R114082000
R114082000
    RADIALL
    SMB
R114082000 数据手册
TECHNICAL DATA SHEET 1/2 R114.082.000 STRAIGHT PLUG CRIMP TYPE Series : SMB CABLE 2.6/50+75 S All dimensions are in mm. . pn . ao COMPONENTS BODY CENTER CONTACT OUTER CONTACT INSULATOR GASKET OTHERS PARTS - MATERIALS BRASS BERYLLIUM COPPER BERYLLIUM COPPER PTFE BRASS - PLATING (µm) GOLD 0.2 OVER NICKEL 2 GOLD 1.3 OVER NICKEL 2 GOLD 0.5 OVER NICKEL 2 GOLD 0.2 OVER NICKEL 2 - Issue : 1008 A In the effort to improve our products, we reserve the right to make changes judged to be necessary. TECHNICAL DATA SHEET 2/2 R114.082.000 STRAIGHT PLUG CRIMP TYPE Series : SMB CABLE 2.6/50+75 S PACKAGING SPECIFICATION Standard 100 Unit ‘W’ option Other Contact us CABLE ASSEMBLY Stripping a b c d e f mm 2,50 6,00 11,0 0,00 8,50 0,00 ELECTRICAL CHARACTERISTICS Impedance 50 Ω Frequency 0-4 GHz VSWR 1.25 + 0,0400 x F(GHz) Maxi Insertion loss 0.25 √F(GHz) dB Maxi RF leakage -( 57 - F(GHz)) dB Maxi Voltage rating 335 Veff Maxi Dielectric withstanding voltage 1000 Veff mini Insulation resistance 1000 MΩ mini MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating end Axial force – Opposite end Torque 10 N mini 10 N mini NA N.cm mini Assembly instruction : Crimp 02 Recommended cable(s) RG 316 KX 22A RG 188 RG 179 RG 187 ECO 316 RG 174 KX 3B RG 174 FTX Characteristics indicated on this data sheet are those that can be achieved with the highest performance cable. Intrinsic limitations of the cable may diminish the performance of the assembly Cable retention - pull off - torque 110 N mini 3.9 N.cm TOOLING Recommended torque Mating Panel nut Clamp nut A/F clamp nut Mating life Weight NA NA NA 0,0000 N.cm N.cm N.cm mm 500 Cycles mini 2,0950 g ENVIRONMENTAL Operating temperature Hermetic seal Panel leakage -65/+165 ° C NA Atm.cm3/s NA Part Number Description . . R282.281.000 CRIMPING TOOL Hexagon . 2x4(pos.3>50 pos.1>75) - R282.983.000 POSITONER FOR CRIMPING TOOL . And - (et) R282.211.000 CRIMPING 3.25 TOOL . Or - (ou) R282.293.000 CRIMPING TOOL M22520/501 R282.235.003 CRIMPING DIES 3.25 M22520/5-03 OTHER CHARACTERISTICS Issue : 1008 A In the effort to improve our products, we reserve the right to make changes judged to be necessary.
R114082000 价格&库存
很抱歉,暂时无法提供与“R114082000”相匹配的价格&库存,您可以联系我们找货
R114082000
    • 1+93.20400
    • 200+36.07200
    • 500+34.80840
    • 1000+34.18200
    R114082000
    • 1+78.04865
    • 5+70.88580
    • 10+66.04669
    • 20+60.65659
    • 50+53.49375
    • 100+49.86441
    库存:37
