2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
KLDX-0202-AP-LT
Part Number Builder
R
E 140125
LR78160
KLDX-0202
DC POWER CONNECTORS: KLDX Series
Series
A
P
LT
Diameter
Peg
Type
Locking Type PCB Mount DC Power Jack
Series
KLDX-0202 - PCB Mount DC Power Jack Locking Type
Product Features
2.0mm and 2.5mm
Built-In DC On/Off Switch
Locking Feature (Will Lock with Kycon Locking Plug)
To Be Used with Locking/Non-Locking Tuning Fork
Style Plug
Laptop and Palm Computers, Portable Modems, Radar
Detectors, and Other Portable Device Applications
CSA/NRTL Certified File No. LR78160
UL File No. E140125
Diameter
A - 2.0mm Center Pin Diameter
B - 2.5mm Center Pin Diameter
Peg
Blank - without Peg
P - with Peg
Type
LT - Locking Type
Contact Kycon For Other Options
Performance Specifications
Materials and Finish
Body: PBT Thermoplastic, UL94V-0 Rated, Color Black
Center Pin: Brass, Nickel Plated
Contact #1: Brass, Tin Plated
Contact #2: Phosphor Bronze, Tin Plated
Contact #3: Brass, Tin Plated
Recommended to be used with Kycon locking plug (tuning fork design):
KLDX-PA-0202-A-LT, KLDX-PA-0202-B-LT
If used with non-locking plug, tuning fork design
is required. See picture.
Tuning fork contact
Electrical Characteristics
Rated Current: 3.5A
Rated Voltage: 24V DC
Insulation Resistance:
50 Megohms Min. at 100 or 200V DC for 1 Minute
KLDX-0202 Series
Dimensions in mm
KLDX-0202-x-LT
Mechanical Characteristics
Durability Test: 5000 Cycles
Insertion Force: 0.3kg - 2.0kg
Extraction Force: 0.3kg - 2.0kg
Operating Temperature: -25˚C to +85˚C
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 2013
很抱歉,暂时无法提供与“KLDX-0202-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+6.203271+0.77628
- 10+5.2733210+0.65990
- 25+4.9413225+0.61836
- 50+4.7038450+0.58864
- 100+4.47841100+0.56043
- 250+4.19797250+0.52534
- 500+3.99727500+0.50022
- 1000+3.806361000+0.47633
- 2500+3.567982500+0.44650
