ST21L5S5ZBJ3J9022
ST21L5S5ZBJ3J9022
    APEM(埃斐)
    船型开关 DPDT 400mA 20V 20V
ST21L5S5ZBJ3J9022 数据手册
ST SERIES - MINIATURE ROCKER & LEVER SWITCHES FEATURES ● Dry circuit through power ratings . ● Ultra-rugged construction SPDT & DPDT models with numerous options. ● Panel, panel & p.c. and p.c. mounting models, lighted and unlighted. SPECIFICATIONS Contact ratings (resistive loads): Initial contact resistance: Insulation resistance: Dielectric strength: Electrical life (resistive loads): Operating temperature range: (Q) power models - coin silver: 6 Amps at 125 VAC, 3 Amps at 250 VAC or 7 Amps at 30 VDC. (B) dry circuit models - gold over nickel over brass: 0.4 VA max. at 20 V max. UL models - coin silver: 6 Amps at 125 VAC or 3 Amps at 250 VAC (75% power factor). UL file no. E66367. CSA models - coin silver: same ratings as UL models. CSA file no. LR54592-1. 3 milliohms max. at 3 VDC, 0.1 Amp. Greater than 200,000 megohms between terminals & case ground. Greater than 2000 VAC for 1 minute between terminals & case ground. 100,000 cycles min.for ST1-1 & ST2-1. Other models, 40,000 cycles min. -30°C to +85°C MATERIALS Contacts: Actuator: Bushing: Strap: Case: Terminal seal: Support bracket: Spring mounting bracket: Bezel: Hardware: LED: Coin silver for power,UL & CSA models. Gold over nickel over brass for dry circuit models. J1 & J2 - Glass filled polyester. J3 & J4 - Nylon or acetal Nickel plated brass Stainless steel Melamine phenolic, color red Epoxy (optional) Brass or steel, tin plated Stainless steel Nylon. Available in black, red & white. Consult factory for other colors. See 'Miscellaneous' section. Intensity: 2.0 mcd at 10 mA. Forward voltage: 2.0V (3.0V max.). Max. continuous forward current: 15 mA for red, 30 mA for green & 20 mA for yellow. Red is standard. Yellow & green are optional. Specifications are subject to change without notice - consult factory. AGENCY RECOGNITION UL, & CSA. Marking: Switches ordered by UL model number are supplied with recognition marking. Switches ordered by UL model no. and with '/CSA' added at end of model no. are supplied with both recognized marks. ABOUT THIS SERIES The material in this series is organized in the following sequence: a. Completely specified switch models b. Miscellaneous c. 'build your own switch' order format d. Option drawings & information e. Mounting information and panel cut-outs B20 B20-B30 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 20 10/11/00, 5:05 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE B ST SERIES - MINIATURE ROCKER & LEVER SWITCHES DOUBLE POLE WITH J2 LEVER Single pole SINGLE POLE WITH J1 ROCKER Double pole SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Solder lug terminals - panel mounting USA marking on other side POWER CKT. MODEL NO. UL MODEL NO. ST1-1L4S4ZQJ12 ST1-2L4S4ZQJ12 ST1-3L4S4ZQJ12 ST1-4L4S4ZQJ12 ST1-5L4S4ZQJ12 UL11L4S4ZQJ12 UL12L4S4ZQJ12 UL13L4S4ZQJ12 UL14L4S4ZQJ12 UL15L4S4ZQJ12 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L4S4ZQJ12 UL21L4S4ZQJ12 ST2-2L4S4ZQJ12 UL22L4S4ZQJ12 ST2-3L4S4ZQJ12 UL23L4S4ZQJ12 ST2-4L4S4ZQJ12 UL24L4S4ZQJ12 ST2-5L4S4ZQJ12 UL25L4S4ZQJ12 ST2-6L4S4ZQJ12 UL26L4S4ZQJ12 ST2-7L4S4ZQJ12 UL27L4S4ZQJ12 ST2-8L4S4ZQJ12 UL28L4S4ZQJ12 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black actuator. Terminal numbers for reference only SINGLE POLE DOUBLE POLE DOUBLE POLE WITH J2 LEVER Double pole SINGLE POLE WITH J1 ROCKER Single pole Straight p.c. terminals with bracket - p.c. mounting USA marking on other side DRY CKT. MODEL NO. UL MODEL NO. ST1-1L4S4V30BJ12 ST1-2L4S4V30BJ12 ST1-3L4S4V30BJ12 ST1-4L4S4V30BJ12 ST1-5L4S4V30BJ12 UL11L4S4V30QJ12 UL12L4S4V30QJ12 UL13L4S4V30QJ12 UL14L4S4V30QJ12 UL15L4S4V30QJ12 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L4S4V30BJ12 UL21L4S4V30QJ12 ST2-2L4S4V30BJ12 UL22L4S4V30QJ12 ST2-3L4S4V30BJ12 UL23L4S4V30QJ12 ST2-4L4S4V30BJ12 UL24L4S4V30QJ12 ST2-5L4S4V30BJ12 UL25L4S4V30QJ12 ST2-6L4S4V30BJ12 UL26L4S4V30QJ12 ST2-7L4S4V30BJ12 UL27L4S4V30QJ12 ST2-8L4S4V30BJ12 UL28L4S4V30QJ12 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black actuator. Terminal numbers for reference only SINGLE POLE DOUBLE POLE APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com B20-B30 21 10/11/00, 5:05 PM B21 B ST SERIES - MINIATURE ROCKER & LEVER SWITCHES SINGLE POLE WITH J1 ROCKER Double pole Single pole B DOUBLE POLE WITH J2 LEVER USA marking on other side DRY CKT. MODEL NO. UL MODEL NO. ST1-1L4S4A-1BJ12 ST1-2L4S4A-1BJ12 ST1-3L4S4A-1BJ12 ST1-4L4S4A-1BJ12 ST1-5L4S4A-1BJ12 UL11L4S4A-1QJ12 UL12L4S4A-1QJ12 UL13L4S4A-1QJ12 UL14L4S4A-1QJ12 UL15L4S4A-1QJ12 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L4S4A-1BJ12 UL21L4S4A-1QJ12 ST2-2L4S4A-1BJ12 UL22L4S4A-1QJ12 ST2-3L4S4A-1BJ12 UL23L4S4A-1QJ12 ST2-4L4S4A-1BJ12 UL24L4S4A-1QJ12 ST2-5L4S4A-1BJ12 UL25L4S4A-1QJ12 ST2-6L4S4A-1BJ12 UL26L4S4A-1QJ12 ST2-7L4S4A-1BJ12 UL27L4S4A-1QJ12 ST2-8L4S4A-1BJ12 UL28L4S4A-1QJ12 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black actuator. Terminal numbers for reference only SINGLE POLE DOUBLE POLE SINGLE POLE WITH J1 ROCKER DOUBLE POLE WITH J2 LEVER Double pole Single pole Vertical right angle p.c. terminals - p.c. mounting USA marking on other side DRY CKT. MODEL NO. UL MODEL NO. ST1-1L4S4V-1BJ12 ST1-2L4S4V-1BJ12 ST1-3L4S4V-1BJ12 ST1-4L4S4V-1BJ12 ST1-5L4S4V-1BJ12 UL11L4S4V-1QJ12 UL12L4S4V-1QJ12 UL13L4S4V-1QJ12 UL14L4S4V-1QJ12 UL15L4S4V-1QJ12 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L4S4V-1BJ12 UL21L4S4V-1QJ12 ST2-2L4S4V-1BJ12 UL22L4S4V-1QJ12 ST2-3L4S4V-1BJ12 UL23L4S4V-1QJ12 ST2-4L4S4V-1BJ12 UL24L4S4V-1QJ12 ST2-5L4S4V-1BJ12 UL25L4S4V-1QJ12 ST2-6L4S4V-1BJ12 UL26L4S4V-1QJ12 ST2-7L4S4V-1BJ12 UL27L4S4V-1QJ12 ST2-8L4S4V-1BJ12 UL28L4S4V-1QJ12 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black actuator. Terminal numbers for reference only SINGLE POLE B22 B20-B30 DOUBLE POLE APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 22 10/11/00, 5:05 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Horizontal right angle p.c. terminals - p.c. mounting ST SERIES - MINIATURE ROCKER & LEVER SWITCHES DOUBLE POLE WITH J4 LEVER Single pole SINGLE POLE WITH J3 ROCKER Double pole SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Solder lug terminals - snap-in bezel with outboard LED USA marking on other side POWER CKT. MODEL NO. UL MODEL NO. ST1-1L5S5ZQJ3J6122 ST1-2L5S5ZQJ3J6122 ST1-3L5S5ZQJ3J6122 ST1-4L5S5ZQJ3J6122 ST1-5L5S5ZQJ3J6122 UL11L5S5ZQJ3J6122 UL12L5S5ZQJ3J6122 UL13L5S5ZQJ3J6122 UL14L5S5ZQJ3J6122 UL15L5S5ZQJ3J6122 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L5S5ZQJ3J6122 UL21L5S5ZQJ3J6122 ST2-2L5S5ZQJ3J6122 UL22L5S5ZQJ3J6122 ST2-3L5S5ZQJ3J6122 UL23L5S5ZQJ3J6122 ST2-4L5S5ZQJ3J6122 UL24L5S5ZQJ3J6122 ST2-5L5S5ZQJ3J6122 UL25L5S5ZQJ3J6122 ST2-6L5S5ZQJ3J6122 UL26L5S5ZQJ3J6122 ST2-7L5S5ZQJ3J6122 UL27L5S5ZQJ3J6122 ST2-8L5S5ZQJ3J6122 UL28L5S5ZQJ3J6122 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black bezel & actuator. Panel thickness range .047" to .125" Terminal numbers for reference only DOUBLE POLE WITH J4 LEVER Double pole SINGLE POLE WITH J3 ROCKER Single pole Solder lug terminals - snap-in bezel USA marking on other side POWER CKT. MODEL NO. UL MODEL NO. ST1-1L5S5ZQJ4J9022 ST1-2L5S5ZQJ4J9022 ST1-3L5S5ZQJ4J9022 ST1-4L5S5ZQJ4J9022 ST1-5L5S5ZQJ4J9022 UL11L5S5ZQJ4J9022 UL12L5S5ZQJ4J9022 UL13L5S5ZQJ4J9022 UL14L5S5ZQJ4J9022 UL15L5S5ZQJ4J9022 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L5S5ZQJ4J9022 UL21L5S5ZQJ4J9022 ST2-2L5S5ZQJ4J9022 UL22L5S5ZQJ4J9022 ST2-3L5S5ZQJ4J9022 UL23L5S5ZQJ4J9022 ST2-4L5S5ZQJ4J9022 UL24L5S5ZQJ4J9022 ST2-5L5S5ZQJ4J9022 UL25L5S5ZQJ4J9022 ST2-6L5S5ZQJ4J9022 UL26L5S5ZQJ4J9022 ST2-7L5S5ZQJ4J9022 UL27L5S5ZQJ4J9022 ST2-8L5S5ZQJ4J9022 UL28L5S5ZQJ4J9022 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black bezel & actuator. Terminal numbers for reference only Panel thickness range .047" to .125" APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com B20-B30 23 10/11/00, 5:05 PM B23 B ST SERIES - MINIATURE ROCKER & LEVER SWITCHES Double pole SINGLE POLE WITH J3 ROCKER USA marking on other side DRY CKT. MODEL NO. UL MODEL NO. ST1-1L5S5CBJ3J9322 ST1-2L5S5CBJ3J9322 ST1-3L5S5CBJ3J9322 ST1-4L5S5CBJ3J9322 ST1-5L5S5CBJ3J9322 UL11L5S5CQJ3J9322 UL12L5S5CQJ3J9322 UL13L5S5CQJ3J9322 UL14L5S5CQJ3J9322 UL15L5S5CQJ3J9322 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L5S5CBJ3J9322 UL21L5S5CQJ3J9322 ST2-2L5S5CBJ3J9322 UL22L5S5CQJ3J9322 ST2-3L5S5CBJ3J9322 UL23L5S5CQJ3J9322 ST2-4L5S5CBJ3J9322 UL24L5S5CQJ3J9322 ST2-5L5S5CBJ3J9322 UL25L5S5CQJ3J9322 ST2-6L5S5CBJ3J9322 UL26L5S5CQJ3J9322 ST2-7L5S5CBJ3J9322 UL27L5S5CQJ3J9322 ST2-8L5S5CBJ3J9322 UL28L5S5CQJ3J9322 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black bezel & actuator. SINGLE POLE DOUBLE POLE Terminal numbers for reference only Single pole Straight p.c. terminals w/bracket - p.c. mounting bezel Double pole SINGLE POLE WITH J4 LEVER USA marking on other side DRY CKT. MODEL NO. UL MODEL NO. ST1-1L5S5V30BJ3J9322 ST1-2L5S5V30BJ3J9322 ST1-3L5S5V30BJ3J9322 ST1-4L5S5V30BJ3J9322 ST1-5L5S5V30BJ3J9322 UL11L5S5V30QJ3J9322 UL12L5S5V30QJ3J9322 UL13L5S5V30QJ3J9322 UL14L5S5V30QJ3J9322 UL15L5S5V30QJ3J9322 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L5S5V30BJ3J9322 UL21L5S5V30QJ3J9322 ST2-2L5S5V30BJ3J9322 UL22L5S5V30QJ3J9322 ST2-3L5S5V30BJ3J9322 UL23L5S5V30QJ3J9322 ST2-4L5S5V30BJ3J9322 UL24L5S5V30QJ3J9322 ST2-5L5S5V30BJ3J9322 UL25L5S5V30QJ3J9322 ST2-6L5S5V30BJ3J9322 UL26L5S5V30QJ3J9322 ST2-7L5S5V30BJ3J9322 UL27L5S5V30QJ3J9322 ST2-8L5S5V30BJ3J9322 UL28L5S5V30QJ3J9322 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black bezel & actuator. SINGLE POLE Terminal numbers for reference only SINGLE POLE B24 B20-B30 DOUBLE POLE DOUBLE POLE APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 24 10/11/00, 5:05 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE B Single pole Straight p.c. terminals - p.c. mounting bezel ST SERIES - MINIATURE ROCKER & LEVER SWITCHES Single pole SINGLE POLE WITH J3 ROCKER Poles SP SP DP DP Option A A-1 A A-1 Dim. A .148 .164 .250 .266 Double pole SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Horizontal right angle p.c. terminals - p.c. mtg. bezel Dim. B .045 max. .095 max. .300 max. .350 max. USA marking on other side DRY CKT. MODEL NO. UL MODEL NO. ST1-1L5S5A-1BJ3J9322 ST1-2L5S5A-1BJ3J9322 ST1-3L5S5A-1BJ3J9322 ST1-4L5S5A-1BJ3J9322 ST1-5L5S5A-1BJ3J9322 UL11L5S5A-1QJ3J9322 UL12L5S5A-1QJ3J9322 UL13L5S5A-1QJ3J9322 UL14L5S5A-1QJ3J9322 UL15L5S5A-1QJ3J9322 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L5S5A-1BJ3J9322 UL21L5S5A-1QJ3J9322 ST2-2L5S5A-1BJ3J9322 UL22L5S5A-1QJ3J9322 ST2-3L5S5A-1BJ3J9322 UL23L5S5A-1QJ3J9322 ST2-4L5S5A-1BJ3J9322 UL24L5S5A-1QJ3J9322 ST2-5L5S5A-1BJ3J9322 UL25L5S5A-1QJ3J9322 ST2-6L5S5A-1BJ3J9322 UL26L5S5A-1QJ3J9322 ST2-7L5S5A-1BJ3J9322 UL27L5S5A-1QJ3J9322 ST2-8L5S5A-1BJ3J9322 UL28L5S5A-1QJ3J9322 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black bezel & actuator. Terminal numbers for reference only SINGLE POLE DOUBLE POLE Single pole Vertical right angle p.c. terminals - p.c. mtg. bezel Double pole SINGLE POLE WITH J4 LEVER USA marking on other side DRY CKT. MODEL NO. UL MODEL NO. ST1-1L5S5V-1BJ3J9322 ST1-2L5S5V-1BJ3J9322 ST1-3L5S5V-1BJ3J9322 ST1-4L5S5V-1BJ3J9322 ST1-5L5S5V-1BJ3J9322 UL11L5S5V-1QJ3J9322 UL12L5S5V-1QJ3J9322 UL13L5S5V-1QJ3J9322 UL14L5S5V-1QJ3J9322 UL15L5S5V-1QJ3J9322 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L5S5V-1BJ3J9322 UL21L5S5V-1QJ3J9322 ST2-2L5S5V-1BJ3J9322 UL22L5S5V-1QJ3J9322 ST2-3L5S5V-1BJ3J9322 UL23L5S5V-1QJ3J9322 ST2-4L5S5V-1BJ3J9322 UL24L5S5V-1QJ3J9322 ST2-5L5S5V-1BJ3J9322 UL25L5S5V-1QJ3J9322 ST2-6L5S5V-1BJ3J9322 UL26L5S5V-1QJ3J9322 ST2-7L5S5V-1BJ3J9322 UL27L5S5V-1QJ3J9322 ST2-8L5S5V-1BJ3J9322 UL28L5S5V-1QJ3J9322 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black bezel & actuator. SINGLE POLE DOUBLE POLE Terminal numbers for reference only APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com B20-B30 25 10/11/00, 5:05 PM B25 B ST SERIES - MINIATURE ROCKER & LEVER SWITCHES Self-keying against rotation Single pole B Double pole ST1-1L5S5ZQJ4J9682 USA marking on other side POWER CKT. MODEL NO. UL MODEL NO. ST1-1L5S5ZQJ4J9622 ST1-2L5S5ZQJ4J9622 ST1-3L5S5ZQJ4J9622 ST1-4L5S5ZQJ4J9622 ST1-5L5S5ZQJ4J9622 UL11L5S5ZQJ4J9622 UL12L5S5ZQJ4J9622 UL13L5S5ZQJ4J9622 UL14L5S5ZQJ4J9622 UL15L5S5ZQJ4J9622 ON ON MOM ON ON NONE OFF OFF OFF NONE ON ON MOM MOM MOM ST2-1L5S5ZQJ4J9622 UL21L5S5ZQJ4J9622 ST2-2L5S5ZQJ4J9622 UL22L5S5ZQJ4J9622 ST2-3L5S5ZQJ4J9622 UL23L5S5ZQJ4J9622 ST2-4L5S5ZQJ4J9622 UL24L5S5ZQJ4J9622 ST2-5L5S5ZQJ4J9622 UL25L5S5ZQJ4J9622 ST2-6L5S5ZQJ4J9622 UL26L5S5ZQJ4J9622 ST2-7L5S5ZQJ4J9622 UL27L5S5ZQJ4J9622 ST2-8L5S5ZQJ4J9622 UL28L5S5ZQJ4J9622 Terminals connected (-6, -7 & -8) ON ON MOM ON ON ON ON MOM 1-2, 4-5 NONE OFF OFF OFF NONE ON ON ON 1-2, 5-6 ON ON MOM MOM MOM ON MOM MOM 2-3, 5-6 Above models have black bezel & actuator. Terminal numbers for reference only Panel thickness range .047" to .125". MISCELLANEOUS ST2-6, -7 & -8 SWITCHES May be wired as a single pole 3 position switch; add external jumper between terminals 1 & 5, then: Common terminal is 2 Output 1 - terminal 4 Output 2 - terminal 6 Output 3 - terminal 3 SIDE VIEW SINGLE POLE SWITCH BODY SIDE VIEW DOUBLE POLE FRONT VIEW SINGLE AND DOUBLE POLE SIZES WITH TERMINAL LOCATION DIMENSIONS TYPICAL SWITCH CROSS SECTIONS Note: Contacts make opposite actuator direction. ON NONE ON B26 B20-B30 ON OFF ON MOM OFF MOM ON OFF MOM ON NONE MOM APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 26 10/11/00, 5:05 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE Snap-in bezel for round hole mounting ST SERIES - MINIATURE ROCKER & LEVER SWITCHES Additional ordering information: Commonly ordered models are shown on prior pages with complete model numbers and specifications. Below is an order format that enables you to 'build your own switch' and specify the correct switch model number by simply selecting from all available options shown and filling in the boxes. B SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE 'BUILD YOUR OWN SWITCH' ORDER FORMAT Fill in boxes with selections shown for Model Structure, then add Options selections for complete model number. Allowable options are shown below each respective box with brief description - see option dwgs. & info. following. Note: 'NONE' indicates box may be left empty. Model Structure: Series Electrical functions Single pole: S T 1 S.P. UL model: U L 1 Double pole: S T 2 D.P. UL model: U L 2 Sub-actuators 1 0N N0NE 0N 2 0N 0FF 0N 3 M0M 0FF M0M 4 0N 0FF M0M 5 0N M0M Following for DP only 6 0N 0N 0N 7 0N 0N M0M 8 M0M 0N M0M L 4 L 5 Sub-Bushings Specify without bezel Specify with bezel Although most combinations of options are available, some may result in incompatibilities. Consult factory if there is any question. S 4 S 5 Terminations Contact materials B Z Solder lug Q C Printed circuit W Wirewrap G W 1 Lg. wirewrap W 3 Sht. wirewrap X Extra lg. wirewrap N Horiz. right angle p.c.: A T A - 1 Vertical right angle p.c.: V V - 1 V - 2 Straight p.c. terms. w/brkt.: V 3 0 or V 3 1 V 4 0 or V 4 1 V 7 0 or V 7 1 V 8 0 or V 8 1 Specify without bezel Specify with bezel Example of completely specified model number: ST2-3L5S5ZQEJ4J9622 Gold Coin silver Gold over coin silver Economy gold Economy silver Options: Sealing Actuator (NONE) E Epoxy J J J J 1 2 3 4 Bezel Rocker Lever Small rocker Small lever Bezel color (NONE) J 6 1 Snap-in w/LED J 9 0 Snap-in no LED J 9 3 P.C. style Self-keying round hole mt.: J 9 6 Snap-in no LED Note: specify J3 or J4 actuators only with bezels. Actuator color (NONE) 2 Black 6 Red 8 White 2 Black 6 Red 8 White Note: J3 & J4 actuators available in black only. Recognition (NONE) / C S A CSA lising ACTUATOR OPTIONS Colors available: J1 & J2: Black, red or white. J3 & J4: Black. J1 ROCKER J2 LEVER J3 ROCKER J4 LEVER APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com B20-B30 27 10/11/00, 5:05 PM B27 ST SERIES - MINIATURE ROCKER & LEVER SWITCHES B A A-1 SINGLE POLE HORIZONTAL P.C. MOUNTING SINGLE POLE HORIZONTAL P.C. MOUNTING A A-1 DOUBLE POLE HORIZONTAL P.C. MOUNTING V, V-1 & V-2 Option V V-1 V-2 Dim. A .550 .500 .500 DOUBLE POLE HORIZONTAL P.C. MOUNTING FRONT VIEW SINGLE POLE FRONT VIEW DOUBLE POLE SIDE VIEW - SINGLE & DOUBLE POLE Dim. B .150 .150 .100 VERTICAL P.C. MOUNTING V30, V40, V70, V80, V31, V41, V71 & V81 PANEL LAYOUT V30, V31, V40 & V41 Option Dim. A V30-V31 .527 V40-V41 .647 Dim. B .024 .048 PANEL LAYOUT V70, V71, V80 & V81 Option V70-V71 V80-V81 Dim. A .630 .953 V31, V41,V71 & V81 ARE THE SAME AS V30, V40, V70 & V80 RESPECTIVELY, EXCEPT WITH CRIMPED LEG DESIGN FOR P.C. BOARD RETENTION, AS SHOWN TO RIGHT. B28 B20-B30 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 28 10/11/00, 5:05 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE TERMINATION OPTIONS ST SERIES - MINIATURE ROCKER & LEVER SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE TERMINATION OPTIONS (CONT'D.) Z C W W1 W3 SOLDER LUG PRINTED CIRCUIT WIREWRAP LONG WIREWRAP SHORT WIREWRAP X B EXTRA LG. WIREWRAP CONTACT MATERIAL OPTIONS B Dry circuit - gold over nickel over brass. RATING: 0.4 Volt-Amps (VA) max. at 20 V max. ELECTRIC LIFE: 100,000 cycles min. (ST1-1 & ST2-1 only - other models 40,000 cycles min.) Q Power circuit - coin silver. RATING: 6 Amps at 125 VAC, 3 Amps at 250 VAC or 7 Amps at 30 VDC (resistive loads). ELECTRIC LIFE: 100,000 cycles min. (ST1-1 & ST2-1 only - other models 40,000 cycles min.) G Dry circuit or power circuit - gold over nickel over coin silver. RATINGS & ELECTRIC LIFE: Same as B & Q above - i.e. - can be used in either dry circuit or power circuit, however once used in power circuit, switch cannot be re-used in dry circuit. This option satisfies those customers who have both dry circuit and power circuit requirements, but prefer to inventory only one switch for both. N Dry circuit - gold over nickel over brass. Note- less gold than B option. RATING: 0.4 Volt-Amps (VA) max. at 20 V max. ELECTRIC LIFE: 10,000 cycles min. at 13 cycles per minute. T Power circuit - Silver plate over brass. RATING: 3 Amps at 125 VAC or 1.5 Amps at 250 VAC (resistive loads). ELECTRIC LIFE: 10,000 cycles min. at 13 cycles per minute. Solder dipped terminals and custom contact plating available - contact factory. UL & CSA OPTIONS UL For power circuits - coin silver RATING: 6 Amps at 125 VAC or 3 Amps at 250 VAC (75% power factor). Underwriter Laboratories file no. E66367. To specify, order UL model no. Note - applicable only to terminations with coin silver contacts (Q or G options). CSA For power circuits - coin silver RATING: 6 Amps at 125 VAC or 3 Amps at 250 VAC (75% power factor).Canadian Standards Association file no. LR54592-1. To specify, order UL model number, then add '/CSA' to complete switch number. Note - applicable only to terminations with coin silver contacts (Q or G options) as CSA recognizes switches for power applications only. SEALING & MISCELLANEOUS OPTIONS E /R Epoxy terminal sealing: Available with all terminal configurations. To specify reverse switch action on non-symmetrical models with bushing keyway, add '/R' to switch model no. The space between terminal & case hole is sealed with epoxy all around terminal. Provides maximum protection from entry of flux or contaminants into the switch case. APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com B20-B30 29 10/11/00, 5:05 PM B29 ST SERIES - MINIATURE ROCKER & LEVER SWITCHES MOUNTING INFORMATION & PANEL CUT-OUTS J1 OR J2 J3 J4 Panel tk'ness. Hardware number Stand-off length Panel tk'ness. Hardware number Stand-off length Panel tk'ness. Hardware number Stand-off length 1/16" 3/32" 1/8" A322-3 A322-2 A322-1 .295 .264 .233 1/16" 3/32" 1/8" A322-2 A322-1 A322-4 .264 .233 .202 1/16" 3/32" 1/8" A322-1 A322-4 A322-5 .233 .202 .171 Mounting hardware consists of 2 each: Hex Nut, stainless steel Screw, stainless steel Lockwasher, stainless steel Stand-off, aluminum 1/8" panel hardware supplied if not specified separately by hardware number shown in tables. TYPICAL ASSEMBLY B30 B20-B30 APEM, PO BOX 8288, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (781) 245-4531 E-mail: info@apem.com 30 10/11/00, 5:05 PM SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE B
ST21L5S5ZBJ3J9022 价格&库存
很抱歉,暂时无法提供与“ST21L5S5ZBJ3J9022”相匹配的价格&库存,您可以联系我们找货
