Monitoring Relays
1-Phase True RMS AC Over or Under Current
Type DIB01 100A
• TRMS AC over or under current
monitoring relay
• Current measuring through built-in current transformer
• Selection of measuring range by DIP-switches
• Measuring ranges from 2 A to 100 A AC
• Adjustable current on relative scale
• Adjustable hysteresis on relative scale
• Adjustable delay function (0.1 to 30 s)
• Programmable latching or inhibit at set level
• Output: 8 A SPDT relay N.D. or N.E. selectable
• For mounting on DIN-rail in accordance with
DIN/EN 50 022
• 22.5 mm Euronorm housing
• LED indication for relay, alarm and power supply ON
• Galvanically separated power supply
Product Description
Ordering Key
DIB01 is a precise TRMS AC
(selectable by DIP-switch)
monitoring relay.
Owing to the built-in latch
function, the ON-position of
the relay output can be
maintained. Inhibit function
can be used to avoid relay
Housing
Function
Type
Item number
Output
Power supply
Measuring range
operation when not desired
(maintenance, transitions).
The LED's indicate the state
of the alarm and the output
relay. Through the built-in
current transformer it is possible to monitor loads up to
100 A AC.
DIB 01 C M24 100A
Type Selection
Mounting
Output
Measuring range
Supply: 24 VDC and 24 to 240 VAC
DIN-rail
SPDT
2 to 100 A AC
DIB 01 C M24 100A
Input Specifications
Input (current level)
DIB01 100A
Built-in current transformer
Measuring ranges
Selectable by DIP-switch
Max current
2 to 20 A AC
120 A
5 to 50 A AC
120 A
10 to 100 A AC
120 A
Max. current for 30 s
250 A
Max. current for 1 s 2000 A
Contact input
DIB01
Disabled
Enabled
Latch disable
Supply Specifications
Output Specifications
Power supply
Rated operational voltage
through terminals:
A1, A2
Output
Rated insulation voltage
Contact ratings (AgSnO2)
Resistive loads
AC 1
DC 12
Small inductive loads AC 15
DC 13
Mechanical life
Electrical life
Dielectric voltage
Supply to input
Supply to output
Input to output
Rated operational power
DC
AC
Overvoltage cat. III
(IEC 60664, IEC 60038)
24 VDC - 15% +10%
24 to 240 VAC ± 15%
45 to 65 Hz
4 kV
4 kV
4 kV
1W
1 W / 35 VA
Specifications are subject to change without notice (19.05.10)
Terminals A1, Y1
Open
< 10 kΩ
> 500 ms
SPDT relay
250 VAC
µ
8 A @ 250 VAC
5 A @ 24 VDC
2.5 A @ 250 VAC
2.5 A @ 24 VDC
≥ 30 x 106 operations
≥ 105 operations
(at 8 A, 250 V, cos ϕ = 1)
≤ 7200 operations/h
Operating frequency
Dielectric strength
Dielectric voltage
≥ 2 kVAC (rms)
Rated impulse withstand volt. 4 kV (1.2/50 µs)
1
DIB01 100A
General Specifications
Power ON delay
Reaction time
Alarm ON delay
Alarm OFF delay
Accuracy
Temperature drift
Delay ON alarm
Repeatability
Indication for
Power supply ON
Alarm ON
Output relay ON
Environment
Degree of protection
Pollution degree
Operating temperature
Storage temperature
1 s ± 0.5 s or 6 s ± 0.5 s
< 100 ms
< 100 ms
(15 min warm-up time)
± 500 ppm/°C
± 10% on set value ± 50 ms
± 0.5% on full-scale
LED, green
LED, red (flashing 2 Hz
during delay time)
LED, yellow
(EN 60529)
IP 20
3
-20 to 60°C, R.H. < 95%
-30 to 80°C, R.H. < 95%
Housing
Dimensions
Material
Weight
Screw terminals
Tightening torque
22.5 x 80 x 99.5 mm
PA66 or Noryl
Approx. 155 g
Max. 0.5 Nm
acc. to IEC 60947
EN 60255-6
UL, CSA
L.V. Directive 2006/95/EC
EMC Directive 2004/108/EC
Product standard
Approvals
CE Marking
EMC
Immunity
According to EN 60255-26
According to EN 61000-6-2
According to EN 61000-6-3
Emissions
Mode of Operation
DIB01 monitors AC over or
under current through an
internal current transformer.
Example 1
(connection between terminals A1, Y1 - latching function enabled - Relay ND)
The relay operates and
latches in operating position
when the measured value
exceeds (or drops below)
the set level for more than
the set delay time. Provided
that the current has dropped
below (or has exceeded) the
set point (see hysteresis setting), the relay releases
when the interconnection
between terminals A1, Y1 is
interrupted or the power
supply is interrupted as well.
The red LED flashes until the
delay time has expired.
Example 2
(no connection between terminals A1, Y1 - latch function disabled - Relay ND)
The relay operates when the
measured value exceeds (or
drops below) the set level for
more than the set delay
time. It releases when the
current drops below (or
exceeds) the set level (see
hysteresis setting) or when
power supply is interrupted.
Note
When the inhibit contact is
opened, if the input signal is
already in alarm position, the
delay time needs to elapse
before relay activation.
Function/Range/Level and Time Delay Setting
Adjust the input range setting DIP switches 1 and 2 as
shown below.
Select the desired function
setting DIP switches 3 to 6
as shown below.
To access the DIP switches
open the grey plastic cover
as shown below.
Selection of level and time
delay:
Upper knob:
Setting of hysteresis on relative scale: 0 to 30% on set
value.
Centre knob:
Current level setting on relative scale: 10 to 110% on
full scale.
2
Lower knob:
Setting of delay on alarm
time on absolute scale (0.1
to 30 s).
Measuring range
SW1
SW2
ON
OFF
20A
ON
ON
50A
OFF
ON
100A
OFF
OFF
100A
Relay working mode
ON: Normally De-energized
OFF: Normally Energized
Power ON delay
ON: 6 s ± 0.5 s
OFF: 1 s ± 0.5 s
Contact input
ON: Latch function enable
OFF: Inhibit function enable
Monitoring function
ON: Over current
OFF: Under current
DIB01 100A
Operation Diagrams
Over current - N.D. relay
Under current - Latch function - N.D. relay
Under current - N.D. relay
Over current - Inhibit function - N.D. relay
Wiring Diagram
Dimensions
22.5
L (+)
99.5
m
16
18
ø 12
A2
63
A1
83.5
I
80
Y1
15
N (-)
28.5
3
很抱歉,暂时无法提供与“DIB01CM24100A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+1938.36381
- 5+1809.10921
- 10+1679.85461
