2SB799
2SB799
    SK(時科)
    SOT89-3
    应用:可用于开关和放大。用于各种电气和电子设备
2SB799 数据手册
2SB799 PNP- Silicon General use Transistors 4 1W 、1.5A、25V Applications:Can be used for switching and amplifying in various 2 1 electrical and electronic circuit. 3 SOT-89 Maximum ratings Parameters Symbol Rating 25 Unit V Collector-emitter voltage (IB=0) VCEO Marking Collector-base voltage(IE=0) VCBO 40 V 2SB799=HD Emitter-base voltage(IC=0) VEBO 6 V IC 1.5 A Ptot 1 W Junction temperature Tjm 150 ℃ Storage temperature Tstg -55~150 ℃ Collector current Total dissipation * power(TA=25℃) * Device is mounted on a printed circuit board. Electrical characteristics(Unless otherwise specified,TA=25℃) Parameters Symbol Test condition Min. typ Max. Unit Collector-emitter breakdown voltage V(BR)CEO IC=2mA,IB=0 25 — — V Collector-base breakdown voltage V(BR)CBO IC=100µA,IE=0 40 — — V Emitter-base breakdown voltage V(BR)EBO IE=100µA,IC=0 6 — — V Forward current transfer ratio hFE VCE=1V;IC=100mA 200 — 300 — Collector-base current ICBO VCB=35V,IE=0 — — 100 nA VCE(sat) IC=800mA,IB=80mA — — 0.5 V fT IC=50mA,VCE=10V, f=100MHz 200 — — MHz Collector-emitter saturation voltage Characteristic frequency REV.08 1 of 2 2SB799 Outline Dimensions Unit:mm Dimensions Symbol A b b1 b2 c D E e e1 HE L LE α REV.08 2 of 2 min 1.4 0.35 0.4 SOT-89 type max 1.6 0.55 0.65 1.6 0.35 4.4 2.35 0.45 4.6 2.55 1.5 3 4.15 2.7 1.0 5o
2SB799 价格&库存
很抱歉,暂时无法提供与“2SB799”相匹配的价格&库存,您可以联系我们找货
2SB799
    • 1000+0.13020
    库存:13200
    2SB799
      • 1000+0.13020
      库存:600
