No. 2.54 5.08 13.97 11.43 ¡4 circuits Q’ty/box Housing Color S03B1-HCMKS 180 Black S04B1A-HCMKS 165 Black S04B1-HCMKS 165 Black S04B1-HCMSS 165 Natural (White) Circuits 13.7 3 4 Model No. Material and Finish Housing: Glass-filled PBT Pin: Brass, tin-plated 15.24 19.05 4 10.8 1 12.8 Circuit No. 2.54 7.62 13.97 Male terminal Applicable wire range Model No. Conductor (mm2) SHCMW-A03T-040 0.3 to 0.5 Insulation O.D. (mm) 1.9 Material and Finish (23.85) Brass, tin-plated (reflow treatment) 7.2 5 8.95 Q’ty/reel 5,000 HCM CONNECTOR Male connector (Wire-to-wire) Single row Model No. Q’ty/box Housing Color Type Circuits Single row 5 HCMWSB-05-K 200 Black Dual row 4 HCMDWSB-04-S 250 Natural (White) Q’ty/box Housing Color ¡5 circuits 12.5 Material and Finish Housing: PBT Retainer: PBT, Blue 17.8 14.65 30.8 2.54 4X2.54=10.16 Dual row 12.5 ¡4 circuits 30.8 2.54 16 12.85 4.6 Female connector Single row ¡5 circuits Type Circuits Single row 5 Dual row 4 Model No. HCMWPB-05-K 500 Black HCMDWPB-04-S 13,000 Natural (White) HCMDWPB-04-K 13,000 Black 14.8 8.65 Material and Finish Housing: PBT Retainer: PBT, Blue 4×2.54=10.16 15 Dual row 11.65 ¡4 circuits 9.78 8.58 2.54 14.8 4.6 6 HCM CONNECTOR PC board layout φ1.1+0.1 0 φ1.35+0.1 0 φ1.1+0.1 0 –0.05 10.16 ¡4 circuits (with screw hole) 12.7–0.05 10.16–0.05 φ3.4+0.1 0 0.35–0.05 φ1.1+0.1 0 2.54–0.05 –0.05 ¡5 circuits (with screw hole) 4.45–0.05 20.32–0.1 φ3.4+0.1 0 φ1.35+0.1 0 φ1.1+0.1 0 2.54–0.05 2.54–0.05 5.08 ¡6 circuits 2.54–0.05 φ1.1+0.1 0 2.6–0.05 φ1.35+0.1 0 2.5–0.05 ¡5 circuits 2.5–0.05 ¡3 circuits 2.5–0.05 Top entry type 5.08–0.05 1.27–0.05 φ1.35+0.1 0 10.16–0.05 7.62–0.05 Side entry type (with reinforcement) ¡3 circuits ¡3 circuits (with 4 circuits housing) ¡4 circuits 5.08–0.05 7.62–0.05 2.54–0.05 φ3+0.1 0 (Cu plated) φ3+0.1 0 (Cu plated) 11.43–0.1 φ1.1+0.1 0 9.4–0.05 φ1.1+0.1 0 9.4–0.05 φ1.1+0.1 0 2.54–0.05 φ3+0.1 0 (Cu plated) 13.97–0.1 9.4–0.05 2.54–0.05 13.97–0.1 Note: 1. Tolerances are non-cumulative. 2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as guideline. Contact JST for details. Assembly layout Top entry type Side entry type HCMPB-05-S HCMPB-A05-S (17.5) (17.5) (16.5) (17.5) HCMPB-04-S HCMPB-04-S B04B-HCMKS-( )( ) B05B-HCMSS-R B05B-AHCMSK S04B1-HCMSS Wire-to-wire type (34.1) (34.1) HCMDWPB-04-S HCMWPB-05-K HCMDWSB-04-S HCMWSB-05-K Crimping machine, Applicator Strip terminal Crimping machine SHCM-A03T-P025 SHCM-A04T-P025 SHCMW-A03T-040 AP-K2N Crimp applicator MKS-L Dies Crimp applicator with dies MK/SHCM-A03-025 APLMK SHCM-A03-025 MK/SHCM-A04-025 APLMK SHCM-A04-025 MK/SHCMW-A03-040 APLMK SHCMW-A03-040 Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 7
B03B-HCMKS 价格&库存
很抱歉,暂时无法提供与“B03B-HCMKS”相匹配的价格&库存,您可以联系我们找货
B03B-HCMKS
    • 1+3.97440
    • 10+3.16440
    • 30+2.80800
    • 100+2.37600
    • 480+2.18160
    • 960+2.06280
