AS37S0000
AS37S0000
    APEM(埃斐)
    船型开关 SPDT 400mA 20V 20V
AS37S0000 数据手册
PANEL SWITCHES - SW 11 20 AS AS series Snap-in rocker switches DISTINCTIVE FEATURES Double insulation Epoxy sealed terminals UL approved ELECTRICAL SPECIFICATIONS • Max. current/voltage rating with resistive load : - silver contacts (code 1) and gold plated silver contacts (code 2) : 4 A 30 VDC - gold plated brass contacts (code 0) : 0.4 VA 20 V AC or DC • Initial contact resistance : 10 mΩ max. • Insulation resistance : 10,000 MΩ min. • Dielectric strength : 1,000 Vrms 50 Hz min. between terminals 4,000 Vrms 50 Hz min. between terminals and metal panel • Electrical life : 50,000 cycles GENERAL SPECIFICATIONS • Panel thickness : 1 (.039) to 3 mm (.118) max. • Operating temperature : -40 °C to +85 °C (-40 °F to +185 °F) MATERIALS • Case : PES • Actuator : polyamide • Contacts 0 : brass, gold plated 1 : silver 2 : silver, gold plated 5 : special contact, lower rating Minimum quantity : consult factory. • Terminal seal : epoxy APEM products may be recycled at end-of-life for the re-claiming of valuable metal components. The company reserves the right to change specifications without notice. 1 Snap-in rocker switches PANEL CUT-OUT AGENCY APPROVALS 2 A 250 VAC 4 A 125 VAC Availability : consult factory for details or approved models. Marking : to order switches marked with above approvals, complete last box of ordering format. ELECTRICAL FUNCTIONS 1 2 3 1.10 (.043) Straight PC 2 1.90 (.074) 3.70 (.145) 4.10 (.161) TERMINALS 5.40 (.212) PANEL SWITCHES AS series 1.80 (.070) 1.10 (.043) Solder lug Snap-in rocker switches BUILD YOUR PART NUMBER BASIC PART NUMBER AS NUMBER OF POLES SERIES 3 ELECTRICAL FUNCTIONS Single pole TERMINALS 6 ON - ON S0 Solder lug 9 ON OFF ON P0 Straight PC 7 MOM OFF MOM 8 ON OFF MOM 2 ON - MOM OPTIONS CONTACT MATERIALS ACTUATORS OTHER OPTIONS 0 Brass, gold plated 00 Black 10 With UL marking 1 Silver 01 Red 20 2 Silver, gold plated 02 Grey 10 mm long straight PC terminals 5 Special contact, lower rating. On request. 03 Blue 04 Ivory 07 White 09 Dark blue Actuator marking on request. ABOUT THIS SERIES On the following pages, you will find successively basic part numbers of switches and options in the same order as in above chart. Notice : please note that not all combinations of above numbers are available. Refer to the following pages for further information. 3 PANEL SWITCHES AS series Snap-in rocker switches SOLDER LUG TERMINALS III II I AS36S0 ON - ON AS39S0 ON OFF ON AS37S0 MOM OFF MOM AS38S0 ON OFF MOM AS32S0 ON - MOM STRAIGHT PC TERMINALS 19.60 (.771) 10.30 (.405) - ON ON OFF ON AS37P0 MOM OFF MOM AS38P0 ON OFF MOM AS32P0 ON - MOM BASIC P/N 0 Brass, gold plated 1 Silver 2 Silver, gold plated 5 Special contact, lower rating. Minimum quantity. Consult factory ACTUATORS 00 01 02 03 04 07 09 Black Red Grey Blue Ivory White Dark blue For marking on actuator, consult factory. 4 II 22˚ I 8.50 (.334) 6.80 (.267) 13.20 (.519) Ø1.60 (.062DIA) EPOXY CONTACT MATERIALS BASIC P/N III 4.70 (.185) ON AS39P0 6.60 (.259) 3.20 (.125) AS36P0 13.70 (.539) 1.20 (.047) I 7.30 (.287) II 8.00 (.314) III 5.40 (.212) PANEL SWITCHES AS series 1.10 (.043) 0.80 (.031) 0.50 (.019) 4.70 (.185) Snap-in rocker switches OTHER OPTIONS BASIC P/N With UL marking 10 mm (.393) long straight PC terminals 8.70 (.342) 10.00 (.212) 10 20 1.10 (.043) 20 5 PANEL SWITCHES AS series Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: AS37S010010 AS36S010010 AS36P0000 AS39P0000 AS39S010010 AS32S0100 AS36P010010 AS36S0111 AS37S0000 AS32S010010 AS36S0100 AS37P0000 AS38P0000 AS38S010010
AS37S0000 价格&库存
很抱歉,暂时无法提供与“AS37S0000”相匹配的价格&库存,您可以联系我们找货
