ES5AC THRU ES5JC
Super Fast Rectifier
DO-214AB(SMC)
Mounting Pad Layout
Features
.129(3.27)
.112(2.85)
Io 5.0A
VRRM 50V-600V
.245(6.22)
.220(5.59)
0.151
(3.84)
.280(7.11)
.260(6.60)
High surge current capability
0.150
(3.82)
.103(2.61)
.078(1.99)
Applications
.008(0.20)
.004(0.10)
.060(1.52)
.030(0.76)
Rectifier
.320(8.13)
.305(7.75)
0.119(3.03)
0.390
(9.90)
.012(0.31)
.006(0.15)
Dimensions in inches and (millimeters)
Limiting Values (Absolute Maximum Rating)
ES5
Item
Symbol Unit
Conditions
A
B
C
D
F
VRRM
V
Average Forward Current
IF(AV)
A
60Hz Half-sine wave, Resistance
load, Ta=50
5.0
Surge(Non-repetitive)Forward
Current
IFSM
A
60Hz Half-sine wave,1 cycle,
Ta=25
150
Repetitive Peak Reverse Voltage
Junction
Storage Temperature
-55~+150
TSTG
-55 ~ +150
Electrical Characteristics (Ta=25
Item
Peak Forward Voltage
Symbol
Unit
VFM
V
IRRM1
Peak Reverse Current
IRRM2
trr
Reverse Recovery time
Thermal
Resistance(Typical)
R
J-A
R
J-L
A
ns
W
H
J
50 100 150 200 300 400 500 600
TJ
Temperature
G
Unless otherwise specified)
Test Condition
IFM=5.0A
ES5
A
B
C
D
F
0.95
1.3
Ta=25
10
Ta=125
IF=0.5A IR=1A
IRR=0.25A
500
VRM=VRRM
Between junction and ambient
Between junction and lead
G
H
J
1.7
35
50
15
Notes:
1)
Thermal resistance from junction to ambient and from junction to lead mounted on P.C.B. with 0.3" x 0.3" (8.0 mm x 8.0 mm) copper
pad areas
REV.08
1 of 2
ES5AC THRU ES5JC
FIG.1
FIG.2: MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT
FORWARD CURRENT DERATING CURVE
175
5.0
150
4.0
8.3ms Single Half Sine Wave
JEDEC Method
3.0
100
2.0
50
ingle Phase
Half Wave 60HZ
Resisteve or
Inductive Load
0.375''(9.5mm)
Lead Length
1.0
FIG.3
100
Ta
1
2
10
Number of Cycles
TYPICAL FORWARD CHARACTERISTICS
FIG.4:TYPICAL REVERSE CHARACTERISTICS
ES5A-ES5D
ES5F-ES5G
10
100
4.0
ES5H-ES5J
2.0
Tj=125
1.0
10
0.4
Tj=100
0.2
1.0
0.1
0.02
0.01
0.6
Tj=25
TJ=25
Pulse width=300us
1% Duty Cycle
0.8
1.0
1.2
1.4
1.6
1.8
0.1
0.01
60
80
100
VF(V)
Voltage(%)
FIG.5: Diagram of circuit and Testing wave form of reverse recovery time
I
D
t rr
IF
VR
IF
RL
t
I RR
IR
REV.08
2 of 2
很抱歉,暂时无法提供与“ES5GC”相匹配的价格&库存,您可以联系我们找货
