PB13P2Y2V1B
PB13P2Y2V1B
    APEM(埃斐)
    PB13P2Y2V1B
PB13P2Y2V1B 数据手册
SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES C FEATURES ● Dry circuit through power ratings . ● Rugged construction SPDT momentary models with numerous options. ● Panel, panel & p.c. and p.c. mounting models, lighted and unlighted. SPECIFICATIONS Contact ratings (resistive loads): Initial contact resistance: Insulation resistance: Dielectric strength: Electrical life (resistive loads): Operating temperature range: Total travel & operating force: (Q) power models - coin silver: 6 Amps at 125 VAC, 3 Amps at 250 VAC or 7 Amps at 30 VDC. (B) dry circuit models - gold over nickel over brass: 0.4 VA max. at 20 V max. UL models - coin silver: 6 Amps at 125 VAC or 3 Amps at 250 VAC (75% power factor). UL file no. E66367. CSA models - coin silver: same ratings as UL models. CSA file no. LR54592-1. 5 milliohms max. at 3 VDC, 0.1 Amp. Greater than 200,000 megohms between terminals & case ground. Greater than 2000 VAC for 1 minute between terminals & case ground. 100,000 cycles min. at full load. -30°C to +85°C .065" (1.6mm) & 19 oz. (approximate values ). MATERIALS Contacts: Actuator: Bushing: Strap: Case: Terminal seal: Support bracket: Spring mounting bracket: Bezel & cap: Hardware: LED: AGENCY RECOGNITION Coin silver for power,UL & CSA models. Gold over nickel over brass for dry circuit models. Glass filled polyester, color white Nickel plated brass Stainless steel Melamine phenolic, color red Epoxy (optional) Brass or steel, tin plated Stainless steel Nylon. Available in black, red or white. Consult factory for other colors. See 'Miscellaneous' section. Intensity: 2.0 mcd at 10 mA. Forward voltage: 2.0V (3.0V max.). Max. continuous forward current: 15 mA for red, 30 mA for green & 20 mA for yellow. Red is standard. Yellow & green are optional. Specifications are subject to change without notice - consult factory. UL, & CSA. Marking: Switches ordered with '/UL' added at end of model no. are supplied with recognition marked. Switches ordered with '/CSA' added at end of model no. are supplied with recognition marked. ABOUT THIS SERIES The material in this series is organized in the following sequence: a. Completely specified switch models b. 'build your own switch' order format d. Option drawings & information e. Panel cut-outs & miscellaneous c. Miscellaneous APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com C65 PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES POWER CKT. MODEL NO. PB1-3P2Y1ZQ DRY CKT. MODEL NO. PB1-3P2Y1ZB C P.C. or wirewrap terminals - panel or p.c. mounting POWER CKT. MODEL NO. PB1-3P2Y1CQ DRY CKT. MODEL NO. PB1-3P2Y1CB Horizontal right angle p.c. terminals - p.c. mounting POWER CKT. MODEL NO. PB1-3P2Y2A-1Q DRY CKT. MODEL NO. PB1-3P2Y2A-1B Vertical right angle p.c. terminals - p.c. mounting POWER CKT. MODEL NO. PB1-3P2Y2V-1Q C66 DRY CKT. MODEL NO. PB1-3P2Y2V-1B APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Solder lug terminals - panel mounting PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Straight p.c. terminals with bracket - p.c. mounting POWER CKT. MODEL NO PB1-3P2Y2V30Q DRY CKT. MODEL NO. PB1-3P2Y2V30B C Solder lug terminals - snap-in bezel with LED POWER CKT. MODEL NO. PB1-3P2Y1ZQJ6168 DRY CKT. MODEL NO. PB1-3P2Y1ZBJ6168 Solder lug terminals - snap-in bezel POWER CKT. MODEL NO. PB1-3P2Y1ZQJ8182 DRY CKT. MODEL NO. PB1-3P2Y1ZBJ8182 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com C67 PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES C POWER CKT. MODEL NO. PB1-3P2Y1CQJ8488 DRY CKT. MODEL NO. PB1-3P2Y1CBJ8488 Straight p.c. terminals with bracket - p.c. mounting bezel POWER CKT. DRY CKT. MODEL NO. MODEL NO. PB1-3P2Y1V30QJ8488 PB1-3P2Y1V30BJ8488 C68 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Straight p.c. terminals - p.c. mounting bezel PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Horizontal right angle p.c. terminals - p.c. mounting bezel C POWER CKT. MODEL NO. PB1-3P2Y1A-1QJ8488 Option A A-1 Dim. A .148 .164 DRY CKT. MODEL NO. PB1-3P2Y1A-1BJ8488 Dim. B .045 max. .095 max. Vertical right angle p.c. terminals - p.c. mounting bezel POWER CKT. MODEL NO. PB1-3P2Y1V-1QJ8488 DRY CKT. MODEL NO. PB1-3P2Y1V-1BJ8488 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com C69 PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES Solder lug terminals - snap-in bezel for round hole mounting SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Self-keying against rotation C POWER CKT. MODEL NO. PB1-3P2Y1ZQJ9688 DRY CKT. MODEL NO. PB1-3P2Y1ZBJ9688 Additional ordering information: Commonly ordered models are shown above and on prior pages with complete model numbers and specifications. Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply selecting from all available options shown and filling in the boxes. 'BUILD YOUR OWN SWITCH' ORDER FORMAT Fill in boxes with selections shown for Model Structure, then add Options selections for complete model number. Allowable options are shown below each respective box with brief description - see option dwgs. & info. following. Note: 'NONE' indicates box may be left empty. Model Structure: Series P B 1 Actuators - Bushings Terminations 3 Note: When bezel is specified, specify P2 actuator and Y1 bushing. Y Y 1/4" thd'd. 1 Short 1/4" thd'd. (standard) D 1/4" thd'd. w/'D' flat Y 2 Non-threaded P Long P 2 Short (standard) Options: Bezel& cap (NONE) J 6 1 J 8 1 J 8 4 J 9 6 Bezel color Snap-in w/LED Snap-in no LED P.C. style Snap-in (round hole) cap color (NONE) (NONE) 2 Black 2 Black 6 Red 6 Red 8 White 8 White Consult factory for other colors. Approvals (NONE) / U L / C S A Although most combinations of options are available, some may result in incompatibilities. Consult factory if there is any question. C70 Contact materials B Gold Z Solder lug Q Coin silver C Printed circuit G Gold over W Wirewrap coin silver W 1 Lg. wirewrap N Economy W 3 Sht. wirewrap gold X Extra lg. wirewrap T Economy Horiz. right angle p.c. silver terminals: A A - 1 Vertical right angle p.c. terminals: V V - 1 V - 2 Straight p.c. terminals w/brkt.: V 3 0 or V 4 1 V 4 0 or V 4 1 V 7 0 Example of completely specified V 8 0 model number: V 7 1 PB1-3P2Y1ZQJ9622/UL/CSA V 8 1 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES MISCELLANEOUS HARDWARE SUPPLIED (See Hardware section of catalog) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Switches with Y option bushings are supplied with (2) A112 Hex Nuts, (1) A115 Lockwasher and (1) A107 Anti-rotate Ring. Switches with D option bushings are supplied with (2) A112 Hex Nuts and (1) A115 Lockwasher. TYPICAL SWITCH CROSS C SECTION Switches with Y1 option bushings are supplied with (1) A112 Hex Nut and (1) A115 Lockwasher. Note: Switches with non-threaded bushings or bezels supplied without hardware. ACTUATOR/BUSHING OPTIONS Drawings reflect allowable actuator/bushing combinations. Note for drawings P2Y1 & P2Y2: Asterisk indicates .290 flats are supplied with options A, V, V30, V40, V70, V71, V80 & V81. For other options, .320 Dia. with no flats may be supplied PY THREADED P2Y1 THREADED P2Y2 NON-THREADED PD THREADED TERMINATION OPTIONS A A-1 HORIZONTAL P.C. MOUNTING HORIZONTAL P.C. MOUNTING APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com C71 PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES TERMINATION OPTIONS (CONT'D.) V, V-1 & V-2 Dim. A .550 .500 .500 Dim. B .150 .150 .100 SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Option V V-1 V-2 C VERTICAL P.C. MOUNTING V30, V40, V70, V80, V31, V41, V71 & V81 PANEL LAYOUT V30, V31, V40 & V41 Option Dim. A V30-V31 .527 V40-V41 .647 Dim. B .024 .048 PANEL LAYOUT V70, V71, V80 & V81 Option V70-V71 V80-V81 Dim. A .630 .953 V31, V41, V71 & V81 ARE THE SAME AS V30, V40, V70 & V80 RESPECTIVELY, EXCEPT WITH CRIMPED LEG DESIGN FOR P.C. BOARD RETENTION, AS SHOWN TO RIGHT. Z C W W1 W3 SOLDER LUG PRINTED CIRCUIT WIREWRAP LONG WIREWRAP SHORT WIREWRAP C72 X EXTRA LG. WIREWRAP APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com PB SERIES - MINIATURE MOMENTARY PUSHBUTTON SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE CONTACT MATERIAL OPTIONS B Dry circuit - gold over nickel over brass. RATING: 0.4 Volt-Amps (VA) max. at 20 V max. ELECTRIC LIFE: 60,000 cycles minimum. MECHANICAL LIFE: 500,000 cycles minimum. Q Power circuit - coin silver. RATING: 6 Amps at 125 VAC, 3 Amps at 250 VAC or 7 Amps at 30 VDC (resistive loads). ELECTRIC LIFE: 60,000 cycles minimum at full load. G Dry circuit or power circuit - gold over nickel over coin silver. RATINGS & ELECTRIC LIFE: Same as B & Q above - i.e. - can be used in either dry circuit or power circuit, however once used in power circuit, switch cannot be re-used in dry circuit. This option satisfies those customers who have both dry circuit and power circuit requirements, but prefer to inventory only one switch for both. N Dry circuit - gold over nickel over brass. Note- less gold than B option. RATING: 0.4 Volt-Amps (VA) max. at 20 V max. ELECTRIC LIFE: 10,000 cycles min. at 13 cycles per minute. T Power circuit - Silver plate over brass. RATING: 1 Amp at 125 VAC or 0.5 Amps at 250 VAC (resistive loads). ELECTRIC LIFE: 10,000 cycles min. at 13 cycles per minute. C Solder dipped terminals and custom contact plating available - contact factory. UL & CSA OPTIONS UL For power circuits - coin silver RATING: 6 Amps at 125 VAC or 3 Amps at 250 VAC (75% power factor). Underwriter Laboratories file no. E66367. Note - applicable only to terminations with coin silver contacts (Q or G options). CSA For power circuits - coin silver RATING: 6 Amps at 125 VAC or 3 Amps at 250 VAC (75% power factor). Canadian Standards Association file no. LR54592-1. Note - applicable only to terminations with coin silver contacts (Q or G options) as CSA recognizes switches for power applications only. EPOXY SEALING OPTION E REVERSE ACTION OPTION /R Space between terminals and case hole is completely epoxy sealed to prevent flux and contaminant entry. To reverse the NO and NC terminals, add /R to the switch model number. PANEL CUT-OUTS Cut-outs that accept all 1/4-40 threaded bushings: Without keying With A107 anti-rotate With A158 anti-rotate With D bushing ring ring With slotted keyway bushings Accepts all 1/4" nonthreaded bushings MISCELLANEOUS QUICK-CONNECT RECEPTACLES that are compatible with solder lug or p.c. terminals are commercially available. Consult factory. FRONT PANEL SEAL: Silicone rubber boots for front panel sealing of the switch against high pressure water or other contaminants are available. See Waterproof Switch Sealing Boots section in catalog. SWITCH CAPS for switches without bezels also available - see Hardware section of catalog APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com C73
PB13P2Y2V1B 价格&库存
很抱歉,暂时无法提供与“PB13P2Y2V1B”相匹配的价格&库存,您可以联系我们找货
