810KSV-1B
810KSV-1B
    APEM(埃斐)
    SWITCH PUSH SPDT 0.4VA 20V
810KSV-1B 数据手册
800 series Snap-action momentary pushbutton switches Distinctive features and specifications ❑ Panel and PC mount models ❑ Snap-in panel mounting version ❑ Tactile feedback B MATERIALS ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - gold over nickel plated brass contacts : 0.4VA - 20V max. - coin silver contacts : 6A 125VAC, 3A 250VAC, 7A 30VDC • Initial contact resistance : 20 mΩ max. • Insulation resistance : 2,000 MΩ min. between terminals & case ground. • Dielectric strength : 1,500 VAC for 1 minute between terminals & case ground. • Electrical life : 60.000 cycles at full load GENERAL SPECIFICATIONS AGENCY APPROVAL • Total travel : 0.9mm (.035) • Actuation force: Single pole: 290+/- 75g Double pole: 550+/- 75g • Operating temperature : -30°C to +85°C • Soldering : 300°C, 3 sec. max. APEM • Case : DAP • Actuator : polyamide, glass filled • Bushing : brass, nickel plated • Strap : stainless steel • Bracket : tin plated steel or brass • Contacts B: Gold Q : Coin Silver • Terminal seal : epoxy Availability: All models with coin silver contacts (Q) only. Marking:: To order switches marked UL, complete appropriate box on ordering format. www.apem.com 800 series Snap-action momentary pushbutton switches SERIES 810 820 Bushing Single pole Double pole B Contact material B Gold Q Coin Silver M Standard 1/4” threaded M1 Short 1/4” threaded S Non-threaded Termination Actuators K K1 K2 J81 Z C A-1 V30 Standard Short Medium Bezel & cap Bezel color (None) (None) Snap-in 2 Black Solder lug Printed circuit board Horizontal Straight w/bracket Cap color 2 Agency approval (None) No approval Black (B contact material only) /UL UL Approval (Q contact material only) ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. Sealing boots are available to protect the switches against dust and water. They are presented in section H. Mounting accessories : standard hardware supplied with all models with Ø 6,35 (1/4) threaded bushing : 2 - 5/16” hex nuts , 1 locking ring and 1 lockwasher. Standard and special hardware available are presented in section I. Packaging unit : 25 pieces for double pole 50 pieces for single pole NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. www.apem.com APEM 800 series Snap-action momentary pushbutton switches Terminations • Solder lug or straight PC terminals • Epoxy sealed terminals standard NO 1.19 (.047) NC 4.82 (.190) 1.98 (.078) COMM C 4.37 (.172) Z 1.57 (.062) ➞ Keyway 1.27 (.050) 2.36 (.093) B Shown with standard plunger (K) ➞ Keyway Ø6.35-40UNS (1/4-40UNS) EPOXY 2.35 (.093) Solder lug terminals 1.00 (.040) MOM NO 0.75 (.030) NC 5.85 (.230) ➞ Keyway Ø6.35-40UNS (1/4-40UNS) 2.35 (.093) Solder lug terminals 7.35 (.290) 1.00 (.040) EPOXY MOM NO 0.75 (.030) NC 5.85 (.230) ➞ Keyway 1.27 (.050) 12.70 (.501) 10.84 (.427) 4.70 (.185) Ø1.91 (Ø.075) 0.79 (.031) C Ø3.09 (Ø.122) 5.45 7.37 (.215) (.290) NO NC MOM 3.05 (.120) 7.57 (.298) 0.36 (.014) ON 13.06 (.514) EPOXY Ø6.22 (Ø.245) 1.02 (.040) APEM www.apem.com 12.70 (.500) 4.70 (.185) Horizontal right angle 810KSA-1 12.70 (.500) 12.70 (.500) COMM 4.35 (.172) Ø3.10 (.122 DIA) 7.35 10.65 (.290) (.420) 4.70 (.185) ON 5.08 (.200) 820KMZ 12.70 (.500) COMM 4.35 (.172) Ø3.10 (.122 DIA) 7.35 10.65 (.290) (.420) 5.35 (.210) ON 4.70 (.185) 810KMZ 800 series Snap-action momentary pushbutton switches ➞ Keyway 1.02 (.040) 13.06 (.514) 12.73 (.501) Ø6.22 (Ø.245) EPOXY 0.41 (.016) ON 3.81 (.150) 12.70 (.501) MOM 5.45 7.37 (.215) (.290) 10.97 (.432) 3.81 (.150) 0.79 (.031) B 4.70 (.185) Ø3.10 (.122) 5.08 (.200) 12.70 (.500) 4.70 (.185) 820KSA-1 3.05 (.120) Horizontal angle ➞ Keyway 4.70 (.185) MOM Ø3.10 (Ø.122) COMM NO 3.18 (.125) 9.40 (.370) 0.66 (.026) 1.02 (.040) 4.70 (.185) ON Ø1.91 (Ø.075) 0.81 (.032) 810KSV30 15.75 (.620) 3.18 (.125) Ø6.22 (Ø.245) 13.39 (.527) 16.36 (.644) Straight PC terminals with bracket NC 0.53 (.021) 5.46 (.215) 7.37 (.290) 7.37 (.290) ➞ Keyway Straight PC terminals with bracket 13.39 (.527) 15.75 (.620) 4.70 (.185) 1.02 (.040) 16.36 (.644) NO 9.40 (.370) 4.70 (.185) COMM 3.18 (.125) 5.33 (.210) 0.61 (.024) MOM 0.81 (.032) ON Ø3.10 (Ø.122) 820KSV30 3.18 (.125) Ø6.22 (Ø.245) Ø1.91 (Ø.075) NC 0.53 (.021) 5.46 (.215) 7.37 (.290) 12.73 (.501) ➞ Keyway R0.13 (R.005) MAX. 12.83 (.505) Solder lug terminals with snap-in bezel 15.24 (.600) MOM 810K2M1ZQJ8122 2.54 [.100] 810K1M1ZQJ8122 0.25 [.010 17.40 (.685) DIM. A 15.62 (.615) 23.04 (.907) 10.41 (.410) MODEL NUMBER 2.29 (.090) NC NO C ON A 4.37 (.172) www.apem.com 10.41 (.410) APEM 800 series Snap-action momentary pushbutton switches Actuator & bushing options Ø6.35 (Ø.250) 6.35 (.250) B 1.02 (.040) S 1.02 (.040) M & M1 7.36 (.290) 1.02 (.040) 7.37 (.290) Ø6.35 (Ø.250) 2.53 (.100) A 3.10 (.122) BUSHING OPTION DIM. B M DIMENSION A ACTUATOR OPTION K K1 K2 6.35 (.250) 5.84 (.230) .069 (1.75) 4.27 (.168) S 6.35 (.250) 5.84 (.230) .069 (1.75) 4.27 (.168) M1 3.91 (.154) 8.18 (.322) 4.91 (.165) 6.70 (.264) B 1.02 (.040) B Ø8.31 (Ø.327) Ø8.31 (Ø.327) Panel cut-outs 4.75 (.187) 6.10 (.241) 2.63 (.104) 1.98 ( .078) 2.36 ( .093) 6.35 ( .251) 6.35 ( .251) Without keying With A107 anti-rotate ring 0.76 (.030) 6.35 ( .251) With A158 anti-rotate ring 6.35 ( .251) With slotted keyway Contact materials B Dry circuit - gold over nickel over brass. RATING: 0.4 Volt-Amps (VA) max. at 20 V max. ELECTRIC LIFE: 60,000 cycles minimum. MECHANICAL LIFE: 500,000 cycles minimum. Q Power circuit - coin silver. RATING: 6 Amps at 125 VAC, 3 Amps at 250 VAC or 7 Amps at 30 VDC (resistive loads). ELECTRIC LIFE: 60,000 cycles minimum at full load. APEM www.apem.com 6.35 ( .251) Accepts all 1/4” nonthreaded bushings 800 series Snap-action momentary pushbutton switches Approvals /UL For power circuits - coin silver RATING: 6 Amps at 125 VAC or 3 Amps at 250 VAC (75% power factor). Underwriter Laboratories file no. E66367. Note - applicable only to terminations with coin silver contacts (Q option). Hardware B Anti-rotate ring A107 Nickel plated brass 1/4 5/16” Hex nut A112 Nickel plated brass 1/4-40 www.apem.com 0.74 (.029) 1.65 (.065) 30° CHAMFER (BOTH FACES) 1.57 (.062) 0.74 (.029) 7.94 (.312) 1/4-40 UNS-2B 11.89 (.468) 9.17 (.361) 8.71 (.343) 2.08 (.082) Anti-rotate ring A158 Nickel plated brass 1/4 APEM
810KSV-1B 价格&库存
很抱歉,暂时无法提供与“810KSV-1B”相匹配的价格&库存,您可以联系我们找货
