FN2070-25-08
FN2070-25-08
    SCHAFFNER(夏弗纳)
    FN2070-25-08
FN2070-25-08 数据手册
DATA SHEET High Performance Single-Phase Filters FN2070 Multi-stage Performance AC/DC EMI Filter Rated currents from 1 to 36 A Approvals & Compliances High differential and common-mode attenuation High frequency attenuation Optional medical versions (B type) Optional safety versions (A type) Features and Benefits FN2070 two-stage filters are designed for easy and fast chassis mounting FN2070 B versions without capacitors to earth comply to 1MOP for ME (medical equipment) acc. IEC 60601-1 FN2070 A version with low capacitance to earth for safety critical applications with necessity for low leakage currents Technical Specifications * ** Rated voltage* 250 VAC, 50/60 Hz; 250 VDC Operating frequency DC to 400 Hz Rated currents 1 to 36 A @ 40°C max High potential test voltage P –> PE 2000 VAC for 2 sec P –> PE 2500 VAC for 2 sec (B types) P –> N 1100 VDC for 2 sec Temperature range (operation and storage) -25°C to +100°C (25/100/21)** Certified to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 (applies to AC and DC applications) Flammability corresponding to Laces for -07 version: UL 94 VW-1 Terminal plastic for -06/-08 version: UL 94 V-0 Grommet for -07 version: UL 94V-0 Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Overvoltage category II acc. IEC 60664-1 Pollution degree 2 acc. IEC 60664-1 Altitude 2000m (above derating applies)** MTBF @ 40°C/230 V (Mil-HB-217F) 1,550,000 hours 1,600,000 hours (B types) maximum RMS operating voltage at rated frequency or the maximum DC operating voltage for dedicated requests exceeding this specification (e.g. -40 °C or higher altitude) please contact your local Schaffner Sales office All filters provide a high conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior FN2070 two-stage filters are designed for high frequency attenuation FN2070 filters are also available as single- stage filters (FN2030 series) FN2070 filters are also available with differential mode choke (FN2080 series) Various terminal options allow you to select the desired connection style Typical Applications Electrical and electronic equipment Consumer goods Household equipment Building automation Industrial applications Machinery Medical equipment Electronic data processing equipment Office automation and datacom equipment Various noisy applications requiering good filter performance Single Phase Motor Drives Typical electrical schematic 2 High Performance Single-Phase Filters Schaffner Group DATA SHEET 15. Jun 2022 Filter Selection Table Filter* Buy Rated current @ 40°C (25°C) Leakage current** Power Loss Inductance*** Capacitance*** Resistance*** @ 250 VAC/50 Hz @25°C/DC L Cx Cy R Input/Output Weight connections (@ 120 VAC/60 Hz) [A] [mA] [W] [mH] [μF] [nF] [kΩ] [g] FN2070-1-.. 1 (1.2) 0.66 (0.38) 2.4 22 0.33 4.7 1000 -06 -07 190 FN2070-3-.. 3 (3.5) 0.66 (0.38) 2.2 9.8 0.47 4.7 470 -06 -07 250 FN2070-6-.. 6 (6.9) 0.66 (0.38) 3.2 7.8 1 4.7 220 -06 -07 450 FN2070-10-.. 10 (11.5) 0.66 (0.38) 9.1 4.5 1 4.7 220 -06 -07 -08 670 FN2070-12-.. 12 (13.8) 0.66 (0.38) 13.1 3.25 1 4.7 220 -06 -07 -08 670 FN2070-16-.. 16 (18.4) 0.66 (0.38) 9.6 2.8 1 4.7 220 -06 -07 -08 1000 FN2070-25-08 25 (28.8) 0.66 (0.38) 11.6 2 2.2 4.7 220 -08 760 FN2070-36-08 36 (41.4) 0.66 (0.38) 13.1 1.23 2.2 4.7 220 -08 790 FN2070A-1-.. 1 (1.2) 0.07 (0.04) 2.4 22 0.33 0.47 1000 -06 -07 190 FN2070A-3-.. 3 (3.5) 0.07 (0.04) 2.2 9.8 0.47 0.47 470 -06 -07 250 FN2070A-6-.. 6 (6.9) 0.07 (0.04) 3.2 7.8 1 0.47 220 -06 -07 450 FN2070A-10-.. 10 (11.5) 0.07 (0.04) 9.1 4.5 1 0.47 220 -06 -07 -08 670 FN2070A-12-.. 12 (13.8) 0.07 (0.04) 13.1 3.25 1 0.47 220 -06 -07 -08 670 FN2070A-16-.. 16 (18.4) 0.07 (0.04) 9.6 2.8 1 0.47 220 -06 -07 -08 1000 FN2070A-25-08 25 (28.8) 0.07 (0.04) 11.6 2 2.2 0.47 220 -08 760 FN2070A-36-08 36 (41.4) 0.07 (0.04) 13.1 1.23 2.2 0.47 220 -08 790 FN2070B-1-.. 1 (1.2) 0.00 2.4 22 0.33 1000 -06 -07 190 FN2070B-3-.. 3 (3.5) 0.00 2.2 9.8 0.47 470 -06 -07 250 FN2070B-6-.. 6 (6.9) 0.00 3.2 7.8 1 220 -06 -07 450 FN2070B-10-.. 10 (11.5) 0.00 9.1 4.5 1 220 -06 -07 -08 FN2070B-12-.. 12 (13.8) 0.00 13.1 3.25 1 220 -06 -07 -08 670 FN2070B-16-.. 16 (18.4) 0.00 9.6 2.8 1 220 -06 -07 -08 1000 FN2070B-25-08 25 (28.8) 0.00 11.6 2 2.2 220 -08 760 FN2070B-36-08 36 (41.4) 0.00 13.1 1.23 2.2 220 -08 790 FN2070M-1-06 1 (1.2) 3.69 (2.13) 2.4 22 0.33 47 1000 -06 170 FN2070M-3-06 3 (3.5) 3.69 (2.13) 2.2 9.8 0.47 47 470 -06 250 FN2070M-6-06 6 (6.9) 3.69 (2.13) 3.2 7.8 1 47 220 -06 450 FN2070M-10-.. 10 (11.5) 3.69 (2.13) 9.1 4.5 1 47 220 -06 -08 670 FN2070M-12-.. 12 (13.8) 3.69 (2.13) 13.1 3.25 1 47 220 -06 -08 670 FN2070M-16-.. 16 (18.4) 3.69 (2.13) 9.6 2.8 1 47 220 -06 -08 1000 FN2070M-25-08 25 (28.8) 3.69 (2.13) 11.6 2 2.2 47 220 -08 750 FN2070L-36-08 36 (41.4) 2.59 (1.49) 13.1 1.23 2.2 33 220 -08 790 670 Enhanced performance * To compile a complete part number, please replace the -.. with the required I/O connection style (e.g. FN 2070-25-08, FN 2070B-10-06). ** Maximum leakage under usual AC operating conditions (acc. IEC60939-3). Note: if the neutral line is interrupted, worst case leakage could reach twice this level. *** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% 3 High Performance Single-Phase Filters Schaffner Group DATA SHEET 15. Jun 2022 Typical Filter Attenuation Per CISPR 17; CM=50 Ω/50 Ω sym; DM=50 Ω/50 Ω asym; 1 A: Standard type A type B type Enhanced performance 3 A: Standard type A type B type Enhanced performance 6 A: Standard type A type B type Enhanced performance 10 A: Standard type A type B type Enhanced performance 12 A: Standard type A type B type Enhanced performance 4 High Performance Single-Phase Filters Schaffner Group DATA SHEET 15. Jun 2022 16 A: Standard type A type B type Enhanced performance 25 A: Standard type A type B type Enhanced performance 36 A: Standard type A type B type Enhanced performance 5 High Performance Single-Phase Filters Schaffner Group DATA SHEET Product selector Mechanical Data Connection style -06, 1 and 3 A types Connection style -06, 6 to 12 A types Connection style -06, 16 A types Connection style -07, 1 to 16 A types (same dimensions as style -06) Connection style -07, 6 to 12 A types (same dimensions as style -06) Connection style -07, 16 A types (same dimensions as style -06) Connection style -08, 16 A type Connection style -08, 10 A, 12 A, 25 A and 36 A types 15. Jun 2022 6 High Performance Single-Phase Filters Schaffner Group DATA SHEET 15. Jun 2022 Dimensions 1A 3A 6A 10 A 12 A 16 A 25 A 36 A Tolerances A 85 ±0.5 85 ±0.5 113.5 156 156 119 156 156 ±1 B 54 ±0.5 54 ±0.5 57.5 57.5 57.5 85.5 57.5 57.5 ±1 C 30.3 ±0.5 40.3 ±0.5 45.4 45.4 45.4 57.6 45.4 45.4 ±1 D 64.8 ±0.5 64.8 ±0.5 94 130.5 130.5 98.5 130.5 130.5 ±1 E 49.8 49.8 56 56 56 84.5 56 56 ±0.5 F 75 75 103 143 143 109 143 143 ±0.3 G 27 27 25 25 25 40 25 25 ±0.2 H 12.3 12.3 12.4 12.4 12.4 15.6 12.4 12.4 ±0.5 I 20.8 29.8 32.4 32.5 32.5 32.5 32.5 ±0.5 J 19.9 11.4 15.5 15.5 15.5 42.25 15.5 15.5 ±0.5 K 5.3 5.3 4.4 5.3 5.3 4.4 5.3 5.3 L 6.3 6.3 6 6 6 7.4 6 6 M 0.7 0.7 1 1 1 1.2 1 1 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 6.3 x 0.8 O 8.3 8.3 8.4 8.4 8.4 8.6 ±0.5 P 14.9 14.9 18 18 18 42.25 ±0.5 AWG type wire AWG 20 AWG 20 AWG 18 AWG 18 AWG 16 AWG 16 Wire length 140 140 140 140 140 140 M4 M4 M4 Recommended torque (Nm) 1.2 - 1.3 1.2 - 1.3 Earth terminal 1.5 - 1.7 1.5 - 1.7 ±0.3 Connection style -06 N Connection style -07 +5 Connection style -08 N Q All dimensions in mm; 1 inch = 25.4 mm Please visit www.schaffner.com to find more details on filter connections. M4 M4 1.2 - 1.3 1.2 - 1.3 1.2 - 1.3 1.5 - 1.7 1.5 - 1.7 1.5 - 1.7 51 ±0.2 7 High Performance Single-Phase Filters Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 15. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN2070-25-08 价格&库存
很抱歉,暂时无法提供与“FN2070-25-08”相匹配的价格&库存,您可以联系我们找货
FN2070-25-08
  • 1+1002.17720
  • 10+909.73700
库存:44
FN2070-25-08
  • 10+714.17854
  • 20+696.32255
  • 40+685.61239
库存:489
