Transient Voltage Suppressors (TVS)
SMBJ6.8A/CA
Description
The SMBJ series is designed specifically to protect sensitive
electronic equipment from voltage transients induced by
lightning and other transient voltage events.
Features
l Very fast response time
l Halogen free and RoHS compliant
l Low incremental surge resistance
Electrical symbol
l Optimized for LAN protection applications
l Matte tin lead–free Plated
l For surface mounted applications to optimize board space
BI
l 600W peak pulse power capability with at 10/1000μs
waveform, repetition rate (duty cycle): 0.01%
Anode
Cathode
l High temperature soldering:260°C/10 seconds at terminals
UNI
Part Number Code
S
M
B
J
Series code
x
x
x
C
Reverse
Stand-Off
Voltage
A
5% Voltage
Tolerance
Blank:Uni-Directional
C:Bi-Directional
Mechanical Characteristics
Rating
Symbol
Value
Units
Peak Pulse Power Dissipation at TA=25ºC by 10/1000μs Waveform (Fig.2)(Note
1), (Note 2)
PPP
600
W
Power Dissipation on Infinite Heat Sink at TL=50°C
PD
5.0
W
Peak Forward Surge Current, 8.3ms Single Half Sine Wave (Note 3)
IFSM
100
A
TJ
-55 to 150
°C
TSTG
-55 to 150
°C
Operating Temperature Range
Storage Temperature Range
Notes:
1. Non-repetitive
repetitive current pulse, per Fig.4 and derated above TA=25ºC per Fig. 3.
2. Mounted on 5.0x5.0mm copper pad to each terminal.
3. Measured on 8.3ms single half sine wave or equivalent square wave for unidirectional device only, duty cycle=4 per minute maximum.
Specifications are subject to change without notice.
Please refer to http://www.ruilon.com.cn for current information.
Revised: 2018-07-11
Page:1
SMBJ6.8A/CA
Electrical Characteristics
Type Number
Reverse
Stand-Off
Voltage
Marking
VRWM
Breakdown
Voltage
Max.
Max.
Reverse
Clamping Peak Pulse
Leakage
Voltage
Current
Test
Current
VBR @IT
Min
Max
IT
VC@IPP
IPP
IR@VRWM
UNI
BI
UNI
BI
V
V
V
mA
V
A
µA
SMBJ6.8A
SMBJ6.8CA
6.8A
6.8CA
5.8
6.45
7.14
10
10.5
57.0
1000
Notes: For bidirectional type having VR of 10V and less, the IR limit is double.
I-V Curve Characteristics
Uni-directional
I
Bi-directional
IPP
VC VBR VR
IR VF
IT
IT
IR
VC VBR VR
V
IR
IT
VR VBR VC
V
IPP
IPP
PPPM Peak Pulse Power Dissipation -- Max power dissipation
VR Stand-off Voltage -- Maximum voltage that can be applied to the TVS without operation
VBR Breakdown Voltage -- Maximum voltage that flows though the TVS at a specified test current (I T)
VC Clamping Voltage -- Peak voltage measured across the TVS at a specified Ippm (peak impulse current)
IR Reverse Leakage Current -- Current measured at VR
VF Forward Voltage Drop for Uni-directional
directional
Ratings and Characteristic Curves (TA=25°C unless otherwise noted)
Figure 1 - TVS Transients Clamping Waveform
Figure 2 - Peak Pulse Power Rating Curve
100
PPPM-Peak Pulse Power (kW)
Voltage or Current
Voltage Transients
Voltage Across TVS
Current Through TVS
TJ initial = Tamb
stacked-die, 800W
at 10x1000μs, 25°C
10
Single die, 600W
at 10x1000μs, 25°C
1
0.1
Time
0.001
0.01
0.
0.1
1
10
td-Pulse
Pulse Width (ms)
Revised: 2018-07-11
Page:2
Figure 4 - Pulse Waveform
100
150
IPPM - Peak Pulse Cur rent, % IRSM
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 3 - Pulse Derating Curve
SMBJ6.8A/CA
80
60
40
tr=10μsec
25
50
75
100
125
Peak Value
IPPM
100
Half Value
IPPM ( IPPM )
2
50
10/1000μsec.Waveform
as defined by R.E.A
td
TA-Ambient temperature (ººC)
Uni--directional V=0V
Cj (pF)
Uni-directional @VR
100
Bi-directional @VR
Tj=25ºC
f=1.0MHz
Vsig=50mVp-p
1
100.0
1000.0
PM(AV), Steady State Power Dissipation (W)
Bi-directional
directional V=0V
1000
10.0
3.0
4.0
Figure 6 - Steady State Power Derating Curve
10000
1.0
2.0
t-Time(ms)
Figure 5 - Typical Junction Capacitance
10
TJ =25°C
Pulse Width(td) is defined
as the point where the peak
current decays to 50% of IPPM
5.0
4.0
3.0
2.0
60Hz Resistive or
Inductive Load
1.0
0.0
VBR - Reverse Breakdown Voltage (V)
50
75
100 125 150
TL-Lead
Lead Temperature(ºC)
Temperature(
175
200
Figure 7 - Maximum Non-Repetitive Surge Current
IFSM - Peak Forward Surve Current
(A)
120
Pulse Width 8.3ms
Single Half-Sine--Wave
(JEDEC METHOD)
100
80
60
40
10
100
Number of Cycles at 60 Hz
Revised: 2018-07-11
Page:3
SMBJ6.8A/CA
Soldering Parameters - Reflow Soldering (Surface Mount Devices)
Reflow Condition
TP
Ramp-up
Critical Zone
TL to TP
TL
Pre
Heat
Temperature
TS(max)
Ramp-down
TS(min)
Preheat
Time to peak temperature
(t 25℃ to peak)
-Temperature
Temperature Min (Ts(min))
150°C
-Temperature Max (Ts(max))
200°C
- Time (min to max) (ts)
60 -180 Seconds
Average ramp up rate ( Liquids
Liquid
Temp TL) to peak
3°C/second max
TS(max) to TL - Ramp-up Rate
3°C/second max
Reflo
w
25
Pb - Free assembly
Time
- Temperature (TL)
(Liquids)
217°C
60 -150 Seconds
Peak Temperature (TP)
260 +0/-5°C
Time within 5°C of actual peak
Temperature (tp)
20 - 40 Seconds
Ramp-down Rate
6°C/second max
Time 25°C to peak Temperature (TP)
8 minutes Max
Do not exceed
260°C
Part Marking System
Cathode band(for Uni-directional products only)
RUILON
XXX XXX
Date Code
Product Code
Marking code
Dimensions
Cathode Band
Millimeters
Inches
DIM
Revised: 2018-07-11
Min
Max
Min
Max
A
1.95
2.20
0.077
0.086
B
4.06
4.57
0.160
0.180
C
3.30
3.94
0.130
0.155
D
2.13
2.44
0.084
0.096
E
0.76
1.52
0.030
0.060
G
5.11
5.49
0.201
0.216
I
2.26
0.089
J
2.16
0.085
K
2.74
0.107
L
2.16
0.085
Page:4
SMBJ6.8A/CA
Taping and Reel Specifications
Symbol
Millimeters
Inches
W
1
12±0.3
0.472±0.012
P
8
8±0.1
0.315±0.004
F
5
5.5±0.1
0.217±0.004
E
1.75±0.1
0.069±0.004
D
1.5+0.1/
1.5+0.1/-0.0
0.059+0.004/-0.0
P0
4±0.1
0.157±0.004
P2
2
2±0.1
0.079±0.004
D0
16.7
16.7±0.15
0.657±0.006
D1
17
178±2
7.007±0.079
D2
59.6
59.6+1/-2
2.346+0.039/-0.079
W1
12.64
12.64±0.4
0.498±0.016
Direction of Unreeling
Part Number
Component
package
Quantity
Packaging option
Packaging specification
SMBJ6.8A/CA
DO-214AA
500
Tape&Reel-12mm/7”tape
EIA STD RS-481
Revised: 2018-07-11
Page:5
很抱歉,暂时无法提供与“SMBJ6.8A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.55317
- 50+0.44119
- 150+0.38521
- 500+0.34322
- 3000+0.29092
- 6000+0.27411
- 国内价格
- 1+0.53856
- 200+0.34680
- 1500+0.30192
- 3000+0.26724
