V1D1B60B-CMC00-000
V1D1B60B-CMC00-000
    CARLING
    船型开关 SPST 20A 12VDC
V1D1B60B-CMC00-000 数据手册
V-Series Contura® II & III Sealed Rocker Switches P ROD UC T WE BP A GE request sample, configure part, watch video Contura® IP66/68 Snap-In Mounted Switches The V-Series switches are well known for their cutting edge design, high quality, maximum performance and unmatched reliability. These snap-in rocker switches offer countless options for ratings, circuits, colors, illuminations and symbols. These single or double pole switches feature removable actuators in a choice of actuator styles and colors, which may be purchased and stocked separately. An optional plug-in terminal connector enables pre-wiring of wire harness. 1-2 Poles .4-20 Amps 125-250 VAC 12-24 VDC Typical Applications ∙ On/Off-Highway ∙ Marine ∙ Armored Vehicles ∙ Industrial Automation www.carlingtech.com 860.793.9281 ∙ Commercial Food ∙ Medical Equipment sales@carlingtech.com ∙ Any Application Requiring Sealing Protection Design Features INTERCHANGEABLE ACTUATORS Panel redesign is a snap with our wide range of rocker styles. Achieve maximum design variety with minimum inventory. Simply swap rockers to create an entirely new look for your panel. OPTIONAL PANEL SEAL Helps prevent water/ dust ingress behind panel. 2. DUAL SEAL PROTECTION Seals out water, dust, debris, and sealed to IP66/68 for above-panel components MULTIPLE LIGHTING OPTIONS In addition to Incandescent lamps, our LED illumination is offered in a wide array of light intensities, colors, as well as dual level, tri-color, and flashing options. CLEAN CONNECTIONS Options for both eight and ten terminal base styles with AMP & Packard compatible connectors affords myriad circuit options while providing ease of assembly. BRASS ROLLER PIN Robust mechanism eliminates the need for lubricants. Enables switch to withstand -40°C to +85°C temperatures. SILVER PLATED BUTT CONTACT MECHANISM Providing 50k to 100k electrical cycles, circuit and load dependent Actuator Options & Accessories Contura II & III Contura X constructed of thermoplastic Contura X helps prevent inadvertent The Contura II & III actuators are polycarbonate and are offered with a hard nylon overlay or a “soft-touch” elastomer overlay. These models incorporate aesthetic designs on the top and bottom of the rocker featuring two rows of raised “bumps” The raised bracket/bezel on the actuation of the rocker, as well as preventing debris from being trapped under the actuator. This curved rocker style is available with a variety of lenses and legends. on the Contura II and three “indented” lines on the Contura III. Contura IV Contura XI a Shape” actuator works with the Contura XI helps prevent inadvertent The Contura IV’s “Shape to create curves, contours & advanced styling of the latest panel designs, flowing with these advanced curves & radii. This actuator style fits on the Contura flush bracket/bezel. The raised bracket/bezel on the actuation of the rocker, as well as preventing debris from being trapped under the actuator. This convex style rocker is available with a wide variety of lenses and legends. Contura V Contura XII V actuator provides the perfect paddle style actuator with the raised “Shape to create a Shape” design contoured handle design provides bracket, Contura V can be mounted in operation and is available with all in groups. offerings. The symmetrically curved Contura The Contura XII version features a complement to the Contura IV’s bracket/bezel of Contura X and XI. The concept. With its flush style mounting intuitive recognition and ease of between two Contura IV’s, by itself, or Contura X and XI lens and legend Contura VI (WAVE) Contura XIV switches, when used in a row, create crossover rocker design which should The Contura VI WAVE sealed rocker an uniquely appealing “wave” design on your panel. A variety of colors and finishes are available for both rocker and wave insert. Contura VI features bar and oval lenses. The Contura XIV represents a sleek new appeal to Trucks, Buses and Heavy Vehicles as well as the Marine Industry. Intuitive feel is provided by recessed ridges along with a Center Groove which effectively defines the boundary between top and bottom switch functions. Contura VII Contura VII featuring gently curved corners and edges assuring compatibility with most any panel design. Intuitive feel is maximized by the use of 2 embossed circular pads located at opposite ends of the rocker. Any combination of Bar or Oval style lenses can be located in the pads providing a truly unique look, exclusive to Contura VII. 3. Illuminated Indicators & Accessories Alert operator of systems functions or malfunctions, are offered with removable/ replaceable lamps in Contura II, II, V or X styles. Accessories include connectors, mounting panels, hole plugs, panel seals, and actuator removal tools. Refer to accessories page for full details Tech Specs Electrical Contact Rating Environmental 4VA @ 24VDC (MAX) resistive 15 amps, 125VAC 10 amps, 250VAC 1/2 HP 125-250VAC 20 amps, 4-14VDC 15 amps, 15-28VDC 10A, 14VT 6A, 125VAC L Sealing IP66/68, for above-panel components of actual switch only. Corrosion Mixed Flowing Gas (MFG) Class III 3 year accelerated exposure per ASTM B-827, B-845 Silver and gold contacts Dielectric Strength 1500 Volts RMS Operating Temp -40°C to +85°C Insulation Resistance 50 Megohms Vibration 1 Initial Contact Resistance 10 milliohms max. @ 4VDC Life Up to 100,000 cycles, circuit and load dependent Per Mil-Std 202F, Method 204D Test Condition A 0.06 DA or 10G’s 10-500 Hz. Tested with VCH connector. Test criteria - No loss of circuit during test, pre and post test contact esistance. Contacts Silver alloy, silver tin-oxide, fine silver Vibration 2 Terminals Brass or copper/silver plate 1/4” (6.3mm) Quick Connect terminations standard. Solder lug, Wire Lead Resonance search24-50 Hz 0.40 DA50-2000 Hz ±10 G’s peak Horizontal Axis 3-5 G’s max. Random 24 Hz 0.06 PSD-Gsq/Hz 60 Hz 0.50 100 Hz 0.50 200 Hz 0.025 2000 Hz 0.025 No loss of circuit during test; Browse Standard Parts > Ordering Scheme V Sample Part Number 1 D A S W 0 B - A Z E 00 - 0 1 Selection 2 3 4 5 6 V-Series 2. CIRCUIT Terminal Connections as viewed ( ) - momentary from bottom of switch: SP - single pole: terminals 1, 2 & 3. 8 terminal 10 terminal DP - double pole: terminals 1, 2, 3, 4, 5 & 6. 8 - - 7 8 - - 7 Terminals 7, 8, 9 & 10 for lamp circuit only. 1 - - 4 1 - - 4 2 - - 5 2 - - 5 3 - - 6 3 - - 6 10- - 9 Position: 1 2 3 SP DP 2 & 3, 5 & 6 Connected Terminals 1 & 2, 4 & 5 1 A ON NONE OFF 4 D ON NONE ON 6 J ON OFF ON 7 K ON OFF (ON) 8 L (ON) OFF (ON) 9 N OFF NONE ON SPECIAL CIRCUITS H* 2 & 3 2 & 3, 5 & 4 5&4 G* 2 & 3, 5 & 6 2 & 3 OFF S* 2 & 3, 5 & 6 2 & 3 1&2 M* (2 & 3, 5 & 6) 2 & 3 OFF R* (2 & 3, 5 & 6) 2 & 3 2&1 E* 5 & 6 5 & 3 5&1 *Jumper between terminals 2 & 5 for circuits H,G,M,R & S are specified in selection 4. External jumper between terminals 2 & 4 for circuit E are provided by customer. Circuit E may be used for SP OFF-ON-ON circuit. 3. RATING 1 B C D E F M N 4 .4VA @ 28VDC Resistive 15A 24V 20A 18V 20A 12V 20A 14V, 10A 14VT (circuit 1, 4 , A & D only) 10A 14V, 6A 14VT (circuit G only) .4VA/20A 12V .4VA/15A 24V 9 10 11 5. ILLUMINATION & SWITCH SEALING 3 & 6 end of switch. Positive (+) and negative (-) symbols apply to LED lamps only Unsealed Lamps S 0 NONE C 3 2 H Z 2 DOUBLE POLE SWITCHES ONLY M R 1 2 P V 1 2 Illumination Type Lamp wired to Terminals – UP INDEPENDENT – 3 (+) 7 (–) 8 (+) 7 (–) UP DOWN UP UP 3 (+) 6 (–) 1 (+) 4 (–) 1 (+) 4 (–) 3 (+) 6 (–) Lock above terminals 1 & 4 end of switch W lock 13 Lamp above terminals 3 & 6 end of switch No lamp 0 Neon 1 125VAC 2 250VAC Incandescent 4 3V 5 6V 6 12V 7 18V 8 24V LED* superbright superbright Red Amber Green Red 2VDC A L F R 6VDC B M G S 12VDC C N H T 24VDC D P J V * Consult factory for “daylight bright” LED options. Typical current draw for LED is 20ma. 8. FLUSH BRACKET COLOR, PANEL SEAL 1 Black White Gray No Seal B W G One Seal C Y H 9. HARD SURFACE ACTUATOR 1 Black Gray Red White Contura II A B G H Contura III C D E F Actuator orientation above terminals: 1,4 3,6 10. LENS Z - No Lens Clear White Amber Green Red Blue 3 8 D J P V Lock Color Match Actuator Black White Red Safety Orange 1 Up Down Up & Down Center 3 A H R 1 B J S 2 C K T 3 D L V 4 E M W 5 12. ACTUATOR LENS OR BODY LEGENDS 2 00 - No Legend 21 22 23 24 OFF ON O I 25 O 26 O 27 O 28 I F N F For additional legend options & codes, visit us at www.carlingtech.com 13. LEGEND ORIENTATION 0 1 2 3 4 No legend (used with codes 21-28 in selection 12) Orientation 1 Orientation 2 Orientation 3 Orientation 4 1 2 3 4 Notes: Consult factory to verify horsepower rating for your particular circuit choice. 1 Custom colors are available. Consult factory. 2 White imprinting is standard on black actuators; Black imprinting is standard on white, red and gray actuators. Custom colors are available, consult factory. 3 Only available with 3 position circuits. Center OFF and special circuits only available with center position lock function. 4 Additional ratings available. See V-Series Switch Accessories page. Configure Complete Part Number > 6. 12 11. ACTUATOR LOCK FUNCTION AND COLOR 8 term 10 Term Termination Jumper 1 2 .250 TAB (QC) no barriers No A B .250 TAB (QC) with barriers No J K .250 TAB (QC) no barriers Yes T2 to 5 3 4 Solder Lug no barriers No C D Solder Lug No 5 6 Wire Leads no barriers No E F Wire Leads No Note: Codes J & K for circuits H, G & M. Do not use silicone based lubricants to reduce terminal insertion forces during connector assembly, as it is detrimental to function and performance. 6. LOCK 8 Lens color for LEDs must be clear, white, or match color of LED. Green or blue lenses are not recommended with Neon lamps. 4. TERMINATION / BASE STYLE Sealed 7 7. LAMP 1. SERIES V Contura II & III locking Browse Standard Parts > Dimensional Specs inches [millimeters] CONTURA II CONTURA III SHOWN WITH SQUARE LENS 1.950 [49.09] CONTURA IV SHOWN WITH BAR LENS 2.000 [50.55] 1.950 [49.09] 1.079 [27.40] 1.126 [28.60] 1.550 [39.37] 8 TERMINAL BASE W/BARRIERS 10 TERMINAL BASE W/BARRIERS 8 TERMINAL BASE W/O BARRIERS 1.050 [26.67] .940 [24.87] .505 [12.83] .505 [12.82] .250 [6.35] .250 [6.35] .031 [.78] .031 [.78] .390 [9.90] .960 [24.38] .820 [20.82] .250 [6.35] .031 [.78] .820 [20.82] .960 [24.38] 10 TERMINAL BASE W/O BARRIERS 10 TERMINAL BASE W/BARRIERS 8 1 2.029 [51.53] SWITCH SHOWN WITH VCH CONNECTOR 8 TERMINAL 7. 7 4 8 1 7 4 2 5 2 5 3 6 3 10 6 9 BOTTOM VIEW TERMINAL ARRANGEMENT 8 TERMINAL BASE .960 [24.38] BOTTOM VIEW TERMINAL ARRANGEMENT 10 TERMINAL BASE SWITCH SHOWN WITH VC1 CONNECTOR 10 TERMINAL Circuit Diagrams: CIRCUIT CODE CIRCUIT DIAGRAM CIRCUIT CODE CIRCUIT DIAGRAM 3 1 3 2 3 5 3 2 2 3 5 3 1 2 5 3 4 2 5 3 4 1 2 5 1 6 5 3 3 1 6 5 3 2 6 5 6 G 2 3 S 2 7 5 2 F 1 1 6 3 4 1 2 6 R 2 6 6 5 2 E 3 4 M 2 1 6 3 6 D 5 4 5 3 1 6 2 3 3 L 2 1 5 2 C 4 6 K 2 3 1 6 B 1 4 J 2 3 CIRCUIT DIAGRAM 13 6 A 2 CIRCUIT CODE SYMBOL LEGEND 2 5 3 3 4 SYM. DEFINITION DESIGNATES TERMINALS AND CONTACTS DESIGNATES MAINTAINED CIRCUITS DESIGNATES OTHER POSITION 8 H 2 8. DESIGNATES MOMENTARY CIRCUITS DESIGNATES TWO POSITION CONNECTION 2 5 DESIGNATES EXTERNAL JUMPER PROVIDED BY CUSTOMER Lamp Circuit Diagrams: LAMP CIRCUIT CODE CIRCUIT DIAGRAM LAMP CIRCUIT CODE +8 +8 A/1 F/6 1 -6 +3 L/9 2 LAMP CIRCUIT CODE G/7 +3 -6 SPECIAL #1 1 +3 +3 M/R 2 1 -7 2 SPECIAL #3 N/T 2 -7 1 2 SPECIAL #4 +3 -8 1 J/8 2 +3 1 +1 +3 -4 -6 +6 P/V 2 1 -7 2 -7 -7 +1 +3 +6 1 +8 +1 +3 -4 -6 H/Z 2 2 -7 +8 C/3 +6 1 +8 -6 -7 +3 CIRCUIT DIAGRAM -7 +8 1 1 2 -7 +1 +3 E/5 CIRCUIT DIAGRAM -7 +3 D/4 +3 1 -7 B/2 LAMP CIRCUIT CODE CIRCUIT DIAGRAM +8 K/W 2 1 U/Y 2 1 -7 +8 +6 (-)7 +10 1 2 -7 -9 J-Series Hazard Warning Circuit Diagrams: CIRCUIT CODE 1 3 17 18 10(-) J1 1 2 11 13 5 17 3 14 1 18 10(-) 3 5 5 3 14 8 6 JA 11 13 3 14 JJ 8 1 2 11 13 17 18 10(-) J4 2 5 1 5 17 18 3 8 J3 1 J5 17 18 10(-) 3 2 10(-) 1 2 1 5 CIRCUIT DIAGRAM 8 J2 9. CIRCUIT CODE CIRCUIT DIAGRAM 11 13 JK 3 14 15 12 6 16 NOTE: J circuits are available for all non-locking V-Series styles. Consult factory for partnumber details. SYMBOL LEGEND SYM. DEFINITION DESIGNATES TERMINALS AND CONTACTS DESIGNATES LAMP LOCATION 2 Stand-Alone Components Reduce inventory levels and cost by stocking actuators and base switches separately. Contura II, III, IV, V, VI, VII, X, XI, XII, XIV Base switches separately: specify V with code selections 2-8 in the ordering schemes. Contura II, III, IV, V Actuator only: VV with code A or C for selection 9, & with selections 10-14 in the ordering schemes. Contura VI Actuator with lenses and inserts only: VT with code selections 9-16 Contura II, III, IV, V, VII Actuator only: VV with code A, C, E, G, P or Z for selection 9 & with selections 10-14 in the ordering schemes. Contura X, XI, XII, XIV actuators with lenses separately: VV with code selections 9-14 in the ordering schemes. Panel Seal: VPS Contura X & XI actuators without lenses separately Contura XII actuators without lenses separately VVR 6 1 00 1 1 2 3 4 VVP J 1 Z 21 1 00 5 1 1. CONTURA X & XI ACTUATOR SEPARATELY 4 5 6 7 VVP 2. ACTUATOR STYLE & COLOR Contura X Contura XI 2. ACTUATOR STYLE & COLOR Black Gray White Red 1 2 3 4 6 7 8 9 J Black Z One bar lens Two bar lenses One square lens Two square lens 5 square lens on top/ bar lens on bottom (Contura X only) 4. ACTUATOR LENS OR BODY LEGEND 2 00 - No Legend 21 OFF 22 ON 23 25 O F F 26 O N 27 O 6 LEGEND ORIENTATION 0 No legend 1 Orientation 1 2 Orientation 2 1 2 1 2 3 4 VVL 2 1 00 0 1 2 3 4 VVT 1 1 TOP OF LENS SEPARATELY VVT 1 Bar lens 2 One Piece Square lens 3 Bottom of Two-Piece Square lens 5 2 COLOR 3 TRANSLUCENT LENS COLOR 5 VVL 2 LENS STYLE 2 2 Smoke 28 I 3 1 CONTURA X, XI & XII LENS SEPARATELY 1 Clear I Contura X, XI & XII actuator lens assembly separately Contura X, XI & XII top piece of 2-piece lens separately 1 24 O For additional legend options & codes, visit us at www.carlingtech.com 1 No legend Orientation 1 Orientation 2 Orientation 3 Orientation 4 Square lens 5, 7 LENS OR BODY LEGEND 2 For additional legend options & code, visit us at www.carlingtech.com 0 1 2 3 4 N White M Red 1 Bar lens No lens 00 - No Legend this location 11 ON 12 OFF 13 I 14 O OFF ON O I 15 O O 16 O O 17 O I 18 I O F N N F F F 5. LEGEND ORIENTATION 1 K Gray 3,4 LENS OPENING FOR 1 3. LENS OPENING FOR 1 actuator stem posts mount toward actuator stem 3 1 Clear 2 White 3 Amber 4 Green 4 3 White Contura X, XI & XII actuator lens assembly: top lens bottom lens } two piece lens assembly 1 piece lens/bar lens are positioned the same as bottom lens for assembly, minus the top lens. Lenses snap in from bottom. Notes: 1 If actuator lens opening for 2 bar or 2 square lenses, legend orientation 0,1, or 2 must be chosen. 2 Center of actuator marking not available for Contura XII. 3 Legend is not available for bar style lens. 4 Not recommended with neon lamps. 5 Must also order top piece of 2 piece square lens separately. 10. 3 1 CONTURA XII ACTUATOR SEPARATELY VVR 1 2 3 4 2 4 LENS OR BODY LEGEND 00 - No Legend 21 25 O F F 5 Red 6 Blue 4 2 OFF 22 ON 23 26 O N O 27 O 24 I 28 I For additional legend options & codes, visit us at www.carlingtech.com. 5 LEGEND ORIENTATION 3 0 1 2 3 4 No legend Orientation 1 Orientation 2 Orientation 3 Orientation 4 1 2 3 4 Accessories Easily integrate Contura products into your system, with Contura Accessories Q.C. SELECTION GUIDE Contura Connectors PART NO COMPANY SERIES WIRE RANGE TIN PLAIN Q.C. SELECTION PLATEDGUIDEAWG BRASS BRASS ORIENTATION MM 2 (REF) WIRE PART NO 02965580 12 3.0 RANGE COMPANY ORIEN02965471 TIN 12010601 (2)16-14 (2)1.0-2.0 2 SERIES TATION PLAIN PACKARD AWG 16-14 MM 1.0-2.0 PLATED 02965470 B BRASS 58 SERIES (REF) BRASS Q.C. SELECTION Q.C.06288318 SELECTION GUIDE Q.C. SELECTION GUIDE GUIDE 02965469 20-18 .5-.8 02965580 12 3.0 WIRE WIRE 105.0 WIRE 12084590 PART NO 12010601 PART NO PART NO 02965471 (2)16-14 (2)1.0-2.0 RANGE RANGE RANGE TANG 12052224 123.0 ORIENCOMPANY COMPANY COMPANY ORIENORIENPACKARD TIN TIN TIN 02965470 16-14 1.0-2.0 B 2 2 SERIES PLAIN SERIES PLAIN PLAIN TATION TATION TATION 58SERIES SERIES AWG MM AWG MM AWG MM 2 12015870 16-14 1.0-2.0 PLATED PLATED PLATED BRASS BRASS PACKARD BRASS 02965469 BRASS 06288318 BRASS 20-18(REF) .5-.8 (REF) (REF) BRASS METRI-PACK 12020035 (2)22-18 (2).5-.8 A 02965580 3.0 12 3.0 105.03.012 12084590 12 02965580 630 SERIES 02965580 12015832 12015869 20-18 .5-.8 TANG 12010601 12010601 12010601 (2)1.0-2.0 02965471 02965471 02965471 (2)1.0-2.0 (2)16-14 (2)16-14 (2)1.0-2.0 12052224(2)16-14 123.0 PACKARD PACKARD PACKARD Q.C. SELECTION GUIDE 12052222 20-22 .35-.5 B1.0-2.0 B1.0-2.0 B 02965470 02965470 16-14 02965470 16-14 1.0-2.0 16-14 16-141.0-2.0 58 SERIES 58 SERIES 5812015870 SERIES TANG SYMBOL = SHOWS ORIENTATION OF TANG IN SLOT PACKARD 02965469 06288318 02965469 20-18 06288318 02965469 .5-.8 20-18 06288318 .5-.8 20-18 .5-.8 WIRE 16-12 PART NO METRI-PACK 12020035 (2)22-18 (2).5-.81.3-3 A SYMBOL RANGE AMPCOMPANY 60253-1 105.0 105.0 105.0 12084590 60253-2 12084590 12084590 630 SERIES ORIEN(2) 16 .5-.8 (2) 1.3 12015832 PLAIN 12015869 TANG TANG TANG TIN12052224 250 SERIES 12052224 123.0 20-18 12052224 123.0 123.0 SERIES TATION B AWG 18-14 MM 2 Q.C. SELECTION GUIDE PLATED FASTIN-FASTON 42100-1 42100-2 .8-2 BRASS 12052222 20-22 .35-.51.0-2.0 12015870 12015870 12015870 16-14 1.0-2.0 16-14 16-14 1.0-2.0 (REF) BRASS PACKARD PACKARD PACKARD TANG SYMBOL = SHOWS ORIENTATION OF TANG IN SLOT WIRE (2)22-18 (2)22-18 (2)22-18 A(2).5-.8 A 12020035 12020035 12020035 METRI-PACK METRI-PACK60295-1 METRI-PACK 22-18 .3-.9 16-12 1.3-3A(2).5-.8 PART NO 60295-2 02965580 12 (2).5-.8 RANGE 3.0 SYMBOL 630 SERIES 630 SERIES 630 SERIES 60253-2 60253-1 12015869 AMP 12015869 12015869 20-18 .5-.8 20-18 .5-.8 20-18 .5-.8 12015832 12015832 12015832 COMPANY ORIEN12010601 02965471 (2)16-14 (2)1.0-2.0 16 (2) 1.3 TIN Amp(2) PACKARD NOTE: Consult Delphi Packard and/or on actual part numbers and 250 SERIES PLAIN SERIES TATION 20-22 .35-.5 20-22 20-22 .35-.5 12052222 12052222 12052222 B 02965470 16-14 1.0-2.0 B availability. AWG MM 2 .35-.5 PLATED TANG SYMBOL = TANGSHOWS SYMBOLORIENTATION = TANGSHOWS SYMBOL = OFORIENTATION TANG INSHOWS SLOTOF ORIENTATION TANG IN SLOTOF TANG IN SLOT BRASS FASTIN-FASTON 42100-102965469 42100-2 .8-2PA AMP 58 is SERIES a registered trademark of AMP18-14 Inc. Harrisburg, (REF) BRASS 06288318 20-181.3-3 16-12 16-12 .5-.8 1.3-3 16-12 1.3-3 SYMBOL SYMBOL SYMBOL Delphi Packard is a registered trademark of Delphi-Packard Electrical Systems Warren, Ohio 60253-2 60253-2 60253-2 60253-1 60253-1 60253-1 AMP AMP AMP 60295-1 60295-2 02965580 12 105.0 12084590 (2) 16 22-18 (2) 1.3 (2) 16 3.0.3-.9 (2) 1.3 (2) 16 (2) 1.3 250 SERIES 250 SERIES 250 SERIES B B TANG B 12010601 (2)16-14 (2)1.0-2.0 .8-2 12052224 123.0.8-2 18-14 18-14 18-14 .8-2 42100-2 42100-2 42100-2 FASTIN-FASTON FASTIN-FASTON 42100-1 02965471 FASTIN-FASTON 42100-1 42100-1 .820 NOTE: Consult Delphi and/or Amp on actual part numbers andB availability. .820 PACKARDPackard 02965470 16-14 1.0-2.0 12015870 16-14 .3-.9 1.0-2.0 22-18 .3-.9 22-18 .3-.9[20.83] 60295-2 60295-2 60295-2 60295-1trademark 60295-1 60295-1 58 SERIES PACKARD AMP is a registered of AMP22-18 Inc. Harrisburg, PA 02965469 06288318 20-18 .5-.8 (2)22-18 (2).5-.8 A 12020035 METRI-PACK [20.83] Packard is a registered trademark of Delphi-Packard Systems Warren, Ohio 630 SERIES NOTE:Delphi Consult Delphi NOTE: Packard Consult and/or Delphi NOTE: Packard Amp Consult on actual and/or Delphi part Packard Amp numbers on actual and/or and part Amp availability. numbers onElectrical actual and part availability. numbers and availability. 12015832 12015869 12084590 20-18 105.0 .5-.8 AMP is a registered AMPtrademark is a registered ofAMP AMP trademark isInc. a registered Harrisburg, of AMP trademark PA Inc. Harrisburg, of AMPPA Inc. Harrisburg, PA TANG 12052224 123.0 of Delphi-Packard .35-.5 Systems 12052222 .820 Delphi Packard is Delphi a registered Packardtrademark is Delphi a registered Packard of Delphi-Packard trademark is a 20-22 registered Electrical trademark of Delphi-Packard Electrical Warren, Systems Ohio Electrical Warren, Warren, Ohio TANG SYMBOLSystems =Ohio SHOWS ORIENTATION OF TANG IN SLOT .820 .770 12015870 16-14 1.0-2.0 16-12 1.3-3 [20.83] PACKARD SYMBOL 60253-2 60253-1 [20.83] AMP .820 .820 A .820 [19.56] .820 12020035 .820(2)22-18 .820 (2).5-.8 METRI-PACK (2) 16 (2) 1.3 250 SERIES SERIES [20.83] [20.83] B [20.83] 630 [20.83] 12015869 [20.83] .5-.8 12015832 18-14 .8-2 42100-2[20.83]20-18 FASTIN-FASTON 42100-1 20-22 .35-.5 12052222 22-18 .3-.9 60295-2 60295-1 TANG SYMBOL SHOWS ORIENTATION OF TANG IN SLOT .770 .920 = .920 1.170 16-12 1.3-3 .770 .770 .770 NOTE: AMP Consult Delphi60253-1 Packard and/or Amp on actual part numbers and availability. [19.56] 60253-2 [23.37] SYMBOL [23.37] [29.72] (2) 16 (2) 1.3 AMP is a registered trademark of AMP Inc. Harrisburg, PA [19.56] [19.56] [19.56] 250 SERIES B Delphi Packard is a registered trademark of Delphi-Packard Electrical Systems Warren, Ohio 18-14 .8-2 42100-2 FASTIN-FASTON 42100-1 A A A A .920 .3-.9 60295-2 .920 22-18 60295-1 .920 .920 .920 .820 .920 PACKARD 630 1.170 1.170 .920 PACKARD .920 .820 1.170 1.170PACKARD 630 VC2 630 PACKARD 630 VC1 VC1 VC2 .950 [20.83] [23.37] [23.37] [23.37] [23.37] [20.83] [23.37] [23.37] [23.37] [29.72] [29.72] [29.72] [23.37] [29.72] NOTE: Consult Delphi Packard and/or Amp on actual B B part numbers and availability. [24.13] AMP is a registered trademark of AMP Inc. Harrisburg, PA B B A A A A A A A A A A A A AMP, PACKARD 58 AMP, PACKARD 58 AMP AMP Delphi Packard is a registered trademark of Delphi-Packard Electrical Systems Warren, Ohio A A A A PACKARD 630 PACKARD 630 PACKARD PACKARD 630630 PACKARD 630 AMP, PACKARD 58PACKARD 630 AMP, PACKARD 58 VC2 VC2 PACKARD PACKARD 630 PACKARD 630 PACKARD 630 VC2 PACKARD 630 PACKARD 630 630 .770 PACKARD 630 PACKARD 630 VC1 VC1 VC1 VC1 VC1 VC2 VC2 VC1 10 3 8 7 4 5 6 9VC2 .950 .9503 2 1 8 .950 VC2 2 1 PACKARD 630 PACKARD 630 7 4 5 6 VC1 B VC2 VC1 B B B B [19.56] .820 .950[24.13] .820 B [24.13] [24.13] B B AMP, PACKARD 581.266 AMP, PACKARD 58 B AMP B B B B B 1.466 1.466 [20.83] AMP, PACKARD AMP, PACKARD 58 58 AMP, PACKARD 58 AMP AMP, PACKARD 58 AMP AMP AMP AMP 1.266 1.250 [20.83] AMP, PACKARD 58 AMP, PACKARD 58 AMP, AMP, PACKARD PACKARD 58 58 [24.13] AMP, PACKARD 58 AMP, PACKARD 58 B B 10PACKARD 3 258[32.16] 1 8 10 3 2 1 78 4AMP, 105PACKARD 3 62958 1[37.24] 78 4 5 6 9 10 73 4 2 51AMP689 10 3 .920 2 1 8 7104 3 5 2 619 8 7 5 69 73 42 15 8 6 9 AMP, AMP4 3 2 34 2 5 1 6 8 7 4 5 [31.75] 6 7 4 5 6 [37.24] [32.16] .920 1.170 1 AMP,8 PACKARD7 58 AMP, PACKARD 58 10 3 1.266 2 1 8 4 1.266 5 6 9 1.466 10 3 2 1.266 1 8 7 41.4665 6 9 1.466 1.466 1.466 1.266 [23.37]71.466 1.266 1.266 1.250 1.250 1.250 [23.37] [29.72] 7 4 5 6 .770 3 2 1 8 [37.24] [37.24] [37.24] [37.24] [37.24] MARKING [37.24] [32.16] [32.16] [32.16] [32.16] [32.16] MARKING DETAIL MARKING DETAIL [32.16] MARKING DETAIL DETAIL[31.75] MARKING DETAIL MARKING1.250 DETAIL [31.75] [31.75] 1.466 1.466 1.266 1.266 [19.56] A A A A 10 3 2 1 8 7 4 FRONT VIEW 5 69 REAR VIEW FRONT VIEW REAR VIEW FRONT VIEW REAR VIEW PACKARD 630 PACKARD 630 VC2 PACKARD DETAIL 630MARKING DETAIL PACKARDMARKING 630 MARKING DETAIL MARKING DETAIL MARKING DETAIL MARKING MARKING MARKING DETAIL MARKING DETAIL DETAIL MARKING DETAIL MARKING DETAIL MARKING DETAIL MARKING DETAIL MARKING DETAIL MARKING MARKING DETAIL [37.24] [37.24] [32.16]DETAIL VC1 VC1 DETAIL VC2 MARKING [32.16] [31.75] .950 DETAIL FRONT FRONT VIEW FRONT VIEW FRONT VIEW FRONT VIEWREARFRONT VIEW VIEWREARB VIEW REARVIEW VIEW REAR VIEW REAR VIEW FRONT REAR VIEW FRONT VIEW REAR VIEW REAR VIEW REAR VIEW VIEW FRONT VIEW B VC1 MARKING DETAIL AMP, PACKARD 58 .920 AMP, PACKARD 58 MARKING DETAIL 1VC1 8 [23.37] 7 4 5 69 VC1 10 3 2 VC1VIEW FRONT REAR VIEW CONNECTOR HOUSING 1.466 CONNECTOR HOUSING CONNECTOR HOUSING CONNECTOR HOUSING 1.266 A A [32.16] VC1 VC1 MARKING DETAIL CONNECTOR HOUSING FRONT VIEW PACKARD 630 B AMP, PACKARD 58 10 3 2 1 8 1.266 VC1 [32.16] CONNECTOR HOUSING MARKING DETAIL FRONT VIEW [37.24]VC1 PACKARD 630 B .920 VC2 MARKING[23.37] DETAIL 10 3 FRONT 2 1 8 VIEW VC2 VC2 AMP 7 VC2 4 5 69 2 1 8 7 VIEW 4 5 6 REAR VIEW 3 VCH FRONT CONNECTOR HOUSING CONNECTOR HOUSING CONNECTOR HOUSING CONNECTOR HOUSING CONNECTOR1.466 HOUSING CONNECTOR HOUSING CONNECTOR CONNECTOR HOUSING 1.266 1.250 HOUSING A A (For AMP terminals only) PACKARD 630 PACKARD 630 (For AMP terminals only) (Foronly) AMP terminals (For AMP terminals VC2 [37.24] only) [32.16] [31.75] VC2 VC2 MARKING DETAILHOUSING MARKING DETAIL CONNECTOR FRONT VIEW REAR VIEW 10 3AMP 2 terminals 1 8 (For only) 7 4 5 6 9 MARKING DETAIL REAR VIEW AMP, PACKARD 58 7 4 [24.13] 1.170 B VCH MARKING AMP, DETAIL PACKARD 58 [29.72] VCH VCH MARKING DETAIL B AMP AMP 5 69 1.466 [37.24] AMP 1.266 VC2 CONNECTOR [32.16]HOUSING (For AMP terminals only) MARKING DETAIL FRONT VIEW MARKING DETAIL REAR VIEW Contura X Boot (P/N VB1-01) VC1 CONNECTOR HOUSING VC2 CONNECTOR HOUSING (For AMP terminals only) 1.466 [37.24] MARKING DETAIL REAR VIEW AMP, PACKARD 58 MARKING DETAIL REAR VIEW .950 VCH MARKING DETAIL MARKING DETAIL [24.13] B B CONNECTOR HOUSING REAR FRONT AMP, PACKARD VIEW 58 AMP, PACKARDVIEW 58 3 2 1 8 1.250 VCH [31.75] CONNECTOR HOUSING MARKING DETAIL FRONT VIEW 7 4 5 6 MARKING DETAIL REAR VIEW Additional V-Series Ratings 1 VCH CONNECTOR HOUSING .4VA @ 28VDC Resistive VB1-01 VB1-01 4VB1-01 X BOOT 10A 250VAC 1/2 HP, 15A 125 CONTURA CONTURA X BOOT CONTURA X BOOT VAC 1/2 HP, No Agency Listings 10A 250VAC 1/2 HP, 15A 125 VAC 1/2 HP, UL Recognized, CSA Certified 5 1 VB1-01 B 15A 24V CONTURA X BOOT C VB1-01 20A 18VVB1-01 .757 .757 .757 CONTURA X BOOT D 20A 12V CONTURA X BOOT [19.23] [19.23] [19.23] E 20A 14V, 10A 14VT (circuits 1, 4, A, & D only) F VB1-01 10A 14V, 6A, 14VT (circuit G only) .757 .757 CONTURA X20A BOOT 6V G [19.23] [19.23] H 20A 3V .757 [19.23] 15A 125 VAC, 10A 250VAC, 1/2 HP 125-250 VAC; 6A 125 VAC L L 2 3.99 3.99 3.99 .757[101.35] [101.35] [101.35] M .4VA/20A 12V (combi-contact) [19.23] VRT (combination gold/silver contacts for borderline dry circuit VRT VRT REMOVAL ACTUATOR REMOVAL 3.99 .900 .900ACTUATOR .900ACTUATOR REMOVAL applications) TOOL TOOL TOOL [101.35] [22.86] [22.86] (For flush[22.86] (For flush bracket) flush bracket) N bracket) .4VA/15A 24V(For (combi-contact) 3.99 VRT (combination gold/silver contacts for borderline dry circuit ACTUATOR REMOVAL .900 [101.35] TOOL 3.99 applications) [22.86] 3.99 (For flush bracket) Contura II, III, IV, V, VI & VII Actuator Removal Tool (P/N VRT) TOP TOP TOP INSERT POINTS UNDER INSERT POINTS UNDER INSERT POINTS UNDER ACTUATOR ACTUATOR ACTUATOR HOLD FLUSH ON BRACKET AND PUSH HOLD FLUSH ON BRACKET AND PUSH HOLD FLUSH ON BRACKET AND PUSH IN IN IN TOP TOP TOP TOP INSERT POINTS UNDER ACTUATOR HOLD FLUSH ON BRACKET AND PUSH IN TOP TOP [101.35] [101.35] TOP TOP INSERT POINTS UNDER ACTUATOR INSERT POINTS UNDER HOLD FLUSH ON BRACKET ACTUATOR INSERT POINTS UNDER HOLD FLUSH ON BRACKET AND PUSH IN IN ACTUATOR HOLD FLUSH ON BRACKET AND TOP PUSH TOP IN TOP 11. VRT ACTUATOR REMOVAL VRT .900 NOTES VRT ACTUATOR REMOVAL TOOL REMOVAL TOOLACTUATOR .900 [22.86] Consult factory to determine availability for individual circuits and their HP rating. (For flush bracket) (For flush bracket) TOOL [22.86] 1. Not(For available with Contura 7 or 14 rocker styles. flush bracket) .900 AND PUSH [22.86] 2. Rating L available with circuits 1, 4, A & D only. Accessories Contura Mounting Panels Dimensional Specifications: in. [mm] TEST CUT HOLE IN ACTUAL MATERIAL TEST CUT HOLE IN ACTUAL MATERIAL VMS MOUNTING PANEL HOLE MOUNTING PANEL OPENING (2) UNITS +.008[+.20] -.000[-.00] 1.90 [48.2] MOUNTING PANEL THICKNESS .187 [4.75] .250 [6.35] .375 [9.52] .62 [1.57] .093 [2.36] .125 [3.17] +.008[+.20] -.000[-.00] 2.02 [51.3] +.008[+.20] -.000[-.00] .984 [25.00] MOUNTING PANEL For additional units, add 1.03[26.2] per unit. For more than 2 V-Series Switches, add middle section. Available in panel Thicknesses listed below. Consult factory. +.008[+.20] -.000[-.00] 2.90 [48.2] 1.970 [50.03] 2.300 [58.42] 1.187 [30.14] 2.300 [58.42] 1.034 [26.26] 1.340 [34.03] VMM MOUNTING PANEL MIDDLE VME MOUNTING PANEL END 1.700 [43.18] VMS MOUNTING PANEL .670 [17.01] 1.030 [26.16] 1.030 [26.16] 2.300 [58.42] 2.300 [58.42] 6.490 [164.85] 3.400 [86.36] VM6 MOUNTING PANEL VM3 MOUNTING PANEL Contura Hole Plug Dimensional Specifications: in. [mm] 1.450 [36.83] TEST CUT HOLE IN ACTUAL PLUG MOUNTING HOLE 1.450 MATERIAL [36.83] .830 [21.08] 1.910 [48.51] .830 [21.08] .960 [24.38] VHP CONTURA II,III HOLE PLUG 1.900 [48.26] 1.900 [48.26] .960 [24.38] .960 [24.38] .430 [10.92] .430 [10.92] TEST CUT HOLE IN ACTUAL MATERIAL VHP CONTURA II,III HOLE PLUG VH1 STANDARD HOLE PLUG (No wing serrations) (With VC1 connector attached) 2.000 [50.80] 1.067 [27.10] DETAIL VIEW VH1 HOLE PLUG (No wing Serrations for ease of removal) 1.928 [48.97] VH1 HOLE PlUG (No wing Serrations with VC1 connector attached) VH3 CONTURA IV HOLE PLUG (No wing serrations) 1.240 [31.50] .080 [2.03] 1.240 [31.50] 1.820 [46.23] VHP MOUNTING PANEL PLUG 1.460 [37.08] 1.820 [46.23] VH2 HOLE PLUG (with wing Serrations ) VH4 CONTURA IV HOLE PLUG (With wing serrations) VH2 STANDARD HOLE PLUG (With wing serrations) DETAIL VIEW VH2 HOLE PLUG (with wing Serrations ) DETAIL VIEW VH1,VH3 & VH5 HOLE PLUGS (No wing serrations for ease of removal) 1.020 [25.91] VH5 CONTURA V HOLE PLUG (No wing serrations) 12. VH6 CONTURA V HOLE PLUG (With wing serrations) DETAIL VIEW VH2,VH4 & VH6 HOLE PLUGS (With wing serrations) Authorized Sales Representatives and Distributors Click on a region of the map below to find your local representatives and distributors or visit www.carlingtech.com/findarep. CANADA EUROPE USA MIDDLE EAST MEXICO AFRICA ASIA-PACIFIC OCEANIA SOUTH AMERICA About Carling Founded in 1920, Carling Technologies is a leading manufacturer of electrical and electronic switches and assemblies, circuit breakers, electronic controls, power distribution units, and multiplexed power distribution systems. With six ISO9001 and IATF16949 registered manufacturing facilities and technical sales offices worldwide, Carling Technologies Sales, Service and Engineering teams do much more than manufacture electrical components, they engineer powerful solutions! To learn more about Carling please visit www.carlingtech.com/company-profile. To view all of Carling’s environmental, quality, health & safety certifications please visit www.carlingtech.com/environmental-certifications. 13. © Carling Technologies, Inc. Carling, Contura are registered trademarks of Carling Technologies, Inc. in the U.S. and other countries.
V1D1B60B-CMC00-000 价格&库存
很抱歉,暂时无法提供与“V1D1B60B-CMC00-000”相匹配的价格&库存,您可以联系我们找货
V1D1B60B-CMC00-000
    • 1+63.34200
    • 200+25.27200
    • 500+24.42960
