MJTP1232AL
MJTP1232AL
    APEM(埃斐)
    插件
    轻触开关 直插
MJTP1232AL 数据手册
MJTP SERIES 6MM THRU-HOLE MTG. TACT SWITCHES SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. MATERIALS Gold plating available on contacts & terminals - consult factory. FEATURES Numerous single pole-single throw momentary configurations. Excellent tactile feed-back (Snap dome). Ultra-compact size. Long operating life for high reliability. Molded-in terminals minimize wicking of flux or solder. Case: Thermoplastic, color black. UL94HB Standard. Actuator: Thermoplastic Cover/Bracket: PET film, tin plated brass or stainless steel. Terminals: Silver plated brass. Shorting Contact: Phosphor bronze or stainless steel with silver plating. L.E.D. rating: Forward voltage- 2.1 V (3.0 V Max.). Cont. fwd. current 20mA max.@ 25°C. GENERAL SPECIFICATIONS ELECTRICALS Contact rating: Insulation resistance: Dielectric withstanding voltage: Contact resistance: Electrical life: Contact bounce: 50 mA @ 12 VDC 100 megohms min. (100 VDC) 250 VAC for 1 minute 100 milliohms max. @ 5 VDC, 10 mA 100,000 cycles min. (except models MJTP1243 & 1250- 50,000 cycles) 1,000,000 cycles available - consult factory less than 10 msec. MECHANICALS, THERMALS, ENVIRONMENTALS Plunger travel: .010"+ .008", - .004" (0,25 +0,2, -0,1 mm) Actuation force: 160 grams ±30 grams Operating temperature range: -20°C to +70°C Storage temperature range: -30°C to +80°C for 96 hours Shock resistance: 30G per method 213, MIL-STD-202 Vibration resistance: passes method 201, MIL-STD-202 M SOLDERING (note - non-washable except for models indicated 'process compatible' below). IR reflow soldering: 240°C max. for 20 seconds max. Wave soldering: 255°C max. for 5 seconds max. Hand soldering: 320°C max. for 3.5 seconds max. (40 watt iron max.) MJTP1105T Right angle, grounding Caps available see end of section. Bulk packaged. US # MJTP1109 EU # PHAP3350 Process compatible, grounding US Model No. Dim. EU Model L (In./mm) No. MJTP1109 .197 (5.0) PHAP3350 MJTP1109A .354 (9.0) PHAP3350A MJTP1109B .512 (13.0) PHAP3350B Bulk packaged. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M3 US # MJTP1117 EU # PHAP3363 Right angle, grounding New! US # MJTP1119 EU # PHAP3351 Process compatible US Model Dim. No. MJTP1119 L (in./mm) No. .197 (5.0) PHAP3351 EU Model MJTP1119A .354 (9.0) PHAP3351A MJTP1119B .512 (13.0) PHAP3351B Bulk packaged. New! M US # MJTP1129 EU # PHAP1152 Right angle, grounding, process compatible US Model No. Dim. EU Model L (in./mm) No. MJTP1129 .171 (4.35) PHAP3352 MJTP1129A .329 (8.35) PHAP3352A MJTP1129B .486 (12.35) PHAP3352B Bulk packaged. US # MJTP1141 EU # PHAP3307 Long terminals US Model No. Dim. EU Model L (in./mm) No. MJTP1141 .169 (4.3) MJTP1141A .197 (5.0) PHAP3307 PHAP3307A Packaged on tape. Note: other models available with this tape packaging - consult factory. M4 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Bulk packaged. SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. US # MJTP1193 EU # PHAP3308 With L.E.D. Note: LED cathode is marked with a dot US Model L.E.D. EU Model No. MJTP1193 Color No L.E.D. No. PHAP3308 MJTP11936 Red MJTP11935 Yellow PHAP3308R PHAP3308Y MJTP11933 Green PHAP3308G Caps available with lens see end of section. Bulk packaged. New! US # MJTP1230 EU # PHAP3301 US Model Dim. No. L (in./mm) MJTP1230 .170 (4,3) MJTP1230A .197 (5,0) MJTP1230B .374 (9,5) MJTP1230C .315 (8,0) MJTP1230D .512 (13,0) MJTP1230E .287 (7,3) MJTP1230F .335 (8,5) MJTP1230G .275 (7,0) EU Model No. PHAP3301 PHAP3301A PHAP3301B PHAP3301C PHAP3301D PHAP3301E PHAP3301F N/A Bulk packaged. US # MJTP1232 EU # PHAP3302 Grounding US Model Dim. No. L (in./mm) MJTP1232 .170 (4,3) MJTP1232A .197 (5,0) MJTP1232B .374 (9,5) MJTP1232C .315 (8,0) MJTP1232D .512 (13,0) MJTP1232E .287 (7,3) MJTP1232F .335 (8,5) MJTP1232G .275 (7,0) M EU Model No. PHAP3302 PHAP3302A PHAP3302B PHAP3302C PHAP3302D PHAP3302E PHAP3302F PHAP3302G Bulk packaged. US # MJTP1234 EU # PHAP3303 US Model No. Dim. L (in./mm) MJTP1234 .094 (2,4) MJTP1234A .110 (2,8) EU Model No. PHAP3303 PHAP3303A Caps available see end of section. Bulk packaged. APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M5 US Model Dim. EU Model No. L (in./mm) No. MJTP1236 .124 (3,1) PHAP3305 MJTP1236A .152 (3,9) PHAP3305A MJTP1236B .329 (8,4) PHAP3305B MJTP1236C .270 (6,9) PHAP3305C MJTP1236D .466 (11,9) PHAP3305D MJTP1236E .244 (6,2) PHAP3305E MJTP1236F .289 (7,3) N/A MJTP1236G.230 (5,8) N/A Bulk packaged. US # MJTP1243 & MJTP1250 US # Model Dim. Dim. No. L1(in./mm) L (in./mm) MJTP1243 MJTP1250 .169 (4,3) .197 (5,0) .307 (7,8) .335 (8,5) Bulk packaged. M US # MJTP2205 EU # PHAP3306 2 switch vertical gang assembly, black actuators 1 4 2 3 US Model Dim. EU Model No. L (in./mm) No. MJTP2205 .124 (3,15) PHAP3306 MJTP2205A .152 (3,85) PHAP3306A MJTP2205B .329 (8,35) PHAP3306B MJTP2205C .270 (6,85) PHAP3306C MJTP2205D .466 (11,85)PHAP3306D MJTP2205E .242 (6,15) PHAP3306E Bulk packaged. M6 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. US # MJTP1236 EU # PHAP3305 Right angle, grounding US # MJTPSHW Process compatible US # Model No. Dim. L (in./mm) MJTPSHW MJTPSHWA .122 (3,1) .091 (2,3) MJTPSHWB .146 (3,8) SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE. Bulk packaged. CAPS (for MJTP1105T and MJTP1234 only) MJ61 Square cap MJ62 Round cap CAPS (for MJTP1193 only) New! CAP COLORS MJ3 Square cap (w/clear lens in center for LED illumination) Note - add digit from table to cap part number for color. Example - MJ612 indicates square black cap. No. 1 2 3 5 6 7 Color blue black green yellow red ivory SCHEMATICS MJTP1109 MJTP1119 MJTP1193 MJTP1230 MJTP1232 MJTP1234 MJTP2205 MJTP4102 MJTP5302 MJTPSHW MJTP1105 MJTP1117 MJTP1129 MJTP1141 MJTP1144 MJTP1145 Note: LED is for MJTP1193 only. MJTP1236 MJTP1243 MJTP1250 MJTP2205 MJTP4102 MJTP5302 M PRINTED CIRCUIT BOARD LAYOUTS Layout tolerances; Linear: ± .004" ( ± 0,1MM) Holes: ± .002" ( ± 0,05MM) MJTP1105T MJTP1141, 44 & 45 MJTP1109 MJTP1117 MJTP1119 MJTP1129 MJTP1193 MJTP1230 MJTP1232 MJTP1234 MJTP1243 MJTP1250 MJTPSHW 4 MJTP1236 MJTP4102 MJTP5302 3 2 1 MJTP2205 APEM, 63 NECK ROAD, HAVERHILL, MA USA 01835-0788 TOLL FREE: (877) 246-7890 FAX: (978) 372-3534 E-mail: info@apem.com M7 Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: Apem: MJTP11933 (BULK) MJTP1164TR MJTP1232AL MJTP1234G MJTP1236BV0 MJTP1236CBLK MJ625 MJ621 MJ32 MJ37 MJ36 MJ35 MJ33 MJ626 MJ623 MJTP11933
MJTP1232AL 价格&库存
很抱歉,暂时无法提供与“MJTP1232AL”相匹配的价格&库存,您可以联系我们找货
