SNAC3W-A021T-0.64
SNAC3W-A021T-0.64
    JST
    Contacts
SNAC3W-A021T-0.64 数据手册
ARVCONNECTOR Wire-to-wire Features ●12 Circuits, 18 Circuits and 22 Circuits Wire-to-Wire Connection ●Optional Wire Routing Attachment (to optimize packaging space) ●Versatile Mounting Options ●Latch Overstress Feature ●Both Female and Male Connectors utilize Independent Secondary Lock for Terminal retention 0.64 Unsealed wire-to-wire connection system for unsealed applications, requiring Automotive durability. Clip mountable type ¡Normal type JS T 1 6 18 Screw hole type ¡Normal type ¡With back cover type JS T 1 C-B 6 JS T 1 18 6 12 18 ¡With back cover type JS Specifications T 1 C-B 6 12 18 JS T C-B ¡Current rating: 5 A DC max. ¡Voltage rating: 14 V DC ¡Temperature range: - 40°C to +125°C (including temperature rise in applying electrical current) ¡Contact resistance: Initial value/ 15 mΩ max. After environmental tests/ 15 mΩ max. ¡Insulation resistance: 100 MΩ min. ¡Applicable Wire: TXL/ ISO 0.35 mm2 to 0.75 mm2 O.D.   1.9 mm (AWG #22 to #18) (Female Terminal) ISO 0.35 mm2 to 0.5 mm2 O.D.   1.7 mm (AWG #22 to #20) (Male Terminal) ∗ Compliant with ELV/RoHS. ∗ Contact JST for details. 1 ARV CONNECTOR Female terminal Applicable wire range Conductor (mm2) Insulation O.D. (mm) Q’ty/reel SAIT-A03T-M064 0.35 to 0.5 1.9 6,500 SAIT-A02T-M064 0.75 1.9 6,500 1.6 Model No. 14 Material and Finish 6.5 2.25 Copper alloy, tin-plated (reflow treatment) Female connector ¡12 circuits (With back cover) 19 (25.2) ¡12 circuits (20.4) 5X2.54=12.7 19 ¡18 circuits (23.85) 12.75 13.65 12.75 19.8 5X2.54=12.7 19 (25.2) ¡18 circuits (With back cover) (20.4) 5X2.54=12.7 19 16.75 17.65 16.75 5X2.54=12.7 (27.85) 19.8 2 ARV CONNECTOR Female connector  ¡22 circuits (With back cover) 19 (25.2)  ¡22 circuits 24.88 (25.48) 7X2.54=17.78 Circuits 12 18 22 Model No. (27.85) 16.75 17.65 16.75 7X2.54=17.78 Back Cover Q’ty/box ARVPB-12-2AK No 1,500 ARVPB-12C12-2AK Yes 1,500 ARVPB-18-3AK No 1,000 ARVPB-18C18-3AK Yes 1,000 ARVPB-22-3AK No 600 ARVPB-22C22-3AK Yes 500 Material and Finish Housing: PBT, Black TPA: Glass-filled PBT, Natural (White) Back cover: Glass-filled PBT, Black Male terminal Applicable wire range Model No. Conductor (mm2) Insulation O.D. (mm) Q’ty/reel SNAC3W-A021T-0.64 0.35 to 0.5 1.7 7,000 Material and Finish 3 14.9 3 8.9 Brass, tin-plated (reflow treatment) ARV CONNECTOR Male connector ¡12 circuits (Clip Mountable Type) 33 33  ¡12 circuits (Screw hole Mountable Type) 23.04 20.4 20.4 13.65 13.65 36.4 5X2.54=12.7 5X2.54=12.7 ¡18 circuits (Clip Mountable Type) 33 33 ¡18 circuits (Screw hole Mountable Type) 23.04 20.4 20.4 17.65 17.65 36.4 5X2.54=12.7 5X2.54=12.7 ¡22 circuits (Clip Mountable Type) 33 33 ¡22 circuits (Screw hole Mountable Type) 28.73 41.48 25.48 17.65 17.65 25.48 7X2.54=17.78 7X2.54=17.78 Circuits 12 18 22 Model No. ARVWSB-12B-2AK ARVWSB-12BC-2AK ARVWSB-18-3AK ARVWSB-18C-3AK ARVWSB-22-3AK ARVWSB-22C-3AK Mountable Style Q’ty/box Screw hole 1,000 Clip 1,000 Screw hole 750 Clip 750 Screw hole 450 Clip 450 Material and Finish Housing: Glass-filled PBT, Black PBT, Black (22P only) TPA: Glass-filled PBT, Natural (White) 4 ARV CONNECTOR Assemby layout ¡12 circuits ¡18, 22 circuits (4.1) (4.1) 33 (13.85) (17.85) 33 ¡12 circuits (With back cover) ¡18, 22 circuits (With back cover) (4.1) (4.1) 33 (23.85) (27.85) 33 (6.25) (6.25) Crimping machine, Applicator Strip terminal Crimping machine SAIT-A03( )-M064 SAIT-A02( )-M064 SNAC3W-A021( )-0.64 AP-K2N Crimp applicator MKS-L Dies Crimp applicator with dies MK/SAIT-A03-064 APLMK SAIT-A03-064 MK/SAIT-A02-064 APLMK SAIT-A02-064 MK/SNAC3W-A021-064 APLMK SNAC3W-A021-064 Note: When crimping operation is conducted using an applicator and die set other than the above, JST cannot guarantee the performance of the terminal. 5
SNAC3W-A021T-0.64 价格&库存
很抱歉,暂时无法提供与“SNAC3W-A021T-0.64”相匹配的价格&库存,您可以联系我们找货
SNAC3W-A021T-0.64
  • 5+0.64930
  • 50+0.52694
  • 150+0.46581
  • 500+0.32752
  • 2500+0.29888
  • 7000+0.28456
库存:4497
SNAC3W-A021T-0.64
    • 500+0.33800
    • 1000+0.31390
    • 7000+0.30180
    库存:54800
    SNAC3W-A021T-0.64
      • 5+0.69440
      • 50+0.56350
      • 150+0.49820
      • 500+0.35020
      • 2500+0.31970
      库存:4850
