W11D2G661-A7900-000
W11D2G661-A7900-000
    CARLING
    船型开关 SPST 10A 12VDC
W11D2G661-A7900-000 数据手册
NOW PART OF W-Series Sealed Rocker Switches PROD UC T WE BP A GE request sample, configure part The W-Series features complete IP68 protection, even below the panel, where the critical connection is made from your wiring harness. When used in conjunction with the integrated connector, the totally submersible W-Series provides a seal for up to ten individual wires, assuring compatibility with even the most complex circuitry. 1-2 Poles .4-10 12-24 IP68 Sealing Amps Typical Applications ∙ Marine ∙ On/Off-Highway www.carlingtech.com 860.793.9281 sales@carlingtech.com VDC Above/Below-Panel Design Features ILLUMINATION Choice of highly reliable SMT LED or incandescent lighting with 21 dependent or independent circuit options. BODY One piece polyester 94V0 seamless body acts as an umbrella to protect critical internal components. 2. TRI-SEAL DESIGN Sealing at actuator, an insert molded neoprene base seal, along with wire lead seals, assures water tight, fully submersible protection. ROLLER PIN Proven reliable mechanism is lubricant free and allows for 100k electrical and 250k mechanical cycles, and withstands extreme temperatures from -40˚C to +85˚C. INTEGRATED CONNECTOR Accommodates Tyco/Amp .110 junior power timer contacts with twin locking tabs to provide a safe, secure, sealed connection. Tech Specs Environmental Electrical Contact Rating .4VA @ 24VDC 10 amps, 3-24VDC Sealing IP68, for above and below-panel components of actual switch only Dielectric Strength 1500 Volts RMS Insulation Resistance 50 Megohms Corrosion/ Chemical Splash Flowing Mixed Gas (FMG) Class III 3 year accelerated exposure per ASTM B-827, B-84 Initial Contact Resistance 10 milliohms max. @ 4VDC Operating Temperature Life Up to 100,000 cycles, circuit and load dependent -40°C to +85°C, 22 cycles, 300 hours Vibration 1 Contacts Silver tin-oxide, 88/12 Per Mil-Std 202F, Method 204D Test Condition A 0.06 DA or 10G’s 10-500 Hz. Terminals Copper with silver or gold plating Vibration 2 Quick Connect terminations. Voltage 3-24 VDC Overcurrent 15A for 50 cycles Resonance search 24-50 Hz 0.40 DA 50-2000 ±10 G’s peak Results Horizontal Axis 3-5 G’s max Random 24 Hz 0.06 PSD-Gsq/Hz 60 Hz 0.50 100 Hz 0.50 200 Hz 0.025 2000 Hz 0.025 Handling/Drop One meter onto concrete floor Salt Spray Per Mil-Std 202F, Method 101D, Test Condition A, 48 Hrs. Dust IP6X Thermal Shock Per Mil-Std 202F, Method 107F, Test Condition A, -55°C to 85°C Test criteria - pre and post test contact resistance Moisture Resistance/ Humidity Per Mil-Std 202F, Method 106F, Test Criteria - pre and post test contact resistance Physical Lighted LED - rated 100,000 hours 1/2 life (LED is internally ballasted for voltages to 24 VDC) Seals Neoprene Base Polyester blend rated to 125C with a UL flammability rating of 94V0. Actuator Basic actuator structure molded of thermoplastic polycarbonate with a hard Nylon 66 thermoplastic surface overlay. Lens Polycarbonate rated at 100°C Function 2 & 3 Position Rocker Style Operation Maintained & Momentary Base PA 6/6 30GF (glass filled) Actuator PA 6/6 13GF Bracket PBT 10GF Connector PBT 10GF, polarized Actuator Travel (Angular Displacement) 24° full throw Mounting Specifications Panel Thickness Range .032 to .125 For optimum panel fit, the following panel thicknesses are suggested: .032, .062, .093, .125 .830[21.08] 1.450[36.83] TEST CUT HOLE IN ACTUAL MATERIAL SWITCH MOUNTING HOLE 3. *Manufacturer reserves the right to change product specification without prior notice. Ordering Scheme Sample Part Number Selection W 11 D 2 B C 0 1 - A 7 Z 00 - 0 00 1 2. 3. 4. 5. 6. 1. SERIES 2. CIRCUIT ( ) - momentary For terminal arrangement, see dimensional specs Position: 1 2 3 SP DP 2 & 3, 5 & 6 Connected Terminals 1 & 2, 4 & 5 11 21 ON NONE OFF 12 22 (ON) NONE OFF 13 23 ON NONE (OFF) 14 24 ON NONE ON 15 25 ON NONE (ON) 16 26 ON OFF ON 17 27 ON OFF (ON) 18 28 (ON) OFF (ON) - 47 2 & 3 & 4, 5 & 6 2 & 3, 4 & 5 2 & 1, 4 & 5 - 49 2 & 3, 5 & 6 2 & 3, 4 & 5 2 & 1, 4 & 5 B 8. 9. 10. 11. 12. 13. 14. 10A 24V Selection 6: above terminals 1 & 4; Selection 7: above terminals 3 & 6 No lamp 0 LED* Red Amber Green White 2VDC A L F 4 6VDC B M G 5 12VDC C N H 6 24VDC D P J 8 * Consult factory for “daylight bright”, blue/green and white LED options. Typical current draw for LED is 20ma. 8. BRACKET COLOR 1 D 10A 12V G 10A 6V H 10A 3V .110 TAB (QC) 5. ILLUMINATION Lamp #1:above terminals 1&4 end of switch.; Lamp #2 above terminals 3&6 end of switch. Positive (+) and negative (-) symbols apply to LED lamps only Actuator Lens Position Lamps Illumination Type Lamp Wired to Terminals O NONE A # 1 Independent 8+ 7B # 1 Down 3+ 7C # 2 Up 3+ 7D # 1 Down 3+ 7 & # 2 Down 1+ 7E # 1 Up 1+ 7 & # 2 Up 3+ 7F # 1 Independent 8+ 7 & # 2 Up 3+ 6G # 1 Independent 8+ 7 & # 2 Up 3+ 7H # 2 Independent 8+ 7Selections for Single Pole Switches Only: J # 1 Down 3+ 8 & # 2 Independent 6+ 7K # 1 Independent 8+ 7 & # 2 Independent 6+ 7Selections for Double Pole Switches Only: L # 1 Down 3+ 6M # 2 Up 3+ 6N # 1 Down 3+ 6 & # 2 Down 1+ 4P # 1 Up 1+ 4 & # 2 Up 3+ 6R # 1 Down 3+ 7 & # 2 Up 6+ 7S # 1 Down 6+ 7 & # 2 Independent 8+ 7U # 1 Independent 8+ 7 & # 2 Independent 10+ 9V # 2 Independent 10+ 9W # 1 Independent 8+ 7 & # 2 Independent 10+ 7Y # 1 & # 2 Independent in Series 8+ 7Z # 1 & # 2 Independent in Parallel 8+ 7- 1 Black 9. ACTUATOR 3 3 4. TERMINATION / BASE STYLE 2 7. 6,7. LAMP (SAME CODING FOR BOTH SELECTIONS) W 3. RATING Rocker 1 Black with Laser Etched A Black 10. LENS COLOR / STYLE - ABOVE LAMP #1 TERMINALS 1 & 4 11. LENS COLOR / STYLE - ABOVE LAMP #2 TERMINALS 3 & 6 Z - No Lens Clear White Amber Green Red Blue 1 - B G M T - 7 C H N U 3 - D J P V - 9 E K R W 5 A - - - - Large Transparent Large Translucent Bar Transparent Bar Translucent Laser-Etched Lens color for LEDs must be clear, white, or match color of LED. 12. ACTUATOR LENS OR BODY LEGENDS 2 00 - No Legend this location/No actuator 11 ON 12 OFF 13 I 14 O OFF ON O I 15 O O 16 O O 17 O I 18 I O F N N F F F 21 22 23 24 OFF ON O I 25 O 26 O 27 O 28 I F N F For additional legend options & codes, visit us at carlingtech.com 13. LEGENDS ORIENTATION 0 1 2 3 4 No legend (used with codes 11-18 in selection 12) Orientation 1 P Orientation 2 P P Orientation 3 P Orientation 4 1 2 14. ACTUATOR LENS LEGENDS 3 4 2 00 No legend (used with codes 11-18 in selection 12) Selection 14 required when switch requires two legends. If the two legends consist of one lens & one body legend, lens legend must be specified in selection 12; body legend specified in selection 14. For standard legends, see “Standard Legend Codes” page. For additional legends, please consult factory Notes: 1 Custom colors are available. Consult factory. 2 White imprinting is standard on black actuators; Black imprinting is standard on white, red & gray actuators; Custom colors are available, consult factory. 3 .4VA @ 24VDC rating is available, consult factory for circuit compatibility. Configure Complete Part Number > 4. COS-0026 Rev: J *Manufacturer reserves the right to change product specification without prior notice. Browse Standard Parts > Ordering Scheme Sample Part Number Selection W 11 D 2 0 W 0 J - P 7 B 00 - 0 1 2. 3. 4. 5. 6. 7. 8. 9. 10. 1. SERIES 8. BRACKET COLOR 2. CIRCUIT 9. ACTUATOR w ( ) - momentary For terminal arrangement, see dimensional specifications Position: 1 2 3 SP DP 2 & 3, 5 & 6 Connected Terminals 1 & 2, 4 & 5 11 21 ON NONE OFF 14 24 ON NONE ON 3. RATING B D G H 10A 24V 10A 12V 10A 6V 10A 3V 4. TERMINATION / BASE STYLE 2 .110 TAB (QC) 5. ILLUMINATION Lamp #1:above terminals 1&4 end of switch.; Lamp #2 above terminals 3&6 end of switch. Positive (+) and negative (-) symbols apply to LED lamps only Actuator Lens Position Lamps Illumination Type Lamp Wired to Terminals O NONE C # 2 Up 3+ 7H # 2 Independent 8+ 7- 6. LOCK W Lock Option 7. LAMP #2 No lamp 0 LED* Red Amber Green White 2VDC A L F 4 6VDC B M G 5 12VDC C N H 6 24VDC D P J 8 * Consult factory for “daylight bright”, blue/green and white LED options. Typical current draw for LED is 20ma. 5. Locking Rocker J P R 11. 12. 13. 1 Black 1 Black Red 10. LENS Z - No Lens Clear White Amber Green Red 1 - B G M - 7 C H N 3 - D J P - 9 E K R Blue T U V W Large Transparent Large Translucent Bar Transparent Bar Translucent Lens color for LEDs must be clear, white, or match color of LED. 11. LOCK FUNCTION Up Down Lock Color B J Black C K White D L Red E M Safety Orange 12. LASER ETCHED, LENS OR BODY LEGEND 1 00 No legend For standard legends, see “Standard Legend Codes” page. For additional legends, please consult factory 13. LEGENDS ORIENTATION 0 1 2 3 4 No legend Orientation 1 Orientation 2 Orientation 3 Orientation 4 1 2 3 4 Notes: 1 White imprinting is standard on black actuators; Black imprinting is standard on white, red & gray actuators; Custom colors are available, consult factory. Configure Complete Part Number > COS-0026 Rev: J *Manufacturer reserves the right to change product specification without prior notice. Browse Standard Parts > Dimensional Specs inches [millimeters] 1.000 [25.40] 1.724 [43.78] 12° 1.962 [49.83] .418 [10.62] 1.707 [43.36] 2.162 [54.91] .031 [.79] .465 [11.81] KEYING FEATURE TERMINAL ARRANGMENT 1.178 [29.93] .714 [18.14] WCH CONNECTOR (190-31214-001) Notes: WCH connector is intended for use with Tyco/Amp .110 Junior Power Timer, female contacts, and wire seals. For 14-16 awg wire, specify Tyco/Amp P/N 927766-3 For 16-20 awg wire, specify Tyco/Amp P/N 927770-3 Tyco/Amp cable seal P/N 828904-1 (20-18 awg wire) or P/N 828905-1 (16-14 awg wire) is required for each individual wire lead, and Tyco/Amp cable plug, P/N 828922-1, is required to seal each unused connector opening. Consult Tyco/Amp for the cable seal recommended for your specific wire gauge and thickness. 6. 1.664 [42.27] .110 [2.79] SWITCH SHOWN WITH CONNECTOR INSTALLED 1.080 [27.43] 1.200 [30.48] 8 1 7 4 2 5 3 6 10 9 Circuit Diagrams CIRCUIT CODE CIRCUIT DIAGRAM CIRCUIT CODE CIRCUIT DIAGRAM 3 3 6 23 11 2 2 5 1 3 12 3 4 6 24 2 2 3 1 13 5 3 4 6 25 2 1 2 1 3 5 3 4 6 26 14 2 2 1 5 1 3 3 4 6 27 15 2 1 2 1 3 5 3 4 6 28 16 2 2 1 3 1 17 5 3 4 6 47 2 1 5 2 3 1 18 3 4 6 49 2 3 6 2 5 21 2 5 3 6 22 2 7. 5 COS-0026 Rev: J *Manufacturer reserves the right to change product specification without prior notice. Lamp Circuit Diagrams LAMP CIRCUIT CODE LAMP CIRCUIT CODE CIRCUIT DIAGRAM +8 A -8 K 1 +8 +10 1 2 -7 -9 +10 V 2 1 2 -7 -7 -9 +3 -7 CIRCUIT DIAGRAM +6 +8 +3 C U 2 1 -7 -7 B +6 +3 J 1 LAMP CIRCUIT CODE CIRCUIT DIAGRAM +3 2 L -6 W 1 +8 +10 1 2 -7 +1 +3 D +3 1 2 +8 -6 M 2 Y -1 +3 +8 +1 +3 -4 -6 1 2 N 2 1 +8 +3 1 +1 +3 -4 -6 -6 P 2 -7 1 -7 +3 2 +3 +8 2 COS-0026 Rev J ISO compliant symbols. Consult factory for custom legends. S +6 2 1 -7 -7 8. R -7 H 2 1 +8 +3 G Z 1 -7 -7 F 2 -7 -7 E 1 1 -7 +6 2 2 Standard Legend Codes YK UA UB US UV UW UX UY MP MR PX MS MT VU MW NZ NX NY YM VW PS PW PZ WG WM RN RP YG TX VD VE VF VG SH SM SN SP SR SY WY WZ UH UJ PD PE PF VC VJ UF UG MU TN NS PB SE VZ YE NN RW PU WA YN UE NM RJ NR YD TL VR SL VA UC VN PK VY UZ RH NU NV RB RC RK RL MZ RG WS WT UD UR WD TY WATER PUMP 9. PA UK WR UU UT YR PM VV WB TB TC TD TE MY PV TA TZ WC PT PN PH RA TU TT YL SK VS UL UM WK TS VT WL VP YJ PJ RY UP NW NP RE RF PP PR TV PC YT YU PL WJ MV RR TK RT SZ VX WF WH PG SJ YA YB RM TM RD RS UN TP TR NT MX YC TW TJ YF TH TF TG YS YH SX RZ YP WN WP WW WX SA SB SC SD ST SU WU WV SV SW VB VH VK VL VM WE SF SG SS RU RV RX CLA-0146 Rev: A ISO compliant symbols. Consult factory for custom legends. Authorized Sales Representatives and Distributors Click on a region of the map below to find your local representatives and distributors or visit www.carlingtech.com/findarep. CANADA EUROPE USA MIDDLE EAST MEXICO AFRICA ASIA-PACIFIC OCEANIA SOUTH AMERICA About Carling Founded in 1920, Carling Technologies is a leading manufacturer of electrical and electronic switches and assemblies, circuit breakers, electronic controls, power distribution units, and multiplexed power distribution systems. With six ISO9001 and IATF16949 registered manufacturing facilities and technical sales offices worldwide, Carling Technologies Sales, Service and Engineering teams do much more than manufacture electrical components, they engineer powerful solutions! To learn more about Carling please visit www.carlingtech.com/company-profile. To view all of Carling’s environmental, quality, health & safety certifications please visit www.carlingtech.com/environmental-certifications. 10. © Carling Technologies, Inc. Carling is a registered trademark of Carling Technologies, Inc. in the U.S. and other countries.
W11D2G661-A7900-000 价格&库存
很抱歉,暂时无法提供与“W11D2G661-A7900-000”相匹配的价格&库存,您可以联系我们找货
