PRK22J5FBBNN
PRK22J5FBBNN
    ZF
    SWITCH ROCKER SPST 6A 125V
PRK22J5FBBNN 数据手册
Single-Pole Rocker Switch PR Series Features     Smallest agency approved rocker switch Available in a variety of colors Low-profile design Mechanical life: min. 50,000 operations Electrical Ratings Electrical Life at Rated Load Switch Series EN61058 Rating UL1054 Rating PR 3A, 250VAC, T100/55 6A, 125VAC; 3A 250VAC Electrical Specifications According to VDE (Min. Operations) According to UL (Min. Operations) 10,000 6,000 Material Specifications PBT UL 94 V-0 rated PA66 UL 94 V-0 rated Ratings: 6A, 125VAC; 3A 250VAC (cULus) 3A, 250VAC, T100/55 (VDE) Actuator: Base: Dielectric Strength: 1000VAC for 1 minute Spring: Piano Wire Insulation Resistance: 100M ohms min at 500VDC Contacts: Silver Alloy Initial Contact Resistance: 20μ ohms max Movable Arm: Silver-Plated Copper Alloy Temperature Range: -0°C to + 100°C (VDE) -20°C to + 65°C (UL) Terminals: Silver-Plated Copper Alloy RoHS Compliant UL File No: E23301 Specifications subject to change without notice. Single-Pole Rocker Switch PR Series Examples of Common Part Numbers and Descriptions inches (mm) Contact Call, fax or visit our Website for more information. ZF Electronics Corporation 11200 88th Avenue Pleasant Prairie, WI 53158 Phone: 262.942.6500 Web: www.cherrycorp.com Email: cep_sales@zf.com Fax: 262.942.6566 The manufacturer accepts no liability for errors or non-availability, and reserves the right to change specifications without prior notice. Technical data relates to product specifications only. Features may differ from those described. Only drawings combined with product specifications shall be deemed binding. © 2007 ZF Electronics Corporation Last Updated:090911
PRK22J5FBBNN 价格&库存
很抱歉,暂时无法提供与“PRK22J5FBBNN”相匹配的价格&库存,您可以联系我们找货
