7737NCDB+U612
7737NCDB+U612
    APEM(埃斐)
    船型开关 SPDT 400mA 20V 20V
7737NCDB+U612 数据手册
7000 series Rocker and paddle switches Distinctive features ❑ Wide variety of actuators Rockers and paddles in different sizes Available in10 different colours Two bezel types ❑ 4 terminal types Solder lugs Quick-connect terminals Straight or right angle PC terminals ❑ Many mounting styles for panel or PCB Snap-in By plate and screw PCB mounting with or without bracket D ❑ 4 contact materials Silver and gold plated silver Gold plated and silver plated brass ❑ 8 electrical functions, maintained or momentary ❑ UL and CSA approved - for VDE refer to 57000 The company reserves the right to change specifications without notice. D-24 www.apem.com APEM 7000 series Rocker and paddle switches Specifications ELECTRICAL SPECIFICATIONS • Current/voltage rating with resistive load : Contact Maximum Minimum Level * Silver A 4A 30VDC 50mA 10VDC III and IV Silver, gold plated AD 4A 30VDC Gold plating withstands up to 100mA 30VDC. 10mA 50mV 10µA 5V I to IV Brass, gold plated CD 0,4 VA at 20VAC or DC 10mA 50mV 10µA 5V I and II • For inductive, lamp or capacitive loads, consult factory. • Initial contact resistance : 10 mΩ • Insulation resistance : 1.000 MΩ min. at 500VDC • Dielectric strength : 1.000 Vrms 50 Hz min. between terminals 1.500 Vrms 50 Hz min. between poles 1.500 Vrms 50 Hz min. between terminals and frame • Contact bounce : 2 ms max. • Electrical life : 50.000 cycles at full load MATERIALS • Case : diallylphthalate (DAP) or high temperature plastic material (UL94-V0) • Actuator : polyamide • Housing : stainless steel or steel tin plated • Bracket : steel, tin plated • Contacts A : silver AD : silver, gold plated CD : brass, gold plated • Terminal seal : epoxy * For details, see technical information, end of catalogue. GENERAL SPECIFICATIONS D • Low level or mechanical life : 100.000 cycles • Panel thickness : 1 (.039) to 2,5 mm(.098) • Operating temperature : -40°C to +85°C AGENCY APPROVALS 3A 250VAC 6A 125VAC For VDE, refer to 57000 series. Availability : consult factory for details of approved models. Marking : to order switches marked UL or CSA, complete appropriate box of ordering format. APEM www.apem.com D-25 7000 series Rocker and paddle switches Overview 7 Number of poles SERIES 3 4 Terminals Single pole Double pole Blank W Consult factory for three and four pole models. WW Y Y4 Y6 Y7 Z } } } } Solder lugs or straight PC depending on model Right angle, horizontal mounting (7900 switches) Right angle, vertical mounting (7000 switches) Bracket mounting (7000 switches) Quick-connect (7200 switches) Mounting plate Mounting with small plate N D Terminals-mounting 0 2 4 6 7 9 Right angle terminals or straight PC terminals with bracket Straight PC or quick-connect terminals, 4,7 (.185) terminal spacing, snap-in mounting Straight PC terminals, 4 (.157) terminal spacing, snap-in mounting Solder lug terminals, snap-in mounting Solder lug terminals, panel mounting Straight PC or quick-connect terminals, 4,7 (.185) terminal spacing, panel mounting Right angle terminals Electrical functions 6 9 7 8 2 ON ON MOM ON ON OFF OFF OFF - ON ON MOM MOM MOM 4 ON ON ON ON ON MOM ∆ MOM ON MOM ∆ Connections for function 4 Momentary for function 4 TH (standard) CT (reversed) 1R ON ON MOM 2R MOM ON MOM . For functions 4, 41R, 42R . Leave blank for all other functions. Leave blank for other functions. Function 4 . Must not have blank in "connections" box. . ∆ Must not have blank in "momentary" box. ABOUT THIS SERIES On the following pages, you will find successively : - model structure of switches - options in the same order as in above chart Dimensions : first dimensions are in mm while inches are shown as bracketed numbers. NOTICE : please note that not all combinations of above numbers are available. Refer to the following pages for further information. D-26 www.apem.com APEM 7000 series Rocker and paddle switches Overview Special options Contact materials A AD CD Actuators Blank No special requirement X653 Vertical right angle with stand-off plate Silver Silver, gold plated Brass, gold plated Other, see following pages. Rockers U530 U620 U730 U830 U1010 Large Medium Small Medium Large Paddles U490 U610 U700 Large Narrow Broad D Sealing Blank No sealing B Epoxy sealed terminals Approvals UL CSA Availability : Consult factory for details of approved models. For VDE, refer to 57000. Bezels - Mounting accessories Bezels for rocker U730 or paddle U700 U1200 U1210 For LED Accessories for panel mounting models U543 U1022 Spacer + nut + screw Spacer + nut + screw + washer Packaging unit : 25 pieces. APEM www.apem.com D-27 7000 series Rocker and paddle switches Snap-in mounting : 7600 - 7200 - 7400 • Solder lug or straight PC terminals 1.80 (.070) 1.10 (.043) 9.80 (0.385) 1.10 (.043) 4.00 (.157) 3 5.30 (.208) 2 3.70 (.145) 1 1.90 (.074) • Epoxy sealing standard on models with straight PC terminals MODEL STRUCTURE Shown with rocker U730 and bezel U1200 Solder lug terminals : 7600 2.00 (.078) 2.50 Maxi (.098 MAX) 4.70 (.185) 2.00 (.078) 1 1.10 (.043) 2 3 0.80 (.031) 0.50 (.019) 12.00 (.472) 4.75 (.187) Epoxy 4.70 (.185) 4.70 (.185) 7.00 (.275) 2.50 Maxi (.098 MAX) ON ON MOM MOM MOM ON MOM MOM 11.30 (.444) II I 24° Ø1.60 (.063 DIA) I 1-2 4-5 III 19.50 C72DT-A (.767) I 1-2 4-5 II 24° 11.30 (.444) I Double pole 7.00 7446 B ON ON (.275) 7449 B ON OFF ON 1 2 3 1.10 7447 B MOM OFF MOM (.043) 0.50 (.019) 7448 B ON OFF MOM 7442 B ON - MOM 7444 B* ON ON ON 7444 1R B* ON ON MOM 7444 2R B* MOM ON MOM * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. 17.85 (.702) Single pole 7436 B 7439 B 7437 B 7438 B 7432 B III 4.00 (.157) Ø1.60 (.063 DIA) 4.00 (.157) 0.80 (.031) 4.00 (.157) 12.00 (.472) Epoxy 4.75 (.187) 4.00 (.157) 15.70 (.618) 2.00 (.078) II 4.75 (.187) 19.50 (.767) Straight PC terminals - spacing 4 (.157) : 7400 III 2-3 5-6 12.00 (.472) 0.80 (.031) 2.50 Maxi (.098 MAX) OFF OFF OFF ON ON ON 3 Ø1.60 (.063 DIA) ON ON MOM ON ON ON ON MOM 2 0.50 (.019) 15.70 (.618) 4.00 (.157) Double pole 7246 B 7249 B 7247 B 7248 B 7242 B 7244 B* 7244 1R B* 7244 2R B* 1 1.80 (.070) Ø1.60 (.063 DIA) Single pole 7236 B 7239 B 7237 B 7238 B 7232 B II 5.20 (.204) 7.00 (.275) Straight PC terminals - spacing 4,7 (.185) : 7200 III 2-3 5-6 11.30 (.444) I 16.50 (.649) ON ON MOM MOM MOM ON MOM MOM 3.70 (.145) OFF OFF OFF ON ON ON II 24˚ III 5.20 (.204) ON ON MOM ON ON ON ON MOM 19.50 (.767) 15.70 (.618) 17.85 (.702) D Double pole 7646 7649 7647 7648 7642 7644* 7644 1R* 7644 2R* I 1-2 4-5 5.20 (.204) Single pole 7636 7639 7637 7638 7632 II 4.70 (.185) III 2-3 5-6 C74DT-A D-28 www.apem.com APEM 7000 series Rocker and paddle switches Snap-in mounting : 7200Z 2 3 5.30 (.208) 1 6.50 (.255) • Quick-connect terminals 1.57 (.061) MODEL STRUCTURE Shown with rocker U730 and bezel U1200 Quick-connect terminals : 7200Z ON ON MOM ON ON ON ON MOM OFF OFF OFF ON ON ON ON ON MOM MOM MOM ON MOM MOM 7.00 (.275) 1.57 (.061) 19.50 (.767) III II 24˚ 11.30 (.444) I 2.00 (.078) 5.20 (.204) 15.70 (.618) 1 2 3 2.50 Maxi (.098 MAX) Double pole 7246Z 7249Z 7247Z 7248Z 7242Z 7244Z* 7244Z 1R* 7244Z 2R* I 1-2 4-5 17.65 (.694) Single pole 7236Z 7239Z 7237Z 7238Z 7232Z II 5.30 (.208) III 2-3 5-6 0.78 (.030) 4.70 (.185) Epoxy 12.00 (.472) 4.75 (.187) * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. PANEL CUT-OUT 7600 - 7200 - 7400 - 7200Z 15.00 (.590) Ø8.00 (.314 DIA) 12.50 (.492) 12.50 (.492) 15.00 (.590) 13.20 (.519) With or without bezel U1200 APEM With bezel U1210 www.apem.com D-29 D 7000 series Rocker and paddle switches Panel mounting : 7700 - 7900 1.10 (.043) 3 1.80 (.070) 1.10 (.043) 9.80 (0.385) 2 4.00 (.157) 1 3.70 (.145) • Epoxy sealing standard on models with straight PC terminals 5.30 (.208) 1.90 (.074) • Large rocker or paddle • Solder lug or straight PC terminals • Quick-connect terminals : on request MODEL STRUCTURE Shown with rocker U530 7.00 (.275) 1.80 (.070) 10.70 (.421) 13.20 (.500) 0.80 (.031) 1 4.70 (.185) Ø1.60 (.063 DIA) III II 4.75 (.187) 24° 7.00 (.275) EPOXY 1.10 (.043) 10.70 (.421) ON ON MOM MOM MOM ON MOM MOM I 26.6 (1.0470 ) 13.20 (.519) 1 2 3 0.80 (.031) 4.70 (.185) 12.00 (.472) 12.30 (.484) OFF OFF OFF ON ON ON 4.75 (.187) 35.00 (1.377) 15.00 (.590) ON ON MOM ON ON ON ON MOM 0.50 (.019) 15.10 (.594) Double pole 7946 B 7949 B 7947 B 7948 B 7942 B 7944 B* 7944 1R B* 7944 2R B* I 1-2 4-5 0.40 (.015) Single pole 7936 B 7939 B 7937 B 7938 B 7932 B II 3 4.70 (.185) Straight PC terminals : 7900 III 2-3 5-6 2 12.00 (.472) Ø1.60 (.063 DIA) ON ON MOM MOM MOM ON MOM MOM 15.00 (.590) 24˚ 11.00 (.433) OFF OFF OFF ON ON ON I 3.70 (.145) ON ON MOM ON ON ON ON MOM 26.60 (1.047 ) 0.50 (.019) 1.10 (.043) 4.00 (.157) D Double pole 7746 7749 7747 7748 7742 7744* 7744 1R* 7744 2R* II III I 1-2 4-5 15.10 (.594) Single pole 7736 7739 7737 7738 7732 II 0.40 (.015) III 2-3 5-6 4.70 (.185) 35.00 (1.377) Solder lug terminals : 7700 4.75 (.187) * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. C79DT-A PANEL CUT-OUT 7700 - 7900 Page 27.50 (1.082) ECHE indice le 06/0 15.50 (.610) Ø2.70 (.106 DIA) FICHIE 35.00 (1.377) D-30 www.apem.com APEM 7000 series Rocker and paddle switches Panel mounting : 7700N - 7900N 1.10 (.043) 3 1.80 (.070) 1.10 (.043) 9.80 (0.385) 2 4.00 (.157) 1 3.70 (.145) • Epoxy sealing standard on models with straight PC terminals 5.30 (.208) 1.90 (.074) • Small or medium rocker or paddle • Solder lug or straight PC terminals • Quick-connect terminals : on request MODEL STRUCTURE Shown with rocker U620 23.80 (.937) ON ON MOM MOM MOM ON MOM MOM III 7.00 (.275) 1.80 (.070) 13.20 (.519) 0.80 (.031) 1 2 3 0.50 (.019) 4.70 (.185) Straight PC terminals : 7900N Ø1.60 (.063 DIA) 4.70 (.185) EPOXY 1.10 (.043) 12.45 (.490) 13.20 (.519) 0.80 (.031) 1 2 12.00 (.472) 3 0.50 (.019) 4.70 (.185) * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. 4.75 (.187) 4.75 (.187) III II I 24° 7.00 (.275) 12.00 (.472) 11.20 (.440) ON ON MOM MOM MOM ON MOM MOM 9.30 (.366) 4.00 (.157) OFF OFF OFF ON ON ON 16.80 ) (.661 9.50 (.374) ON ON MOM ON ON ON ON MOM I 1-2 4-5 0.60 (.023) Double pole 7946N B 7949N B 7947N B 7948N B 7942N B 7944N B* 7944N 1R B* 7944N 2R B* II Ø1.60 (.063 DIA) 23.80 (.937) III 2-3 5-6 Single pole 7936N B 7939N B 7937N B 7938N B 7932N B II I 24˚ 12.45 (.490) OFF OFF OFF ON ON ON 9.30 (.366) 9.85 (.387) ON ON MOM ON ON ON ON MOM 16.80) (.661 3.70 (.145) Double pole 7746N 7749N 7747N 7748N 7742N 7744N* 7744N 1R* 7744N 2R* I 1-2 4-5 9.50 (.374) Single pole 7736N 7739N 7737N 7738N 7732N II 0.60 (.023) III 2-3 5-6 4.70 (.185) Solder lug terminals : 7700N 4.75 (.187) 1.10 (.043) C79NDT-A PANEL CUT-OUT 17.00 (.669) Ø2.30 (.090 DIA) 23.80 (.937) With small rocker U730 or small paddle U700 APEM Ø2.30 (.090 DIA) 10.00 (.393) 12.00 (.472) 11.70 (.460) 7700N - 7900N 23.80 (.937) With medium rocker U620 or medium paddle U610 www.apem.com D-31 D 7000 series Rocker and paddle switches Right angle terminals - horizontal : 7900W 1 2 3 MODEL STRUCTURE Shown with rocker U620 12.70 (.500) 4.70 (.185) 8.30 (.326) 13.20 (.519) 3.81 12.70 (.150) (.500) 2 24° 3 3.70 (.145) 0.40 (.015) ø1.60 (.062 DIA) 4.70 (.185) 12.00 (.472) 1.00 (.039) 1 6 3 6.00 (.236) ON ON MOM MOM MOM ON MOM MOM 5.00 (.196) 4.40 (.173) 4 1 16.80 (.661) OFF OFF OFF ON ON ON 5.00 (.196) ON ON MOM ON ON ON ON MOM I 1-2 4-5 12.70 (.500) I 7946W 7949W 7947W 7948W** 7942W** 7944W* 7944W 1R* 7944W 2R* II 7.60 (.299) 1.10 (.043) III III 2-3 5-6 9.30 (.366) 4.70 (.185) 3.20 (.125) 0.40 (.015) Ø1.60 (.062 DIA) 5.00 (.196) 15.30 (.602) II Double pole 0.80 (.031) 13.20 (.519) 3 5.00 (.196) 24˚ 2.50 (.098) D ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM 4.40 (.173) 0.80 (.031) 7936W 7939W 7937W 7938W** 7932W** 5.00 (.196) 16.80 (.661) 1.00 (.039) 1 I I 1-2 II II III III 2-3 7.60 (.299) 4.70 (.185) 9.30 (.366) Single pole 1.10 (.043) 12.70 (.500) 3.81 (.150) * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. ** Functions 2 and 8 : standard connection (CT) shown on drawing - reversed connection available. Consult factory. PANEL CUT-OUT With small rocker U730 or small paddle U700 D-32 With medium rocker U620 or medium paddle U610 www.apem.com 27.30 (1.074) 11.80 (.464) 10.00 (.393) 17.00 (.669) 11.70 (.460) 12.00 (.472) With large rocker U1010 APEM 7000 series Rocker and paddle switches Right angle terminals - vertical : 7000WW 1 2 3 MODEL STRUCTURE Shown with rocker U830 Single pole 3.00 (.118) 9.30 (.366) 0.40 (.015) 5.08 (.200) 1 2 3 3.81 (.150) 13.46 (.529) D 7.00 (.275) 11.00 (.433) 6 2 5 1 4 13.20 (.519) I 4.75 (.187) 0.80 (.301) II 24° III 1.00 (.039) 0.40 (.015) 5.08 (.200) 1 13.46 (.529) 2 3 3.81 (.150) 5.08 (.200) 4.75 (.187) 3 3.81 (.150) ø1.60 (.062 DIA) 7.60 (.299) 1.10 (.043) ON ON MOM MOM MOM ON MOM MOM 9.30 (.366) 13.46 (.529) 3.00 (.118) I 1-2 4-5 OFF OFF OFF ON ON ON 3.81 (.150) 1 1.00 (.039) 12.00 (.472) ON ON MOM ON ON ON ON MOM 13.46 (.529) III 16.80 (.661) 7046WW 7049WW 7047WW 7048WW** 7042WW** 7044WW* 7044WW 1R* 7044WW 2R* II 13.20 (.519) 16.80 (.661) 0.80 (.301) II 24° Double pole III 2-3 5-6 5.08 (.200) I 2 ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM ø1.60 (.062 DIA) 7.60 (.299) 3 7036WW 7039WW 7037WW 7038WW** 7032WW** 11.00 (.433) 3.00 (.118) I 1-2 1.10 (.043) II 3.00 (.118) III 2-3 * Function 4 :SP in DP case - specify CT or TH connections, see end of catalogue. ** Functions 2 and 8 : standard connection (CT) shown on drawing - reversed connection available. Consult factory. PANEL CUT-OUT With small rocker U730 APEM 12.00 (.472) 11.70 (.460) 10.00 (.393) 17.00 (.669) 11.70 (.460) 12.00 (.472) With medium rocker U830 www.apem.com With broad paddle U700 D-33 7000 series Rocker and paddle switches Straight PC terminals - bracket mounting : 7000Y 1 2 3 8.50 (.334) 1.10 (.043) 9.80 (.385) • Epoxy sealed terminals standard (B included in model structure) 4.00 (.157) 5.30 (.208) Brackets reduce mechanical stress on solder joints and increase the resistance to vibrations. 1.10 (.043) Y - Y6 Y4 - Y7 MODEL STRUCTURE Shown with rocker U620 7.00 (.275) I 9.30 (.366) 3.18 (.125) 8.20 (.322) 3.18 (.125) 1 2 3 15.75 (.620) 4.70 (.185) 0.40 (.015) EPOXY 4.70 (.185) 12.00 (.472) 4.75 (.187) 4.75 (.187) 15.75 (.620) EPOXY 4.70 (.185) Ø1.60 (.062 DIA) Ø1.60 (.062 DIA) 15.75 (.620) 6.00 (.236) ON ON MOM MOM MOM ON MOM MOM II 24˚ 3.18 (.125) 15.60 (.614) OFF OFF OFF ON ON ON 13.00 (.511) ON ON MOM ON ON ON ON MOM 3 2 15.75 (.620) III I 1-2 4-5 4.70 (.185) 7046Y B 7049Y B 7047Y B 7048Y B 7042Y B 7044Y* B 7044Y 1R* B 7044Y 2R* B II 1 3.18 (.125) Short bracket - width 15,75 (.620) - double pole : 7040Y 9.30 (.366) 8.95 (.352) 6.00 (.236) 0.40 (.015) 6.60 (.259) III 2-3 5-6 I 15.60 (.614) ON ON ON OFF ON MOM OFF MOM ON OFF MOM ON - MOM II 24˚ 8.95 (.352) D III I 1-2 4-5 13.00 (.511) 7036Y B 7039Y B 7037Y B 7038Y B 7032Y B II 4.10 (.161) III 2-3 5-6 4.70 (.185) Short bracket - width 15,75 (.620) - single pole : 7030Y * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. D-34 www.apem.com APEM 7000 series Rocker and paddle switches Straight PC terminals - bracket mounting : 7000Y4 - Y6 - Y7 8.20 (.322) 3.18 (.125) 1 3.18 (.125) 3.18 (.125) EPOXY 3 2 4.70 (.185) 15.75 (.620) 12.00 (.472) 4.75 (.187) 6.35 (.250) III II I 8.95 (.352) 6.00 (.236) ON ON MOM MOM MOM ON MOM MOM Ø1.60 (.062 DIA) 6.35 (.250) EPOXY 1 0.40 (.015) 6.35 (.250) 3 2 4.70 (.185) 8.20 (.322) 6.35 (.250) 12.00 (.472) 19.05 (.750) 4.70 (.185) OFF OFF OFF ON ON ON 15.60 (.614) ON ON MOM ON ON ON ON MOM 4.70 (.185) 9.30 (.366) 24° 13.00 (.511) Double pole 7046Y6 B 7049Y6 B 7047Y6 B 7048Y6 B 7042Y6 B 7044Y6* B 7044Y6 1R* B 7044Y6 2R* B I 1-2 4-5 4.70 (.185) Single pole 7036Y6 B 7039Y6 B 7037Y6 B 7038Y6 B 7032Y6 B II Ø1.60 (.062 DIA) 4.75 (.187) Short bracket - width 19,05 (.750) : 7000Y6 III 2-3 5-6 15.75 (.620) 4.70 (.185) 8.95 (.352) 6.00 (.236) 0.40 (.015) 9.30 (.366) 15.75 (.620) ON ON MOM MOM MOM ON MOM MOM I 19.05 (.750) OFF OFF OFF ON ON ON II 24˚ 19.05 (.750) ON ON MOM ON ON ON ON MOM 19.60 (.771) Double pole 7046Y4 B 7049Y4 B 7047Y4 B 7048Y4 B 7042Y4 B 7044Y4* B 7044Y4 1R* B 7044Y4 2R* B III I 1-2 4-5 17.00 (.669) Single pole 7036Y4 B 7039Y4 B 7037Y4 B 7038Y4 B 7032Y4 B II 4.20 (.165) III 2-3 5-6 4.70 (.185) Tall bracket - width 15,75 (.620) : 7000Y4 D 4.75 (.187) C70Y6DT OFF OFF OFF ON ON ON ON ON MOM MOM MOM ON MOM MOM 8.20 (.322) 0.40 (.015) 1 2 3 19.05 (.750) 4.70 (.185) 8.95 (.352) 6.00 (.236) 6.35 (.250) 6.35 (.250) 9.30 (.366) Ø1.60 (.062 DIA) 6.35 (.250) FICHIER: C70Y EPOXY 4.70 (.185) 19.05 (.750) I 12.00 (.472) 4.75 (.187) ECHELLE: 0.7 le 07-01-2010 4.75 (.187) 19.05 (.750) ON ON MOM ON ON ON ON MOM II 24˚ 19.60 (.771) Double pole 7046Y7 B 7049Y7 B 7047Y7 B 7048Y7 B 7042Y7 B 7044Y7* B 7044Y7 1R* B 7044Y7 2R* B III I 1-2 4-5 17.00 (.669) Single pole 7036Y7 B 7039Y7 B 7037Y7 B 7038Y7 B 7032Y7 B II 4.20 (.165) III 2-3 5-6 4.70 (.185) Tall bracket - width 19,05 (.750) : 7000Y7 * Function 4 :SP in DP case - specify CT or TH connections, see end of catalogue. PANEL CUT-OUT 7000Y - Y4 - Y6 - Y7 With small rocker U730 or small paddle U700 APEM 27.30 (1.074) 11.80 (.464) 10.00 (.393) 17.00 (.669) 11.70 (.460) 12.00 (.472) With medium rocker U620 or medium paddle U610 www.apem.com With large rocker U1010 D-35 7000 series Rocker and paddle switches CONTACT MATERIALS A AD CD Silver Silver, gold plated Brass, gold plated SEALING No sealing B Epoxy sealed terminals SPECIAL OPTIONS Blank No special requirement X653 Vertical right angle with stand-off plate Shown with rocker U620 3.00 (.118) 11.00 (.433) 5.08 (.200) 12.00 (.472) 5.08 (.200) 12.70 (.500) 3.81 (.150) Ø1.60 (.062 DIA) 0.50 (.019) 3.81 (.150) 1.27 (.050) Double pole 7046WW X653 ON ON 7049WW X653 ON OFF ON 1 2 3 0.80 7047WW X653 MOM OFF MOM (.031) 7048WW X653** ON OFF MOM 4.75 1.10 7042WW X653** ON - MOM (.187) (.043) 9.20 (.362) 7044WW X653* ON ON ON 6.60 (.259) 7044 1RWW X653* ON ON MOM 3.30 15.80 (.129) (.622) 7044 2RWW X653* MOM ON MOM * Function 4 : SP in DP case - specify CT or TH connections, see end of catalogue. ** Functions 2 and 8 : reversed connection available. Consult factory. 12.70 (.500) 5.08 (.200) 24˚ 12.70 (.500) Single pole 7036WW X653 7039WW X653 7037WW X653 7038WW X653 7032WW X653 9.30 (.366) 5.93 7.60 (.233) (.299) I 1-2 4-5 III II II III 2-3 5-6 3.81 (.150) 16.80 (.661) I D Blank Actuators for X653 : small rocker U730 and medium rocker U620, broad paddle U700 and narrow paddle U610. X601 D-36 Silver plated brass contacts Current voltage rating for an electrical life of 20.000 cycles : 0,5A 30VDC Minimum quantity : 5.000 pieces per model and shipment. www.apem.com APEM 7000 series Rocker and paddle switches AGENCY APPROVALS UL CSA All standard models Availability : consult factory for details of approved combinations or options. Marking : to order switches marked UL or CSA, complete above box with desired approvals in this order, without space (ex. ULCSA). Blank : no agency approval required. VDE (with UL & CSA) Refer to 57000 series on the following pages. ACTUATORS + U... For snap-in mounting models : 7600 - 7200 - 7400 - 7200Z 11.70 (.460) U730 16.50 (.649) 11.20 (.440) 18.40 (.724) 9.00 (.354) 7.10 (.279) 9.05 (.356) 7.90 (.311) 11.30 (.444) 2.50 (.098) 5.37 (.211) Actuator colours 5 R:5.7 R.) (.226 1 1/4 2 3 4 5 6 7 7/1 9 U700 Small rocker Broad paddle For 7700 and 7900 models 15.00 (.590) 22.55 (.887) 10.00 (.393) 12.10 (.476) 23.00 (.905) 5.00 (.196) 29.80 (1.173) 31.80 (1.251) 15.00 (.590) 9.30 ) (.366 2.50 (.098) 14.00 (.551) D Replace last "0" by number 26.60 (1.047) blue dark blue black green grey yellow red ivory white orange U530 U490 Large paddle Large rocker For 7700N - 7900N - 7900W - 7000WWX653 and 7000Y models U620 Medium rocker Small rocker APEM 11.70 (.460) 11.30 (.444) 11.40 (.448) 7.10 (.279) 9.00 (.354) U730 9.05 (.356) 7.90 (.311) 11.30 (.444) U1010 16.50 (.649) 16.80 (.661) 5.37 (.211) 2.50 (.098) 5 R:5.7 R.) (.226 U700 Broad paddle 22.60 (.889) 9.50 (.374) U610 Narrow paddle 11.20 (.440) 18.40 (.724) 7.60 (.299) .43 R:8 1 R.) 3 (.3 13.50 (.531) 9.30 (.366) 9.50 (.374) 20.70 (.814) 3.96 (.155) 2.13 (.083) 7.87 ) (.309 18.80 (.740) 9.50 (.374) 26.80 (1.055) Large rocker For 7900W, available on DP only. www.apem.com D-37 7000 series Rocker and paddle switches ACTUATORS (continued) For 7000WW models 5 R:5.7 R.) (.226 9.05 (.356) 7.10 (.279) 5.37 (.211) 11.30 (.444) 9.00 (.354) 18.40 (.724) 2.50 (.098) 11.70 (.460) U700 U730 Broad paddle Small rocker 7.60 (.299) 6.95 ) (.273 U830 Actuator colours Replace last "0" by number 1 1/4 2 3 4 5 6 7 7/1 9 13.50 (.531) 9.30 (.366) 9.50 (.374) 7.90 (.311) 16.50 (.649) 11.20 (.440) 16.80 (.661) blue dark blue black green grey yellow red ivory white orange Medium rocker BEZELS - MOUNTING ACCESSORIES + U... Bezels for paddle U700 and rocker U730 Bezel colours 12.10 (.476) 13.20 (.519) 12.10 (.476) 12.10 (.476) Ø5.00 (.196 DIA) 28.00 (1.102) U1210 U1200 Replace last "0" by number 5.00 (.196) 2.00 (.078) Ø7.10 (.279 DIA) 15.70 (.618) 2.00 (.078) 12.10 (.476) 15.70 (.618) 19.50 (.767) For LED Ø 5 (.196) - not supplied 1 1/4 2 3 4 5 6 7 7/1 9 blue dark blue black green grey yellow red ivory white orange STANDARD PANEL MOUNTING U730 + U1200 12.60 (.496) 14.60 (.574) 3.20 (.125) 5.20 (.204) Panel thickness with bezel 1 to 2,5 mm (.039 to .098) U700 + U1210 6.00 (.236) M2.5x0.45 (.098 DIA x0.45 IS) M2x0.40 SI (.078 DIA x0.4 IS) 6.00 (.236) 12.00 (.472) Mounting accessories 10.80 (.425) D U543 - Spacers, screws and nuts U1022 - Spacers, screws, nut and washers For rocker U530 or paddle U490 For rockers U620 or U730 For paddles U610 or U700 D-38 www.apem.com APEM Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: 7036WWAB+U832 7036WWCDBX653+U622 7036YAB+U622 7637AB+U732+U1202 7646AB+U732+U1202 7736NAB+U622 7737AB+U532 7737NAB+U622 7746NAB+U622 7936WAB+U622 7036Y6AB+U622 7037Y4CDB+U622 7046Y6AB+U622 7047YABX766+U532 7247ZCD+U702+U1202 7636A+U702+U1202 7636A+U732+U1202 7637AB+U732+U1212 7646A+U702+U1202 7646A+U732+U1202 7646CDB+U732+U1202 7737NCDB+U612 7739AB+U532 7749AB+U532 7646CDBU732U1202
7737NCDB+U612 价格&库存
很抱歉,暂时无法提供与“7737NCDB+U612”相匹配的价格&库存,您可以联系我们找货
