L12D1S001-AZZ00-000
L12D1S001-AZZ00-000
    CARLING
    船型开关 SPST 20A 12VAC
L12D1S001-AZZ00-000 数据手册
L-Series Switch The L-Series rocker switch is an innovative product offering total design flexibility, while at the same time setting new standards for performance and reliability. Its versatile design features include a neatly proportioned size that fits into an industry standard mounting hole of 1.734 x .867 (44.0mm x 22.0mm), countless unique choices for ratings, circuits, colors, illuminations and laser etched legends. These single or double pole switches also feature a broad choice of actuator styles, colors, and lenses with up to twelve terminals offering an extensive range of switch and lamp circuit options, including LED or incandescent illumination. Additionally, an optional plug-in terminal connector enables pre-wiring of wire your harness. Performance Features: Typical Applications: ŠŠ IP67 certified sealed front panel components ŠŠ Construction machinery ŠŠ Withstands temperatures from -40°C to +85°C ŠŠ Agricultural equipment ŠŠ Vibration, shock, thermoshock, moisture and salt spray ŠŠ On-highway transportation equipment Carling Technologies, Inc. 60 Johnson Avenue • Plainville, CT 06062 Phone: (860) 793-9281 • Fax: (860) 793-9231 Email: sales@carlingtech.com • www.carlingtech.com resistant 2 | L–Series Sealed Rocker Switches L-Series Switch DESIGN FEATURES LED LAMPS Utilize less current and are not affected by vibration, providing long lasting illumination. Available in 3 standard colors. LENS & LEGENDS Lens available in 2 sizes and 6 standard colors in either translucent or transparent materials. Numerous symbols and text available for imprinting or laser etching. SEAL PROTECTION Locks out elements such as water, dust & debris. Certified to IP67 for front panel components. ACTUATOR Available in rocker or paddle styles. Several standard color options also available. ROLLER PIN Eliminates need for lubricants, increasing the temperature range of the switch from -40˚ C to +85˚C [-40˚ F to 185˚ F]. TERMINALS Available with 2 industry standard termination options: .250 or .187 tabs with up to 12 terminal options. BASE Fits into industry standard mounting hole of 1.734 x .867 in [44.0mm x 22.0mm]. Email: sales@carlingtech.com Application Support: team2@carlingtech.com Phone: (860) 793–9281 Fax: (860) 793–9231 www.carlingtech.com L–Series Sealed Rocker Switches - General Specifications | 3 Electrical Environmental Contact Rating .4VA @ 24VDC (MAX) resistive 15 amps, 125VAC 10 amps, 250VAC 20 amps, 4-14VDC 15 amps, 15-28VDC Dielectric Strength 1250 Volts RMS between pole to pole 3750 Volts RMS between live parts and accessible surfaces Insulation Resistance 50 Megaohms Initial Contact Resistance 10 milliohms max. @ 4 VDC Life 100,000 cycles maintained, 50,000 cycles momentary at rated voltage and current Contacts 90/10 silver-nickel, silver tin-oxide, gold Terminals Brass or copper/silver plate 3/16” (4.76mm) & 1/4” (6.3mm) Quick Connect terminations standard. Environmental IP67 for above panel components of the actual switch, representing an index of protection as applied to electrical equipment in accordance with IEC 529, BS 5490, DIN 400 50 & NFC 20 010. Corrosion Mixed Flowing Gas MFG Class III per ASTM B-827 & B-845, Method H, with 3 years exposure. Operating Temperature -40°C to + 85°C Vibration 1 Per Mil-Std 202F, Method 204D Test Condition A 0.06 DA or 10G’s 10-500 Hz. Tested with VCH connector. Test criteria - No loss of circuit during test and pre and post test contact resistance. Vibration 2 Resonance search 24-50 Hz 0.40 DA 50-2000 ±10 G’s peak Results Horizontal Axis 3-5 G’s max. Random 24 Hz 0.06 PSD-Gsq/Hz 60 Hz 0.50 100 Hz 0.50 200 Hz 0.025 2000 Hz 0.025 No loss of circuit during test;
L12D1S001-AZZ00-000 价格&库存
很抱歉,暂时无法提供与“L12D1S001-AZZ00-000”相匹配的价格&库存,您可以联系我们找货
L12D1S001-AZZ00-000
  • 1+141.466241+18.30082
