IL715/IL716/IL717
High Speed Four-Channel Digital Isolators
Functional Diagrams
Features
IN1
OUT1
IN2
OUT2
IN3
OUT3
IN4
OUT4
IL715
IN1
OUT1
IN2
OUT2
OUT3
IN3
OUT4
IN4
IL716
High speed: 110 Mbps
High temperature: −40°C to +125°C (“T” and “V” Series)
Very high isolation: 6 kVRMS Reinforced Isolation (V-Series)
High working voltage: 1 kVRMS per VDE V 0884-10 (V-Series)
50 kV/μs typical common mode transient immunity
No carrier or clock for low EMI emissions and susceptibility
1.2 mA/channel typical quiescent current
100 ps pulse jitter
2 ns channel-to-channel skew
10 ns typical propagation delay
44000 year barrier life
Excellent magnetic immunity
VDE V 0884-10 certified; UL 1577 recognized
0.15" and 0.3" True 8™ mm 16-pin SOIC; 16-pin QSOP packages
Applications
ADCs and DACs
Digital Fieldbus
Multiplexed data transmission
Board-to-board communication
Ground loop elimination
Parallel bus
Logic level shifting
Equipment covered under IEC 61010-1 Edition 3
5 kVRMS rated IEC 60601-1 medical applications
Description
IN1
OUT1
IN2
OUT2
IN3
OUT3
A unique ceramic/polymer composite barrier provides excellent isolation
and virtually unlimited barrier life.
IN4
All transmit and receive channels operate at 110 Mbps over the full
temperature and supply voltage range. The symmetric magnetic coupling
barrier provides a typical propagation delay of only 10 ns and a pulse width
distortion of 2 ns, achieving the best specifications of any isolator.
OUT4
IL717
NVE’s IL715, IL716, and IL717 four-channel high-speed digital isolators
are CMOS devices manufactured with NVE’s patented* IsoLoop®
spintronic Giant Magnetoresistive (GMR) technology.
Typical transient immunity of 50 kV/µs is unsurpassed. High channel
density makes these devices ideal for isolating ADCs and DACs, parallel
buses and peripheral interfaces.
The IL715, IL716, and IL717 are available in 16-pin 0.3" and 0.15" SOIC,
and ultraminiature QSOP packages.
Performance is specified over a temperature range of −40°C to +100°C.
“T” and “V” Series parts have a maximum operating temperature of 125°C.
V-Series versions have an extremely high isolation voltage of 6 kVRMS.
IsoLoop is a registered trademark of NVE Corporation.
*U.S. Patent numbers 5,831,426; 6,300,617 and others.
NVE Corporation
11409 Valley View Road, Eden Prairie, MN 55344-3617
REV. AE
Phone: (952) 829-9217
Fax: (952) 829-9189
www.IsoLoop.com
©NVE Corporation
IL715/IL716/IL717
Absolute Maximum Ratings
Parameters
Storage Temperature
Junction Temperature
Ambient Operating Temperature(1)
“T” and “V” Versions
Supply Voltage
Input Voltage
Output Voltage
Output Current Drive
Lead Solder Temperature
ESD
Symbol
TS
TJ
Min.
−55
−55
TA
−40
VDD1, VDD2
VI
VO
IO
−0.5
−0.5
−0.5
Typ.
Max.
150
150
100
125
7
VDD+0.5
VDD+0.5
10
260
Units
°C
°C
Max.
100
125
110
125
5.5
VDD
0.8
1
Units
Max.
Units
2
Test Conditions
°C
V
V
V
mA
°C
kV
10 sec.
HBM
Recommended Operating Conditions
Parameters
Supply Voltage
Logic High Input Voltage
Logic Low Input Voltage
Input Signal Rise and Fall Times
Symbol
Min.
TA
−40
TJ
−40
VDD1, VDD2
VIH
VIL
tIR, tIF
3.0
2.4
Symbol
Min.
4.03
4.03
8.03
0.012
Typ.
Test Conditions
°C
°C
V
V
V
µs
Insulation Specifications
Parameters
QSOP
Creepage Distance
0.15" SOIC
(external)
0.3" SOIC
Total Barrier Thickness (internal)
Leakage Current(5)
Barrier Resistance(5)
Barrier Capacitance(5)
QSOP
Comparative
0.15" SOIC
Tracking Index
0.3" SOIC
AC
High Voltage Endurance
(Maximum Barrier Voltage
DC
for Indefinite Life)
Surge Immunity (“V” Versions)
CTI
VIO
VIOSM
Typ.
8.3
0.016
0.2
>1014
4
mm
Per IEC 60601
mm
µA
Ω
pF
240 VRMS, 60 Hz
500 V
f = 1 MHz
VRMS
Per IEC 60112
≥175
≥175
≥600
1000
VRMS
1500
12.8
VDC
kVPK
Barrier Life
44000
Test Conditions
Years
At maximum
Per IEC 61000-4-5
100°C, 1000 VRMS, 60%
CL activation energy
Thermal Characteristics
Parameter
Symbol
Junction–Ambient
Thermal Resistance
Junction–Case (Top)
Thermal Resistance
Power Dissipation
QSOP
0.15" SOIC
0.3" SOIC
QSOP
0.15" SOIC
0.3" SOIC
QSOP
0.15" SOIC
0.3" SOIC
Min.
Typ.
60
60
60
10
10
θJA
ΨJT
Max.
°C/W
°C/W
675
700
800
PD
Units
Test Conditions
Soldered to doublesided board;
free air
mW
2
NVE Corporation
Fax: (952) 829-9189
www.IsoLoop.com
©NVE Corporation
IL715/IL716/IL717
Safety and Approvals
VDE V 0884-10 (VDE V 0884-11 pending)
V-Series (Reinforced Isolation; VDE File Number 5016933-4880-0002)
• Working Voltage (VIORM) 1000 VRMS (1415 VPK); reinforced insulation; pollution degree 2
• Isolation voltage (VISO) 6000 VRMS
• Surge immunity (VIOSM) 12.8 kVPK
• Surge rating 8 kV
• Transient overvoltage (VIOTM) 6000 VPK
• Each part tested at 2387 VPK for 1 second, 5 pC partial discharge limit
• Samples tested at 6000 VPK for 60 sec.; then 2122 VPK for 10 sec. with 5 pC partial discharge limit
Standard versions (Basic Isolation; VDE File Number 5016933-4880-0001)
• Working Voltage (VIORM) 600 VRMS (848 VPK); basic insulation; pollution degree 2
• Isolation voltage (VISO) 2500 VRMS
• Transient overvoltage (VIOTM) 4000 VPK
• Surge rating 4000 V
• Each part tested at 1590 VPK for 1 second, 5 pC partial discharge limit
• Samples tested at 4000 VPK for 60 sec.; then 1358 VPK for 10 sec. with 5 pC partial discharge limit
Safety-Limiting Values
Safety rating ambient temperature
Safety rating power (180°C)
Supply current safety rating (total of supplies)
Symbol
TS
PS
IS
Value
180
270
54
Units
°C
mW
mA
IEC 61010-1 (Edition 2; TUV Certificate Numbers N1502812; N1502812-101)
Reinforced Insulation; Pollution Degree II; Material Group III
Part No.
Suffix
-1
-3
None
V
Package
QSOP
0.15" SOIC
0.3" SOIC (standard)
0.3" SOIC (high isolation voltage)
Working
Voltage
300 VRMS
300 VRMS
300 VRMS
1000 VRMS
UL 1577 (Component Recognition Program File Number E207481)
• 6 kV-rated V-Series parts tested at 7.2 kVRMS (10.2 kVPK) for 1 second; each lot sample tested at 6 kVRMS (8485 VPK) for 1 minute
• 2.5 kV-rated parts tested at 3000 VRMS (4240 VPK) for 1 second; each lot sample tested at 2500 VRMS (3530 VPK) for 1 minute
Soldering Profile
Per JEDEC J-STD-020C, MSL 1
3
NVE Corporation
Fax: (952) 829-9189
www.IsoLoop.com
©NVE Corporation
IL715/IL716/IL717
IL715 Pin Connections
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
VDD1
GND1
IN1
IN2
IN3
IN4
NC
GND1
GND2
NC
OUT4
OUT3
OUT2
OUT1
GND2
VDD2
Supply voltage
Ground return for VDD1*
Data in, channel 1
Data in, channel 2
Data in, channel 3
Data in, channel 4
No connection
Ground return for VDD2*
No connection
Data out, channel 4
Data out, channel 3
Data out, channel 2
Data out, channel 1
Supply voltage
VDD1
GND1
IN1
IN2
OUT3
OUT4
NC
GND1
GND2
NC
IN4
IN3
OUT2
OUT1
GND2
VDD2
1
16
VDD2
GND1
2
15
GND2
IN1
3
14
OUT1
IN2
4
13
OUT2
IN3
5
12
OUT3
IN4
6
11
OUT4
NC
7
10
NC
GND1
8
9
GND2
IL715
IL716 Pin Connections
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
VDD1
Supply voltage
Ground Return for VDD1*
Data in, channel 1
Data in, channel 2
Data out, channel 3
Data out, channel 4
No connection
Ground Return for VDD2*
No connection
Data in, channel 4
Data in, channel 3
Data out, channel 2
Data out, channel 1
Supply voltage
VDD1
1
16
VDD2
GND1
2
15
GND2
IN1
3
14
OUT1
IN2
4
13
OUT2
OUT3
5
12
IN3
OUT4
6
11
IN4
NC
7
10
NC
GND1
8
9
GND2
IL716
*NOTE: Pins 2 and 8 are internally connected, as are pins 9 and 15.
4
NVE Corporation
Fax: (952) 829-9189
www.IsoLoop.com
©NVE Corporation
IL715/IL716/IL717
IL717 Pin Connections
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
VDD1
GND1
IN1
IN2
IN3
OUT4
NC
GND1
GND2
NC
IN4
OUT3
OUT2
OUT1
GND2
VDD2
Supply voltage
Data in, channel 1
Data in, channel 2
Data in, channel 3
Data out, channel 4
No connection
No connection
Data in, channel 4
Data out, channel 3
Data out, channel 2
Data out, channel 1
Supply voltage
VDD1
1
16
VDD2
GND1
2
15
GND2
IN1
3
14
OUT1
IN2
4
13
OUT2
IN3
5
12
OUT3
OUT4
6
11
IN4
NC
7
10
NC
GND1
8
9
GND2
IL717
Timing Diagram
Legend
tPLH
tPHL
tPW
tR
tF
Propagation Delay, Low to High
Propagation Delay, High to Low
Minimum Pulse Width
Rise Time
Fall Time
5
NVE Corporation
Fax: (952) 829-9189
www.IsoLoop.com
©NVE Corporation
IL715/IL716/IL717
Parameters
Input Quiescent Supply Current
IL715 and IL715-3
IL715-1
IL716
IL717
Output Quiescent Supply Current
IL715
IL716
IL717
Logic Input Current
3.3 Volt Electrical Specifications (Tmin to Tmax unless otherwise stated)
Symbol
Min.
Typ.
Max.
Units
IDD1
16
300
2.4
1.2
3.5
1.75
µA
µA
mA
mA
IDD2
4.8
2.4
3.6
7
3.5
5.25
10
mA
mA
mA
µA
II
Logic High Output Voltage
VOH
Logic Low Output Voltage
VOL
Maximum Data Rate
Pulse Width(7)
Propagation Delay Input to Output
(High to Low)
(Low to High)
Pulse Width Distortion (2)
Propagation Delay Skew (3)
Output Rise Time (10%−90%)
Output Fall Time (10%−90%)
Common Mode Transient Immunity
(Output Logic High or Logic Low)(4)
Channel-to-Channel Skew
Dynamic Power Consumption(6)
Power Frequency Magnetic Immunity
Pulse Magnetic Field Immunity
Damped Oscillatory Magnetic Field
Cross-axis Immunity Multiplier(9)
−10
VDD − 0.1
0.8 x VDD
VDD
0.9 x VDD
V
0.1
0.8
Switching Specifications (VDD = 3.3 V)
100
110
PW
10
V
Mbps
ns
Test Conditions
IO = −20 µA, VI = VIH
IO = −4 mA, VI = VIH
IO = 20 µA, VI = VIL
IO = 4 mA, VI = VIL
CL = 15 pF
50% Points, VO
tPHL
12
18
ns
CL = 15 pF
tPLH
12
18
ns
CL = 15 pF
PWD
tPSK
tR
tF
2
4
2
2
3
6
4
4
ns
ns
ns
ns
CL = 15 pF
CL = 15 pF
CL = 15 pF
CL = 15 pF
VCM = 1500 VDC
tTRANSIENT = 25 ns
CL = 15 pF
per channel
|CMH|,|CML|
30
50
tCSK
2
140
kV/µs
3
240
Magnetic Field Immunity(8) (VDD2 = 3V, 3V
