PBAR1AF2000A0G
PBAR1AF2000A0G
    APEM(埃斐)
    SWITCH PUSH SPST-NO 0.2A 24V
PBAR1AF2000A0G 数据手册
SW PANEL SWITCHES BA -P 08 18 16 PBA series Piezo switches Ø 16 mm DISTINCTIVE FEATURES Bushing diameter 16 (.630), 19 (.748), 22 (.866) or 30 mm (1.181) Sealed to IP68 and IP69K (switches mounted on panel) Easy to clean metal surface Very long life expectancy Ring illumination ENVIRONMENTAL SPECIFICATIONS • Sealing : IP68 per IEC 60529, IP69K per DIN 40050-9 (switches mounted on panel) • Vibration resistance : 10-500 Hz / 10 g per IEC 60068-2-6 • Operating temperature : -40 °C to +75 °C (-40 °F to + 167 °F) • EMC compatibility according to EN 61058-1 for the whole range • EMC compatibility according to EN 61000-4 & EN61000-6-2 for model 1A (code 002) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - Function A : standard 200 mA 24 VAC/DC - option 1 A 24 VAC/DC - Function B : standard 100 mA 24 VAC/DC • Switch resistance ON : 10 Ω max. • Switch resistance OFF : 5 MΩ min. • Life expectancy : 50 million cycles • LED consumption : Illuminated dot 10 mA - Illuminated ring 20 mA (functions A-B-C) • Power consumption for function 1 : non-illuminated 10 mA - illuminated 30 mA GENERAL SPECIFICATIONS • Operating force : 2 to 6 N • Torque : 2.5 Nm min. - 3 Nm max. The company reserves the right to change specifications without notice. 1 Piezo switches Ø 16 mm 1m Note : to maintain the ESD performance, always add a ground washer when the panel is made of non-conductive material (PVC, polycarbonate). For part numbers, see “Mounting accessories” on the following pages. MATERIALS • Case : aluminum, anodized or stainless steel 316L • Multi-wire leads section 0.22 mm2 length 300 mm, twisted by pair 3 • Cable, length 300 mm, section depending on switch model • PC terminals : bronze, tin plated APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. CPBAET1-A SEALING SEALING IP68 SEALING IP69K - One-piece bushing - Epoxy sealed terminals - O-ring 1m PANEL SWITCHES PBA series 3 3 1 2 CPBAET1-A Continuous immersion in water IP68 test conditions Continuous immersion in water (1 m, 24 hours) High pressure, high temperature wash down CPBAET2-A IP69K test conditions . Pressure : 80 - 120 bars . Distance : 15 cm . Temperature : 80 °C ± 5 °C (176 °F ± 41 °F) . Flow : 14 - 16 l/mn . Duration : 30 seconds per position PANEL CUT-OUT MODELS Ø16 (.630) 3 1 FICHIER: CPBAET-P ECHELLE: 0.7 indice A le 09/01/09 Ø16.20 (.637 DIA) 2 2 CPBAET2-A Piezo switches Ø 16 mm 1 t20s t20s ELECTRICAL FUNCTIONS 0 FINGER PRESSURE APPLIED TO SWITCH 1 : pressure / 0 : no pressure 1 1 OUTPUT 1 : closed output / 0 : open output Momentary NO (pulse) No external power supply required Momentary NC (pulse) No external power supply required Latching (ON - OFF) Requires external power supply WIRING t 1 0 0 t t 0 t 1 1 1 0 0 0 1 1 Up to 20s 0 0 1 1 Up to 20s Up to 20s t t tt t t t 0 0 1 1 PBARCHR1-B 0 DIAGRAMS 0 RED RED RED RED RED 1 LED * C D 1 Momentary NO 0 Momentary NC Latching (ON - OFF) 0 00 WHITE 9-24V AC/DC WHITE C C D D t=Xs 2 LEDs A B A B B A A RED 1 WHITE 1 WHITEt=Xs 9-24V t=Xs AC/DC WHITE RED WHITE RED WHITE 0 RED WHITE 9-24V AC/DC WHITE C AA RED WHITE D 3 LEDs B A B GREEN RED GREEN RED GREEN RED B B WHITE GREEN D D A t A A WHITE GREEN C C B GREEN RED A A B BA B A A B B A A B B B WHITE GREEN GREEN WHITE GREEN GREEN t tt WHITE GREEN Legend : C : yellow, D : blue, B : black , A0: same color as LED WHITE 9-24V AC/DC WHITE B GREEN RED GREEN RED 1 11 GREEN WHITE A GREEN RED GREEN RED RED PBARCHR1-B RED Non-illuminated RED t t PBARCHR1-B BA A B A B A B WHITE PBARCHR2 WHITE t resinCPBACHR FICHIER: B A * LED colorAis indicated by protective color on bottom of unit.. RED RED ECHELLE: 0.7 t indice B le 23/11/10 PBARCHR2 PBARCHR2 PBARSH1-A RED FICHIER: CPBACHR ECHELLE:CPBACHR 0.7 FICHIER: ECHELLE: indice B 0.7 PBARSH1-A indice B le 23/11/10 le 23/11/10 3 PANEL SWITCHES PBA series PANEL SWITCHES PBA series Piezo switches Ø 16 mm BUILD YOUR PART NUMBER BASIC PART NUMBER PBA SERIES BUSHINGS / OPERATORS R1 Flat operator, height 4.50 (.177) T5 Flat operator, height 1 (.039) (non illuminated) R5 Operator with finger location, height 4.50 (.177) (non-illuminated) OPTIONS ELECTRICAL FUNCTIONS TERMINALS COLORS / MATERIALS A NO (pulse) F Flying leads 0 Natural anodized B NC (pulse) C Cable 1 Blue anodized Black anodized P Straight PC (T5 model, non-illuminated, functions A & B only) 2 3 Green anodized 1 ON - OFF (requires external power supply - cannot be combined with T5 operator - illumination type W only) 5 Gold anodized 6 Red anodized B Stainless steel 316L RATINGS TYPE OF ILLUMINATION/ VOLTAGE 000 Standard 002 1 A 24 VAC/DC (NO pulse only, function A) Blank Non-illuminated A Standard ring 5 VDC N Standard ring 12 VDC K Standard ring 24 VDC W Standard ring, microcontroller driven Bold = standard LED COLORS Blank LED COLORS (CONTINUED) Non-illum. 2A Red/green 2G Green/white 3A Red/green/blue 0B Blue 2B Red/yellow 2H Blue/yellow 3B Red/green/yellow 0G Green 2C Red/blue 2I Blue/white 3D Red/green/white 0S Red 2D Red/white 2K Yellow/white 3E Red/blue/yellow 0Y Yellow 2E Green/blue 3F Red/blue/white 0W White 2F Green/yellow 3G Red/yellow/white 3H Green/blue/ yellow 3I Green/blue/white 3J Green/yellow/ white 3K Blue/yellow/white For options not listed above, please contact APEM. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : standard hardware supplied : 1 hex nut and 1 O-ring. Always add a ground washer U5735 (Ø16 mm) when the panel is non-conductive (PVC, polycarbonate). 4 Ø13.00 (.512DIA) Ø13.00 (.512DIA) Ø16.00x1.00 SI (.630DIAx1.00 IS) 20.00 (.787) 5.00 (.197) 0.22mm 2 Ø16.00x1.00 SI (.630DIAx1.00 IS) 4.50 (.177) 5.00 (.197) 20.00 (.787) Ø18.00 (.708DIA) Flat R1 0.22mm 2 Ø16.00x1.00 SI (.630DIAx1.00 IS) R5 CPBA161-A R1 With finger location 5.00 (.197) PBAR1 Ø13.00 (.512DIA) 4.50 (.177) 20.00 (.787) Ø18.00 (.708DIA) Ø16 (.630) - NON-ILLUMINATED OPERATOR HEIGHT 4.50 MM Piezo switches Ø 16 mm 4.50 (.177) Ø18.00 (.708DIA) PANEL SWITCHES PBA series 0.22mm 2 PBAR5 R5 CPBA161-A R1 R5 Ø18.00 (.708DIA) 0.22mm 2 PBAT5 Ø18.00 SI Ø16.00x1.00 (.708DIA) IS) (.630DIAx1.00 10.00 (.394) 10.00 (.394) Flat Ø16.00x1.00 SI (.630DIAx1.00 IS) 1.00 (.039) 10.00 (.394) Ø18.00 (.708DIA) 1.00 (.039) Ø16 (.630) - NON-ILLUMINATED OPERATOR HEIGHT 1 MM 1.00 (.039) CPBA161-A 0.22mm 2 Ø16.00x1.00 SI (.630DIAx1.00 IS) CPBA162-A 0.22mm 2 CPBA162-A Ø16 (.630) - STANDARD ILLUMINATED RING OPERATOR HEIGHT 4.5 MM CPBA162-A Ø16.00x1.00 SI (.630DIAx1.00 IS) 4.50 (.177) Ø13.50 (.531DIA) 5.00 (.197) 4.50 (.177) Ø18.00 (.708DIA) PBAR1 5.00 (.197) 20.00 (.787) Ø18.00 (.708DIA) 4.50 (.177) Ø18.00 (.708DIA) Ø16.00x1.00 SI (.630DIAx1.00 IS) Flat 20.00 (.787) Ø13.50 (.531DIA) Ø16.00x1.00 SI (.630DIAx1.00 IS)2 0.22mm 5.00 (.197) Ø13.50 1.20 (.531DIA) (.047) 0.22mm 2 1.20 (.047) 0.22mm 2 CPBA163-A 1.20 (.047) 20.00 (.787) FICHIER: CPBA16-P ECHELLE: 0.7 indice A CPBA163-A 25/11/08 FICHIER:le CPBA16-P9 ECHELLE: 0.7 indice A le 25/11/08 FICHIER: CPBA ECHELLE: 0.7 indice A le 25/11/08 CPBA163-A 5 Piezo switches Ø 16 mm ELECTRICAL FUNCTIONS BASIC P/N A B 1 NO pulse NC pulse ON - OFF - Requires external power supply - Cannot be combined with T5 operator - Illumination type W only. TERMINALS BASIC P/N 2.67 (.105) F Flying leads C Cable P Straight PC (T5 model, non-illuminated, functions A and B only 0.22mm 2 3.17 (.125) CASE COLORS / MATERIALS 0.64 (.025) 2.54 (.100) CPBACO1-A BASIC P/N 0 1 2 3 5 6 B Natural anodized aluminum Blue anodized aluminum Black anodised aluminum Green anodized aluminum Gold anodized aluminum Red anodised aluminum Stainless steel 316L 0.22mm 2 Bold = standard CPBACO2-A 1 2 3 5 6 B 5.08 (.200) 0 RATINGS 000 002 Standard 1 A 24 VAC or DC (NO pulse only, function A) 0.80 (.031) BASIC P/N 0.22mm 2.80 (.110) 2 3.60 (.142) PANEL SWITCHES PBA series CPBACO3-A 6 FICHIER: CPBACO ECHELLE: 0.7 indice A le 25/11/08 Piezo switches Ø 16 mm TYPE OF ILLUMINATION / VOLTAGE BASIC P/N Blank A N K CPBA22IL-A W Non-illuminated Thin ring - 5 VDC Thin ring - 12 VDC Thin ring - 24 VDC Thin ring - µcontroller driven LED COLORS BASIC P/N Blank Non-illuminated Integrated LED resistor Illuminated 1 LED * 0B : blue - 0G : green - 0S : red - 0Y : yellow - 0W : white Illuminated 2 LEDs 2A : red/green - 2B : red/yellow - 2C : red/blue - 2D : red/white - 2E : green/blue - 2F : green/yellow - 2G : green/white 2H : blue/yellow - 2I : blue/white - 2K : yellow/white Illuminated 3 LEDs 3A : red/green/blue - 3B : red/green/yellow - 3D : red/green/white - 3E : red/blue/yellow - 3F : red/blue/white 3G: red/yellow/white - 3H : green/blue/yellow - 3I : green/blue/white - 3J : green/yellow/white - 3K : blue/yellow/white * LED color is indicated by protective resin color on bottom of unit. FICHIER: CPBA22IL-P19 ECHELLE: 0.3 indice A le 25/11/08 0B 0G 0S 0Y 0W 7 PANEL SWITCHES PBA series SW PANEL SWITCHES BA -P 08 18 19 PBA series Piezo switches Ø 19 mm DISTINCTIVE FEATURES Bushing diameter 16 (.630), 19 (.748), 22 (.866) or 30 mm (1.181) Sealed to IP68 and IP69K (switches mounted on panel) Easy to clean metal surface Very long life expectancy Ring illumination ENVIRONMENTAL SPECIFICATIONS • Sealing : IP68 per IEC 60529, IP69K per DIN 40050-9 (switches mounted on panel) • Vibration resistance : 10-500 Hz / 10 g per IEC 60068-2-6 • Operating temperature : -40 °C to +75 °C (-40 °F to + 167 °F) • EMC compatibility according to EN 61058-1 for the whole range • EMC compatibility according to EN 61000-4 & EN61000-6-2 for model 1A (code 002) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - Function A : standard 200 mA 24 VAC/DC - option 1 A 24 VAC/DC - Function B : standard 100 mA 24 VAC/DC • Switch resistance ON : 10 Ω max. • Switch resistance OFF : 5 MΩ min. • Life expectancy : 50 million cycles • LED consumption : Illuminated dot 10 mA - Illuminated ring 20 mA (functions A-B-C) • Power consumption for function 1 : non-illuminated 10 mA - illuminated 30 mA GENERAL SPECIFICATIONS • Operating force : 2 to 6 N • Torque : 2.5 Nm min. - 3 Nm max. The company reserves the right to change specifications without notice. 1 Piezo switches Ø 19 mm 1m Note : to maintain the ESD performance, always add a ground washer when the panel is made of non-conductive material (PVC, polycarbonate). For part numbers, see “Mounting accessories” on the following pages. MATERIALS • Case : aluminum, anodized or stainless steel 316L • Multi-wire leads section 0.22 mm2 length 300 mm, twisted by pair 3 • Cable, length 300 mm, section depending on switch model • PC terminals : bronze, tin plated APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. CPBAET1-A SEALING SEALING IP68 SEALING IP69K - One-piece bushing - Epoxy sealed terminals - O-ring 1m PANEL SWITCHES PBA series 3 3 1 2 CPBAET1-A Continuous immersion in water IP68 test conditions Continuous immersion in water (1 m, 24 hours) High pressure, high temperature wash down CPBAET2-A IP69K test conditions . Pressure : 80 - 120 bars . Distance : 15 cm . Temperature : 80 °C ± 5 °C (176 °F ± 41 °F) . Flow : 14 - 16 l/mn . Duration : 30 seconds per position Ø16.20 (.637 DIA) PANEL CUT-OUT CPBADEC1-A MODELS Ø19 (.748) 3 1 FICHIER: CPBAET-P ECHELLE: 0.7 indice A le 09/01/09 Ø19.20 (.756 DIA) 2 2 CPBAET2-A CPBADEC2-A Piezo switches Ø 19 mm 1 t20s t20s ELECTRICAL FUNCTIONS 0 FINGER PRESSURE APPLIED TO SWITCH 1 : pressure / 0 : no pressure 1 1 OUTPUT 1 : closed output / 0 : open output Momentary NO (pulse) No external power supply required Momentary NC (pulse) No external power supply required Latching (ON - OFF) Requires external power supply WIRING t 1 0 0 t t 0 t 1 1 1 0 0 0 1 1 Up to 20s 0 0 1 1 Up to 20s Up to 20s t t tt t t t 0 0 1 1 PBARCHR1-B 0 DIAGRAMS 0 RED RED RED RED RED 1 LED * C D 1 Momentary NO 0 Momentary NC Latching (ON - OFF) 0 00 WHITE 9-24V AC/DC WHITE C C D D t=Xs 2 LEDs A B A B B A A RED 1 WHITE 1 WHITEt=Xs 9-24V t=Xs AC/DC WHITE RED WHITE RED WHITE 0 RED WHITE 9-24V AC/DC WHITE C AA RED WHITE D 3 LEDs B A B GREEN RED GREEN RED GREEN RED B B WHITE GREEN D D A t A A WHITE GREEN C C B GREEN RED A A B BA B A A B B A A B B B WHITE GREEN GREEN WHITE GREEN GREEN t tt WHITE GREEN Legend : C : yellow, D : blue, B : black , A0: same color as LED WHITE 9-24V AC/DC WHITE B GREEN RED GREEN RED 1 11 GREEN WHITE A GREEN RED GREEN RED RED PBARCHR1-B RED Non-illuminated RED t t PBARCHR1-B BA A B A B A B WHITE PBARCHR2 WHITE t resinCPBACHR FICHIER: B A * LED colorAis indicated by protective color on bottom of unit.. RED RED ECHELLE: 0.7 t indice B le 23/11/10 PBARCHR2 PBARCHR2 PBARSH1-A RED FICHIER: CPBACHR ECHELLE:CPBACHR 0.7 FICHIER: ECHELLE: indice B 0.7 PBARSH1-A indice B le 23/11/10 le 23/11/10 3 PANEL SWITCHES PBA series PANEL SWITCHES PBA series Piezo switches Ø 19 mm BUILD YOUR PART NUMBER BASIC PART NUMBER PBA SERIES BUSHINGS / OPERATORS R9 Flat operator, height 3 (.118) RA With chamfer, height 3 (.118) OPTIONS ELECTRICAL FUNCTIONS TERMINALS COLORS / MATERIALS A NO (pulse) F Flying leads 0 Natural anodized B NC (pulse) C Cable 1 Blue anodized Black anodized P Straight PC (T5 model, non-illuminated, functions A & B only) 2 3 Green anodized 1 ON - OFF (requires external power supply - cannot be combined with T5 operator - illumination type W only) 5 Gold anodized 6 Red anodized B Stainless steel 316L RATINGS TYPE OF ILLUMINATION/ VOLTAGE 000 Standard 002 1 A 24 VAC/DC (NO pulse only, function A) Blank Non-illuminated A Standard ring 5 VDC N Standard ring 12 VDC K Standard ring 24 VDC W Standard ring, microcontroller driven Bold = standard LED COLORS Blank LED COLORS (CONTINUED) Non-illum. 2A Red/green 2G Green/white 3A Red/green/blue 0B Blue 2B Red/yellow 2H Blue/yellow 3B Red/green/yellow 0G Green 2C Red/blue 2I Blue/white 3D Red/green/white 0S Red 2D Red/white 2K Yellow/white 3E Red/blue/yellow 0Y Yellow 2E Green/blue 3F Red/blue/white 0W White 2F Green/yellow 3G Red/yellow/white 3H Green/blue/ yellow 3I Green/blue/white 3J Green/yellow/ white 3K Blue/yellow/white For options not listed above, please contact APEM. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : standard hardware supplied : 1 hex nut 10-621 (19 mm ac. flats) and 1 O-ring. Always add a ground washer U5736 (Ø19 mm) when the panel is non-conductive (PVC, polycarbonate). 4 Piezo switches Ø 19 mm 20.00 (.787) Flat PBAR9 Ø19.00x1.00 SI (.748DIAx1.00 IS) 0.22mm 2 Ø19.00x1.00 SI (.748DIAx1.00 IS) R9 With chamfer 2.00 (.079) 2.00 (.079) 45° 3.00 (.118) Ø22.00 (.866DIA) 20.00 (.787) Ø19 (.748) - NON-ILLUMINATED OPERATOR HEIGHT 3 MM 45° 3.00 (.118) Ø22.00 (.866DIA) PANEL SWITCHES PBA series RA 0.22mm 2 PBARA R9 CPBA191-A RA CPBA191-A Wire colors : see “Wiring diagrams”. Ø13.50 (.531DIA) 2.00 (.079) 2.00 (.079) 1.20 (.047) R9 1.20 (.047) Ø13.50 0.22mm 2 Wire colors : see “Wiring diagrams”. 3.00 (.118) 1.20 (.047) Ø13.50 (.531DIA) PBARA Ø19.00x1.00 SI (.748DIAx1.00 IS) (.531DIA) 0.22mm 2 With chamfer Ø19.00x1.00 SI (.748DIAx1.00 IS) 1.20 (.047) 20.00 (.787) PBAR9 45° Ø13.50 Flat Ø22.00 (.866DIA) 45° 3.00 (.118) 20.00 (.787) Ø22.00 (.866DIA) (.531DIA) Ø19 (.748) - ILLUMINATED RING OPERATOR HEIGHT 3 MM RA CPBA192-A ELECTRICAL FUNCTIONS R9 RA CPBA192-A BASIC P/N A B 1 NO pulse NC pulse ON - OFF - Requires external power supply - Cannot be combined with T5 operator - Illumination type W only. TERMINALS 0.22mm 2 3.17 (.125) F Flying leads C Cable P Straight PC (T5 model, non-illuminated, functions A and B only 2.67 (.105) BASIC P/N 0.64 (.025) 2.54 (.100) CPBACO1-A FICHIER: CPB ECHELLE: 0.7 indice A le 26/11/08 FICHIER: CPBA ECHELLE: 0.7 indice A le 26/11/08 5 PANEL SWITCHES PBA series Piezo switches Ø 19 mm CASE COLORS / MATERIALS BASIC P/N 0 1 2 3 5 6 B Natural anodized aluminum Blue anodized aluminum Black anodised aluminum Green anodized aluminum Gold anodized aluminum Red anodised aluminum Stainless steel 316L Bold = standard 0 1 2 3 5 RATINGS BASIC P/N 000 002 Standard 1 A 24 VAC or DC (NO pulse only, function A) TYPE OF ILLUMINATION / VOLTAGE BASIC P/N Blank A N K CPBA22IL-A W 6 Non-illuminated Thin ring - 5 VDC Thin ring - 12 VDC Thin ring - 24 VDC Thin ring - µcontroller driven 6 B Piezo switches Ø 19 mm LED COLORS BASIC P/N Blank Non-illuminated Integrated LED resistor Illuminated 1 LED * 0B : blue - 0G : green - 0S : red - 0Y : yellow - 0W : white Illuminated 2 LEDs 2A : red/green - 2B : red/yellow - 2C : red/blue - 2D : red/white - 2E : green/blue - 2F : green/yellow - 2G : green/white 2H : blue/yellow - 2I : blue/white - 2K : yellow/white Illuminated 3 LEDs 3A : red/green/blue - 3B : red/green/yellow - 3D : red/green/white - 3E : red/blue/yellow - 3F : red/blue/white 3G: red/yellow/white - 3H : green/blue/yellow - 3I : green/blue/white - 3J : green/yellow/white - 3K : blue/yellow/white * LED color is indicated by protective resin color on bottom of unit. 0B 0G 0S 0Y 0W 7 PANEL SWITCHES PBA series SW PANEL SWITCHES BA -P 08 18 22 PBA series Piezo switches Ø 22 mm DISTINCTIVE FEATURES Bushing diameter 16 (.630), 19 (.748), 22 (.866) or 30 mm (1.181) Sealed to IP68 and IP69K (switches mounted on panel) Easy to clean metal surface Very long life expectancy Ring or dot illumination ENVIRONMENTAL SPECIFICATIONS • Sealing : IP68 per IEC 60529, IP69K per DIN 40050-9 (switches mounted on panel) • Vibration resistance : 10-500 Hz / 10 g per IEC 60068-2-6 • Operating temperature : -40 °C to +75 °C (-40 °F to + 167 °F) • EMC compatibility according to EN 61058-1 for the whole range • EMC compatibility according to EN 61000-4 & EN61000-6-2 for model 1A (code 002) ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - Function A : standard 200 mA 24 VAC/DC - option 1 A 24 VAC/DC - Function B : standard 100 mA 24 VAC/DC • Switch resistance ON : 10 Ω max. • Switch resistance OFF : 5 MΩ min. • Life expectancy : 50 million cycles • LED consumption : Illuminated dot 10 mA - Illuminated ring 20 mA (functions A-B-C) • Power consumption for function 1 : non-illuminated 10 mA - illuminated 30 mA GENERAL SPECIFICATIONS • Operating force : 2 to 6 N • Torque : 2.5 Nm min. - 3 Nm max. The company reserves the right to change specifications without notice. 1 Piezo switches Ø 22 mm 1m Note : to maintain the ESD performance, always add a ground washer when the panel is made of non-conductive material (PVC, polycarbonate). For part numbers, see “Mounting accessories” on the following pages. MATERIALS • Case : aluminum, anodized or stainless steel 316L • Multi-wire leads section 0.22 mm2 length 300 mm, twisted by pair 3 • Cable, length 300 mm, section depending on switch model • PC terminals : bronze, tin plated APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. CPBAET1-A SEALING SEALING IP68 SEALING IP69K - One-piece bushing - Epoxy sealed terminals 1m - O-ring Ø16.20 (.637 DIA) 3 3 1 2 CPBAET1-A CPBADEC1-A Continuous immersion in water IP68 test conditions Continuous immersion in water (1 m, 24 hours) High pressure, high temperature wash down CPBAET2-A IP69K test conditions . Pressure : 80 - 120 bars . Distance : 15 cm . Temperature : 80 °C ± 5 °C (176 °F ± 41 °F) . Flow : 14 - 16 l/mn . Duration : 30 seconds per position Ø19.20 (.756 DIA) PANEL CUT-OUT CPBADEC2-A MODELS Ø22 (.866) 3 Ø22.20 (.874 DIA) 1 2 2 Ø22.20 (.874 DIA) FICHIER: CPBAET-P ECHELLE: 0.7 indice A le 09/01/09 9.70 (.381) PANEL SWITCHES PBA series 2.80 (.110) CPBAET2-A Piezo switches Ø 22 mm 1 t20s t20s ELECTRICAL FUNCTIONS 0 FINGER PRESSURE APPLIED TO SWITCH 1 : pressure / 0 : no pressure 1 1 OUTPUT 1 : closed output / 0 : open output Momentary NO (pulse) No external power supply required Momentary NC (pulse) No external power supply required Latching (ON - OFF) Requires external power supply WIRING t 1 0 0 t t 0 t 1 1 1 0 0 0 1 1 Up to 20s 0 0 1 1 Up to 20s Up to 20s t t tt t t t 0 0 1 1 PBARCHR1-B 0 DIAGRAMS 0 RED RED RED RED RED 1 LED * C D 1 Momentary NO 0 Momentary NC Latching (ON - OFF) 0 00 WHITE 9-24V AC/DC WHITE C C D D t=Xs 2 LEDs A B A B B A A RED 1 WHITE 1 WHITEt=Xs 9-24V t=Xs AC/DC WHITE RED WHITE RED WHITE 0 RED WHITE 9-24V AC/DC WHITE C AA RED WHITE D 3 LEDs B A B GREEN RED GREEN RED GREEN RED B B WHITE GREEN D D A t A A WHITE GREEN C C B GREEN RED A A B BA B A A B B A A B B B WHITE GREEN GREEN WHITE GREEN GREEN t tt WHITE GREEN Legend : C : yellow, D : blue, B : black , A0: same color as LED WHITE 9-24V AC/DC WHITE B GREEN RED GREEN RED 1 11 GREEN WHITE A GREEN RED GREEN RED RED PBARCHR1-B RED Non-illuminated RED t t PBARCHR1-B BA A B A B A B WHITE PBARCHR2 WHITE t resinCPBACHR FICHIER: B A * LED colorAis indicated by protective color on bottom of unit.. RED RED ECHELLE: 0.7 t indice B le 23/11/10 PBARCHR2 PBARCHR2 PBARSH1-A RED FICHIER: CPBACHR ECHELLE:CPBACHR 0.7 FICHIER: ECHELLE: indice B 0.7 PBARSH1-A indice B le 23/11/10 le 23/11/10 3 PANEL SWITCHES PBA series PANEL SWITCHES PBA series Piezo switches Ø 22 mm BUILD YOUR PART NUMBER BASIC PART NUMBER PBA SERIES BUSHINGS / OPERATORS R2 Flat, operator height 3 mm (.118) - Not available w. illuminated ring. RY With chamfer, operator height 4.5 mm (.177). Available with thin or large illuminated ring only. R6 With finger location, operator height 3 mm (.118). Not available with illuminated ring. RZ Flat, operator height 4.5 mm (.177). Available with thin or large illuminated ring only. OPTIONS TERMINALS ELECTRICAL FUNCTIONS A NO (pulse) F Flying leads B NC (pulse) C Cable 1 ON - OFF (requires external power supply Illumination types V, Y and Z only - only one LED color) COLORS / MATERIALS RATINGS TYPE OF ILLUMINATION/VOLTAGE 0 Natural anodized 000 Standard 1 Blue anodized 002 2 Black anodized 1 A 24 VAC/DC (NO pulse only, function A) 3 Green anodized 5 Blank Non-illuminated C thin ring - 5 VDC D thin ring - 12 VDC E thin ring - 24 VDC F large ring - 5 VDC Gold anodized G large ring - 12 VDC 6 Red anodized H large ring - 24 VDC B Stainless steel 316L L* dot - 5 VDC P* dot - 12 VDC J* dot - 24 VDC V* dot - µcontroller driven Bold = standard Non-illum. 0B Blue 0G Green 0S Red 0Y Yellow 0W White SG Red/green (dot only) 2A Red/green 2B Red/yellow 2C Red/blue 2D Red/white thin ring - µcontroller driven Z large ring - µcontroller driven *Dot illumination only available with LED colors 0B, 0G, 0S, 0Y, 0W and SG. LED COLORS (CONTINUED) LED COLORS Blank Y 2E Green/blue 3A Red/green/blue 2F Green/yellow 3B Red/green/yellow 2G Green/white 3D Red/green/white 2H Blue/yellow 3E Red/blue/yellow 2I Blue/white 3F Red/blue/white 2K Yellow/white 3G Red/yellow/white 3H Green/blue/ yellow 3I Green/blue/white 3J Green/yellow/ white 3K Blue/yellow/white ABOUT THIS SERIES Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. Mounting accessories : standard hardware supplied : 1 hex nut 10-856-0 (25 mm ac. flats) and 1 O-ring Always add a ground washer U5737 when the panel is non-conductive (PVC, polycarbonate). 4 PANEL SWITCHES PBA series Piezo switches Ø 22 mm Ø22.00 (.866DIA) Ø28.00 (1.102DIA) Ø22.00 (.866DIA) 3.00 3.00 (.118) (.118) PBAR2 19.50 19.50 (.768) (.768) Flat Ø28.00 (1.102DIA) 5.00 5.00 (.197) (.197) NON-ILLUMINATED OPERATOR HEIGHT 3 MM Ø22.00x1.00 SI (.866DIAx1.00 IS) Ø22.00x1.00 SI 2 (.866DIAx1.00 0.22mm IS) Ø20.70 (.815DIA) With finger location 0.22mm 2 Ø20.70 (.815DIA) R2 R2 PBAR6 R6 R6 CPBA221-A CPBA221-A Ø28.00 (1.102DIA) Ø22.00 (.866DIA) Ø28.00 (1.102DIA) Ø22.00 (.866DIA) 3.00 (.118) R6 R6 Ø28.00 (1.102DIA) Ø28.00 (1.102DIA) 2.00 (.079) 2.00 (.079) Ø28.00 (1.102DIA) 2.00 (.079) Ø20.70 (.815DIA) Ø20.70 (.815DIA) With chamfer Ø18.00 Ø18.00 Ø18.00 (.709DIA) (.709DIA) (.709DIA) PBARY Ø20.70 (.815DIA) 30° 30° Ø22.00x1.00 SI (.866DIAx1.00 IS) 2 0.22mm Ø22.00x1.00 SI 0.22mm (.866DIAx1.00 IS)2 0.22mm 2 RY RY RY Ø13.50 (.531DIA) RZ CPBA223-A 4.00 (.157) 2 4.70 (.185) 0.22mm 4.70 (.185) With chamfer 3 Ø22.00x1.00 SI (.866DIAx1.00 IS) Ø13.50 (.531DIA) 20.00 (.787) 3.50 (.138) Ø20.70 (.815DIA) CPBA223-A CPBA223-B 0° 2.00 (.079) PBARZ PBARY CPBA222-A Ø22.00x1.00 SI (.866DIAx1.00 IS) RZ RZ RZ Ø28.00 (1.102DIA) CPBA222-A 30° DIMENSION OF ON-OFF MODELS WITH LARGE ILLUMINATED RING OPERATOR HEIGHT 4.50 Flat R2 R2 Ø18.00 Ø18.00 Ø18.00 (.709DIA) (.709DIA) (.709DIA) 20.00 20.00 20.00 (.787) (.787) (.787) 3.50 3.50 3.50(.138) (.138) (.138) PBARZ ZONE 3.00 (.118) DIMENSION OF ON-OFF MODELS WITH THIN ILLUMINATED RING OPERATOR HEIGHT 4.50 Flat PUSH ZONE PUSH 4.00 (.157) 6.50 (.256) 0.22mm 2 ZONE 4.50 2.40 2.40 2.40(.094) 4.50 4.50(.177) (.094) (.094) (.177) (.177) PBAR6 PUSH ZONE PUSH 4.50 (.177) With finger location LED Ø3.00 (.118DIA) LED Ø3.00 (.118DIA) 6.50 (.256) Ø22.00x1.00 SI (.866DIAx1.00 IS)2 0.22mm 2.40 2.40 2.40(.094) (.094) (.094) PBAR2 Ø22.00x1.00 SI (.866DIAx1.00 IS) 8.20 8.20 (.323) (.323) 5.00 5.00 (.197) (.197) Flat 3.00 3.00 (.118) (.118) 19.50 19.50 (.768) (.768) WITH ILLUMINATED DOT OPERATOR HEIGHT 3 MM RY 5 CPBA224-B FICHIE ECHEL FICHIE indice ECHELA le 25/11 indice A le 25/11 2.67 (.105) Piezo switches Ø 22 mm 3.17 (.125) 0.22mm 2 0.64 (.025) 2.54 (.100) CPBACO1-A ELECTRICAL FUNCTIONS BASIC P/N A B 1 NO pulse NC pulse ON - OFF - Requires external power supply - Illumination types V, Y 0.22mm and Z only - one LED color only. 2 TERMINALS CPBACO2-A BASIC P/N F C 0.80 (.031) 5.08 (.200) Flying leads Cable 2.80 (.110) 0.22mm 2 3.60 (.142) PANEL SWITCHES PBA series CPBACO3-A CASE COLORS / MATERIALS FICHIER: CPBACO ECHELLE: 0.7 indice A le 25/11/08 BASIC P/N 0 1 2 3 5 6 B Natural anodized aluminum Blue anodized aluminum Black anodised aluminum Green anodized aluminum Gold anodized aluminum Red anodised aluminum Stainless steel 316L Bold = standard 0 1 2 3 5 RATINGS BASIC P/N 000 002 6 Standard 1 A 24 VAC or DC (NO pulse only, function A) 6 B Piezo switches Ø 22 mm PANEL SWITCHES PBA series TYPE OF ILLUMINATION / VOLTAGE BASIC P/N Blank Non-illuminated CPBA22IL-A C D E Y CPBA22IL-A Thin ring - 5 VDC Thin ring - 12 VDC Thin ring - 24 VDC Thin ring - µcontroller driven F GCPBA22IL-A H Z L P J V Large ring - 5 VDC Large ring - 12 VDC Large ring - 24 VDC Large ring - µcontroller driven Dot - 5 VDC Dot - 12 VDC Dot - 24 VDC Dot - µcontroller driven Dot illumination only available with LED colors : 0B, 0G, 0S, 0Y, 0W and SG. LED COLORS BASIC P/N Blank Non-illuminated Integrated LED resistor Illuminated 1 LED * 0B : blue - 0G : green - 0S : red - 0Y : yellow - 0W : white SG : red/green (reversed polarity LED - for dot illumination only) Illuminated 2 LEDs 2A : red/green - 2B : red/yellow - 2C : red/blue - 2D : red/white - 2E : green/blue - 2F : green/yellow - 2G : green/white 2H : blue/yellow - 2I : blue/white - 2K : yellow/white Illuminated 3 LEDs FICHIER: CPBA2 3A : red/green/blue - 3B : red/green/yellow - 3D : red/green/white - 3E : red/blue/yellow - 3F : red/blue/white ECHELLE: 0.3 indice A 3G: red/yellow/white - 3H : green/blue/yellow - 3I : green/blue/white - 3J : green/yellow/white - 3K : blue/yellow/white * LED color is indicated by protective resin color on bottom of unit. FICHIER: CPBA22IL-P19 ECHELLE: 0.3 indice A le 25/11/08 0B 0G 0S 0Y FICHIER: CPBA22IL-P19 ECHELLE: 0.3 indice A le 25/11/08 le 25/11/08 0W 7 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: PBAR1AF0000 PBAR1AF0000A0G PBAR1AF0020 PBAR1AF1000 PBAR1AF2000 PBAR1AF2000A0B PBAR1AF2000A0G PBAR1AF2000A0S PBAR1AF2000A0Y PBAR1AF3000 PBAR1AF6000 PBAR1AF6000A0G PBAR1AF6000A0S PBAR1AF6000A0Y PBAR1AF9000 PBAR2AF0000 PBAR2AF0000L0G PBAR2AF0000L0S PBAR2AF1000 PBAR2AF2000 PBAR2AF2000L0G PBAR2AF2000L0S PBAR2AF6000 PBAR2AF9000 PBAR5AF0000 PBAR5AF6000 PBAR6AF0000 PBAR6AF0000L0G PBAR6AF0000L0S PBAR6AF0000L0Y PBAR6AF1000 PBAR6AF3000 PBAR6AF5000 PBAR6AF6000 PBAR6AF6000L0S PBAR6AF9000 PBAR1AF6000A0B PBAR2AF2000L0B PBAR2AF6000L0Y PBAR11F0000A0W PBAR6BF0000 PBAR11F0000WOW PBAR1ACB002K3B PBAR1CF0000 PBAR1AF0000K2B PBAR1AF2000A2A PBAT5AF0000 PBAT5AF2000 PBAR1AC2002K0G PBAR1AF1000A0B PBAR1AF0000A2A PBAR11C2000W2C PBAR1AFB000 PBAR1AF2002N0S PBAR1AF2000A0W PBAR1AFB000A0G PBAR11FB000 PBAR1AF2000K0G PBAR1BF2000K0S PBAR1AF2002 PBAR1AF3002 PBAR1AFB000A2A PBAR1AFB000A0B PBAR1AFB000A0W PBAR1CF0000A3A PBAR1AF0000A0S PBAT5AFB000 PBAR1CFB000A0S PBAR1AF0000A0B PBAR1AF0000K0Y PBAR1CFB000K0B PBAR1AF0000K2A PBAR1AF0000K0W PBAR1CFB000K0G PBAT5AF3002 PBAR1CF0000A0G PBAR11F0000W0W PBAT5AF6000 PBAT5AF1000 PBAT5AP3000 PBAR1CFB000 PBAT5AP0000 PBAR1AF0000K0G PBAT5AF0002 PBAR1CFB000A0G PBAR1AFB000A0S PBAT5CF0061 PBAR1AF0000K0S PBAR11CB000W0B PBARZAF0000C3A
PBAR1AF2000A0G 价格&库存
很抱歉,暂时无法提供与“PBAR1AF2000A0G”相匹配的价格&库存,您可以联系我们找货
PBAR1AF2000A0G
  • 1+640.56553
  • 50+623.95546
  • 250+592.04747
库存:13
PBAR1AF2000A0G
  • 20+623.7816720+80.63040
  • 60+607.6375460+78.54360
  • 100+587.80087100+75.97950
