MINIATURE ALUMINUM ELECTROLYTIC CAPACITORS
GXE
Series
Long Life, Downsized, 125℃
GXF
Downsized
Downsized
Higher ripple
・For automobile modules and other high temperature applications
・Downsize, long life, low impedance and better low temperature characteristics
GXE
・Endurance with ripple current : 2,000 to 5,000 hours at 125℃
・Solvent resistant type except 63 to 450V (see PRECAUTIONS AND GUIDELINES)
・RoHS2 Compliant
・AEC-Q200 compliant : Please contact Chemi-Con for more details, test data, information.
GPA
◆SPECIFICATIONS
Items
Characteristics
Category
Temperature Range
Rated Voltage Range
Capacitance Tolerance
Leakage Current
-40 to +125℃ (10 to 250Vdc ) -25 to +125℃ (350 to 450Vdc)
10 to 450Vdc
±20% (M)
10 to 100Vdc
I=0.03CV or 4µA, whichever is greater.
(at 20℃, 120Hz)
160 to 450Vdc
CV≦1,000 I=0.1CV+40
CV>1,000
I=0.04CV+100
Where, I : Max. leakage current (µA), C : Nominal capacitance (µF), V : Rated voltage (V)
(at 20℃, 1 minute)
Rated voltage (Vdc)
10V 16V 25V 35V 50V 63V 80V 100V 160 to 250V 350 to 450V
tanδ (Max.)
0.20 0.16 0.14 0.12 0.10 0.10 0.08 0.08
0.20
0.24
When nominal capacitance exceeds 1,000µF, add 0.02 to the value above for each 1,000µF increase.
(at 20℃, 120Hz)
Rated voltage (Vdc)
Z(-25℃)/Z(+20℃)
3
2
2
2
2
2
2
2
3
6
Z(-40℃)/Z(+20℃)
6
4
4
4
4
4
4
4
6
(at 120Hz)
The following specifications shall be satisfied when the capacitors are restored to 20℃ after subjected to DC voltage with the rated
ripple current is applied (the peak voltage shall not exceed the rated voltage) for the specified time at 125℃.
10 to 100Vdc
160 to 450Vdc
Time
2,000hours
φ8 : 2,000hoursφ10 : 3,000hoursφ12.5 &φ16 : 5,000hours
Capacitance change
≦±30% of the initial value
≦±20% of the initial value
D.F. (tanδ)
≦300% of the initial specified value
≦200% of the initial specified value
Leakage current
≦The initial specified value
The following specifications shall be satisfied when the capacitors are restored to 20℃ after exposing them for 1,000 hours (500
hours for 350 to 450Vdc) at 125℃ without voltage applied. Before the measurement, the capacitor shall be preconditioned by
applying voltage according to Item 4.1 of JIS C 5101-4.
10 to 100Vdc
160 to 450Vdc
Capacitance change
D.F. (tanδ)
Leakage current
≦500% of the initial specified value
Dissipation Factor
(tanδ)
Low Temperature
Characteristics
(Max. Impedance Ratio)
Endurance
Shelf Life
◆DIMENSIONS [mm]
F±0.5
Code : E
φD'
φd
Sleeve (PET : Orange)
F±0.5
●Terminal
φD
φd
F
φD'
L'
Vent
15min.
4min.
(φ8 & φ10)
(φ12.5 & φ16)
L'
8
0.6
3.5
10 12.5 16
0.6 0.6 0.8
5.0 5.0 7.5
φD+0.5max.
L+2.0max.
Gas escape end seal
◆PART NUMBERING SYSTEM
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
E GXE AAA E AA AAA M AAA N
Supplement code
Size code
Capacitance tolerance code
Capacitance code (ex. 4.7µF:4R7,10µF:100,100µF:101)
Lead forming·taping code
Terminal code
Voltage code (ex. 10V:100,100V:101)
Series code
Category
Please refer to "Product code guide (radial lead type)"
Product specifications in this catalog are subject to change without notice.Request our product specifications before purchase and/or use. Please use our products based on the information contained in this catalog and product specifications.
CAT. No. E1001V 2021
GXESeries
◆STANDARD RATINGS
WV
(Vdc)
10
16
25
35
50
63
80
Cap
(µF)
is not solvent resistant.
Rated ripple
Impedance
current
Case size
(Ω max./
(mArms/
φD×L(mm)
20℃, 100kHz)
125℃, Note1)
220
330
470
1,000
2,200
3,300
4,700
100
220
330
470
1,000
2,200
3,300
100
220
330
470
1,000
2,200
100
100
220
330
470
1,000
10
22
33
47
100
220
330
470
1,000
33
47
100
220
330
470
1,000
22
33
8×12
10×12.5
10×12.5
10×20
12.5×25
16×25
16×31.5
8×12
10×12.5
10×12.5
10×16
12.5×20
16×25
16×31.5
8×12
10×12.5
10×16
10×20
12.5×25
16×31.5
8×12
10×12.5
10×16
10×20
12.5×20
16×25
8×12
8×12
8×12
8×12
10×12.5
10×20
12.5×20
12.5×25
16×31.5
8×12
10×12.5
10×16
12.5×20
12.5×25
12.5×30
16×31.5
8×12
10×12.5
0.32
0.15
0.15
0.075
0.040
0.031
0.025
0.32
0.15
0.15
0.094
0.058
0.031
0.025
0.32
0.15
0.094
0.075
0.040
0.025
0.32
0.15
0.094
0.075
0.058
0.031
0.75
0.50
0.50
0.50
0.20
0.098
0.081
0.059
0.032
1.5
0.59
0.41
0.16
0.12
0.097
0.059
1.5
0.80
340
620
620
950
1,350
1,620
1,860
340
620
620
790
1,080
1,620
1,860
340
620
790
950
1,350
1,860
340
620
790
950
1,080
1,620
180
250
280
280
520
880
990
1,150
1,590
150
530
690
1,050
1,290
1,460
1,850
150
480
WV
(Vdc)
Part No.
EGXE100E□□221MH12D
EGXE100E□□331MJC5S
EGXE100E□□471MJC5S
EGXE100E□□102MJ20S
EGXE100E□□222MK25S
EGXE100E□□332ML25S
EGXE100E□□472MLN3S
EGXE160E□□101MH12D
EGXE160E□□221MJC5S
EGXE160E□□331MJC5S
EGXE160E□□471MJ16S
EGXE160E□□102MK20S
EGXE160E□□222ML25S
EGXE160E□□332MLN3S
EGXE250E□□101MH12D
EGXE250E□□221MJC5S
EGXE250E□□331MJ16S
EGXE250E□□471MJ20S
EGXE250E□□102MK25S
EGXE250E□□222MLN3S
EGXE350E□□101MH12D
EGXE350E□□101MJC5S
EGXE350E□□221MJ16S
EGXE350E□□331MJ20S
EGXE350E□□471MK20S
EGXE350E□□102ML25S
EGXE500E□□100MH12D
EGXE500E□□220MH12D
EGXE500E□□330MH12D
EGXE500E□□470MH12D
EGXE500E□□101MJC5S
EGXE500E□□221MJ20S
EGXE500E□□331MK20S
EGXE500E□□471MK25S
EGXE500E□□102MLN3S
EGXE630E□□330MH12D
EGXE630E□□470MJC5S
EGXE630E□□101MJ16S
EGXE630E□□221MK20S
EGXE630E□□331MK25S
EGXE630E□□471MK30S
EGXE630E□□102MLN3S
EGXE800E□□220MH12D
EGXE800E□□330MJC5S
80
100
160
200
250
350
400
450
Cap
(µF)
47
100
220
330
470
4.7
10
22
33
47
100
220
330
22
33
47
68
100
150
10
22
33
47
68
100
10
22
33
47
68
4.7
10
22
33
47
4.7
10
22
33
47
4.7
10
22
33
Rated ripple
Impedance
current
Case size
(Ω max./
(mArms/
φD×L(mm)
20℃, 100kHz)
125℃, Note1)
10×12.5
10×20
12.5×25
12.5×30
16×25
8×12
8×12
10×12.5
10×12.5
10×16
12.5×20
16×25
16×31.5
10×20
10×25
12.5×20
12.5×25
16×25
16×31.5
10×20
10×25
12.5×20
12.5×25
16×20
16×25
10×20
12.5×20
12.5×25
16×25
16×31.5
10×20
10×25
12.5×25
16×25
16×31.5
10×20
10×25
12.5×30
16×25
16×31.5
10×25
12.5×20
16×25
16×31.5
0.80
0.39
0.18
0.16
0.11
2.0
1.5
0.80
0.80
0.55
0.25
0.11
0.079
480
790
1,240
1,390
1,500
130
150
480
480
630
990
1,500
1,790
115
154
187
245
329
434
78
126
157
204
250
329
78
128
171
225
292
53
85
139
189
243
53
86
142
189
243
58
86
154
203
Part No.
EGXE800E□□470MJC5S
EGXE800E□□101MJ20S
EGXE800E□□221MK25S
EGXE800E□□331MK30S
EGXE800E□□471ML25S
EGXE101E□□4R7MH12D
EGXE101E□□100MH12D
EGXE101E□□220MJC5S
EGXE101E□□330MJC5S
EGXE101E□□470MJ16S
EGXE101E□□101MK20S
EGXE101E□□221ML25S
EGXE101E□□331MLN3S
EGXE161E□□220MJ20S
EGXE161E□□330MJ25S
EGXE161E□□470MK20S
EGXE161E□□680MK25S
EGXE161E□□101ML25S
EGXE161E□□151MLN3S
EGXE201E□□100MJ20S
EGXE201E□□220MJ25S
EGXE201E□□330MK20S
EGXE201E□□470MK25S
EGXE201E□□680ML20S
EGXE201E□□101ML25S
EGXE251E□□100MJ20S
EGXE251E□□220MK20S
EGXE251E□□330MK25S
EGXE251E□□470ML25S
EGXE251E□□680MLN3S
EGXE351E□□4R7MJ20S
EGXE351E□□100MJ25S
EGXE351E□□220MK25S
EGXE351E□□330ML25S
EGXE351E□□470MLN3S
EGXE401E□□4R7MJ20S
EGXE401E□□100MJ25S
EGXE401E□□220MK30S
EGXE401E□□330ML25S
EGXE401E□□470MLN3S
EGXE451E□□4R7MJ25S
EGXE451E□□100MK20S
EGXE451E□□220ML25S
EGXE451E□□330MLN3S
□□ : Enter the appropriate lead forming or taping code.
(Note1) Ripple current frequency
10 to 100V = 100kHz
160 to 450V = 120Hz
◆RATED RIPPLE CURRENT MULTIPLIERS
・Frequency Multipliers
(10 to 100Vdc)
Capacitance(µF)
Frequency(Hz)
4.7 to 100
220 to 470
1,000
2,200 to 3,300
4,700
120
0.40
0.50
0.60
0.75
0.85
(160 to 450Vdc)
1k
0.75
0.85
0.87
0.90
0.95
10k
0.90
0.94
0.95
0.95
0.98
100k
1.00
1.00
1.00
1.00
1.00
Capacitance(µF)
Frequency(Hz)
4.7 to 33
47 to 150
50
0.75
0.80
120
1.00
1.00
300
1.25
1.15
1k
1.50
1.30
10k
1.75
1.40
100k
1.80
1.50
The endurance of capacitors is reduced with internal heating produced by ripple current at the rate of halving the lifetime with every 5℃ rise.
When long life performance is required in actual use, the rms ripple current has to be reduced.
