SDN10-24-100P
SDN10-24-100P
    SOLAHD
    SDN10-24-100P
SDN10-24-100P 数据手册
Power Supplies SDN-P™ DIN Rail Series The SolaHD SDN-P DIN Rail Series power supplies provide industry leading performance. Sag Immunity, transient suppression and noise tolerant, the SDN-P Series ensures compatibility in demanding applications. Power factor correction to meet European directives, hazardous location approvals and optional redundant accessories allow the SDN-P series to be used in a wide variety of applications. Wide operation temperature range, high tolerance to shock and vibration and reliable design make the SDN-P series the preferred choice of users. UL 60950 EMC and E137632 E61379 UL 508 Listed E137632 Low Volt. E234790 IND. CONT. EQ. CUL/CSA-C22.2 Directive E61379 No. 234-M90 Applications Accessories • Industrial/Machine Control • Process Control • SDN-C Redundant Modules • Conveying Equipment • Chassis Mount Bracket (SDN-PMBRK2) • Material Handling • Vending Machines Certifications and Compliances * • Packaging Equipment All Models • DeviceNet • • Amusement Park Equipment UL 508 Listed IND. CONT. EQ. E61379 TM - UL 508, CSA C22.2 No. 107.1 UL Recognized Component, ITE, E137632 UL 60950 E137632 - UL 60950-1/CSA C22.2 No. 60950-1, 2nd Edition CUL/CSA-C22.2 No. 234-M90 • UL Recognized Component, Haz. Loc., UL 60950 E137632 E234790 CUL/CSA-C22.2 • • Semiconductor Fabrication Equipment Features • Power Factor Correction (per EN61000-3-2) No. 234-M90 - ISA 12.12.01, CSA C22.2 No. 213 - Class I, Division 2, Groups A, B, C, D • - Low Voltage Directive • Auto Select 115/230 Vac, 50/60 Hz Input • Improved metal mounting clip • DC OK Signal - IEC/EN60950-1, 2nd Edition • Sag Immunity: SEMI F47 • Adjustable Voltage • Parallel Capability standard on all units • RoHS Compliant • Industrial grade design - -10°C to 60°C operation without derating. Indefinite short circuit, overvoltage and overtemperature protection. - Powers high inrush loads without shutdown or foldback - Rugged metal case and DIN connector Models SDN 2.5-24-100P, SDN 4-24-100LP • Class II per UL 1310, CSA C22.2 No. 223 Related Products • SVL Series • Narrow width on rail for space critical applications • SDP™ Series • User-friendly front panel - Large, rugged, accessible, multiple connection screw terminations - Easy installation Listed, Ind. Control Equipment, E61379 • SCP Series • SCL Series • SDU UPS • 12 Vdc and 48 Vdc single phase models available • Highly efficient >90% switching technology • High MTBF and reliability * Refer to user manual for installation requirements when used in hazardous locations. 130 Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © September 2019 Power Supplies SDN-P Specifications (Single Phase), 24 Vdc Output Description Catalog Number SDN 2.5-24-100P SDN 4-24-100LP SDN 5-24-100P SDN 10-24-100P Input 115/230 Vac, Auto select Nominal Voltage 85-264 Vac -AC Range -DC Range 1 85-132/176-264 Vac 90 - 375 Vdc 210 - 375 Vdc 47 - 63 Hz -Frequency Nominal Current 2 1.3 / 0.7 A -Inrush current max. typ. < 25 A Efficiency (Losses 3) > 86 % (10.0 W) 2.1 / 1.0 A 2.2 / 1.0 A 5 / 2 A typ. > 88% typ. (16.4 W) > 88 % (33.0 W) typ. < 20 A > 86 % (14.1 W) typ. < 40 A Units Fulfill EN61000-3-2 Power Factor Correction Output Nominal Voltage 24 Vdc (22.5 - 28.5 Vdc adj.) 24 Vdc (22.5 - 25.7 Vdc adj.) < ±2% overall (combination Line, load, time and temperature related changes) -Tolerance < 50 mVpp -Ripple 4 Overvoltage Protection Nominal Current -Current Limit 24 Vdc (22.5 - 28.5 Vdc adj.) < 33 Vdc < 27 Vdc 2.5 A (60 W) 3.8 A (92 W) < 33 Vdc 5 A (120 W) 10 A (240 W) Fold Forward (Current rises, voltage drops to maintain constant power during overload up to max peak current) > 20 ms @ full load Holdup Time 5 Single or Parallel use is selectable via Front Panel Switch (SDN 2.5, 4 should not be used in parallel as Class II rating would be violated.) Parallel Operation General EMC: -Emissions -Immunity Temperature EN61000-6-3, -4; Class B EN55011, EN55022 Radiated and Conducted including Annex A. EN61000-3-2 EN61000-6-1, -2; EN61000-4-2 Level 4, EN61000-4-3 Level 3; EN61000-4-6 Level 3; EN61000-4-4 Level 4 input and Level 3 output; EN61000-4-5 Isolation Class 4, EN61000-4-11; Storage: -25°C...+85°C Operation. -10°-60°C full power with operation to 70°C possible with a linear derating to half power from 60°C to 70°C (Convection cooling, no forced air required). Operation up to 50% load permissible with sideways or front-side-up mounting orientation. The relative humidity is < 90% RH, noncondensing; IEC 68-2-2, 68-2-3. Humidity MTBF: > 820,000 hours > 640,000 hours > 600,000 hours Bellcore Issue 6 Method 1 Case 3 @ 40°C - Standard 5 year limited warranty Warranty Protected against continuous short-circuit, overload, open-circuit. Protection Class I (IEC536), degree of protection IP20 (IEC 529) Safe low voltage: SELV (acc. EN60950) General Protection/Safety Green LED and DC OK signal (N.O. Solid State Contact rated 200 mA / 60 Vdc) Status Indicators Installation Fusing -Input -Output Mounting Connections Internally fused. External 10 A slow acting fusing for the input is recommended to protect input wiring. Outputs are capable of providing high currents for short periods of time for inductive load startup or switching. Fusing may be required for wire/ loads if 2x Nominal O/P current rating cannot be tolerated. Continuous current overload allows for reliable fuse tripping. Simple snap-on system for DIN Rail TS35/7.5 or TS35/15 or chassis-mounted (optional screw mounting set SDN-PMBRK2 required). Input: IP20-rated screw terminals, connector size range: 16-10 AWG (1.5-6 mm2) for solid conductors. 16-12 AWG (0.5-4 mm2) for flexible conductors. Output: Two connectors per output, connector size range: 16-10 AWG (1.5 - 6 mm2) for solid conductors. Fully enclosed metal housing with fine ventilation grid to keep out small parts. Case -Free Space Dimensions - WxDxH in (mm) Weight - lbs (kg) 25 mm above and below, 25 mm left and right, 15 mm in front 25 mm above and below, 25 mm left and right, 10 mm in front 70 mm above and below, 25 mm left and right, 15 mm in front 4.88. x 1.97 x 4.55 (124.0 x 50.0 x 116.0) 4.88 x 2.56 x 4.55 (124.0 x 65.0 x 116.0) 4.88 x 3.26 x 4.55 (124.0 x 83.0 x 116.0) 1.6 (.73) 2.4 (1.10) 3.3 (1.50) 1. Not UL listed for DC input. 2. Input current ratings are conservatively specified with low input, worst case efficiency and power factor. 3. Losses are heat dissipation in watts at full load, nominal input line. 4. Ripple/noise is stated as typical values when measured with a 20 MHz, bandwidth scope and 50 Ohm resistor. 5. Full load, 100 Vac Input @ Tamb = +25°C Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © September 2019 131 Power Supplies SDN-P Specifications (Single Phase), 12 Vdc and 48 Vdc Output Description Catalog Number SDN 9-12-100P SDN 5-48-100P Input 115/230 Vac auto select Nominal Voltage -AC Range 85-132/176-264 Vac; 210 - 375 Vdc -DC Range 1 210 - 375 Vdc 47 - 63 Hz -Frequency Nominal Current 2 2.0 A / 1.5 A 4 A / 2.3 A -Inrush current max. Typ. < 20 A typ. < 40 A Efficiency (Losses 3) > 82 % (23.4 W) > 87 % (32.6 W) Units fulfill EN61000-3-2 Power Factor Correction Output Nominal Voltage Tolerance 12 V (11.6-15.2 Vdc Adj.) 48 V (35.8 - 52 Vdc Adj.) < ±2 % overall (combination Line, load, time and temperature related changes) -Line Regulation < 0.5% -Load Regulation < 0.5% < 1% -Time & Temp. Drift Ripple < 50 mVpp 4 Overvoltage Protection Nominal Current -Current Limit < 16 Vdc with auto-recovery < 60 Vdc with auto-recovery 9 A (108 W) 5 A (240 W) 110% of nominal - Fold Forward (Current rises, voltage drops to maintain constant power during overload up to max peak current) >20 ms @ full load Holdup Time 5 Supplies will not be damaged with parallel operation Parallel Operation Power Back Immunity 16 Vdc 60 Vdc General EMC: -Emissions -Immunity Temperature EN61000-6-3, EN61204-3, EN55022 Class B, EN61000-3-2, EN61000-3-3 EN61000-6-2, EN61204-3, EN55024, IEC61000-4-2, IEC61000-4-3, IEC61000-4-4, IEC61000-4-5, IEC61000-4-6, IEC61000-4-8, IEC610004-11 Storage: -25 to +85°C, Operation -10 to +60°C full power; with linear derating to half power from 60 to 70°C (Convection cooling, no forced air required). Operation up to 50% load permissible with sideways or front-side-up mounting orientation. < 90% RH, non-condensing; IEC 68-2-2, 68-2-3 Humidity >500,000 hrs MTBF: Telcordia/Bellcore, Issue Case 3 @ 25°C - Standard 5 year limited warranty Warranty General Protection/Safety Protected against continuous short -circuit, continuous overload, continuous open circuit. Protection Class I (IEC536), Degree of Protection IP20 (IEC 529) Safe low voltage: SELV (acc. EN60950) Status Indicators (Visual) Green LED on when Vout > 75% (with ± 5% tolerance) of nominal output voltage Status Indicators (Relay) Normally Open solid state relay - signal active when Vout >70% of nominal output voltage (rated up to 200 mA, 60 Vdc) Installation Fusing -Input -Output Mounting Connections Case Internally fused Outputs are capable of providing high currents for short periods of time for inductive load startup or switching. Fusing may be required if Nominal O/P current rating cannot be tolerated. Continuous current overload allows for reliable fuse tripping. Simple snap-on to DIN TS35/7.5 or TS35/15 rail system. Unit should handle normal shock and vibration of industrial use and transportation without falling off the rail. Input: Screw terminals, connector size range: 16-10 AWG (1.5-6 mm2) for solid conductors. Output: Two terminals per output, connector size range: 16-10 AWG (1.5-6 mm2) for solid conductors. Fully enclosed metal housing with fine ventilation grid to keep out small parts. 70 mm above and below, 25 mm left and right, 15 mm in front -Free Space Dimensions - WxDxH in (mm) Weight - lbs (kg) 4.88 × 2.56 × 4.55 (124.0 x 65.0 × 116.0) 4.88 × 3.23 × 4.55 (124.0 × 83.0 × 116.0) 2.4 (1.10) 3.3 (1.50) 1. Not UL listed for DC input. 2. Input current ratings are conservatively specified with low input, worst case efficiency and power factor. 3. Losses are heat dissipation in watts at full load, nominal input line. 132 4. Ripple/noise is stated as typical values when measured with a 20 MHz, bandwidth scope and 50 Ohm resistor. 5. Full load, 100 Vac Input @ Tamb = +25°C Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © September 2019 Power Supplies SDN-P Series Dimensions D W + + - - OK 24 VDC / 2.5 A OK NEC Class 2 Power Supply 24-28 V Single Parallel H S O LA Power Supply SDN 2.5-24-100P C U L ���� ���� �� ���� US LISTED 115/230 VAC 1.3-0.7 A 50/60 HZ N Catalog Number L Dimensions - inches (mm) H W D 12 Vdc SDN 9-12-100P 4.88 (124.0) 2.56 (65.0) 4.55 (116.0) SDN 16-12-100P 4.88 (124.0) 3.23 (83.0) 4.55 (116.0) 24 Vdc SDN 2.5-24-100P 4.88 (124.0) 1.97 (50.0) 4.55 (116.0) SDN 4-24-100LP 4.88 (124.0) 2.56 (65.0) 4.55 (116.0) SDN 5-24-100P 4.88 (124.0) 2.56 (65.0) 4.55 (116.0) SDN 10-24-100P 4.88 (124.0) 3.26 (83.0) 4.55 (116.0) SDN 5-48-100P 4.88 (124.0) 3.23 (83.0) 4.55 (116.0) 48 Vdc Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © September 2019 133 Power Supplies SDN-P Series Mounting DIN Rail Mounting Snap on the DIN Rail: 1. Tilt unit slightly backwards 2. Put it onto the DIN Rail 3. Push downwards until stopped 4. Push at the lower front edge to lock 5. Shake the unit slightly to ensure that the retainer has locked Alternative Panel Mount: Using the optional SDN-PMBRK2 accessory, the unit can be screw mounted to a panel. Detachment from DIN Rail: Chassis Mounting Dimensions - in. (mm) Instead of snapping a SolaHD SDN unit on the DIN Rail, you can also attach it using the screw mounting set SDN-PMBRK2. This set consists of two metal brackets, which replace the existing two aluminum profiles. .70 (17.8) .43 (10.9) 1.59 (40.4) .60 (15.2) .23 (5.8) .51 (13.0) .18 .86 (4.6) (21.8) .60 (15.2) 1.30 (33.0) 2.16 (54.9) 1.80 (45.7) .35 (8.9) .08 (2.0) .23 (5.8) 134 .40 (10.2) .25 (6.4) .26 (6.6) .52 (13.2) .52 (13.2) Visit our website at www.emerson.com or contact Technical Services at (800) 377-4384 with any questions. © September 2019
SDN10-24-100P 价格&库存
很抱歉,暂时无法提供与“SDN10-24-100P”相匹配的价格&库存,您可以联系我们找货
