AMS1086CM-3.3
AMS1086CM-3.3
    AMSOSRAM(艾迈斯半导体)
    TO263-3
    AMS1086CM-3.3
AMS1086CM-3.3 数据手册
Advanced Monolithic Systems AMS1086 1.5A LOW DROPOUT VOLTAGE REGULATOR RoHS compliant FEATURES APPLICATIONS • Three Terminal Adjustable or Fixed Voltages 1.5V, 1.8V, 2.5V, 2.85V, 3.0V, 3.3V, 3.5V and 5.0V • Output Current of 1.5A • Operates Down to 1V Dropout • Line Regulation: 0.015% • Load Regulation: 0.1% • TO-220, TO-263, TO-252 and SOT-223 packages available • High Efficiency Linear Regulators • Post Regulators for Switching Supplies • Microprocessor Supply • Battery Chargers • Constant Current Regulators • Notebook/Personal Computer Supplies • Portable Instrumentation GENERAL DESCRIPTION The The AMS1086 series of adjustable and fixed voltage regulators are designed to provide 1.5A output current and to operate down to 1V input-to-output differential. The dropout voltage of the device is guaranteed maximum 1.5V at maximum output current, decreasing at lower load currents. On-chip trimming adjusts the reference voltage to 1%. Current limit is also trimmed, minimizing the stress under overload conditions on both the regulator and power source circuitry. The AMS1086 devices are pin compatible with older three-terminal regulators and are offered in 3 lead TO-220 package, 3 lead TO-263 (Plastic DD), TO-252 (D PAK) and SOT-223 package. ORDERING INFORMATION: PACKAGE TYPE 3 LEAD TO-220 AMS1086CT AMS1086CT-1.5 AMS1086CT-1.8 AMS1086CT-2.5 AMS1086CT-2.85 AMS1086CT-3.0 AMS1086CT-3.3 AMS1086CT-3.5 AMS1086CT-5.0 SOT-223 AMS1086 AMS1086-1.5 AMS1086-1.8 AMS1086-2.5 AMS1086-2.85 AMS1086-3.0 AMS1086-3.3 AMS1086-3.5 AMS1086-5.0 OPERATING JUNCTION 3 LEAD TO-263 AMS1086CM AMS1086CM-1.5 AMS1086CM-1.8 AMS1086CM-2.5 AMS1086CM-2.85 AMS1086CM-3.0 AMS1086CM-3.3 AMS1086CM-3.5 AMS1086CM-5.0 TO-252 AMS1086CD AMS1086CD-1.5 AMS1086CD-1.8 AMS1086CD-2.5 AMS1086CD-2.85 AMS1086CD-3.0 AMS1086CD-3.3 AMS1086CD-3.5 AMS1086CD-5.0 TEMPERATURE RANGE -40 to 125° C -40 to 125° C -40 to 125° C -40 to 125° C -40 to 125° C -40 to 125° C -40 to 125° C -40 to 125° C -40 to 125° C TO-220 FRONT VIEW PIN CONNECTIONS TO-252 FRONT VIEW FIXED VERSION ADJUSTABLE VERSION 1- Ground 2- VOUT 3- VIN 1- Ground 2- VOUT 3- VIN TAB IS OUTPUT 3 2 1 TAB IS OUTPUT 2 1 TO-263 FRONT VIEW TAB IS OUTPUT Advanced Monolithic Systems, Inc. 3 3 2 1 www.advanced-monolithic.com 1 Phone (925) 443-0722 2 3 Fax (925) 443-0723 AMS1086 ABSOLUTE MAXIMUM RATINGS (Note 1) Power Dissipation Input Voltage Operating Junction Temperature Range Control Section Power Transistor Storage temperature Soldering information Lead Temperature (25 sec) Internally limited 15V -40°C to 125°C -40°C to 150°C - 65°C to +150°C 265°C Thermal Resistance TO-220 package TO-263 package TO-252 package SOT-223 package ϕ JA= 50°C/W ϕ JA= 30°C/W * ϕ JA= 100°C/W ϕ JA= 90°C/W** * With package soldering to 0.5in2 copper area over backside ground plane or internal power plane ϕ JA can vary from 20°C/W to >40°C/W depending on mounting technique. **With package soldering to copper area over backside ground plane or internal power plane ϕ JA can vary from 46°C/W to >90°C/W depending on mounting technique and the size of the copper area. ELECTRICAL CHARACTERISTICS Electrical Characteristics at IOUT = 0 mA, CO=10µF and TJ = +25°C unless otherwise specified. Parameter Device Conditions Min Reference Voltage (Note 2) AMS1086 IOUT = 10 mA 10mA ≤ IOUT ≤ 1.5A, 1.5V≤ (VIN - VOUT) ≤ 12V 1.238 1.225 1.250 1.250 1.262 1.270 V V Output Voltage (Note 2) AMS1086-1.5 0 ≤ IOUT ≤ 1.5A , 3V≤ VIN ≤ 12V 1.485 1.470 1.500 1.500 1.515 1.530 V V AMS1086-1.8 0 ≤ IOUT ≤ 1,5A , 3.3V≤ VIN ≤ 12V 1.782 1.773 1.800 1.800 1.818 1.827 V V AMS1086-2.5 0 ≤ IOUT ≤ 1.5A , 4V≤ VIN ≤ 12V 2.475 2.450 2.500 2.500 2.525 2.550 V V AMS1086-2.85 0 ≤ IOUT ≤ 1.5A , 4.35V≤ VIN ≤ 12V 2.82 2.79 2.850 2.850 2.88 2.91 V AMS1086-3.0 0 ≤ IOUT ≤ 1.5A , 4.5V ≤ VIN ≤ 12V 2.970 2.940 3.000 3.000 3.300 3.360 V V AMS1086-3.3 0 ≤ IOUT ≤ 1.5A , 4.75V ≤ VIN ≤ 12V 3.267 3.235 3.300 3.300 3.333 3.365 V V AMS1086-3.5 0 ≤ IOUT ≤ 1.5A , 5V ≤ VIN ≤ 12V 3.465 3.430 3.500 3.500 3.535 3.570 V V AMS1086-5.0 0 ≤ IOUT ≤ 1.5A , 6.5V ≤ VIN ≤ 12V 4.950 4.900 5.000 5.000 5.050 5.100 V V Line Regulation AMS1086/-1.5/-1.8/-2.5/2.85/ -3.0/-3.3/-3.5/-5.0 ILOAD = 10 mA , 1.5V≤ (VIN - VOUT) ≤ 12V 03 0.6 6 10 mV mV Load Regulation AMS1086 (VIN - VOUT) =3V, 10mA ≤ IOUT ≤ 1.5A 0.1 0.2 0.3 0.4 % % AMS1086-1.5/ -1.8/ -2.5/ 2.85/ -3.0 VIN = 5V, 0 ≤ IOUT ≤ 1.5A 3 6 12 20 mV mV AMS1086-3.3 VIN = 5V, 0 ≤ IOUT ≤ 1.5A 3 7 15 25 mV mV AMS1086-3.5 VIN = 5.25V, 0 ≤ IOUT ≤ 1.5A 3 6 15 25 mV mV AMS1086-5.0 VIN = 8V, 0 ≤ IOUT ≤ 1.5A 5 10 20 35 mV mV Dropout Voltage (VIN - VOUT) AMS1086/-1.5/-1.8/-2.5/2.85/ -3.0/-3.3/-3.5/-5.0 ∆VOUT , ∆VREF = 1%, IOUT = 1.5 A (Note 4) 1.3 1.5 V Current Limit AMS1086/-1.5/-1.8/-2.5/2.85/ -3.0/-3.3/-3.5/-5.0 (VIN - VOUT) = 5V 2.0 2.8 A (Notes 2, 3) Advanced Monolithic Systems, Inc. www.advanced-monolithic.com 1.5 Typ Phone (925) 443-0722 Max Units Fax (925) 443-0723 AMS1086 ELECTRICAL CHARACTERISTICS Electrical Characteristics at IOUT = 0 mA, CO=10µF and TJ = +25°C unless otherwise specified. Parameter Device Conditions Minimum Load Current AMS1086 (VIN - VOUT) = 12V (Note 5) 5 10 mA Quiescent Current AMS1086/-1.5/-1.8/-2.5/2.85/ -3.0/-3.3/-3.5/-5.0 VIN ≤ 12V 5 10 mA Ripple Rejection AMS1086 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A, (VIN-VOUT ) = 3V, CADJ =25µF 60 75 dB AMS1086-1.5 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A, VIN = 4.5V 60 72 dB AMS1086-1.8 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A, VIN = 4.5V 60 72 dB AMS1086-2.5 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A, VIN =5.5V 60 72 dB AMS1086-2.85 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A, VIN = 6V 60 72 dB AMS1086-3.0 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A VIN = 6V 60 72 dB AMS1086-3.3 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A VIN = 6.3V 60 72 dB AMS1086-3.5 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A VIN = 6.5V 60 72 dB AMS1086-5.0 f =120Hz , COUT = 25µF Tantalum, IOUT = 1.5A VIN = 8V 60 68 dB Thermal Regulation AMS1086 TA = 25°C, 30ms pulse Adjust Pin Current AMS1086 10mA ≤ IOUT ≤ 1.5A , 1.5V≤ (VIN - VOUT) ≤ 12V Adjust Pin Current AMS1086 Min Typ 0.008 10mA ≤ IOUT ≤ 1.5A , 1.5V≤ (VIN - VOUT) ≤ 12V Max 0.04 %W 120 µA µA 5 µA 55 0.2 Units Change Temperature Stability % 0.5 Long Term Stability TA =125°C, 1000Hrs RMS Output Noise TA = 25°C , 10Hz ≤ f ≤ 10kHz 0.3 1 0.003 % % (% of VOUT ) Thermal Resistance Junction-to-Case M Package: Control Circuitry/ Power Transistor T Package: Control Circuitry/ Power Transistor 1.5/4.0 1.5/4.0 °C/W °C/W Parameters identified with boldface type apply over the full operating temperature range. Note 1: Absolute Maximum Ratings indicate limits beyond which damage to the device may occur. For guaranteed specifications and test conditions, see the Electrical Characteristics. The guaranteed specifications apply only for the test conditions listed. Note 2: Line and Load regulation are guaranteed up to the maximum power dissipation of 15W. Power dissipation is determined by the input/output differential and the output current. Guaranteed maximum power dissipation will not be available over the full input/output range. Note 3: See thermal regulation specifications for changes in output voltage due to heating effects. Line and load regulation are measured at a constant junction temperature by low duty cycle pulse testing. Load regulation is measured at the output lead ~1/8” from the package. Note 4: Dropout voltage is specified over the full output current range of the device. Note 5: Minimum load current is defined, as the minimum output current required to maintain regulation. When (VIN - VOUT) = 12V the device is guaranteed to regulate if the output current is greater than 10mA. Advanced Monolithic Systems, Inc. www.advanced-monolithic.com Phone (925) 443-0722 Fax (925) 443-0723 AMS1086 APPLICATION HINTS The AMS1086 series of adjustable and fixed regulators are easy to use and have all the protection features expected in high performance voltage regulators: short circuit protection and thermal shutdown. Pin compatible with older three terminal adjustable regulators, these devices offer the advantage of a lower dropout voltage, more precise reference tolerance and improved reference stability with temperature. D1 AMS1086 IN OUT ADJ VIN Stability CADJ 1µF The circuit design used in the AMS1086 series requires the use of a 10µF output capacitor as part of the device frequency compensation. If the output voltage is set for 3.0V or higher, AMS1086 will operate with an output capacitor as low as 1µF tantalum or 3.3µF electrolytic and CADJ as low as 0.5µF. For output voltages lower than 3.0V, CADJ capacitor value should be minimum 1µF to ensure stability. To improve stability and transient response, larger values of output capacitor can be used. Protection Diodes Unlike older regulators, the AMS1086 family does not need any protection diodes between the adjustment pin and the output and from the output to the input to prevent over-stressing the die. Internal resistors are limiting the internal current paths on the AMS1086 adjustment pin, therefore even with capacitors on the adjustment pin no protection diode is needed to ensure device safety under short-circuit conditions. Diodes between the input and output are not usually needed. Microsecond surge currents of 50A to 100A can be handled by the internal diode between the input and output pins of the device. In normal operations it is difficult to get those values of surge currents even with the use of large output capacitances. If high value output capacitors are used, such as 1000µF to 5000µF and the input pin is instantaneously shorted to ground, damage can occur. A diode from output to input is recommended, when a crowbar circuit at the input of the AMS1086 is used. Normal power supply cycling or even plugging and unplugging in the system will not generate current large enough to do any damage. The adjustment pin can be driven on a transient basis ±25V, with respect to the output without any device degradation. As with any IC regulator, none the protection circuitry will be functional and the internal transistors will break down if the maximum input to output voltage differential is exceeded. VOUT R1 + COUT 10µF R2 Overload Recovery When the power is first turned on, as the input voltage rises, the output follows the input, permitting the regulator to start up into heavy loads. During the start-up, as the input voltage is rising, the input-to-output voltage differential remains small, allowing the regulator to supply large output currents. A problem can occur with a heavy output load when the input voltage is high and the output voltage is low, when the removal of an output short will not permit the output voltage to recover. The load line for such a load may intersect two points on the output current curve. In this case, there are two stable output operating points for the regulator. With this double intersection, the power supply may need to be cycled down to zero and brought up again to make the output recover. Ripple Rejection The ripple rejection values are measured with the adjustment pin bypassed. The impedance of the adjust pin capacitor at the ripple frequency should be less than the value of R1 (normally 100Ω to120Ω) for a proper bypassing and ripple rejection approaching the values shown. The size of the required adjust pin capacitor is a function of the input ripple frequency. If R1=100Ω at 120Hz the adjust pin capacitor should be 25µF. At 10kHz only 0.22µF is needed. The ripple rejection will be a function of output voltage, in circuits without an adjust pin bypass capacitor. The output ripple will increase directly as a ratio of the output voltage to the reference voltage (VOUT / VREF). Output Voltage The AMS1086 series develops a 1.25V reference voltage between the output and the adjust terminal. Placing a resistor between these two terminals causes a constant current to flow through R1 and down through R2 to set the overall output voltage. Advanced Monolithic Systems, Inc. www.advanced-monolithic.com Phone (925) 443-0722 Fax (925) 443-0723 AMS1086 APPLICATION HINTS This current is normally the specified minimum load current of 10mA. Because IADJ is very small and constant it represents a small error and it can usually be ignored. AMS1086 IN OUT ADJ VIN VOUT VREF IADJ 50µA R2 Figure 1. Basic Adjustable Regulator Load Regulation True remote load sensing it is not possible to provide, because the AMS1086 is a three terminal device. The resistance of the wire connecting the regulator to the load will limit the load regulation. The data sheet specification for load regulation is measured at the bottom of the package. Negative side sensing is a true Kelvin connection, with the bottom of the output divider returned to the negative side of the load. The best load regulation is obtained when the top of the resistor divider R1 is connected directly to the case not to the load. If R1 were connected to the load, the effective resistance between the regulator and the load would be: VIN AMS1086 IN OUT ADJ RP = Parasitic Line Resistance RP PARASITIC LINE RESISTANCE R1* Thermal Considerations R1 VOUT = VREF (1+ R2/R1)+IADJR2 RP x ( R2+R1 ) , R1 Connected as shown, RP is not multiplied by the divider ratio. Using 16-gauge wire the parasitic line resistance is about 0.004Ω per foot, translating to 4mV/ft at 1A load current. It is important to keep the positive lead between regulator and load as short as possible and use large wire or PC board traces. The AMS1086 series have internal power and thermal limiting circuitry designed to protect the device under overload conditions. However maximum junction temperature ratings should not be exceeded under continuous normal load conditions. Careful consideration must be given to all sources of thermal resistance from junction to ambient, including junction-to-case, case-to-heat sink interface and heat sink resistance itself. To ensure safe operating temperatures and reflect more accurately the device temperature, new thermal resistance specifications have been developed. Unlike older regulators with a single junction-to-case thermal resistance specification, the data section for these new regulators provides a separate thermal resistance and maximum junction temperature for both the Control Section and the Power Transistor. Calculations for both temperatures under certain conditions of ambient temperature and heat sink resistance and to ensure that both thermal limits are met. Junction-to-case thermal resistance is specified from the IC junction to the bottom of the case directly below the die. This is the lowest resistance path for the heat flow. In order to ensure the best possible thermal flow from this area of the package to the heat sink proper mounting is required. Thermal compound at the case-to-heat sink interface is recommended. A thermally conductive spacer can be used, if the case of the device must be electrically isolated, but its added contribution to thermal resistance has to be considered. RL R2* *CONNECT R1 TO CASE CONNECT R2 TO LOAD Figure 2. Connections for Best Load Regulation Advanced Monolithic Systems, Inc. www.advanced-monolithic.com Phone (925) 443-0722 Fax (925) 443-0723 AMS1086 TYPICAL PERFORMANCE CHARACTERISTICS Dropout Voltage Load Regulation TJ =25° C 1 TJ =150° C 0 0.5 1 1.5 OUTPUT CURRENT (A) 2.0 ∆I = 1.5A 0.05 0 -0.05 -0.10 -0.15 -0.20 -50 -25 Ripple Rejection (VIN-VOUT) ≥ 3V 40 (VIN-VOUT)≥VDROPOUT 30 20 IOUT= 1.5A 10 0 100 1k 10k FREQUENCY (Hz) 80 60 fR =20kHz VRIPPLE≤ 0.5VP-P 50 40 30 20 VOUT = 5V CADJ = 25µF COUT =25µF 0 C ADJ = 0 0 -0.1 C IN = 1µF C OUT = 10µF TANTALUM -0.2 -0.3 1.5 ~ ~ 1.0 ~ ~ VOUT = 10V VIN = 13V PRELOAD = 100mA 0.5 0 0 50 TIME (µs) 2.0 1.5 1.0 0.5 0 0.25 0.5 0.75 1.0 1.25 1.5 OUTPUT CURRENT 4 6 0 2 8 10 12 14 INPUT/OUTPUT DIFFERENTIAL (V) Maximum Power Dissipation* Line Transient Response 100 INPUT OUTPUT VOLTAGE DEVIATION (V) DEVIATION (mV) LOAD OUTPUT VOLTAGE CURRENT (A) DEVIATION (V) Load Transient Response 0.1 Short-Circuit Current fR = 120Hz VRIPPLE≤ 3VP-P 70 100k 0 25 50 75 100 125 150 TEMPERATURE (° C) 2.5 10 0 0.3 0.2 -2.0 -50 -25 SHORT-CIRCUIT CURRENT (A) RIPPLE REJECTION (dB) VRIPPLE≤ 0.5VP-P 60 50 -1.0 0 25 50 75 100 125 150 TEMPERATURE (° C) 100 90 RIPPLE REJECTION (dB) VRIPPLE≤ 3VP-P 0 Ripple Rejection vs. Current 80 70 1.0 20 60 40 CADJ = 0 20 15 0 -20 -40 -60 14 ~ ~ VOUT = 10V IIN = 0.2A CIN = 1µF TANTALUM COUT = 10µF TANTALUM ~ ~ POWER (W) 0 Temperature Stability 0.10 OUTPUT VOLTAGE CHANGE (%) OUTPUT VOLTAGE DEVIATION (%) MINIMUM INPUT/OUTPUT DIFFERENTIAL (V) 2 10 5 13 12 0 0 100 TIME (µs) 200 50 60 70 80 90 100 110 120 130 140 150 CASE TEMPERATURE (° C) *AS LIMITED BY MAXIMUM JUNCTION TEMPERATURE Advanced Monolithic Systems, Inc. www.advanced-monolithic.com Phone (925) 443-0722 Fax (925) 443-0723 AMS1086 TYPICAL PERFORMANCE CHARACTERISTICS (Continued) Adjust Pin Current (Adjustable only) 10 100 9 90 ADJUST PIN CURRENT ( µA) MINIMUM OPERATING CURRENT (mA) Minimum Operating Current (Adjustable only) 8 7 6 5 4 TJ = 150° C 3 2 1 0 TJ = 25° C 0 2 4 6 8 10 12 14 INPUT/OUTPUT DIFFERENTIAL (V) Advanced Monolithic Systems, Inc. 80 70 60 50 40 30 20 10 0 -50 -25 www.advanced-monolithic.com 0 25 50 75 100 125 150 TEMPERATURE (° C) Phone (925) 443-0722 Fax (925) 443-0723 AMS1086 PACKAGE DIMENSIONS inches (millimeters) unless otherwise noted 3 LEAD TO-220 PLASTIC PACKAGE (T) 0.147-0.155 (3.734-3.937) DIA 0.390-0.415 (9.906-10.541) 0.165-0.180 (4.191-4.572) 0.045-0.055 (1.143-1.397) 0.230-0.270 (5.842-6.858) 0.570-0.620 (14.478-15.748) 0.460-0.500 (11.684-12.700) 0.330-0.370 (8.382-9.398) 0.980-1.070 (24.892-27.178) 0.218-0.252 (5.537-6.401) 0.520-0.570 (13.208-14.478) 0.090-0.110 (2.286-2.794) 0.050 (1.270) TYP 0.028-0.038 (0.711-0.965) 0.013-0.023 (0.330-0.584) 0.095-0.115 (2.413-2.921) T (TO-220) AMS DRW# 042193 3 LEAD SOT-223 PLASTIC PACKAGE 0.248-0.264 (6.30-6.71) 0.116-0.124 (2.95-3.15) 0.264-0.287 (6.71-7.29) 0.130-0.146 (3.30-3.71) 0.033-0.041 (0.84-1.04) 0.090 (2.29) NOM 10°-16° 10° MAX 0.071 (1.80) MAX 0.010-0.014 (0.25-0.36) 10°-16° 0.025-0.033 (0.64-0.84) 0.012 (0.31) MIN 0.181 (4.60) NOM Advanced Monolithic Systems, Inc. www.advanced-monolithic.com 0.025-0.033 (0.64-0.84) (SOT-223 ) AMS DRW# 042292 Phone (925) 443-0722 Fax (925) 443-0723 AMS1086 PACKAGE DIMENSIONS inches (millimeters) unless otherwise noted (Continued). 3 LEAD TO-263 PLASTIC DD (M) 0.060 (1.524) TYP 0.390-0.415 (9.906-10.541) 0.165-0.180 (4.191-4.572) 0.004 +0.008 -0.004 (0.102 +0.203 ) -0.102 0.330-0.370 (8.382-9.398) 0.108 (2.74) TYP 0.199-0.218 (5.05-5.54) 0.090-0.110 (2.286-2.794) 0.045-0.055 (1.143-1.397) 0.032 (0.81) TYP 0.095-0.115 (2.413-2.921) 0.90-0.110 (2.29-2.79) 0.013-0.023 (0.330-0.584) M (DD3) AMS DRW# 042191R1 TO-252 PLASTIC PACKAGE (D) 0.255-0.265 (6.48-6.73) 0.206-0.214 (5.23-5.44) 0.087-0.094 (2.21-2.39) 0.018-0.023 (0.46-0.58) 0.035-0.050 (0.89-1.27) 7.0° 0.235-0.245 (5.969-6.223) 0.380-0.410 (9.65-10.41) 0.156-0.204 (3.96-5.18) Advanced Monolithic Systems, Inc. 0.035-0.045 (0.89-1.14) 0.045-0.060 (1.14-1.52) 0.025 (0.635) TYP 0.020±0.002 (0.510±0.0508) 0.030 (0.762) TYP www.advanced-monolithic.com 0.018-0.023 (0.46-0.58) D (D3) AMS DRW# 011601 Phone (925) 443-0722 Fax (925) 443-0723
AMS1086CM-3.3
物料型号:AMS1086
器件简介: AMS1086系列是可调节和固定电压稳压器,设计用于提供1.5A的输出电流,并能在输入与输出电压差低至1V的情况下工作。该器件的典型特点包括高效率线性稳压器、多种固定电压选项、低至1V的压降以及良好的线路和负载调整率。
引脚分配: - 固定版本:1-地(Ground),2-输出(VOUT),3-输入(VIN) - 可调版本:1-地(Ground),2-输出(VOUT),3-可调输入(ADJ)
参数特性: - 输出电流:1.5A - 工作电压范围:1.5V至5V - 线路调整率:0.015% - 负载调整率:0.1% - 封装类型:TO-220, TO-263, TO-252, SOT-223
功能详解: AMS1086系列提供了多种固定电压选项,包括1.5V, 1.8V, 2.5V, 2.85V, 3.0V, 3.3V, 3.5V和5.0V。这些稳压器适用于多种应用,如微处理器电源、开关电源的后稳压器、电池充电器、笔记本电脑/个人电脑电源和便携式仪器电源。
应用信息: 适用于需要高效率和高输出电流的场合,例如在微处理器、电池充电器或笔记本电脑电源中提供稳定的电源。
封装信息: AMS1086系列提供了多种封装选项,包括3引脚的TO-220、SOT-223、3引脚的TO-263(塑料DD)、TO-252(D PAK)。
AMS1086CM-3.3 价格&库存
很抱歉,暂时无法提供与“AMS1086CM-3.3”相匹配的价格&库存,您可以联系我们找货
AMS1086CM-3.3
    • 1+4.03920
    • 10+3.29400
    • 30+2.91600
    • 100+2.54880
    • 500+2.33280
    • 1000+2.21400
    库存:1397
