VX1KXWXX-C8100-000-XBLU1
    CARLING
    Rocker Switch SP3T 0.4VA (AC/DC) 28V Panel Mount, Snap-In
VX1KXWXX-C8100-000-XBLU1 数据手册
DWG NO. LOCK MOTION POS 1 POS 2 VX1KXWXX-C8100-000-XBLU1 LET REV. DO NOT SCALE DRAWING WORK TO FIGURE REVISIONS DATE .830 21.0 POS 3 RATING 1.933 49.09 0.4 VA MAX. @ 28V MAX (RESISTIVE) 1.450 36.83 .505 12.83 SWITCH FUNCTION POS 1 POS 2 ON ON MOUNTING HOLE PANEL THICKNESS (SNAP - IN BRACKET) .030 MIN ---- .187 MAX .76 4.75 .080 2.0 1.370 34.80 .820 20.8 .340 8.64 .960 24.3 1.126 28.60 ±.003 -8 1 ±.001 3 2 TO 3 5 TO 6 +4 6 .250 X .031 6.35 .78 2 LAMP 2 9 6 5 4 7 .317 8.05 5 (ON) 2 TO 1 5 TO 4 NOTES: 1. BRACKET IS BLACK NYLON 2. ROCKER IS BLACK NYLON WITH WHITE POLYCARBONATE LENS 3. LOCK COLOR IS BLACK 4. 12V BLUE LED T4+ TO T85. SPECIAL BRACKET DESIGNED TO PREVENT ACTUATION FROM POS 2 TO POS 1 ONLY YOU MUST ACTUATE THE LOCK AND PRESS DOWN ROCKER TO ACTUATE THE SWITCH FROM POS 2 TO POS 1 THE LOCK DOES NOT HAVE TO BE USED TO ACTUATE THE SWITCH FROM POS 2 TO POS 3 10 3 2 1 8 CIRCUIT 2 TO 3 5 TO 4 POS 3 FINISH CARLINGSWITCH, INC. DIMENSIONS SUBJECT TO CHANGE WITHOUT NOTICE PROPRIETARY NOTE: NOTICE TO ALL PERSONS RECEIVING THIS DRAWING. THIS DOCUMENT IS THE PROPERTY OF CARLINGSWITCH, INC. AND IS NOT TO BE DISCLOSED, REPRODUCED IN WHOLE OR IN PART OR USED FOR MANUFACTURING PURPOSES BY ANYONE WITHOUT THE CONSENT OF CARLINGSWITCH, INC. PLAINVILLE, CT TOOL NO. REV DR BY DATE UNSPECIFIED TOLERANCES KRAMARZ X.XXX ±.015 PROJECTIONS DIMENSIONS IN [mm] 8-8-12 CHK BY DATE APPD BY DATE TITLE "V" SERIES SWITCH SIZE DWG NO. B VX1KXWXX-C8100-000-XBLU1 USED ON REV. SCALE: FULL SHT 1 OF 1
VX1KXWXX-C8100-000-XBLU1 价格&库存
很抱歉,暂时无法提供与“VX1KXWXX-C8100-000-XBLU1”相匹配的价格&库存,您可以联系我们找货
