BZT52B24
BZT52B24
    SK(時科)
    SOD-123
    特性:总功耗:最大500mW。 宽齐纳反向电压范围:2.0V至75V。 小型塑料封装,适合表面贴装设计。 公差约为±2%
BZT52B24 数据手册
BZT52B2V4 THRU BZT52B43 SOD-123 Plastic-Encapsulate Diodes SOD-123 1.80(.071) 1.40(.055) FEATURES: z z 3.86(0.152) Planar Die Construction 2.84(0.112) 3.56(0.145) 2.54(0.100) 500mW Power Dissipation on Ceramic PCB .71(0.028) z General Purpose, Medium Current .50(0.020) .15(.006) z Ideally Suited for Automated Assembly Processes z Available in Lead Free Version 1.35(.053) MAX .94(.037) .25(.010) MIN Dimensions in millimeters and (inches) Maximum Ratings(Ta=25 ℃ unless otherwise specified) Characteristic Forward Voltage (Note 2) Symbol Value Unit VF 0.9 V Pd 500 mW ℃ /W @ IF = 10mA Power Dissipation(Note 1) Thermal Resistance, Junction to Ambient Air RθJA 357 Operating and Storage Temperature Range Tj,TSTG -65 ~ +150 ℃ 2 Notes:1. Device mounted on ceramic PCB; 7.6mm x 9.4mm x 0.87mm with pad areas 25mm . 2. Short duration test pulse used to minimize self-heating effect. 3. f = 1kHz. REV.08 1 of 2 BZT52B2V4 THRU BZT52B43 Electrical Characteristics( T a = 25°C unless otherwise specified) Type Type Number Code Maximum Zener Impedance Zener Voltage Range (Note 2) VZ@IZT Nom(V) Maximum Reverse (Note 4) IZT ZZT@IZT Min(V) Max(V) mA ZZK@IZK Ω Current IZK mA IR VR uA V Typical Temperature Coefficent @IZTC Test Current IZTC mV/°C Min Max mA BZT52B2V4 2WX 2.4 2.35 2.45 5 100 600 1.0 50 1.0 -3.5 0 5 BZT52B2V7 2W1 2.7 2.65 2.75 5 100 600 1.0 20 1.0 -3.5 0 5 BZT52B3V0 2W2 3.0 2.94 3.06 5 95 600 1.0 10 1.0 -3.5 0 5 BZT52B3V3 2W3 3.3 3.23 3.37 5 95 600 1.0 5 1.0 -3.5 0 5 BZT52B3V6 2W4 3.6 3.53 3.67 5 90 600 1.0 5 1.0 -3.5 0 5 BZT52B3V9 2W5 3.9 3.82 3.98 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52B4V3 2W6 4.3 4.21 4.39 5 90 600 1.0 3 1.0 -3.5 0 5 BZT52B4V7 2W7 4.7 4.61 4.79 5 80 500 1.0 3 2.0 -3.5 0.2 5 BZT52B5V1 2W8 5.1 5.00 5.20 5 60 480 1.0 2 2.0 -2.7 1.2 5 BZT52B5V6 2W9 5.6 5.49 5.71 5 40 400 1.0 1 2.0 -2.0 2.5 5 BZT52B6V2 2WA 6.2 6.08 6.32 5 10 150 1.0 3 4.0 0.4 3.7 5 BZT52B6V8 2WB 6.8 6.66 6.94 5 15 80 1.0 2 4.0 1.2 4.5 5 BZT52B7V5 2WC 7.5 7.35 7.65 5 15 80 1.0 1 5.0 2.5 5.3 5 BZT52B8V2 2WD 8.2 8.04 8.36 5 15 80 1.0 0.7 5.0 3.2 6.2 5 BZT52B9V1 2WE 9.1 8.92 9.28 5 15 100 1.0 0.5 6.0 3.8 7.0 5 BZT52B10 2WF 5 20 150 1.0 0.2 7.0 4.5 8.0 5 BZT52B11 2WG 11 10.78 11.22 5 20 150 1.0 0.1 8.0 5.4 9.0 5 BZT52B12 2WH 12 11.76 12.24 5 25 150 1.0 0.1 8.0 6.0 10.0 5 10 9.80 10.20 BZT52B13 2WI 13 12.74 13.26 5 30 170 1.0 0.1 8.0 7.0 11.0 5 BZT52B15 2WJ 15 14.70 15.30 5 30 200 1.0 0.1 10.5 9.2 13.0 5 BZT52B16 2WK 16 15.68 16.32 5 40 200 1.0 0.1 11.2 10.4 14.0 5 BZT52B18 2WL 18 17.64 18.36 5 45 225 1.0 0.1 12.6 12.4 16.0 5 BZT52B20 2WM 20 19.60 20.40 5 55 225 1.0 0.1 14.0 14.4 18.0 5 BZT52B22 2WN 22 21.56 22.44 5 55 250 1.0 0.1 15.4 16.4 20.0 5 BZT52B24 2WO 24 23.52 24.48 5 70 250 1.0 0.1 16.8 18.4 22.0 5 BZT52B27 2WP 27 26.46 27.54 2 80 300 0.5 0.1 18.9 21.4 25.3 2 BZT52B30 2WQ 30 29.40 30.60 2 80 300 0.5 0.1 21.0 24.4 29.4 2 BZT52B33 2WR 33 32.34 33.66 2 80 325 0.5 0.1 23.1 27.4 33.4 2 BZT52B36 2WS 36 35.28 36.72 2 90 350 0.5 0.1 25.2 30.4 37.4 2 BZT52B39 2WT 39 38.22 39.78 2 130 350 0.5 0.1 27.3 33.4 41.2 2 BZT52B43 2WU 43 41.16 42.84 2 130 350 0.5 0.1 29.4 36.4 45.2 2 REV.08 2 of 2
BZT52B24 价格&库存
很抱歉,暂时无法提供与“BZT52B24”相匹配的价格&库存,您可以联系我们找货
BZT52B24
  • 50+0.15228
  • 500+0.12572
  • 3000+0.10228
  • 6000+0.09342
  • 24000+0.08576
  • 51000+0.08154
库存:1210
