DATA SHEET
3-Phase Filters FN3258
Ultra-compact EMC/RFI Filter for Motor Drives Applications
New: solid safety connector blocks available
for the whole range
Approvals & Compliances
Exceptional attenuation performance from
150 kHz to 30 MHz
Excellent saturation resistance up to 50 m
cable length
Most compact and slim filter design in its
class
Features and Benefits
The extremely compact and slim filter design
allows a trouble-free installation even where the
available mounting space is minimal
Performance indicators
With new additional filter types providing safety
terminal blocks, the most preferred connection
style can be chosen fast and easy. This helps to
stay in line with the electrical connection concept
of a given application
FN 3258 filters ensure compliance with Class A
limits according to EN 55011 up to 50 m cable
length and beyond. Further they can contribute
significantly to meet conducted emission limits
according to Class B
Filter operation on the mains input side of
consumers increases their reliability and
conducted immunity significant
Chokes with exceptional saturation resistance
and excellent thermal behavior are a vital part of
FN 3258 design. Thus, all filters retain the
expected filter performance even in very noisy
applications and under full load conditions
Technical Specifications
Maximum continuous operating voltage
3x 520/300 VAC (FN 3258 H)
3x 480/277 VAC (FN 3258)
Operating frequency
DC to 60 Hz
Rated currents
7 to 180 A
High potential test voltage
P –> E 2650 / 2750 VDC for 2 sec (FN 3258 / FN 3258H)
P –> P 2100 / 2250 VDC for 2 sec (FN 3258 / FN 3258H)
Protection category
IP 20
Applications comprising energy conversion
devices like machines or process automation
equipment
Overload capability
4x rated current at switch on,
1.5x rated current for 1 minute, once per hour
HVAC equipment, elevators, power supplies, UPS
and further three-phase applications
Temperature range (operation and storage)
-25°C to +100°C (25/100/21)
Flammability corresponding to
UL 94 V-2 or better
Design corresponding to
UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939
MTBF @ 50°C/400 V (Mil-HB-217F)
300,000 hours
Typical Applications
Three-phase variable speed motor drives, servo
drives, inverters and converters
Typical electrical schematic
2
3-Phase Filters
Schaffner Group
DATA SHEET
04. Jul 2022
Filter Selection Table
Filter
FN3258-7-44
Buy
Rated current
Typical drive
Leakage current**
Power loss
Input/Output
@ 50°C (40°C)
Power Rating*
@ 480/520 VAC/50 Hz
@ 25°C/50 Hz
Connections
[A]
[kW]
[mA]
[W]
Weight
[kg]
7 (7.7)
4
4.3
3.8
-44
0.5
FN3258-16-44
16 (17.5)
7.5
4.3
6.1
-44
0.8
FN3258-30-33
30 (32.9)
15
4.3
11.8
-33
1.2
FN3258-42-33
42 (46.0)
22
4.3
15.7
-33
1.4
FN3258-55-34
55 (60.2)
30
4.3
25.9
-34
2.0
FN3258-75-34
75 (82.2)
37
4.3
32.2
-34
2.7
FN3258-100-35
100 (109.5)
55
4.3
34.5
-35
4.3
FN3258-130-35
130 (142.4)
75
4.3
43.1
-35
4.5
FN3258-180-40
180 (197.1)
90
4.3
58.3
-40
6.0
FN3258H-7-44
7 (7.7)
4
4.7
3.8
-44
0.5
FN3258H-16-44
16 (17.5)
7.5
4.7
6.1
-44
0.8
FN3258H-30-33
30 (32.9)
18.5
4.7
11.8
-33
1.2
FN3258H-42-33
42 (46.0)
22
4.7
15.7
-33
1.4
FN3258H-55-34
55 (60.2)
37
4.7
25.9
-34
2.0
FN3258H-75-34
75 (82.2)
45
4.7
32.2
-34
2.7
FN3258H-100-35
100 (109.5)
55
4.7
34.5
-35
4.3
FN3258H-130-35
130 (142.4)
75
4.7
43.1
-35
4.5
FN3258H-180-40
180 (197.1)
110
4.7
58.3
-40
6.0
* Calculated at rated current, 440 VAC (FN3258)/480 VAC (FN3258H) and cos phi=0.8. The exact value depends upon the efficiency of the drive, the motor and
the entire
application.
** Standardized calculated leakage current acc. IEC60939 under normal operating conditions (FN3258 at 480 VAC and FN3258H at 520 VAC).
Thermal Derating
If higher ambient temperatures than the specified apply, the nominal current needs to be reduced
according to the graph below.
3
3-Phase Filters
Schaffner Group
Typical Filter Attenuation
Per CISPR 17; DM=50/50 sym; CM=50/50 asym
7 A type
16 A type
30 A type
42 A type
55 A type
75 A type
100 A type
130 A type
180 A type
DATA SHEET
04. Jul 2022
4
3-Phase Filters
Schaffner Group
DATA SHEET
04. Jul 2022
Mechanical data
I
D
C
J
F
H
B
G
E
A
Note: in favour of a better readability, connectors and earth studs are not shown in the horizontal projection.
Dimensions
7A
16 A
30 A
42 A
55 A
75 A
100 A
130 A
180 A
A
190
250
270
310
250
270
270
270
380
B
40
45
50
50
85
80
90
90
120
C
70
70
85
85
90
135
150
150
170
D
160
220
240
280
220
240
240
240
350
E
180
235
255
295
235
255
255
255
365
F
30
30
60
60
65
65
102
G
4.5
5.4
5.4
5.4
5.4
6.5
6.5
6.5
6.5
H
1
1
1
1
1
1.5
1.5
1.5
1.5
I
22
22
25
25
39
39
45
45
51
J
M5
M5
M5
M6
M6
M6
M10
M10
M10
K
25
25
42.5
40
45
45
60
L2
29.5
29.5
39.5
37.5
26.5
70.5
64
64
47
All dimensions in mm; 1 inch = 25.4 mm
Tolerances according: ISO 2768-m/EN 22768-m
Filter Input/Output Connector Cross Sections
-33
-34
-35
-40
-44
Solid wire
16 mm2
35 mm2
50 mm2
95 mm2
10 mm2
Flex wire
10 mm2
25 mm2
50 mm2
95 mm2
6 mm2
AWG type wire
AWG 6
AWG 2
AWG 1/0
AWG 4/0
AWG 8
Recommended torque
1.5-1.8 Nm
4.0-4.5 Nm
7-8 Nm
17-20 Nm
1.0-1.2 Nm
Please visit www.schaffner.com to find more details on filter connectors.
5
3-Phase Filters
Headquarters, Global
Innovation and
Development
Switzerland
Schaffner Holding AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
info@schaffner.com
Schaffner Group
China
Schaffner EMC Ltd. Shanghai
T20-3 C, No 565 Chuangye Road, Pudong
district
201201
Shanghai
+86 2138139500
cschina@schaffner.com
Spain
Schaffner EMC España
Calle Caléndula 93, Miniparc III, Edificio E El
Soto de Moraleja, Alcobendas
28109
Madrid
+34 917 912 900
spainsales@schaffner.com
Finland
Schaffner Oy
Sauvonrinne 19 H
8500
Lohja
+358 50 468 7284
finlandsales@schaffner.com
Sweden
Schaffner EMC AB
Östermalmstrorg 1
114 42
Stockholm
+46 8 5050 2425
swedensales@schaffner.com
France
Schaffner EMC S.A.S.
16-20 Rue Louis Rameau
95875
Bezons
+33 1 34 34 30 60
francesales@schaffner.com
Switzerland
Schaffner EMV AG
Industrie Nord
Nordstrasse 11e
4542
Luterbach
+41 32 681 66 26
switzerlandsales@schaffner.com
India
Schaffner India Pvt. Ltd
Regus World Trade Centre
WTC, 22nd Floor Unit No 2238, Brigade
Gateway Campus, 26/1, Dr. Rajkumar Road
Malleshwaram (W)
560055
Bangalore
+91 8067935355
indiasales@schaffner.com
© 2022 Schaffner Group
The content of this document has been
carefully
checked
and
understood.
However, neither Schaffner nor its
subsidiaries
assume
any
liability
whatsoever for any errors or inaccuracies
of this document and the consequences
thereof. Published specifica-tions are
subject to change without notice. Product
suitability for any area of application must
ultimately
be
determined
by
the
customer. In all cases, products must
never be operated outside their published
specifications.
Schaffner
does
not
guarantee the availability of all published
products. This disclaimer shall be
governed by substantive Swiss law and
resulting disputes shall be settled by the
courts at the place of business of Schaffner
Holding AG. Latest publications and a
complete disclaimer can be downloa-ded
from the Schaffner website. All trademarks
recognized.
04. Jul 2022
Sales and Application
Centers
Germany
Schaffner Deutschland GmbH
Schoemperlenstrasse 12B
76185
Karlsruhe
+49 721 56910
germanysales@schaffner.com
To find your local partner within
Schaffner‘s global network schaffner.com
DATA SHEET
Italy
Schaffner EMC S.r.l.
Via Ticino, 30
20900
Monza (MB)
+39 039 21 41 070
italysales@schaffner.com
Japan
Schaffner EMC K.K.
ISM Sangenjaya 7F
1-32-12 Kamiuma, Setagaya-ku
154-0011
Tokyo
+81 3 5712 3650
japansales@schaffner.com
Singapore
Schaffner EMC Pte Ltd.
Blk 3015A Ubi Road 1, #05-09, Kampong Ubi
Industrial Estate
408705
Singapore
+65 63773283
singaporesales@schaffner.com
Taiwan
Schaffner EMV Ltd.
U-Town
20 Floor-2, No 97, Section 1, XinTai 5th Road,
XiZhi District
22175
New Taipei City
+886 226975500
taiwansales@schaffner.com
Thailand
Schaffner EMC Co. Ltd.
Sathorn Square Tower
Room 3780, 37FL, 98 North-Sathorn Rd,
Silom, Bangrak
10500
Bangkok
+66 621056397
thailandsales@schaffner.com
United Kingdom
Schaffner Ltd.
1, Oakmede Place
Terrace Road
RG42 4JF
Binfield
+44 118 9770070
uksales@schaffner.com
United States
Schaffner EMC Inc.
52 Mayfield Avenue
Edison, New Jersey
+1 732 225 9533
usasales@schaffner.com
很抱歉,暂时无法提供与“FN3258-30-33”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+2096.25396
- 3+2054.32910
- 5+1992.70022
