Technical Data Sheet
BULKHEAD ADAPTOR N FEMALE - SMA FEMALE SQUARE FLANGE
PAGE 1/2
ISSUE 06-12-16D
SERIES ADAPT
PART NUMBER R191381000
All dimensions are in mm.
pn
ao
COMPONENTS
Body
Center contact
Outer contact
Insulator
Gasket
Others parts
MATERIALS
BRASS.
BERYLLIUM COPPER
PTFE
BERYLLIUM COPPER
PLATING (m)
NICKEL .
GOLD OVER NICKEL
NICKEL
This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written
agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
PAGE 2/2
ISSUE 06-12-16D
SERIES ADAPT
PACKAGING
Standard
1
Unit
Other
Contact us
ELECTRICAL CHARACTERISTICS
Impedance
Frequency
1.30
VSWR
Insertion loss
RF leakage
Voltage rating
Dielectric withstanding voltage
Insulation resistance
50
0-11
0,0000
0.05
101
500
1000
5000
GHz
x F(GHz) Maxi
F(GHz) dB Maxi
- F(GHz)) dB Maxi
Veff Maxi
Veff mini
M mini
ENVIRONMENTAL
Operating
Hermetic seal
Panel leakage
-55/+155
NA
NA
°C
Atm.cm3/s
MECHANICAL CHARACTERISTICS
SPECIFICATION
Center contact retention
Axial force – Mating End
Axial force – Opposite end
Torque
*18
*18
NA
N mini
N mini
N.cm mini
OTHER CHARACTERISTICS
Recommended torque
Mating
N
SMA
NA
Panel nut
Mating life
Weight
500
35,6900
N.cm
N.cm
N.cm
N.cm
*out of SMA CDC
Cycles mini
g
很抱歉,暂时无法提供与“R191381000”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+386.92533
- 10+371.46174
- 50+355.97418
- 100+347.88903
