RS614-2-02
RS614-2-02
    SCHAFFNER(夏弗纳)
    插件
    RS614-2-02
RS614-2-02 数据手册
DATA SHEET Differential Mode Chokes RS series Differential-mode chokes Rated currents from 0.3 to 10 A Approvals & Compliances DC to 400 Hz frequency 100 kHz to 3 MHz common-mode resonance frequency Dual-choke configurations Multiple PCB-mounting options RS chokes are state of the art differential-mode or symmetric chokes, which can be used in various kinds of applications. The datasheet gives an overview of three different kinds of applications with the related electrical specifcations. Features and Benefits 3 different applications specified Performance indicators usable for basic and reinforced equipment Quasi linear saturation for storage mode 40 to 450 microjoules storage Resonance Frequency from 500kHz to 60MHz in symmetrical mode Custom-specific versions are available on request Multiple housing options Typical Applications Energy filtering Multistage discrete filtering General purpose differential/symmetrical mode filtering Technical Specifications SMPS and UPS DC/DC converters Frequency converters Operating voltage 250 VAC Operating frequency DC to 400 Hz Rated currents 0.5 to 4 A @ rated ambient temperature Rated inductance 0.003 to 3.6 mH High potential test voltage winding-towinding @ 25°C 1500 VAC, 60 sec, guaranteed 1500 VAC, 2 sec, factory test Winding-to-housing @ 25°C 4000 VAC, 60 sec, guaranteed Surge current @ 10 msec 20 x IN @ 25°C Temperature range (operation and storage) -40°C to 125°C (40/125/56) acc. IEC 60068-1 Flammability corresponding to Housing UL 94V-0 Potting compound UL 94V-0 Ringcore coating UL 94V-0 Design corresponding to UL 1283, IEC/EN 60938-1 Typical electrical schematic 2 Differential Mode Chokes Schaffner Group DATA SHEET 15. Jun 2022 Application Type #1: Symmetrical/Differential Mode Choke Selection Table Current (lN) Inductance Resistance typ. Resonance Frequency typ. Attenuation typ. parasitic Capacitance @ 40°C ambient (L) (R) f0 @ f0 Cp [A] [µH] [mOhm] [MHz] [dB] [pF] 0.5 200 650 8 44.9 1.98 RS 512-1-02 / RS 612-1-02 1 55 130 20 37.3 3.83 RS 512-2-02 / RS 612-2-02 2 14 30 25 25.3 3.31 RS 512-4-02 / RS 612-4-02 4 3 10 33 10..7 7.75 0.5 480 800 7 50.6 8.87 RS 514-1-02 / RS 614-1-02 1 120 200 11 42.7 7.39 RS 514-2-02 / RS 614-2-02 2 30 50 16 32.5 3.66 RS 514-4-02 / RS 614-4-02 4 8 20 22 25.6 3.43 0.5 900 1250 2 54.9 12.64 RS 622-1-02 1 225 300 4 46 6.33 RS 622-2-02 2 55 70 7 33.2 9.40 RS 622-4-02 4 15 30 13 28.7 4.86 Choke RS 512-0.5-02 / RS 612-0.5-02 RS 514-0.5-02 / RS 614-0.5-02 RS 622-0.5-02 Test conditions: Measuring frequency: 10 kHz; 50 mV; Inductance tolerance: +50%, -30%; Resistance tolerance: ±15% @ 25°C; Electrical characteristics @ 25°C: ±2°C For mechanical tolerances refer to mechanical data section. 3 Differential Mode Chokes Schaffner Group DATA SHEET 15. Jun 2022 Application Type #2: Symmetrical/Differential Mode Choke Selection Table Current (lN) Inductance Resistance calc. Resonance Frequency typ. Attenuation typ. parasitic Capacitance @ 40°C ambient (L) (R) F0 @ F0 Cp [A] [µH] [mOhm] [MHz] [dB] [pF] 0.5 800 1300 2 50 7.9 RS 512-1-02 / RS 612-1-02 1 220 260 8 47 4.8 RS 512-2-02 / RS 612-2-02 2 56 60 17 36 3.0 RS 512-4-02 / RS 612-4-02 4 12 20 27 22 2.9 Filter RS 512-0.5-02 / RS 612-0.5-02 RS 514-0.5-02 / RS 614-0.5-02 0.5 1920 1600 2.5 60 7.0 RS 514-1-02 / RS 614-1-02 1 480 400 5.5 53 6.6 RS 514-2-02 / RS 614-2-02 2 120 100 10 42 4.4 RS 514-4-02 / RS 614-4-02 4 32 40 18 34 5.8 11.7 RS 622-0.5-02 0.5 3600 2500 0.6 63 RS 622-1-02 1 900 600 1.5 55 9.3 RS 622-2-02 2 220 140 3 33 12.8 RS 622-4-02 4 60 60 5 38 5.2 Test conditions: Measuring frequency: 10 kHz; 50 mV; Inductance tolerance: +50%, -30%; Resistance tolerance: ±15% @ 25°C; Electrical characteristics @ 25°C: ±2°C For mechanical tolerances refer to mechanical data section. 4 Differential Mode Chokes Schaffner Group DATA SHEET 15. Jun 2022 Application Type #3: Energy Storage Choke Selection Table Filter Current (lN) Inductance Resistance Energy @ 40°C ambient (L) (R) E [A] [µH] [mOhm] [µJ] 0.5 800 1300 100 RS 512-1-02 / RS 612-1-02 1 220 260 100 RS 512-2-02 / RS 612-2-02 2 56 60 100 RS 512-4-02 / RS 612-4-02 4 12 20 100 0.5 1960 1600 240 RS 514-1-02 / RS 614-1-02 1 480 400 240 RS 514-2-02 / RS 614-2-02 2 120 100 240 RS 514-4-02 / RS 614-4-02 4 32 40 240 0.5 3600 2500 450 RS 622-1-02 1 900 600 450 RS 622-2-02 2 220 140 450 RS 622-4-02 4 60 60 450 RS 512-0.5-02 / RS 612-0.5-02 RS 514-0.5-02 / RS 614-0.5-02 RS 622-0.5-02 Test conditions: Measuring frequency: 10 kHz; 50 mV; Inductance tolerance: +50%, -30%; Resistance tolerance: ±15% @ 25°C; Electrical characteristics @ 25°C: ±2°C For mechanical tolerances refer to mechanical data section. Differential Mode Chokes Schaffner Group DATA SHEET 15. Jun 2022 Product selector Thermal Derating If higher ambient temperatures than the specified apply, the nominal current needs to be reduced according to the graph below. Mechanical Data RS 612 1 P 3 2 3 4 P 1 2 4 3 2 1 3 L H 4 1 P P L 4 P 2 W 4 W 3 1 A H 4 3 2 1 W A H B A RS 614, RS 622 B RS 512, RS 514 B 5 2 L P Pin material: Steel (base), Cu (under plating), Sn (final plating 6µm) Dimensions A B H L W P ØP weight (±0.6 mm) (±0.6 mm) (±0.3 mm) (±0.3 mm) (±0.3 mm) (±0.5 mm) (±0.1 mm) [g] RS 512 15.0 mm 10.0 mm 12.6 mm 17.7 mm 17.1 mm 4.0 mm 0.8 mm 6 RS 514 20.1 mm 12.5 mm 13.2 mm 22.5 mm 21.5 mm 4.0 mm 0.8 mm 11 RS 612 10.0 mm 15.0 mm 20.0 mm 12.5 mm 18.0 mm 4.0 mm 0.8 mm 9 RS 614 12.5 mm 10.0 mm 25.0 mm 15.5 mm 23.0 mm 4.0 mm 0.8 mm 15 RS 622 15.0 mm 12.5 mm 29.3 mm 18.0 mm 31.0 mm 4.3 mm 0.8 mm 30 Please visit www.schaffner.com to find more details on filter connections. 6 Differential Mode Chokes Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 15. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
RS614-2-02 价格&库存
很抱歉,暂时无法提供与“RS614-2-02”相匹配的价格&库存,您可以联系我们找货
